Date/Time: Mon, 06 May 2024 23:38:14 +0000
Graphic problem
View Count: 1303
[2013-07-27 10:16:23] |
jaban - Posts: 66 |
I use a setup " Color Bar based on Above/Below study " , plus "Color bar based on alert condition " In my FX charts I get red bars with the down condition and green bars in the up condition I copy the setting in a stock chart then I get all bars in 1 color ( only the bar based on alert is oke ) Also when I copy to an index chart with IB data feed , I get all bars in 1 color. I cannot find how to correct this. http://www.sierrachart.com/image.php?l=1374919973264.png http://www.sierrachart.com/image.php?l=1374920126597.png I add 2 screenshots Have a look please , thanks |
[2013-07-29 23:05:21] |
This really is outside the scope of our support to debug. These studies all do work properly as designed. One thing to check is the Value Format setting: https://www.sierrachart.com/index.php?l=doc/doc_AlertCondAndScan.html#ValueFormat Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-07-30 05:24:31] |
Please provide us a simple example Chartbook demonstrating the problem and then we can have a look at it. Otherwise, it is not possible for us to determine what is going on. Here are the instructions to attach a Chartbook: https://www.sierrachart.com/index.php?l=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
