Date/Time: Wed, 21 Oct 2026 09:55:05 +0000
P&L
View Count: 1428
| [2016-10-12 23:50:18] |
| User153928 - Posts: 35 |
Hi there, I'm a new customer and new to Sierra Chart I try to set it up to the way I like it which is not easy it drives me crazy anyway my challenge this time is I try to set up on my Dome the currency in dollars on my P&L next to my Buy TradeDome Columns I managed to change it one time I guess by accident now I cannot do it again. On the dome I go to chart-chart settings-advanced settings-position profit and loss-and change to C for currency-apply it changes on the main dome to C ok but not the P&L next to the buy column I tried to reset on Global Settings-customize chart dome columns I removed Profit & Loss several times and added it on again same thing it wont change from P to currency sorry I need your help again Walter |
| [2016-10-13 01:41:47] |
The instructions for how to do this are here: Chart Trading and the Chart DOM: Chart DOM Position Profit and Loss Column Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-10-13 20:58:04] |
Thank you, great one more question on the top of the chart where the symbol name is and the time frame and chart # I have a lot of information on it which I really don't need how can I change it please point me to the right page again thanks Walter |
| [2016-10-14 04:35:35] |
Refer to: Working With Charts: Region Data Line / Chart Header Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
