Date/Time: Sat, 18 May 2024 15:00:41 +0000
Adding Uasage Credit
View Count: 691
[2016-10-15 16:14:18] |
wingz - Posts: 121 |
Can you please tell me what the deal is with this Dal Pay thing? I went to add some usage credit and the only amount it'll let me add is $10. I was going to just put $100 on there but it never gave me an option to change the amount from $10 to $100 so I ended up making a payment to Sierra for $10. The default amount on the Dal Pay page was $10 and I saw nowhere in the process to make a change to that amount.
[2016-10-15 20:34:40] |
On the "Add Services Balance Credit" page: https://www.sierrachart.com/usercp.php?page=AddAccountCredit&Amount=100 You can specify the USD amount that you need, by setting the amount next to "Specify USD Amount". The minimum supported payment amount is 10 USD. Note that the link above would auto set the amount to 100 USD. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
