Date/Time: Sat, 18 May 2024 14:44:44 +0000
Password for formulas in spreadsheet
View Count: 652
[2016-10-14 13:51:03] |
User625993 - Posts: 7 |
Hello, maybe in the next release there could be the possibility to block, using a password the formulas that are in the spreadsheet? I mean like it is possible to with with Excel. Thank you Kind regards, Patrizia |
[2016-10-14 17:46:01] |
This is not something that we would add to Sierra Chart Spreadsheets.
