Date/Time: Fri, 24 May 2024 06:57:19 +0000
Pivot points from formula 4 not equidistant
View Count: 704
[2016-10-16 11:50:16] |
gomifromparis - Posts: 244 |
Hi, From what I understand from formula 4, R1 R2 R3 and S1 S2 S3 should all be equidistant (they should be separated by yhigh-ylow), but it doesn't seem to be the case. Anything I may have missed ? |
pivots.PNG / V - Attached On 2016-10-16 11:46:31 UTC - Size: 104.65 KB - 225 views |
[2016-10-16 12:27:13] |
That is not what the formulas are indicating. Go through the calculations manually and you will see. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-10-16 12:27:27
[2016-10-16 12:57:52] |
got it, sorry
