Date/Time: Wed, 21 Oct 2026 09:55:05 +0000
everytime I load a new Chart Symbol and Tick Size
View Count: 1550
| [2016-10-12 18:44:53] |
| Executor - Posts: 40 |
I would I like to keep my tick size permanently under Chart > Chart Settings. So whenever I change to a new stock symbol the tick size will always be 0.05 Regards, |
| [2016-10-12 18:46:59] |
This is only for one of my chart windows
| [2016-10-12 19:11:13] |
If you want this tick size for all stock symbols then change it through Global Settings >> Symbol Settings for the symbol patterns like ???. Refer to: http://www.sierrachart.com/index.php?page=doc/GlobalSymbolSettings.php If you want it only for specific stocks, then add the specific stock symbol into the Global Symbol Settings. You will need to use the Duplicate button to set up the symbol and duplicate the symbol ???. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-10-12 19:53:14] |
I actually want to change tick size for all symbols. Even new tickers I come across in the future. Momentum stocks. I won't have time to add the symbol to Symbol Settings list.
| [2016-10-13 02:34:18] |
You just therefore need to modify the Tick Size for the four or so stock symbol patterns. Here are instructions: Global Symbol Settings: Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-10-13 13:19:35] |
Like I mentioned earlier. I don't have time to add new symbols to stock symbol list. is there a way to change the tick size for every stock in the nasdaq and nyse. for a particular window? The link you have provided does not show this information.
| [2016-10-13 13:24:21] |
I want the tick size to be 0.05, not 0.01. So when i type in a new stock symbol throughout the trading day, the tick size of 0.05 will be set. Example, I see OCUL moving using my stock screener. I type in /OCUL. This new stock symbol will have the setting of 0.05 Tick size already applied to it. I don't want to go to stock symbol, add OCUL to this list and modify the tick size. This process will slow down my trading, considering I trade momentum stocks. |
| [2016-10-13 17:28:29] |
This is what we said previously: You just therefore need to modify the Tick Size for the four or so stock symbol patterns. Here are instructions:
Global Symbol Settings: Instructions You only need to modify the tick size for four patterns. These are: ? ?? ??? ???? Although this is modifying the tick size globally, and will apply under these conditions: http://www.sierrachart.com/index.php?page=doc/ChartSettings.html#DefaultSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-10-13 21:41:27] |
Thanks got it :)
