Date/Time: Thu, 09 May 2024 06:58:11 +0000
position of crosshair cursor in reversal bar graph with lock fill space
View Count: 695
[2016-10-13 00:19:59] |
User144295 - Posts: 59 |
Hi Sierra Chart team, I am using crosshair cursor in combination of reversal bar graph with lock fill space and 2 min graphs also with lock fill space. When I place crosshair on trading chart DOM (this example is NOT visible on screen) or at the end of lock fill space (this example is visible on screen) of any 2 min graph, the vertical line of crosshair is placed on the end of the last bar on reversal bar graph, and it actually blocks the doji of this last bar. On the attached picture I moved crosshair on the end of ESZ6 of 2 min graph (middle one), but on the reversal bar graph (most right one) this vertical part of crosshair is in front of the last bar, even though there is still lot of lock fill space on the right (where I would like to see it actually instead of covering this last bar). It works good on replay I noticed as per other picture attached, but it does not work good during the real time data feed trading. Thank you for your reaction on this. |
Private File Private File |
[2016-10-13 01:56:55] |
We cannot help you with this. There is proper matching of the Chart Values tool from one chart to another chart under all of the various circumstances and conditions. Also, when you are using variable timeframe bars, the Date-Time of when the next bar starts, will vary further adding to the complexity. Once again we cannot help with this and what you see is based on all the complex facts that are present. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-10-13 01:57:18
