Date/Time: Sat, 04 May 2024 12:28:47 +0000
Alerts
View Count: 1378
[2013-07-27 06:23:33] |
SKY - Posts: 45 |
Hi 1. i would like to set alerts based on slope and on color of the study/SG#. which operators (of APIs) are accessible for that matter 2. whee can i find a list of operators acailable for alerts (e.g. CROSSOVER()) 3. The documentation is unclear for positive indexes (SG1[1]) apperaciate if u can elaborate Tnx. SKY |
[2013-07-29 22:08:49] |
1. You can only work with values, not colors. So if the colors are based upon definite study Subgraph values, then you know how to program your formula because you can check the values for certain conditions. 2. Refer documentation on this page: https://www.sierrachart.com/index.php?l=doc/doc_AlertCondAndScan.html#AlertConditionFormulaFormat 3. The documentation for this has been updated here: https://www.sierrachart.com/index.php?l=doc/doc_AlertCondAndScan.html#ReferencingDataOtherLastBar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-07-29 22:09:28
[2013-07-29 22:22:45] |
Sawtooth - Posts: 3993 |
You can also use many spreadsheet functions: http://www.sierrachart.com/index.php?l=doc/doc_WorksheetFunctions.html#AvailableFunctions Date Time Of Last Edit: 2013-07-29 22:24:02
