Date/Time: Sat, 18 May 2024 21:55:18 +0000
Cheaper Futures Data
View Count: 659
[2016-10-16 01:44:56] |
Executor - Posts: 40 |
I live in Canada and is a customer to td waterhouse which is the canadian version of td ameritrade. I would like the cheap futures data per month. Unfortunately, when I log into td ameritrade under Global Settings > Data/Trade Service Settings. It is not logging me in. Can I get the cheap futures data rate? per month. I will only be using /es, and this is only for market confirmation. Regards, |
[2016-10-16 02:16:59] |
If you are not able to connect to TD Ameritrade, then the answer is no. Have a look at using Interactive Brokers which is also supported. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
