Date/Time: Wed, 15 May 2024 16:13:04 +0000
Real Millisecond timestamps on IQ Feed data?
View Count: 1275
[2016-10-11 18:15:53] |
DabbaDo - Posts: 146 |
This old thread: https://www.sierrachart.com/supportboard/showpost.php?p=236254&postcount=7 said: "We will be using the actual IQ feed timestamps and they will override the Sierra Chart incremental millisecond timestamp." Did that ever happen? Or does your IQ Feed data also have sequence-during-second stamps instead of true milliseconds? Thank you. |
[2016-10-12 01:46:26] |
No, this has not been done but we expect to get to it in 2017. The true milliseconds are not supported. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-10 12:20:36] |
Is this still in your 2017 plans? It will be very helpful to me. I am able to write .scid files from my own data and replay them with true milliseconds, but all SC realtime data apparently still uses the sequence numbers. Thanks in advance, Dale |
[2017-01-10 18:45:04] |
Yes but we do not know when in 2017 this will be done.
