Date/Time: Thu, 09 May 2024 07:32:17 +0000
Downloading continuous contract data
View Count: 893
[2016-10-11 17:02:18] |
User46129 - Posts: 22 |
I'm thinking I've inadvertently changed a setting when I switched my trade broker. I realize that since I use SC Data, my broker has nothing to do with this, however, since switching, each time I open SC, each chart has to 'download continuous contract data' instead of just loading it from local files. It seems to take a lot longer than before for all charts to load. I was under impression that all historical data is stored on my computer. Maybe I am misunderstanding what is happening. Please advise if there is something I can do to speed things up. Thanks in advance.
[2016-10-11 17:44:52] |
Select "Global Settings >> Data/Trade Service Settings". What is the "Service" at the top left set to? What is the symbol of one of the charts? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-11 18:14:22] |
TD Ameritrade (Trading ) on main and DTC-Sub Instance (Trading ) on new instance. Symbol: ESZ16
[2016-10-11 18:48:34] |
So do you notice this on the main instance of Sierra Chart as well? What we want you to do is the following: Enable Global Settings >> General Settings >> Detailed Continuous Futures Contract Chart Logging. Restart the main instance of Sierra Chart. Open a Chartbook in the main instance , wait about a minute and then provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-10-11 18:49:13
[2016-10-11 20:30:52] |
It seems to be with both instances, but I could be wrong. I just know that in the morning, when I fire everything up, I usually have to wait 5 to 10 minutes, sometimes longer, for everything to download. It seems like QM takes longer than the others. I believe I have all charts set the same as far as history. Reading Internal Order ID file. | 2016-10-11 15:23:05 Reading Trade Orders file. | 2016-10-11 15:23:05 Reading Trade Positions file. | 2016-10-11 15:23:05 Software version: 1469 | 2016-10-11 15:23:05 Uses New Spreadsheets | 2016-10-11 15:23:05 Usage end date: 2016-11-11 | 2016-10-11 15:23:05 Enabled for: Advanced Features. | 2016-10-11 15:23:05 Enabled for: Advanced Features 2. | 2016-10-11 15:23:05 Enabled for: Sierra Chart Historical Data Service. | 2016-10-11 15:23:05 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2016-10-11 15:23:05 Enabled for: INDEXES_DATA_BARCHART | 2016-10-11 15:23:05 Enabled for: CME (Trading Account Required) | 2016-10-11 15:23:05 Enabled for: CBOT (Trading Account Required) | 2016-10-11 15:23:05 Enabled for: COMEX (Trading Account Required) | 2016-10-11 15:23:05 Enabled for: NYMEX (Trading Account Required) | 2016-10-11 15:23:05 Received 1 data feed usernames. | 2016-10-11 15:23:05 Allow Support for Sierra Chart Data Feeds is enabled. | 2016-10-11 15:23:05 Current selected Data/Trading service: TD Ameritrade | 2016-10-11 15:23:05 Chart Update Interval: 900 | 2016-10-11 15:23:05 Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-10-11 15:23:05 2016-10-11 15:23:10 Local computer time | 2016-10-11 15:23:05 2016-10-11 20:23:10 Local computer time in UTC | 2016-10-11 15:23:05 2016-10-11 15:23:10 Local computer time in SC Time Zone | 2016-10-11 15:23:05 2016-10-11 20:23:06 Server time in UTC | 2016-10-11 15:23:05 Local computer UTC time and Server UTC time difference: 4 seconds. | 2016-10-11 15:23:05 Program path: C:\SierraChart\ | 2016-10-11 15:23:05 Data Files path: C:\SierraChart\Data\ | 2016-10-11 15:23:05 OS Version Number: 6.1 | 2016-10-11 15:23:05 Locale Setting: C | 2016-10-11 15:23:05 Created the DTC Protocol server. | 2016-10-11 15:23:05 DTC Protocol Server listening on port 11099. | 2016-10-11 15:23:05 Created the DTC Protocol historical data server. | 2016-10-11 15:23:05 HD Server Manager | Listening on port 11098 | 2016-10-11 15:23:05 Checking for new symbol settings for tda | 2016-10-11 15:23:05 HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-10-11 15:23:05 HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-10-11 15:23:05 HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-10-11 15:23:05 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-10-11 15:23:11 Symbol settings are up-to-date for tda | 2016-10-11 15:23:12 TD Ameritrade | Connecting. | 2016-10-11 15:23:15 TD Ameritrade | Logging in. (Step 1 of 3) | 2016-10-11 15:23:15 HTTPS connection to apis.tdameritrade.com:443 (0) | Resolved address apis.tdameritrade.com to IP 216.105.251.201. | 2016-10-11 15:23:16 HTTPS connection to apis.tdameritrade.com:443 (4) | Connected. | 2016-10-11 15:23:16 HTTPS connection to apis.tdameritrade.com:443 (4) | Starting TLS 1.0 connection. | 2016-10-11 15:23:16 HTTPS connection to apis.tdameritrade.com:443 (4) | SSL connection established. | 2016-10-11 15:23:16 TD Ameritrade | Authorized for streamer data. Account: 86*** | 2016-10-11 15:23:17 TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2016-10-11 15:23:17 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-10-11 15:23:17 HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-10-11 15:23:17 HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-10-11 15:23:17 HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-10-11 15:23:17 TD Ameritrade | Requesting message key for account activity streamer (Step 3 of 3) | 2016-10-11 15:23:17 TD Ameritrade | Requesting account balance data. Connection will be complete once received. | 2016-10-11 15:23:18 TD Ameritrade | Connected to data and trading server. | 2016-10-11 15:23:18 TD Ameritrade | Starting real-time market data updates for: ZN-201512-ECBOT. ID: 1 | 2016-10-11 15:23:18 TD Ameritrade | Requesting security definition data for: ZN-201512-ECBOT. ID: 1 | 2016-10-11 15:23:18 TD Ameritrade | Streamer request #1 initiated. | 2016-10-11 15:23:19 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.38. | 2016-10-11 15:23:19 HTTPS connection to ameritrade02.streamer.com:443 (5) | Connected. | 2016-10-11 15:23:19 HTTPS connection to ameritrade02.streamer.com:443 (5) | Starting TLS 1.0 connection. | 2016-10-11 15:23:19 HTTPS connection to ameritrade02.streamer.com:443 (5) | SSL connection established. | 2016-10-11 15:23:20 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-3 | 2016-10-11 15:23:20 QMZ16 [CB] Weekly #1 | Reloading chart. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMV06 to next contract occurs at 2006-09-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMX06 to next contract occurs at 2006-10-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMZ06 to next contract occurs at 2006-11-21. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMF07 to next contract occurs at 2006-12-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMG07 to next contract occurs at 2007-01-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMH07 to next contract occurs at 2007-02-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMJ07 to next contract occurs at 2007-03-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMK07 to next contract occurs at 2007-04-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMM07 to next contract occurs at 2007-05-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMN07 to next contract occurs at 2007-06-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMQ07 to next contract occurs at 2007-07-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMU07 to next contract occurs at 2007-08-21. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMV07 to next contract occurs at 2007-09-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMX07 to next contract occurs at 2007-10-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMZ07 to next contract occurs at 2007-11-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMF08 to next contract occurs at 2007-12-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMG08 to next contract occurs at 2008-01-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMH08 to next contract occurs at 2008-02-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMJ08 to next contract occurs at 2008-03-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMK08 to next contract occurs at 2008-04-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMM08 to next contract occurs at 2008-05-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMN08 to next contract occurs at 2008-06-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMQ08 to next contract occurs at 2008-07-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMU08 to next contract occurs at 2008-08-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMV08 to next contract occurs at 2008-09-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMX08 to next contract occurs at 2008-10-21. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMZ08 to next contract occurs at 2008-11-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMF09 to next contract occurs at 2008-12-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMG09 to next contract occurs at 2009-01-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMH09 to next contract occurs at 2009-02-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMJ09 to next contract occurs at 2009-03-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMK09 to next contract occurs at 2009-04-21. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMM09 to next contract occurs at 2009-05-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMN09 to next contract occurs at 2009-06-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMQ09 to next contract occurs at 2009-07-21. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMU09 to next contract occurs at 2009-08-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMV09 to next contract occurs at 2009-09-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMX09 to next contract occurs at 2009-10-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMZ09 to next contract occurs at 2009-11-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMF10 to next contract occurs at 2009-12-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMG10 to next contract occurs at 2010-01-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMH10 to next contract occurs at 2010-02-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMJ10 to next contract occurs at 2010-03-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMK10 to next contract occurs at 2010-04-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMM10 to next contract occurs at 2010-05-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMN10 to next contract occurs at 2010-06-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMQ10 to next contract occurs at 2010-07-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMU10 to next contract occurs at 2010-08-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMV10 to next contract occurs at 2010-09-21. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMX10 to next contract occurs at 2010-10-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMZ10 to next contract occurs at 2010-11-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMF11 to next contract occurs at 2010-12-21. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMG11 to next contract occurs at 2011-01-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMH11 to next contract occurs at 2011-02-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMJ11 to next contract occurs at 2011-03-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMK11 to next contract occurs at 2011-04-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMM11 to next contract occurs at 2011-05-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMN11 to next contract occurs at 2011-06-21. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMQ11 to next contract occurs at 2011-07-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMU11 to next contract occurs at 2011-08-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMV11 to next contract occurs at 2011-09-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMX11 to next contract occurs at 2011-10-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMZ11 to next contract occurs at 2011-11-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMF12 to next contract occurs at 2011-12-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMG12 to next contract occurs at 2012-01-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMH12 to next contract occurs at 2012-02-21. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMJ12 to next contract occurs at 2012-03-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMK12 to next contract occurs at 2012-04-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMM12 to next contract occurs at 2012-05-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMN12 to next contract occurs at 2012-06-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMQ12 to next contract occurs at 2012-07-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMU12 to next contract occurs at 2012-08-21. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMV12 to next contract occurs at 2012-09-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMX12 to next contract occurs at 2012-10-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMZ12 to next contract occurs at 2012-11-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMF13 to next contract occurs at 2012-12-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMG13 to next contract occurs at 2013-01-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMH13 to next contract occurs at 2013-02-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMJ13 to next contract occurs at 2013-03-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMK13 to next contract occurs at 2013-04-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMM13 to next contract occurs at 2013-05-21. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMN13 to next contract occurs at 2013-06-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMQ13 to next contract occurs at 2013-07-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMU13 to next contract occurs at 2013-08-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMV13 to next contract occurs at 2013-09-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMX13 to next contract occurs at 2013-10-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMZ13 to next contract occurs at 2013-11-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMF14 to next contract occurs at 2013-12-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMG14 to next contract occurs at 2014-01-21. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMH14 to next contract occurs at 2014-02-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMJ14 to next contract occurs at 2014-03-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMK14 to next contract occurs at 2014-04-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMM14 to next contract occurs at 2014-05-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMN14 to next contract occurs at 2014-06-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMQ14 to next contract occurs at 2014-07-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMU14 to next contract occurs at 2014-08-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMV14 to next contract occurs at 2014-09-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMX14 to next contract occurs at 2014-10-21. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMZ14 to next contract occurs at 2014-11-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMF15 to next contract occurs at 2014-12-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMG15 to next contract occurs at 2015-01-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMH15 to next contract occurs at 2015-02-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMJ15 to next contract occurs at 2015-03-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMK15 to next contract occurs at 2015-04-21. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMM15 to next contract occurs at 2015-05-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMN15 to next contract occurs at 2015-06-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMQ15 to next contract occurs at 2015-07-21. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMU15 to next contract occurs at 2015-08-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMV15 to next contract occurs at 2015-09-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMX15 to next contract occurs at 2015-10-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMZ15 to next contract occurs at 2015-11-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMF16 to next contract occurs at 2015-12-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMG16 to next contract occurs at 2016-01-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMH16 to next contract occurs at 2016-02-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMJ16 to next contract occurs at 2016-03-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMK16 to next contract occurs at 2016-04-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMM16 to next contract occurs at 2016-05-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMN16 to next contract occurs at 2016-06-21. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMQ16 to next contract occurs at 2016-07-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMU16 to next contract occurs at 2016-08-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMV16 to next contract occurs at 2016-09-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMX16 to next contract occurs at 2016-10-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMZ16 to next contract occurs at 2016-11-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMV06 for the date range from 2006-08-22 to 2006-09-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMV06 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMX06 for the date range from 2006-09-20 to 2006-10-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMX06 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMZ06 for the date range from 2006-10-20 to 2006-11-21. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMZ06 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMF07 for the date range from 2006-11-21 to 2006-12-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMF07 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMG07 for the date range from 2006-12-20 to 2007-01-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMG07 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMH07 for the date range from 2007-01-22 to 2007-02-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMH07 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMJ07 for the date range from 2007-02-20 to 2007-03-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMJ07 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMK07 for the date range from 2007-03-20 to 2007-04-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMK07 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMM07 for the date range from 2007-04-20 to 2007-05-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMM07 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMN07 for the date range from 2007-05-22 to 2007-06-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMN07 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMQ07 for the date range from 2007-06-20 to 2007-07-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMQ07 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMU07 for the date range from 2007-07-20 to 2007-08-21. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMU07 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMV07 for the date range from 2007-08-21 to 2007-09-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMV07 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMX07 for the date range from 2007-09-20 to 2007-10-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMX07 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMZ07 for the date range from 2007-10-22 to 2007-11-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMZ07 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMF08 for the date range from 2007-11-20 to 2007-12-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMF08 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMG08 for the date range from 2007-12-20 to 2008-01-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMG08 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMH08 for the date range from 2008-01-22 to 2008-02-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMH08 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMJ08 for the date range from 2008-02-20 to 2008-03-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMJ08 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMK08 for the date range from 2008-03-20 to 2008-04-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMK08 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMM08 for the date range from 2008-04-22 to 2008-05-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMM08 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMN08 for the date range from 2008-05-20 to 2008-06-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMN08 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMQ08 for the date range from 2008-06-20 to 2008-07-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMQ08 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMU08 for the date range from 2008-07-22 to 2008-08-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMU08 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMV08 for the date range from 2008-08-20 to 2008-09-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMV08 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMX08 for the date range from 2008-09-22 to 2008-10-21. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMX08 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMZ08 for the date range from 2008-10-21 to 2008-11-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMZ08 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMF09 for the date range from 2008-11-20 to 2008-12-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMF09 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMG09 for the date range from 2008-12-22 to 2009-01-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMG09 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMH09 for the date range from 2009-01-20 to 2009-02-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMH09 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMJ09 for the date range from 2009-02-20 to 2009-03-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMJ09 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMK09 for the date range from 2009-03-20 to 2009-04-21. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMK09 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMM09 for the date range from 2009-04-21 to 2009-05-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMM09 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMN09 for the date range from 2009-05-20 to 2009-06-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMN09 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMQ09 for the date range from 2009-06-22 to 2009-07-21. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMQ09 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMU09 for the date range from 2009-07-21 to 2009-08-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMU09 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMV09 for the date range from 2009-08-20 to 2009-09-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMV09 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMX09 for the date range from 2009-09-22 to 2009-10-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMX09 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMZ09 for the date range from 2009-10-20 to 2009-11-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMZ09 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMF10 for the date range from 2009-11-20 to 2009-12-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMF10 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMG10 for the date range from 2009-12-22 to 2010-01-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMG10 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMH10 for the date range from 2010-01-20 to 2010-02-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMH10 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMJ10 for the date range from 2010-02-22 to 2010-03-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMJ10 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMK10 for the date range from 2010-03-22 to 2010-04-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMK10 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMM10 for the date range from 2010-04-20 to 2010-05-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMM10 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMN10 for the date range from 2010-05-20 to 2010-06-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMN10 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMQ10 for the date range from 2010-06-22 to 2010-07-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMQ10 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMU10 for the date range from 2010-07-20 to 2010-08-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMU10 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMV10 for the date range from 2010-08-20 to 2010-09-21. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMV10 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMX10 for the date range from 2010-09-21 to 2010-10-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMX10 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMZ10 for the date range from 2010-10-20 to 2010-11-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMZ10 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMF11 for the date range from 2010-11-22 to 2010-12-21. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMF11 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMG11 for the date range from 2010-12-21 to 2011-01-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMG11 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMH11 for the date range from 2011-01-20 to 2011-02-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMH11 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMJ11 for the date range from 2011-02-22 to 2011-03-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMJ11 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMK11 for the date range from 2011-03-22 to 2011-04-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMK11 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMM11 for the date range from 2011-04-20 to 2011-05-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMM11 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMN11 for the date range from 2011-05-20 to 2011-06-21. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMN11 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMQ11 for the date range from 2011-06-21 to 2011-07-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMQ11 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMU11 for the date range from 2011-07-20 to 2011-08-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMU11 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMV11 for the date range from 2011-08-22 to 2011-09-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMV11 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMX11 for the date range from 2011-09-20 to 2011-10-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMX11 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMZ11 for the date range from 2011-10-20 to 2011-11-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMZ11 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMF12 for the date range from 2011-11-22 to 2011-12-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMF12 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMG12 for the date range from 2011-12-20 to 2012-01-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMG12 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMH12 for the date range from 2012-01-20 to 2012-02-21. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMH12 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMJ12 for the date range from 2012-02-21 to 2012-03-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMJ12 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMK12 for the date range from 2012-03-20 to 2012-04-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMK12 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMM12 for the date range from 2012-04-20 to 2012-05-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMM12 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMN12 for the date range from 2012-05-22 to 2012-06-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMN12 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMQ12 for the date range from 2012-06-20 to 2012-07-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMQ12 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMU12 for the date range from 2012-07-20 to 2012-08-21. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMU12 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMV12 for the date range from 2012-08-21 to 2012-09-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMV12 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMX12 for the date range from 2012-09-20 to 2012-10-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMX12 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMZ12 for the date range from 2012-10-22 to 2012-11-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMZ12 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMF13 for the date range from 2012-11-20 to 2012-12-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMF13 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMG13 for the date range from 2012-12-20 to 2013-01-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMG13 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMH13 for the date range from 2013-01-22 to 2013-02-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMH13 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMJ13 for the date range from 2013-02-20 to 2013-03-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMJ13 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMK13 for the date range from 2013-03-20 to 2013-04-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMK13 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMM13 for the date range from 2013-04-22 to 2013-05-21. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMM13 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMN13 for the date range from 2013-05-21 to 2013-06-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMN13 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMQ13 for the date range from 2013-06-20 to 2013-07-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMQ13 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMU13 for the date range from 2013-07-22 to 2013-08-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMU13 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMV13 for the date range from 2013-08-20 to 2013-09-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMV13 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMX13 for the date range from 2013-09-20 to 2013-10-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMX13 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMZ13 for the date range from 2013-10-22 to 2013-11-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMZ13 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMF14 for the date range from 2013-11-20 to 2013-12-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMF14 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMG14 for the date range from 2013-12-20 to 2014-01-21. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMG14 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMH14 for the date range from 2014-01-21 to 2014-02-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMH14 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMJ14 for the date range from 2014-02-20 to 2014-03-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMJ14 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMK14 for the date range from 2014-03-20 to 2014-04-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMK14 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMM14 for the date range from 2014-04-22 to 2014-05-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMM14 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMN14 for the date range from 2014-05-20 to 2014-06-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMN14 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMQ14 for the date range from 2014-06-20 to 2014-07-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMQ14 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMU14 for the date range from 2014-07-22 to 2014-08-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMU14 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMV14 for the date range from 2014-08-20 to 2014-09-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMV14 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMX14 for the date range from 2014-09-22 to 2014-10-21. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMX14 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMZ14 for the date range from 2014-10-21 to 2014-11-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMZ14 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMF15 for the date range from 2014-11-20 to 2014-12-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMF15 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMG15 for the date range from 2014-12-22 to 2015-01-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMG15 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMH15 for the date range from 2015-01-20 to 2015-02-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMH15 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMJ15 for the date range from 2015-02-20 to 2015-03-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMJ15 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMK15 for the date range from 2015-03-20 to 2015-04-21. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMK15 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMM15 for the date range from 2015-04-21 to 2015-05-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMM15 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMN15 for the date range from 2015-05-20 to 2015-06-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMN15 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMQ15 for the date range from 2015-06-22 to 2015-07-21. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMQ15 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMU15 for the date range from 2015-07-21 to 2015-08-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMU15 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMV15 for the date range from 2015-08-20 to 2015-09-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMV15 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMX15 for the date range from 2015-09-22 to 2015-10-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMX15 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMZ15 for the date range from 2015-10-20 to 2015-11-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMZ15 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMF16 for the date range from 2015-11-20 to 2015-12-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMF16 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMG16 for the date range from 2015-12-22 to 2016-01-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMG16 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMH16 for the date range from 2016-01-20 to 2016-02-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMH16 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMJ16 for the date range from 2016-02-22 to 2016-03-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMJ16 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMK16 for the date range from 2016-03-22 to 2016-04-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMK16 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMM16 for the date range from 2016-04-20 to 2016-05-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMM16 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMN16 for the date range from 2016-05-20 to 2016-06-21. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMN16 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMQ16 for the date range from 2016-06-21 to 2016-07-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMQ16 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMU16 for the date range from 2016-07-20 to 2016-08-22. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMU16 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMV16 for the date range from 2016-08-22 to 2016-09-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Performing historical Daily data download for symbol QMV16 starting at last date in file. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMX16 for the date range from 2016-09-20 to 2016-10-11. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMZ16 for the date range from 2016-10-11 to 2016-10-11. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMZ16.dly. Date: 2016-10-11, Price: 51.525. Date: 2016-10-11, Price: 51.525 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMX16.dly. Date: 2016-09-20, Price: 44.05. Date: 2016-10-10, Price: 51.35 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMV16.dly. Date: 2016-08-22, Price: 47.41. Date: 2016-09-19, Price: 43.3 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMU16.dly. Date: 2016-07-20, Price: 45.75. Date: 2016-08-19, Price: 48.52 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMQ16.dly. Date: 2016-06-21, Price: 49.85. Date: 2016-07-19, Price: 44.65 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMN16.dly. Date: 2016-05-20, Price: 48.4. Date: 2016-06-20, Price: 49.375 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMM16.dly. Date: 2016-04-20, Price: 44.175. Date: 2016-05-19, Price: 48.15 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMK16.dly. Date: 2016-03-22, Price: 41.45. Date: 2016-04-19, Price: 41.075 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMJ16.dly. Date: 2016-02-22, Price: 33.4. Date: 2016-03-21, Price: 39.45 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMH16.dly. Date: 2016-01-20, Price: 28.35. Date: 2016-02-19, Price: 29.64 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMG16.dly. Date: 2015-12-22, Price: 36.15. Date: 2016-01-19, Price: 28.45 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMF16.dly. Date: 2015-11-20, Price: 41.9. Date: 2015-12-21, Price: 34.725 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMZ15.dly. Date: 2015-10-20, Price: 46.29. Date: 2015-11-19, Price: 40.54 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMX15.dly. Date: 2015-09-22, Price: 46.36. Date: 2015-10-19, Price: 45.89 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMV15.dly. Date: 2015-08-20, Price: 41.32. Date: 2015-09-21, Price: 46.68 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMU15.dly. Date: 2015-07-21, Price: 50.86. Date: 2015-08-19, Price: 40.8 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMQ15.dly. Date: 2015-06-22, Price: 60.375. Date: 2015-07-20, Price: 50.15 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMN15.dly. Date: 2015-05-20, Price: 58.975. Date: 2015-06-19, Price: 59.6 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMM15.dly. Date: 2015-04-21, Price: 56.6. Date: 2015-05-19, Price: 59.425 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMK15.dly. Date: 2015-03-20, Price: 46.575. Date: 2015-04-20, Price: 56.375 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMJ15.dly. Date: 2015-02-20, Price: 50.8. Date: 2015-03-19, Price: 43.95 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMH15.dly. Date: 2015-01-20, Price: 46.475. Date: 2015-02-19, Price: 51.15 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMG15.dly. Date: 2014-12-22, Price: 55.25. Date: 2015-01-19, Price: 48.7 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMF15.dly. Date: 2014-11-20, Price: 75.85. Date: 2014-12-19, Price: 54.1 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMZ14.dly. Date: 2014-10-21, Price: 82.5. Date: 2014-11-19, Price: 74.575 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMX14.dly. Date: 2014-09-22, Price: 90.875. Date: 2014-10-20, Price: 82.7 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMV14.dly. Date: 2014-08-20, Price: 93.45. Date: 2014-09-19, Price: 92.4 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMU14.dly. Date: 2014-07-22, Price: 102.4. Date: 2014-08-19, Price: 94.475 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMQ14.dly. Date: 2014-06-20, Price: 106.825. Date: 2014-07-21, Price: 104.6 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMN14.dly. Date: 2014-05-20, Price: 102.325. Date: 2014-06-19, Price: 106.425 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMM14.dly. Date: 2014-04-22, Price: 101.75. Date: 2014-05-19, Price: 102.6 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMK14.dly. Date: 2014-03-20, Price: 98.9. Date: 2014-04-21, Price: 104.375 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMJ14.dly. Date: 2014-02-20, Price: 102.75. Date: 2014-03-19, Price: 100.375 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMH14.dly. Date: 2014-01-21, Price: 94.975. Date: 2014-02-19, Price: 103.3 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMG14.dly. Date: 2013-12-20, Price: 99.325. Date: 2014-01-20, Price: 94.375 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMF14.dly. Date: 2013-11-20, Price: 93.85. Date: 2013-12-19, Price: 97.8 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMZ13.dly. Date: 2013-10-22, Price: 98.3. Date: 2013-11-19, Price: 93.35 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMX13.dly. Date: 2013-09-20, Price: 104.75. Date: 2013-10-21, Price: 99.225 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMV13.dly. Date: 2013-08-20, Price: 105.1. Date: 2013-09-19, Price: 106.4 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMU13.dly. Date: 2013-07-22, Price: 106.95. Date: 2013-08-19, Price: 107.1 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMQ13.dly. Date: 2013-06-20, Price: 95.15. Date: 2013-07-19, Price: 108.05 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMN13.dly. Date: 2013-05-21, Price: 96.175. Date: 2013-06-19, Price: 98.25 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMM13.dly. Date: 2013-04-22, Price: 89.2. Date: 2013-05-20, Price: 96.7 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMK13.dly. Date: 2013-03-20, Price: 93.5. Date: 2013-04-19, Price: 88 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMJ13.dly. Date: 2013-02-20, Price: 95.225. Date: 2013-03-19, Price: 92.15 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMH13.dly. Date: 2013-01-22, Price: 96.675. Date: 2013-02-19, Price: 96.65 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMG13.dly. Date: 2012-12-20, Price: 90.125. Date: 2013-01-21, Price: 95.55 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMF13.dly. Date: 2012-11-20, Price: 86.75. Date: 2012-12-19, Price: 87.925 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMZ12.dly. Date: 2012-10-22, Price: 88.65. Date: 2012-11-19, Price: 85.45 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMX12.dly. Date: 2012-09-20, Price: 92.425. Date: 2012-10-19, Price: 90.05 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMV12.dly. Date: 2012-08-21, Price: 96.85. Date: 2012-09-19, Price: 91.975 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMU12.dly. Date: 2012-07-20, Price: 91.825. Date: 2012-08-20, Price: 95.975 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMQ12.dly. Date: 2012-06-20, Price: 81.45. Date: 2012-07-19, Price: 92.65 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMN12.dly. Date: 2012-05-22, Price: 91.85. Date: 2012-06-19, Price: 84.025 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMM12.dly. Date: 2012-04-20, Price: 103.875. Date: 2012-05-21, Price: 92.575 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMK12.dly. Date: 2012-03-20, Price: 106.075. Date: 2012-04-19, Price: 102.275 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMJ12.dly. Date: 2012-02-21, Price: 106.25. Date: 2012-03-19, Price: 108.1 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMH12.dly. Date: 2012-01-20, Price: 98.325. Date: 2012-02-20, Price: 103.25 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMG12.dly. Date: 2011-12-20, Price: 97.25. Date: 2012-01-19, Price: 100.4 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMF12.dly. Date: 2011-11-22, Price: 98. Date: 2011-12-19, Price: 93.875 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMZ11.dly. Date: 2011-10-20, Price: 86.075. Date: 2011-11-21, Price: 98.825 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMX11.dly. Date: 2011-09-20, Price: 86.925. Date: 2011-10-19, Price: 86.1 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMV11.dly. Date: 2011-08-22, Price: 84.425. Date: 2011-09-19, Price: 85.7 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMU11.dly. Date: 2011-07-20, Price: 98.4. Date: 2011-08-19, Price: 82.25 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMQ11.dly. Date: 2011-06-21, Price: 94.175. Date: 2011-07-19, Price: 97.5 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMN11.dly. Date: 2011-05-20, Price: 100.1. Date: 2011-06-20, Price: 93.25 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMM11.dly. Date: 2011-04-20, Price: 111.45. Date: 2011-05-19, Price: 98.45 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMK11.dly. Date: 2011-03-22, Price: 104.975. Date: 2011-04-19, Price: 107.125 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMJ11.dly. Date: 2011-02-22, Price: 95.425. Date: 2011-03-21, Price: 102.325 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMH11.dly. Date: 2011-01-20, Price: 89.6. Date: 2011-02-21, Price: 86.2 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMG11.dly. Date: 2010-12-21, Price: 89.825. Date: 2011-01-19, Price: 90.85 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMF11.dly. Date: 2010-11-22, Price: 81.75. Date: 2010-12-20, Price: 88.025 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMZ10.dly. Date: 2010-10-20, Price: 82.55. Date: 2010-11-19, Price: 81.85 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMX10.dly. Date: 2010-09-21, Price: 74.975. Date: 2010-10-19, Price: 79.5 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMV10.dly. Date: 2010-08-20, Price: 73.825. Date: 2010-09-20, Price: 74.85 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMU10.dly. Date: 2010-07-20, Price: 77.575. Date: 2010-08-19, Price: 74.425 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMQ10.dly. Date: 2010-06-22, Price: 77.85. Date: 2010-07-19, Price: 76.55 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMQ10.dly has a volume of 0 at 2010-07-19. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMN10.dly. Date: 2010-05-20, Price: 70.8. Date: 2010-06-21, Price: 77.825 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMN10.dly has a volume of 0 at 2010-06-21. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMM10.dly. Date: 2010-04-20, Price: 83.85. Date: 2010-05-19, Price: 69.875 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMM10.dly has a volume of 0 at 2010-05-19. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMK10.dly. Date: 2010-03-22, Price: 81.6. Date: 2010-04-19, Price: 81.45 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMK10.dly has a volume of 0 at 2010-04-19. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMJ10.dly. Date: 2010-02-22, Price: 80.3. Date: 2010-03-19, Price: 80.675 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMJ10.dly has a volume of 0 at 2010-03-19. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMH10.dly. Date: 2010-01-20, Price: 77.75. Date: 2010-02-19, Price: 79.8 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMH10.dly has a volume of 0 at 2010-02-19. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMG10.dly. Date: 2009-12-22, Price: 74.4. Date: 2010-01-19, Price: 79.025 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMG10.dly has a volume of 0 at 2010-01-19. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMF10.dly. Date: 2009-11-20, Price: 77.475. Date: 2009-12-21, Price: 73.35 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMF10.dly has a volume of 0 at 2009-12-21. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMZ09.dly. Date: 2009-10-20, Price: 79.12. Date: 2009-11-19, Price: 77.45 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMZ09.dly has a volume of 0 at 2009-11-19. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMX09.dly. Date: 2009-09-22, Price: 71.76. Date: 2009-10-19, Price: 79.61 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMX09.dly has a volume of 0 at 2009-10-19. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMV09.dly. Date: 2009-08-20, Price: 72.91. Date: 2009-09-21, Price: 69.71 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMV09.dly has a volume of 0 at 2009-09-21. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMU09.dly. Date: 2009-07-21, Price: 65.61. Date: 2009-08-19, Price: 72.42001 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMU09.dly has a volume of 0 at 2009-08-19. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMQ09.dly. Date: 2009-06-22, Price: 67.5. Date: 2009-07-20, Price: 63.98 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMQ09.dly has a volume of 0 at 2009-07-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMN09.dly. Date: 2009-05-20, Price: 62.04. Date: 2009-06-19, Price: 69.55 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMN09.dly has a volume of 0 at 2009-06-19. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMM09.dly. Date: 2009-04-21, Price: 48.55. Date: 2009-05-19, Price: 59.03 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMM09.dly has a volume of 0 at 2009-05-19. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMK09.dly. Date: 2009-03-20, Price: 52.07. Date: 2009-04-20, Price: 45.88 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMK09.dly has a volume of 0 at 2009-04-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMJ09.dly. Date: 2009-02-20, Price: 40.03. Date: 2009-03-19, Price: 51.61 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMJ09.dly has a volume of 0 at 2009-03-19. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMH09.dly. Date: 2009-01-20, Price: 40.84. Date: 2009-02-19, Price: 39.48 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMH09.dly has a volume of 0 at 2009-02-19. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMG09.dly. Date: 2008-12-22, Price: 39.91. Date: 2009-01-19, Price: 36.51 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMF09.dly. Date: 2008-11-20, Price: 49.42. Date: 2008-12-19, Price: 36.22 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMF09.dly has a volume of 0 at 2008-12-19. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMZ08.dly. Date: 2008-10-21, Price: 72.18. Date: 2008-11-19, Price: 53.62 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMZ08.dly has a volume of 0 at 2008-11-19. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMX08.dly. Date: 2008-09-22, Price: 109.37. Date: 2008-10-20, Price: 74.25 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMX08.dly has a volume of 0 at 2008-10-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMV08.dly. Date: 2008-08-20, Price: 115.56. Date: 2008-09-19, Price: 104.55 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMV08.dly has a volume of 0 at 2008-09-19. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMU08.dly. Date: 2008-07-22, Price: 128.42. Date: 2008-08-19, Price: 114.53 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMU08.dly has a volume of 0 at 2008-08-19. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMQ08.dly. Date: 2008-06-20, Price: 135.36. Date: 2008-07-21, Price: 131.04 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMQ08.dly has a volume of 0 at 2008-07-21. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMN08.dly. Date: 2008-05-20, Price: 128.98. Date: 2008-06-19, Price: 131.93 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMN08.dly has a volume of 0 at 2008-06-19. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMM08.dly. Date: 2008-04-22, Price: 118.07. Date: 2008-05-19, Price: 127.05 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMM08.dly has a volume of 0 at 2008-05-19. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMK08.dly. Date: 2008-03-20, Price: 101.84. Date: 2008-04-21, Price: 117.48 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMK08.dly has a volume of 0 at 2008-04-21. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMJ08.dly. Date: 2008-02-20, Price: 99.7. Date: 2008-03-19, Price: 109.42 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMJ08.dly has a volume of 0 at 2008-03-19. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMH08.dly. Date: 2008-01-22, Price: 89.21. Date: 2008-02-19, Price: 100.01 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMH08.dly has a volume of 0 at 2008-02-19. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMG08.dly. Date: 2007-12-20, Price: 91.06. Date: 2008-01-21, Price: 90.57 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMG08.dly has a volume of 0 at 2008-01-21. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMF08.dly. Date: 2007-11-20, Price: 98.03. Date: 2007-12-19, Price: 90.63 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMF08.dly has a volume of 0 at 2007-12-19. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMZ07.dly. Date: 2007-10-22, Price: 86.02. Date: 2007-11-19, Price: 93.43 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMZ07.dly has a volume of 0 at 2007-11-19. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMX07.dly. Date: 2007-09-20, Price: 81.78. Date: 2007-10-19, Price: 88.6 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMX07.dly has a volume of 0 at 2007-10-19. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMV07.dly. Date: 2007-08-21, Price: 69.57. Date: 2007-09-19, Price: 81.93 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMV07.dly has a volume of 0 at 2007-09-19. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMU07.dly. Date: 2007-07-20, Price: 75.79. Date: 2007-08-20, Price: 71.12 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMU07.dly has a volume of 0 at 2007-08-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMQ07.dly. Date: 2007-06-20, Price: 68.86. Date: 2007-07-19, Price: 75.92001 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMQ07.dly has a volume of 0 at 2007-07-19. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMN07.dly. Date: 2007-05-22, Price: 65.51. Date: 2007-06-19, Price: 69.1 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMN07.dly has a volume of 0 at 2007-06-19. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMM07.dly. Date: 2007-04-20, Price: 64.11. Date: 2007-05-21, Price: 66.27 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMM07.dly has a volume of 0 at 2007-05-21. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMK07.dly. Date: 2007-03-20, Price: 59.25. Date: 2007-04-19, Price: 61.83 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMK07.dly has a volume of 0 at 2007-04-19. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMJ07.dly. Date: 2007-02-20, Price: 58.85. Date: 2007-03-19, Price: 56.59 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMJ07.dly has a volume of 0 at 2007-03-19. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMH07.dly. Date: 2007-01-22, Price: 52.58. Date: 2007-02-19, Price: 59.39 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMH07.dly has a volume of 0 at 2007-02-19. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMG07.dly. Date: 2006-12-20, Price: 63.72. Date: 2007-01-19, Price: 51.99 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMG07.dly has a volume of 0 at 2007-01-19. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMF07.dly. Date: 2006-11-21, Price: 60.17. Date: 2006-12-19, Price: 62.21 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMF07.dly has a volume of 0 at 2006-12-19. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMZ06.dly. Date: 2006-10-20, Price: 59.33. Date: 2006-11-20, Price: 56.26 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMZ06.dly has a volume of 0 at 2006-11-20. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMX06.dly. Date: 2006-09-20, Price: 60.74. Date: 2006-10-19, Price: 58.5 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMX06.dly has a volume of 0 at 2006-10-19. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Price data for daily data file QMV06.dly. Date: 2006-08-22, Price: 73.1. Date: 2006-09-19, Price: 61.66 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | File QMV06.dly has a volume of 0 at 2006-09-19. | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Symbols used for continuous contract chart: | 2016-10-11 15:23:38 QMV06 | 2016-10-11 15:23:38 QMX06 | 2016-10-11 15:23:38 QMZ06 | 2016-10-11 15:23:38 QMF07 | 2016-10-11 15:23:38 QMG07 | 2016-10-11 15:23:38 QMH07 | 2016-10-11 15:23:38 QMJ07 | 2016-10-11 15:23:38 QMK07 | 2016-10-11 15:23:38 QMM07 | 2016-10-11 15:23:38 QMN07 | 2016-10-11 15:23:38 QMQ07 | 2016-10-11 15:23:38 QMU07 | 2016-10-11 15:23:38 QMV07 | 2016-10-11 15:23:38 QMX07 | 2016-10-11 15:23:38 QMZ07 | 2016-10-11 15:23:38 QMF08 | 2016-10-11 15:23:38 QMG08 | 2016-10-11 15:23:38 QMH08 | 2016-10-11 15:23:38 QMJ08 | 2016-10-11 15:23:38 QMK08 | 2016-10-11 15:23:38 QMM08 | 2016-10-11 15:23:38 QMN08 | 2016-10-11 15:23:38 QMQ08 | 2016-10-11 15:23:38 QMU08 | 2016-10-11 15:23:38 QMV08 | 2016-10-11 15:23:38 QMX08 | 2016-10-11 15:23:38 QMZ08 | 2016-10-11 15:23:38 QMF09 | 2016-10-11 15:23:38 QMG09 | 2016-10-11 15:23:38 QMH09 | 2016-10-11 15:23:38 QMJ09 | 2016-10-11 15:23:38 QMK09 | 2016-10-11 15:23:38 QMM09 | 2016-10-11 15:23:38 QMN09 | 2016-10-11 15:23:38 QMQ09 | 2016-10-11 15:23:38 QMU09 | 2016-10-11 15:23:38 QMV09 | 2016-10-11 15:23:38 QMX09 | 2016-10-11 15:23:38 QMZ09 | 2016-10-11 15:23:38 QMF10 | 2016-10-11 15:23:38 QMG10 | 2016-10-11 15:23:38 QMH10 | 2016-10-11 15:23:38 QMJ10 | 2016-10-11 15:23:38 QMK10 | 2016-10-11 15:23:38 QMM10 | 2016-10-11 15:23:38 QMN10 | 2016-10-11 15:23:38 QMQ10 | 2016-10-11 15:23:38 QMU10 | 2016-10-11 15:23:38 QMV10 | 2016-10-11 15:23:38 QMX10 | 2016-10-11 15:23:38 QMZ10 | 2016-10-11 15:23:38 QMF11 | 2016-10-11 15:23:38 QMG11 | 2016-10-11 15:23:38 QMH11 | 2016-10-11 15:23:38 QMJ11 | 2016-10-11 15:23:38 QMK11 | 2016-10-11 15:23:38 QMM11 | 2016-10-11 15:23:38 QMN11 | 2016-10-11 15:23:38 QMQ11 | 2016-10-11 15:23:38 QMU11 | 2016-10-11 15:23:38 QMV11 | 2016-10-11 15:23:38 QMX11 | 2016-10-11 15:23:38 QMZ11 | 2016-10-11 15:23:38 QMF12 | 2016-10-11 15:23:38 QMG12 | 2016-10-11 15:23:38 QMH12 | 2016-10-11 15:23:38 QMJ12 | 2016-10-11 15:23:38 QMK12 | 2016-10-11 15:23:38 QMM12 | 2016-10-11 15:23:38 QMN12 | 2016-10-11 15:23:38 QMQ12 | 2016-10-11 15:23:38 QMU12 | 2016-10-11 15:23:38 QMV12 | 2016-10-11 15:23:38 QMX12 | 2016-10-11 15:23:38 QMZ12 | 2016-10-11 15:23:38 QMF13 | 2016-10-11 15:23:38 QMG13 | 2016-10-11 15:23:38 QMH13 | 2016-10-11 15:23:38 QMJ13 | 2016-10-11 15:23:38 QMK13 | 2016-10-11 15:23:38 QMM13 | 2016-10-11 15:23:38 QMN13 | 2016-10-11 15:23:38 QMQ13 | 2016-10-11 15:23:38 QMU13 | 2016-10-11 15:23:38 QMV13 | 2016-10-11 15:23:38 QMX13 | 2016-10-11 15:23:38 QMZ13 | 2016-10-11 15:23:38 QMF14 | 2016-10-11 15:23:38 QMG14 | 2016-10-11 15:23:38 QMH14 | 2016-10-11 15:23:38 QMJ14 | 2016-10-11 15:23:38 QMK14 | 2016-10-11 15:23:38 QMM14 | 2016-10-11 15:23:38 QMN14 | 2016-10-11 15:23:38 QMQ14 | 2016-10-11 15:23:38 QMU14 | 2016-10-11 15:23:38 QMV14 | 2016-10-11 15:23:38 QMX14 | 2016-10-11 15:23:38 QMZ14 | 2016-10-11 15:23:38 QMF15 | 2016-10-11 15:23:38 QMG15 | 2016-10-11 15:23:38 QMH15 | 2016-10-11 15:23:38 QMJ15 | 2016-10-11 15:23:38 QMK15 | 2016-10-11 15:23:38 QMM15 | 2016-10-11 15:23:38 QMN15 | 2016-10-11 15:23:38 QMQ15 | 2016-10-11 15:23:38 QMU15 | 2016-10-11 15:23:38 QMV15 | 2016-10-11 15:23:38 QMX15 | 2016-10-11 15:23:38 QMZ15 | 2016-10-11 15:23:38 QMF16 | 2016-10-11 15:23:38 QMG16 | 2016-10-11 15:23:38 QMH16 | 2016-10-11 15:23:38 QMJ16 | 2016-10-11 15:23:38 QMK16 | 2016-10-11 15:23:38 QMM16 | 2016-10-11 15:23:38 QMN16 | 2016-10-11 15:23:38 QMQ16 | 2016-10-11 15:23:38 QMU16 | 2016-10-11 15:23:38 QMV16 | 2016-10-11 15:23:38 QMX16 | 2016-10-11 15:23:38 QMZ16 | 2016-10-11 15:23:38 QMZ16 [CB] Weekly #1 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Reloading chart. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Date rule based rollover from QMV15 to next contract occurs at 2015-09-22. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Date rule based rollover from QMX15 to next contract occurs at 2015-10-20. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Date rule based rollover from QMZ15 to next contract occurs at 2015-11-20. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Date rule based rollover from QMF16 to next contract occurs at 2015-12-22. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Date rule based rollover from QMG16 to next contract occurs at 2016-01-20. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Date rule based rollover from QMH16 to next contract occurs at 2016-02-22. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Date rule based rollover from QMJ16 to next contract occurs at 2016-03-22. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Date rule based rollover from QMK16 to next contract occurs at 2016-04-20. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Date rule based rollover from QMM16 to next contract occurs at 2016-05-20. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Date rule based rollover from QMN16 to next contract occurs at 2016-06-21. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Date rule based rollover from QMQ16 to next contract occurs at 2016-07-20. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Date rule based rollover from QMU16 to next contract occurs at 2016-08-22. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Date rule based rollover from QMV16 to next contract occurs at 2016-09-20. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Date rule based rollover from QMX16 to next contract occurs at 2016-10-20. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Date rule based rollover from QMZ16 to next contract occurs at 2016-11-22. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Checking Daily data file for symbol QMV15 for the date range from 2015-08-20 to 2015-09-22. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Skipping Daily data download for symbol QMV15 since download was already done in last 24 hours. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Checking Daily data file for symbol QMX15 for the date range from 2015-09-22 to 2015-10-20. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Skipping Daily data download for symbol QMX15 since download was already done in last 24 hours. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Checking Daily data file for symbol QMZ15 for the date range from 2015-10-20 to 2015-11-20. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Skipping Daily data download for symbol QMZ15 since download was already done in last 24 hours. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Checking Daily data file for symbol QMF16 for the date range from 2015-11-20 to 2015-12-22. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Skipping Daily data download for symbol QMF16 since download was already done in last 24 hours. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Checking Daily data file for symbol QMG16 for the date range from 2015-12-22 to 2016-01-20. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Skipping Daily data download for symbol QMG16 since download was already done in last 24 hours. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Checking Daily data file for symbol QMH16 for the date range from 2016-01-20 to 2016-02-22. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Skipping Daily data download for symbol QMH16 since download was already done in last 24 hours. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Checking Daily data file for symbol QMJ16 for the date range from 2016-02-22 to 2016-03-22. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Skipping Daily data download for symbol QMJ16 since download was already done in last 24 hours. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Checking Daily data file for symbol QMK16 for the date range from 2016-03-22 to 2016-04-20. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Skipping Daily data download for symbol QMK16 since download was already done in last 24 hours. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Checking Daily data file for symbol QMM16 for the date range from 2016-04-20 to 2016-05-20. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Skipping Daily data download for symbol QMM16 since download was already done in last 24 hours. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Checking Daily data file for symbol QMN16 for the date range from 2016-05-20 to 2016-06-21. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Skipping Daily data download for symbol QMN16 since download was already done in last 24 hours. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Checking Daily data file for symbol QMQ16 for the date range from 2016-06-21 to 2016-07-20. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Skipping Daily data download for symbol QMQ16 since download was already done in last 24 hours. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Checking Daily data file for symbol QMU16 for the date range from 2016-07-20 to 2016-08-22. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Skipping Daily data download for symbol QMU16 since download was already done in last 24 hours. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Checking Daily data file for symbol QMV16 for the date range from 2016-08-22 to 2016-09-20. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Skipping Daily data download for symbol QMV16 since download was already done in last 24 hours. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Checking Daily data file for symbol QMX16 for the date range from 2016-09-20 to 2016-10-11. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Checking Daily data file for symbol QMZ16 for the date range from 2016-10-11 to 2016-10-11. | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Price data for daily data file QMZ16.dly. Date: 2016-10-11, Price: 51.525. Date: 2016-10-11, Price: 51.525 | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Price data for daily data file QMX16.dly. Date: 2016-09-20, Price: 44.05. Date: 2016-10-10, Price: 51.35 | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Price data for daily data file QMV16.dly. Date: 2016-08-22, Price: 47.41. Date: 2016-09-19, Price: 43.3 | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Price data for daily data file QMU16.dly. Date: 2016-07-20, Price: 45.75. Date: 2016-08-19, Price: 48.52 | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Price data for daily data file QMQ16.dly. Date: 2016-06-21, Price: 49.85. Date: 2016-07-19, Price: 44.65 | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Price data for daily data file QMN16.dly. Date: 2016-05-20, Price: 48.4. Date: 2016-06-20, Price: 49.375 | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Price data for daily data file QMM16.dly. Date: 2016-04-20, Price: 44.175. Date: 2016-05-19, Price: 48.15 | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Price data for daily data file QMK16.dly. Date: 2016-03-22, Price: 41.45. Date: 2016-04-19, Price: 41.075 | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Price data for daily data file QMJ16.dly. Date: 2016-02-22, Price: 33.4. Date: 2016-03-21, Price: 39.45 | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Price data for daily data file QMH16.dly. Date: 2016-01-20, Price: 28.35. Date: 2016-02-19, Price: 29.64 | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Price data for daily data file QMG16.dly. Date: 2015-12-22, Price: 36.15. Date: 2016-01-19, Price: 28.45 | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Price data for daily data file QMF16.dly. Date: 2015-11-20, Price: 41.9. Date: 2015-12-21, Price: 34.725 | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Price data for daily data file QMZ15.dly. Date: 2015-10-20, Price: 46.29. Date: 2015-11-19, Price: 40.54 | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Price data for daily data file QMX15.dly. Date: 2015-09-22, Price: 46.36. Date: 2015-10-19, Price: 45.89 | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Price data for daily data file QMV15.dly. Date: 2015-08-20, Price: 41.32. Date: 2015-09-21, Price: 46.68 | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Symbols used for continuous contract chart: | 2016-10-11 15:23:38 QMV15 | 2016-10-11 15:23:38 QMX15 | 2016-10-11 15:23:38 QMZ15 | 2016-10-11 15:23:38 QMF16 | 2016-10-11 15:23:38 QMG16 | 2016-10-11 15:23:38 QMH16 | 2016-10-11 15:23:38 QMJ16 | 2016-10-11 15:23:38 QMK16 | 2016-10-11 15:23:38 QMM16 | 2016-10-11 15:23:38 QMN16 | 2016-10-11 15:23:38 QMQ16 | 2016-10-11 15:23:38 QMU16 | 2016-10-11 15:23:38 QMV16 | 2016-10-11 15:23:38 QMX16 | 2016-10-11 15:23:38 QMZ16 | 2016-10-11 15:23:38 QMZ16 [CB] Daily #2 | Waiting for historical downloads to complete with the IDs: 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, | 2016-10-11 15:23:38 QMZ16 [CB] 30 Min #3 | Reloading chart. | 2016-10-11 15:23:38 QMZ16 [CB] 30 Min #3 | Date rule based rollover from QMN16 to next contract occurs at 2016-06-21. | 2016-10-11 15:23:38 QMZ16 [CB] 30 Min #3 | Date rule based rollover from QMQ16 to next contract occurs at 2016-07-20. | 2016-10-11 15:23:38 QMZ16 [CB] 30 Min #3 | Date rule based rollover from QMU16 to next contract occurs at 2016-08-22. | 2016-10-11 15:23:38 QMZ16 [CB] 30 Min #3 | Date rule based rollover from QMV16 to next contract occurs at 2016-09-20. | 2016-10-11 15:23:38 QMZ16 [CB] 30 Min #3 | Date rule based rollover from QMX16 to next contract occurs at 2016-10-20. | 2016-10-11 15:23:38 QMZ16 [CB] 30 Min #3 | Date rule based rollover from QMZ16 to next contract occurs at 2016-11-22. | 2016-10-11 15:23:38 QMZ16 [CB] 30 Min #3 | Intraday data file for QMN16 exists and is empty. Skipping Intraday data download. | 2016-10-11 15:23:38 QMZ16 [CB] 30 Min #3 | Checking Daily data file for symbol QMN16 for the date range from 2016-05-20 to 2016-06-21. | 2016-10-11 15:23:38 QMZ16 [CB] 30 Min #3 | Skipping Daily data download for symbol QMN16 since download was already done in last 24 hours. | 2016-10-11 15:23:38 QMZ16 [CB] 30 Min #3 | Intraday data file for QMQ16 exists and is empty. Skipping Intraday data download. | 2016-10-11 15:23:38 QMZ16 [CB] 30 Min #3 | Checking Daily data file for symbol QMQ16 for the date range from 2016-06-21 to 2016-07-20. | 2016-10-11 15:23:38 QMZ16 [CB] 30 Min #3 | Skipping Daily data download for symbol QMQ16 since download was already done in last 24 hours. | 2016-10-11 15:23:38 QMZ16 [CB] 30 Min #3 | Checking Intraday data file for symbol QMU16 for the date range from 2016-07-20 to 2016-08-22. | 2016-10-11 15:23:38 QMZ16 [CB] 30 Min #3 | Checking Daily data file for symbol QMU16 for the date range from 2016-07-20 to 2016-08-22. | 2016-10-11 15:23:38 QMZ16 [CB] 30 Min #3 | Skipping Daily data download for symbol QMU16 since download was already done in last 24 hours. | 2016-10-11 15:23:38 QMZ16 [CB] 30 Min #3 | Checking Intraday data file for symbol QMV16 for the date range from 2016-08-22 to 2016-09-20. | 2016-10-11 15:23:38 QMZ16 [CB] 30 Min #3 | Checking Daily data file for symbol QMV16 for the date range from 2016-08-22 to 2016-09-20. | 2016-10-11 15:23:38 QMZ16 [CB] 30 Min #3 | Skipping Daily data download for symbol QMV16 since download was already done in last 24 hours. | 2016-10-11 15:23:38 QMZ16 [CB] 30 Min #3 | Checking Intraday data file for symbol QMX16 for the date range from 2016-09-20 to 2016-10-11. | 2016-10-11 15:23:38 QMZ16 [CB] 30 Min #3 | Checking Daily data file for symbol QMX16 for the date range from 2016-09-20 to 2016-10-11. | 2016-10-11 15:23:38 QMZ16 [CB] 30 Min #3 | Checking Intraday data file for symbol QMZ16 for the date range from 2016-10-11 to 0. | 2016-10-11 15:23:38 QMZ16 [CB] 30 Min #3 | Checking Daily data file for symbol QMZ16 for the date range from 2016-10-11 to 2016-10-11. | 2016-10-11 15:23:38 QMZ16 [CB] 30 Min #3 | Price data for daily data file QMZ16.dly. Date: 2016-10-11, Price: 51.525. Date: 2016-10-11, Price: 51.525 | 2016-10-11 15:23:38 QMZ16 [CB] 30 Min #3 | Price data for daily data file QMX16.dly. Date: 2016-09-20, Price: 44.05. Date: 2016-10-10, Price: 51.35 | 2016-10-11 15:23:38 QMZ16 [CB] 30 Min #3 | Price data for daily data file QMV16.dly. Date: 2016-08-22, Price: 47.41. Date: 2016-09-19, Price: 43.3 | 2016-10-11 15:23:38 QMZ16 [CB] 30 Min #3 | Price data for daily data file QMU16.dly. Date: 2016-07-20, Price: 45.75. Date: 2016-08-19, Price: 48.52 | 2016-10-11 15:23:38 QMZ16 [CB] 30 Min #3 | Price data for daily data file QMQ16.dly. Date: 2016-06-21, Price: 49.85. Date: 2016-07-19, Price: 44.65 | 2016-10-11 15:23:38 QMZ16 [CB] 30 Min #3 | Price data for daily data file QMN16.dly. Date: 2016-05-20, Price: 48.4. Date: 2016-06-20, Price: 49.375 | 2016-10-11 15:23:38 QMZ16 [CB] 30 Min #3 | Symbols used for continuous contract chart: | 2016-10-11 15:23:38 QMN16 | 2016-10-11 15:23:38 QMQ16 | 2016-10-11 15:23:38 QMU16 | 2016-10-11 15:23:38 QMV16 | 2016-10-11 15:23:38 QMX16 | 2016-10-11 15:23:38 QMZ16 | 2016-10-11 15:23:38 QMZ16 [CB] 30 Min #3 | Waiting for historical downloads to complete with the IDs: 118, 119, 120, 121, 122, 123, | 2016-10-11 15:23:38 Mapping QMV06 to QMV06. Service code: nymex | 2016-10-11 15:23:38 HD Request # 2 | Downloading Historical Daily chart data for QMV06. Starting date: 2006-09-18. Service: tda | 2016-10-11 15:23:38 HD Request # 2 | Using user Barchart Historical data account. | 2016-10-11 15:23:38 HD Request # 2 | Requesting historical Daily data for QMV06 starting at 2006-09-17 | 2016-10-11 15:23:38 Mapping QMU16 to QMU16. Service code: nymex | 2016-10-11 15:23:38 HD Request # 3 | Downloading Intraday chart data for QMU16 to the file QMU16.scid. Service: nymex | 2016-10-11 15:23:38 HD Request # 3 | Download start date-time: 2016-09-20 18:59:59.000 | 2016-10-11 15:23:38 HD Request # 3 | Using server: ds6.sierracharts.com port 10149 | 2016-10-11 15:23:38 HTTP connection to ds01.ddfplus.com:80 (0) | Resolved address ds01.ddfplus.com to IP 8.18.161.123. | 2016-10-11 15:23:38 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-10-11 15:23:38 HTTP connection to ds01.ddfplus.com:80 (7) | Connected. | 2016-10-11 15:23:44 Socket (6) | Connected. | 2016-10-11 15:23:44 Setting HD DTC Encoding to Binary VLS | 2016-10-11 15:23:44 * HD Request # 3 | Sending historical data logon request message. | 2016-10-11 15:23:44 HD Request # 3 | Requesting Intraday data. Start date-time: 2016-09-20 18:59:59. Record interval: 0. Symbol: QMU16 | 2016-10-11 15:23:45 HD Request # 2 | Receiving historical Daily data for QMV06 starting at 2006-09-18 | 2016-10-11 15:23:45 HD Request # 2 | Writing historical Daily data to the file QMV06.dly | 2016-10-11 15:23:45 HD Request # 2 | Received 2 records from 2006-09-18 00:00:00 to 2006-09-19 00:00:00 (2.0 days) and wrote 2 records for QMV06 | 2016-10-11 15:23:45 HD Request # 2 | Daily download COMPLETE for QMV06. Completion time: 0s. Unique request ID: 1 | 2016-10-11 15:23:45 Removed historical data download ID 1 | 2016-10-11 15:23:45 Mapping QMX06 to QMX06. Service code: nymex | 2016-10-11 15:23:45 HD Request # 4 | Downloading Historical Daily chart data for QMX06. Starting date: 2006-10-18. Service: tda | 2016-10-11 15:23:45 HD Request # 4 | Using user Barchart Historical data account. | 2016-10-11 15:23:45 HD Request # 4 | Requesting historical Daily data for QMX06 starting at 2006-10-17 | 2016-10-11 15:23:45 HD Request # 3 | Decompressing data. | 2016-10-11 15:23:45 HD Request # 3 | Receiving Intraday data for QMU16 starting at 2016-08-18 13:27:52 | 2016-10-11 15:23:45 HD Request # 4 | Receiving historical Daily data for QMX06 starting at 2006-10-18 | 2016-10-11 15:23:45 HD Request # 4 | Writing historical Daily data to the file QMX06.dly | 2016-10-11 15:23:45 Socket (6) | Shutdown and closed. | 2016-10-11 15:23:45 The network socket for historical data has been closed. | 2016-10-11 15:23:45 HD Request # 4 | Received 3 records from 2006-10-18 00:00:00 to 2006-10-19 00:00:00 (2.0 days) and wrote 2 records for QMX06 | 2016-10-11 15:23:45 HD Request # 4 | Daily download COMPLETE for QMX06. Completion time: 1s. Unique request ID: 2 | 2016-10-11 15:23:45 Removed historical data download ID 2 | 2016-10-11 15:23:45 HD Request # 3 | Received 1290 records from 2016-08-18 13:27:52 to 2016-08-19 13:27:46 (24.0 hours) and wrote 0 records for QMU16 | 2016-10-11 15:23:45 HD Request # 3 | Intraday download COMPLETE for QMU16. Completion time: 2s. Unique request ID: 122 | 2016-10-11 15:23:45 Removed historical data download ID 122 | 2016-10-11 15:23:45 Real-time Intraday chart data file updates started for QMU16 | 2016-10-11 15:23:45 Intraday chart data file opened for QMU16 | 2016-10-11 15:23:45 Mapping QMZ06 to QMZ06. Service code: nymex | 2016-10-11 15:23:45 HD Request # 5 | Downloading Historical Daily chart data for QMZ06. Starting date: 2006-11-15. Service: tda | 2016-10-11 15:23:45 HD Request # 5 | Using user Barchart Historical data account. | 2016-10-11 15:23:45 HD Request # 5 | Requesting historical Daily data for QMZ06 starting at 2006-11-14 | 2016-10-11 15:23:45 Mapping QMV16 to QMV16. Service code: nymex | 2016-10-11 15:23:45 HD Request # 6 | Downloading Intraday chart data for QMV16 to the file QMV16.scid. Service: nymex | 2016-10-11 15:23:45 HD Request # 6 | Download start date-time: 2016-10-01 15:23:45.000 | 2016-10-11 15:23:45 HD Request # 6 | Using server: ds1.sierracharts.com port 10149 | 2016-10-11 15:23:45 Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-10-11 15:23:45 Socket (8) | Connected. | 2016-10-11 15:23:45 Setting HD DTC Encoding to Binary VLS | 2016-10-11 15:23:45 * HD Request # 6 | Sending historical data logon request message. | 2016-10-11 15:23:45 HD Request # 5 | Receiving historical Daily data for QMZ06 starting at 2006-11-15 | 2016-10-11 15:23:45 HD Request # 5 | Writing historical Daily data to the file QMZ06.dly | 2016-10-11 15:23:45 HD Request # 5 | Received 3 records from 2006-11-15 00:00:00 to 2006-11-16 00:00:00 (2.0 days) and wrote 2 records for QMZ06 | 2016-10-11 15:23:45 HD Request # 5 | Daily download COMPLETE for QMZ06. Completion time: 0s. Unique request ID: 3 | 2016-10-11 15:23:45 Removed historical data download ID 3 | 2016-10-11 15:23:45 Mapping QMF07 to QMF07. Service code: nymex | 2016-10-11 15:23:45 HD Request # 7 | Downloading Historical Daily chart data for QMF07. Starting date: 2006-12-15. Service: tda | 2016-10-11 15:23:45 HD Request # 7 | Using user Barchart Historical data account. | 2016-10-11 15:23:45 HD Request # 7 | Requesting historical Daily data for QMF07 starting at 2006-12-14 | 2016-10-11 15:23:45 HD Request # 6 | Requesting Intraday data. Start date-time: 2016-10-01 15:23:45. Record interval: 0. Symbol: QMV16 | 2016-10-11 15:23:46 HD Request # 6 | Decompressing data. | 2016-10-11 15:23:46 HD Request # 7 | Receiving historical Daily data for QMF07 starting at 2006-12-15 | 2016-10-11 15:23:46 HD Request # 7 | Writing historical Daily data to the file QMF07.dly | 2016-10-11 15:23:46 HD Request # 7 | Received 3 records from 2006-12-15 00:00:00 to 2006-12-18 00:00:00 (4.0 days) and wrote 2 records for QMF07 | 2016-10-11 15:23:46 HD Request # 7 | Daily download COMPLETE for QMF07. Completion time: 0s. Unique request ID: 4 | 2016-10-11 15:23:46 Removed historical data download ID 4 | 2016-10-11 15:23:46 Mapping QMG07 to QMG07. Service code: nymex | 2016-10-11 15:23:46 HD Request # 8 | Downloading Historical Daily chart data for QMG07. Starting date: 2007-01-18. Service: tda | 2016-10-11 15:23:46 HD Request # 8 | Using user Barchart Historical data account. | 2016-10-11 15:23:46 HD Request # 8 | Requesting historical Daily data for QMG07 starting at 2007-01-17 | 2016-10-11 15:23:46 HD Request # 6 | Receiving Intraday data for QMV16 starting at 2016-09-18 17:00:00 | 2016-10-11 15:23:46 Socket (8) | Shutdown and closed. | 2016-10-11 15:23:46 The network socket for historical data has been closed. | 2016-10-11 15:23:46 HD Request # 6 | Received 874 records from 2016-09-18 17:00:00 to 2016-09-19 13:29:58 (20.5 hours) and wrote 0 records for QMV16 | 2016-10-11 15:23:46 HD Request # 6 | Intraday download COMPLETE for QMV16. Completion time: 0s. Unique request ID: 123 | 2016-10-11 15:23:46 Removed historical data download ID 123 | 2016-10-11 15:23:46 Real-time Intraday chart data file updates started for QMV16 | 2016-10-11 15:23:46 Intraday chart data file opened for QMV16 | 2016-10-11 15:23:46 HD Request # 8 | Receiving historical Daily data for QMG07 starting at 2007-01-18 | 2016-10-11 15:23:46 HD Request # 8 | Writing historical Daily data to the file QMG07.dly | 2016-10-11 15:23:46 HD Request # 8 | Received 3 records from 2007-01-18 00:00:00 to 2007-01-19 00:00:00 (2.0 days) and wrote 2 records for QMG07 | 2016-10-11 15:23:46 HD Request # 8 | Daily download COMPLETE for QMG07. Completion time: 0s. Unique request ID: 5 | 2016-10-11 15:23:46 Removed historical data download ID 5 | 2016-10-11 15:23:46 Mapping QMH07 to QMH07. Service code: nymex | 2016-10-11 15:23:46 HD Request # 9 | Downloading Historical Daily chart data for QMH07. Starting date: 2007-02-15. Service: tda | 2016-10-11 15:23:46 HD Request # 9 | Using user Barchart Historical data account. | 2016-10-11 15:23:46 HD Request # 9 | Requesting historical Daily data for QMH07 starting at 2007-02-14 | 2016-10-11 15:23:46 HD Request # 9 | Receiving historical Daily data for QMH07 starting at 2007-02-15 | 2016-10-11 15:23:47 HD Request # 9 | Writing historical Daily data to the file QMH07.dly | 2016-10-11 15:23:47 HD Request # 9 | Received 3 records from 2007-02-15 00:00:00 to 2007-02-16 00:00:00 (2.0 days) and wrote 2 records for QMH07 | 2016-10-11 15:23:47 HD Request # 9 | Daily download COMPLETE for QMH07. Completion time: 0s. Unique request ID: 6 | 2016-10-11 15:23:47 Removed historical data download ID 6 | 2016-10-11 15:23:47 Mapping QMJ07 to QMJ07. Service code: nymex | 2016-10-11 15:23:47 HD Request # 10 | Downloading Historical Daily chart data for QMJ07. Starting date: 2007-03-16. Service: tda | 2016-10-11 15:23:47 HD Request # 10 | Using user Barchart Historical data account. | 2016-10-11 15:23:47 HD Request # 10 | Requesting historical Daily data for QMJ07 starting at 2007-03-15 | 2016-10-11 15:23:47 HD Request # 10 | Receiving historical Daily data for QMJ07 starting at 2007-03-16 | 2016-10-11 15:23:47 HD Request # 10 | Writing historical Daily data to the file QMJ07.dly | 2016-10-11 15:23:47 HD Request # 10 | Received 3 records from 2007-03-16 00:00:00 to 2007-03-19 00:00:00 (4.0 days) and wrote 2 records for QMJ07 | 2016-10-11 15:23:47 HD Request # 10 | Daily download COMPLETE for QMJ07. Completion time: 0s. Unique request ID: 7 | 2016-10-11 15:23:47 Removed historical data download ID 7 | 2016-10-11 15:23:47 Mapping QMK07 to QMK07. Service code: nymex | 2016-10-11 15:23:47 HD Request # 11 | Downloading Historical Daily chart data for QMK07. Starting date: 2007-04-18. Service: tda | 2016-10-11 15:23:47 HD Request # 11 | Using user Barchart Historical data account. | 2016-10-11 15:23:47 HD Request # 11 | Requesting historical Daily data for QMK07 starting at 2007-04-17 | 2016-10-11 15:23:47 HD Request # 11 | Receiving historical Daily data for QMK07 starting at 2007-04-18 | 2016-10-11 15:23:47 HD Request # 11 | Writing historical Daily data to the file QMK07.dly | 2016-10-11 15:23:47 HD Request # 11 | Received 3 records from 2007-04-18 00:00:00 to 2007-04-19 00:00:00 (2.0 days) and wrote 2 records for QMK07 | 2016-10-11 15:23:47 HD Request # 11 | Daily download COMPLETE for QMK07. Completion time: 1s. Unique request ID: 8 | 2016-10-11 15:23:47 Removed historical data download ID 8 | 2016-10-11 15:23:47 Mapping QMM07 to QMM07. Service code: nymex | 2016-10-11 15:23:47 HD Request # 12 | Downloading Historical Daily chart data for QMM07. Starting date: 2007-05-18. Service: tda | 2016-10-11 15:23:47 HD Request # 12 | Using user Barchart Historical data account. | 2016-10-11 15:23:47 HD Request # 12 | Requesting historical Daily data for QMM07 starting at 2007-05-17 | 2016-10-11 15:23:47 HD Request # 12 | Receiving historical Daily data for QMM07 starting at 2007-05-18 | 2016-10-11 15:23:48 HD Request # 12 | Writing historical Daily data to the file QMM07.dly | 2016-10-11 15:23:48 HD Request # 12 | Received 3 records from 2007-05-18 00:00:00 to 2007-05-21 00:00:00 (4.0 days) and wrote 2 records for QMM07 | 2016-10-11 15:23:48 HD Request # 12 | Daily download COMPLETE for QMM07. Completion time: 0s. Unique request ID: 9 | 2016-10-11 15:23:48 Removed historical data download ID 9 | 2016-10-11 15:23:48 Mapping QMN07 to QMN07. Service code: nymex | 2016-10-11 15:23:48 HD Request # 13 | Downloading Historical Daily chart data for QMN07. Starting date: 2007-06-18. Service: tda | 2016-10-11 15:23:48 HD Request # 13 | Using user Barchart Historical data account. | 2016-10-11 15:23:48 HD Request # 13 | Requesting historical Daily data for QMN07 starting at 2007-06-17 | 2016-10-11 15:23:48 HD Request # 13 | Receiving historical Daily data for QMN07 starting at 2007-06-18 | 2016-10-11 15:23:48 HD Request # 13 | Writing historical Daily data to the file QMN07.dly | 2016-10-11 15:23:48 HD Request # 13 | Received 2 records from 2007-06-18 00:00:00 to 2007-06-19 00:00:00 (2.0 days) and wrote 2 records for QMN07 | 2016-10-11 15:23:48 HD Request # 13 | Daily download COMPLETE for QMN07. Completion time: 1s. Unique request ID: 10 | 2016-10-11 15:23:48 Removed historical data download ID 10 | 2016-10-11 15:23:48 Mapping QMQ07 to QMQ07. Service code: nymex | 2016-10-11 15:23:48 HD Request # 14 | Downloading Historical Daily chart data for QMQ07. Starting date: 2007-07-18. Service: tda | 2016-10-11 15:23:48 HD Request # 14 | Using user Barchart Historical data account. | 2016-10-11 15:23:48 HD Request # 14 | Requesting historical Daily data for QMQ07 starting at 2007-07-17 | 2016-10-11 15:23:48 HD Request # 14 | Receiving historical Daily data for QMQ07 starting at 2007-07-18 | 2016-10-11 15:23:48 HD Request # 14 | Writing historical Daily data to the file QMQ07.dly | 2016-10-11 15:23:48 HD Request # 14 | Received 3 records from 2007-07-18 00:00:00 to 2007-07-19 00:00:00 (2.0 days) and wrote 2 records for QMQ07 | 2016-10-11 15:23:48 HD Request # 14 | Daily download COMPLETE for QMQ07. Completion time: 0s. Unique request ID: 11 | 2016-10-11 15:23:48 Removed historical data download ID 11 | 2016-10-11 15:23:48 Mapping QMU07 to QMU07. Service code: nymex | 2016-10-11 15:23:48 HD Request # 15 | Downloading Historical Daily chart data for QMU07. Starting date: 2007-08-17. Service: tda | 2016-10-11 15:23:48 HD Request # 15 | Using user Barchart Historical data account. | 2016-10-11 15:23:48 HD Request # 15 | Requesting historical Daily data for QMU07 starting at 2007-08-16 | 2016-10-11 15:23:48 HD Request # 15 | Receiving historical Daily data for QMU07 starting at 2007-08-17 | 2016-10-11 15:23:49 HD Request # 15 | Writing historical Daily data to the file QMU07.dly | 2016-10-11 15:23:49 HD Request # 15 | Received 3 records from 2007-08-17 00:00:00 to 2007-08-20 00:00:00 (4.0 days) and wrote 2 records for QMU07 | 2016-10-11 15:23:49 HD Request # 15 | Daily download COMPLETE for QMU07. Completion time: 0s. Unique request ID: 12 | 2016-10-11 15:23:49 Removed historical data download ID 12 | 2016-10-11 15:23:49 Mapping QMV07 to QMV07. Service code: nymex | 2016-10-11 15:23:49 HD Request # 16 | Downloading Historical Daily chart data for QMV07. Starting date: 2007-09-18. Service: tda | 2016-10-11 15:23:49 HD Request # 16 | Using user Barchart Historical data account. | 2016-10-11 15:23:49 HD Request # 16 | Requesting historical Daily data for QMV07 starting at 2007-09-17 | 2016-10-11 15:23:49 HD Request # 16 | Receiving historical Daily data for QMV07 starting at 2007-09-18 | 2016-10-11 15:23:49 HD Request # 16 | Writing historical Daily data to the file QMV07.dly | 2016-10-11 15:23:49 HD Request # 16 | Received 3 records from 2007-09-18 00:00:00 to 2007-09-19 00:00:00 (2.0 days) and wrote 2 records for QMV07 | 2016-10-11 15:23:49 HD Request # 16 | Daily download COMPLETE for QMV07. Completion time: 0s. Unique request ID: 13 | 2016-10-11 15:23:49 Removed historical data download ID 13 | 2016-10-11 15:23:49 Mapping QMX07 to QMX07. Service code: nymex | 2016-10-11 15:23:49 HD Request # 17 | Downloading Historical Daily chart data for QMX07. Starting date: 2007-10-18. Service: tda | 2016-10-11 15:23:49 HD Request # 17 | Using user Barchart Historical data account. | 2016-10-11 15:23:49 HD Request # 17 | Requesting historical Daily data for QMX07 starting at 2007-10-17 | 2016-10-11 15:23:49 HD Request # 17 | Receiving historical Daily data for QMX07 starting at 2007-10-18 | 2016-10-11 15:23:50 HD Request # 17 | Writing historical Daily data to the file QMX07.dly | 2016-10-11 15:23:50 HD Request # 17 | Received 3 records from 2007-10-18 00:00:00 to 2007-10-19 00:00:00 (2.0 days) and wrote 2 records for QMX07 | 2016-10-11 15:23:50 HD Request # 17 | Daily download COMPLETE for QMX07. Completion time: 0s. Unique request ID: 14 | 2016-10-11 15:23:50 Removed historical data download ID 14 | 2016-10-11 15:23:50 Mapping QMZ07 to QMZ07. Service code: nymex | 2016-10-11 15:23:50 HD Request # 18 | Downloading Historical Daily chart data for QMZ07. Starting date: 2007-11-14. Service: tda | 2016-10-11 15:23:50 HD Request # 18 | Using user Barchart Historical data account. | 2016-10-11 15:23:50 HD Request # 18 | Requesting historical Daily data for QMZ07 starting at 2007-11-13 | 2016-10-11 15:23:50 HD Request # 18 | Receiving historical Daily data for QMZ07 starting at 2007-11-14 | 2016-10-11 15:23:50 HD Request # 18 | Writing historical Daily data to the file QMZ07.dly | 2016-10-11 15:23:50 HD Request # 18 | Received 3 records from 2007-11-14 00:00:00 to 2007-11-15 00:00:00 (2.0 days) and wrote 2 records for QMZ07 | 2016-10-11 15:23:50 HD Request # 18 | Daily download COMPLETE for QMZ07. Completion time: 1s. Unique request ID: 15 | 2016-10-11 15:23:50 Removed historical data download ID 15 | 2016-10-11 15:23:50 Mapping QMF08 to QMF08. Service code: nymex | 2016-10-11 15:23:50 HD Request # 19 | Downloading Historical Daily chart data for QMF08. Starting date: 2007-12-14. Service: tda | 2016-10-11 15:23:50 HD Request # 19 | Using user Barchart Historical data account. | 2016-10-11 15:23:50 HD Request # 19 | Requesting historical Daily data for QMF08 starting at 2007-12-13 | 2016-10-11 15:23:50 HD Request # 19 | Receiving historical Daily data for QMF08 starting at 2007-12-14 | 2016-10-11 15:23:50 HD Request # 19 | Writing historical Daily data to the file QMF08.dly | 2016-10-11 15:23:50 HD Request # 19 | Received 3 records from 2007-12-14 00:00:00 to 2007-12-17 00:00:00 (4.0 days) and wrote 2 records for QMF08 | 2016-10-11 15:23:50 HD Request # 19 | Daily download COMPLETE for QMF08. Completion time: 0s. Unique request ID: 16 | 2016-10-11 15:23:50 Removed historical data download ID 16 | 2016-10-11 15:23:50 Mapping QMG08 to QMG08. Service code: nymex | 2016-10-11 15:23:50 HD Request # 20 | Downloading Historical Daily chart data for QMG08. Starting date: 2008-01-17. Service: tda | 2016-10-11 15:23:50 HD Request # 20 | Using user Barchart Historical data account. | 2016-10-11 15:23:50 HD Request # 20 | Requesting historical Daily data for QMG08 starting at 2008-01-16 | 2016-10-11 15:23:50 HD Request # 20 | Receiving historical Daily data for QMG08 starting at 2008-01-17 | 2016-10-11 15:23:51 HD Request # 20 | Writing historical Daily data to the file QMG08.dly | 2016-10-11 15:23:51 HD Request # 20 | Received 3 records from 2008-01-17 00:00:00 to 2008-01-18 00:00:00 (2.0 days) and wrote 2 records for QMG08 | 2016-10-11 15:23:51 HD Request # 20 | Daily download COMPLETE for QMG08. Completion time: 0s. Unique request ID: 17 | 2016-10-11 15:23:51 Removed historical data download ID 17 | 2016-10-11 15:23:51 Mapping QMH08 to QMH08. Service code: nymex | 2016-10-11 15:23:51 HD Request # 21 | Downloading Historical Daily chart data for QMH08. Starting date: 2008-02-15. Service: tda | 2016-10-11 15:23:51 HD Request # 21 | Using user Barchart Historical data account. | 2016-10-11 15:23:51 HD Request # 21 | Requesting historical Daily data for QMH08 starting at 2008-02-14 | 2016-10-11 15:23:51 HD Request # 21 | Receiving historical Daily data for QMH08 starting at 2008-02-15 | 2016-10-11 15:23:51 HD Request # 21 | Writing historical Daily data to the file QMH08.dly | 2016-10-11 15:23:51 HD Request # 21 | Received 3 records from 2008-02-15 00:00:00 to 2008-02-19 00:00:00 (5.0 days) and wrote 2 records for QMH08 | 2016-10-11 15:23:51 HD Request # 21 | Daily download COMPLETE for QMH08. Completion time: 1s. Unique request ID: 18 | 2016-10-11 15:23:51 Removed historical data download ID 18 | 2016-10-11 15:23:51 Mapping QMJ08 to QMJ08. Service code: nymex | 2016-10-11 15:23:51 HD Request # 22 | Downloading Historical Daily chart data for QMJ08. Starting date: 2008-03-17. Service: tda | 2016-10-11 15:23:51 HD Request # 22 | Using user Barchart Historical data account. | 2016-10-11 15:23:51 HD Request # 22 | Requesting historical Daily data for QMJ08 starting at 2008-03-16 | 2016-10-11 15:23:51 HD Request # 22 | Receiving historical Daily data for QMJ08 starting at 2008-03-17 | 2016-10-11 15:23:51 HD Request # 22 | Writing historical Daily data to the file QMJ08.dly | 2016-10-11 15:23:51 HD Request # 22 | Received 2 records from 2008-03-17 00:00:00 to 2008-03-18 00:00:00 (2.0 days) and wrote 2 records for QMJ08 | 2016-10-11 15:23:51 HD Request # 22 | Daily download COMPLETE for QMJ08. Completion time: 0s. Unique request ID: 19 | 2016-10-11 15:23:51 Removed historical data download ID 19 | 2016-10-11 15:23:51 Mapping QMK08 to QMK08. Service code: nymex | 2016-10-11 15:23:51 HD Request # 23 | Downloading Historical Daily chart data for QMK08. Starting date: 2008-04-18. Service: tda | 2016-10-11 15:23:51 HD Request # 23 | Using user Barchart Historical data account. | 2016-10-11 15:23:51 HD Request # 23 | Requesting historical Daily data for QMK08 starting at 2008-04-17 | 2016-10-11 15:23:51 HD Request # 23 | Receiving historical Daily data for QMK08 starting at 2008-04-18 | 2016-10-11 15:23:52 HD Request # 23 | Writing historical Daily data to the file QMK08.dly | 2016-10-11 15:23:52 HD Request # 23 | Received 3 records from 2008-04-18 00:00:00 to 2008-04-21 00:00:00 (4.0 days) and wrote 2 records for QMK08 | 2016-10-11 15:23:52 HD Request # 23 | Daily download COMPLETE for QMK08. Completion time: 0s. Unique request ID: 20 | 2016-10-11 15:23:52 Removed historical data download ID 20 | 2016-10-11 15:23:52 Mapping QMM08 to QMM08. Service code: nymex | 2016-10-11 15:23:52 HD Request # 24 | Downloading Historical Daily chart data for QMM08. Starting date: 2008-05-16. Service: tda | 2016-10-11 15:23:52 HD Request # 24 | Using user Barchart Historical data account. | 2016-10-11 15:23:52 HD Request # 24 | Requesting historical Daily data for QMM08 starting at 2008-05-15 | 2016-10-11 15:23:52 HD Request # 24 | Receiving historical Daily data for QMM08 starting at 2008-05-16 | 2016-10-11 15:23:52 HD Request # 24 | Writing historical Daily data to the file QMM08.dly | 2016-10-11 15:23:52 HD Request # 24 | Received 3 records from 2008-05-16 00:00:00 to 2008-05-19 00:00:00 (4.0 days) and wrote 2 records for QMM08 | 2016-10-11 15:23:52 HD Request # 24 | Daily download COMPLETE for QMM08. Completion time: 0s. Unique request ID: 21 | 2016-10-11 15:23:52 Removed historical data download ID 21 | 2016-10-11 15:23:52 Mapping QMN08 to QMN08. Service code: nymex | 2016-10-11 15:23:52 HD Request # 25 | Downloading Historical Daily chart data for QMN08. Starting date: 2008-06-18. Service: tda | 2016-10-11 15:23:52 HD Request # 25 | Using user Barchart Historical data account. | 2016-10-11 15:23:52 HD Request # 25 | Requesting historical Daily data for QMN08 starting at 2008-06-17 | 2016-10-11 15:23:52 HD Request # 25 | Receiving historical Daily data for QMN08 starting at 2008-06-18 | 2016-10-11 15:23:53 HD Request # 25 | Writing historical Daily data to the file QMN08.dly | 2016-10-11 15:23:53 HD Request # 25 | Received 3 records from 2008-06-18 00:00:00 to 2008-06-19 00:00:00 (2.0 days) and wrote 2 records for QMN08 | 2016-10-11 15:23:53 HD Request # 25 | Daily download COMPLETE for QMN08. Completion time: 0s. Unique request ID: 22 | 2016-10-11 15:23:53 Removed historical data download ID 22 | 2016-10-11 15:23:53 Mapping QMQ08 to QMQ08. Service code: nymex | 2016-10-11 15:23:53 HD Request # 26 | Downloading Historical Daily chart data for QMQ08. Starting date: 2008-07-18. Service: tda | 2016-10-11 15:23:53 HD Request # 26 | Using user Barchart Historical data account. | 2016-10-11 15:23:53 HD Request # 26 | Requesting historical Daily data for QMQ08 starting at 2008-07-17 | 2016-10-11 15:23:53 HD Request # 26 | Receiving historical Daily data for QMQ08 starting at 2008-07-18 | 2016-10-11 15:23:53 HD Request # 26 | Writing historical Daily data to the file QMQ08.dly | 2016-10-11 15:23:53 HD Request # 26 | Received 3 records from 2008-07-18 00:00:00 to 2008-07-21 00:00:00 (4.0 days) and wrote 2 records for QMQ08 | 2016-10-11 15:23:53 HD Request # 26 | Daily download COMPLETE for QMQ08. Completion time: 0s. Unique request ID: 23 | 2016-10-11 15:23:53 Removed historical data download ID 23 | 2016-10-11 15:23:53 Mapping QMU08 to QMU08. Service code: nymex | 2016-10-11 15:23:53 HD Request # 27 | Downloading Historical Daily chart data for QMU08. Starting date: 2008-08-18. Service: tda | 2016-10-11 15:23:53 HD Request # 27 | Using user Barchart Historical data account. | 2016-10-11 15:23:53 HD Request # 27 | Requesting historical Daily data for QMU08 starting at 2008-08-17 | 2016-10-11 15:23:53 HD Request # 27 | Receiving historical Daily data for QMU08 starting at 2008-08-18 | 2016-10-11 15:23:53 HD Request # 27 | Writing historical Daily data to the file QMU08.dly | 2016-10-11 15:23:53 HD Request # 27 | Received 2 records from 2008-08-18 00:00:00 to 2008-08-19 00:00:00 (2.0 days) and wrote 2 records for QMU08 | 2016-10-11 15:23:53 HD Request # 27 | Daily download COMPLETE for QMU08. Completion time: 1s. Unique request ID: 24 | 2016-10-11 15:23:53 Removed historical data download ID 24 | 2016-10-11 15:23:53 Mapping QMV08 to QMV08. Service code: nymex | 2016-10-11 15:23:53 HD Request # 28 | Downloading Historical Daily chart data for QMV08. Starting date: 2008-09-18. Service: tda | 2016-10-11 15:23:53 HD Request # 28 | Using user Barchart Historical data account. | 2016-10-11 15:23:53 HD Request # 28 | Requesting historical Daily data for QMV08 starting at 2008-09-17 | 2016-10-11 15:23:53 HD Request # 28 | Receiving historical Daily data for QMV08 starting at 2008-09-18 | 2016-10-11 15:23:54 HD Request # 28 | Writing historical Daily data to the file QMV08.dly | 2016-10-11 15:23:54 HD Request # 28 | Received 3 records from 2008-09-18 00:00:00 to 2008-09-19 00:00:00 (2.0 days) and wrote 2 records for QMV08 | 2016-10-11 15:23:54 HD Request # 28 | Daily download COMPLETE for QMV08. Completion time: 0s. Unique request ID: 25 | 2016-10-11 15:23:54 Removed historical data download ID 25 | 2016-10-11 15:23:54 Mapping QMX08 to QMX08. Service code: nymex | 2016-10-11 15:23:54 HD Request # 29 | Downloading Historical Daily chart data for QMX08. Starting date: 2008-10-17. Service: tda | 2016-10-11 15:23:54 HD Request # 29 | Using user Barchart Historical data account. | 2016-10-11 15:23:54 HD Request # 29 | Requesting historical Daily data for QMX08 starting at 2008-10-16 | 2016-10-11 15:23:54 HD Request # 29 | Receiving historical Daily data for QMX08 starting at 2008-10-17 | 2016-10-11 15:23:54 HD Request # 29 | Writing historical Daily data to the file QMX08.dly | 2016-10-11 15:23:54 HD Request # 29 | Received 3 records from 2008-10-17 00:00:00 to 2008-10-20 00:00:00 (4.0 days) and wrote 2 records for QMX08 | 2016-10-11 15:23:54 HD Request # 29 | Daily download COMPLETE for QMX08. Completion time: 0s. Unique request ID: 26 | 2016-10-11 15:23:54 Removed historical data download ID 26 | 2016-10-11 15:23:54 Mapping QMZ08 to QMZ08. Service code: nymex | 2016-10-11 15:23:54 HD Request # 30 | Downloading Historical Daily chart data for QMZ08. Starting date: 2008-11-18. Service: tda | 2016-10-11 15:23:54 HD Request # 30 | Using user Barchart Historical data account. | 2016-10-11 15:23:54 HD Request # 30 | Requesting historical Daily data for QMZ08 starting at 2008-11-17 | 2016-10-11 15:23:54 HD Request # 30 | Receiving historical Daily data for QMZ08 starting at 2008-11-18 | 2016-10-11 15:23:54 HD Request # 30 | Writing historical Daily data to the file QMZ08.dly | 2016-10-11 15:23:54 HD Request # 30 | Received 3 records from 2008-11-18 00:00:00 to 2008-11-19 00:00:00 (2.0 days) and wrote 2 records for QMZ08 | 2016-10-11 15:23:54 HD Request # 30 | Daily download COMPLETE for QMZ08. Completion time: 0s. Unique request ID: 27 | 2016-10-11 15:23:54 Removed historical data download ID 27 | 2016-10-11 15:23:54 Mapping QMF09 to QMF09. Service code: nymex | 2016-10-11 15:23:54 HD Request # 31 | Downloading Historical Daily chart data for QMF09. Starting date: 2008-12-17. Service: tda | 2016-10-11 15:23:54 HD Request # 31 | Using user Barchart Historical data account. | 2016-10-11 15:23:54 HD Request # 31 | Requesting historical Daily data for QMF09 starting at 2008-12-16 | 2016-10-11 15:23:54 HD Request # 31 | Receiving historical Daily data for QMF09 starting at 2008-12-17 | 2016-10-11 15:23:55 HD Request # 31 | Writing historical Daily data to the file QMF09.dly | 2016-10-11 15:23:55 HD Request # 31 | Received 3 records from 2008-12-17 00:00:00 to 2008-12-18 00:00:00 (2.0 days) and wrote 2 records for QMF09 | 2016-10-11 15:23:55 HD Request # 31 | Daily download COMPLETE for QMF09. Completion time: 0s. Unique request ID: 28 | 2016-10-11 15:23:55 Removed historical data download ID 28 | 2016-10-11 15:23:55 Mapping QMG09 to QMG09. Service code: nymex | 2016-10-11 15:23:55 HD Request # 32 | Downloading Historical Daily chart data for QMG09. Starting date: 2009-01-15. Service: tda | 2016-10-11 15:23:55 HD Request # 32 | Using user Barchart Historical data account. | 2016-10-11 15:23:55 HD Request # 32 | Requesting historical Daily data for QMG09 starting at 2009-01-14 | 2016-10-11 15:23:55 HD Request # 32 | Receiving historical Daily data for QMG09 starting at 2009-01-15 | 2016-10-11 15:23:55 HD Request # 32 | Writing historical Daily data to the file QMG09.dly | 2016-10-11 15:23:55 HD Request # 32 | Received 3 records from 2009-01-15 00:00:00 to 2009-01-16 00:00:00 (2.0 days) and wrote 2 records for QMG09 | 2016-10-11 15:23:55 HD Request # 32 | Daily download COMPLETE for QMG09. Completion time: 1s. Unique request ID: 29 | 2016-10-11 15:23:55 Removed historical data download ID 29 | 2016-10-11 15:23:55 Mapping QMH09 to QMH09. Service code: nymex | 2016-10-11 15:23:55 HD Request # 33 | Downloading Historical Daily chart data for QMH09. Starting date: 2009-02-18. Service: tda | 2016-10-11 15:23:55 HD Request # 33 | Using user Barchart Historical data account. | 2016-10-11 15:23:55 HD Request # 33 | Requesting historical Daily data for QMH09 starting at 2009-02-17 | 2016-10-11 15:23:55 HD Request # 33 | Receiving historical Daily data for QMH09 starting at 2009-02-18 | 2016-10-11 15:23:55 HD Request # 33 | Writing historical Daily data to the file QMH09.dly | 2016-10-11 15:23:55 HD Request # 33 | Received 3 records from 2009-02-18 00:00:00 to 2009-02-19 00:00:00 (2.0 days) and wrote 2 records for QMH09 | 2016-10-11 15:23:55 HD Request # 33 | Daily download COMPLETE for QMH09. Completion time: 0s. Unique request ID: 30 | 2016-10-11 15:23:55 Removed historical data download ID 30 | 2016-10-11 15:23:55 Mapping QMJ09 to QMJ09. Service code: nymex | 2016-10-11 15:23:55 HD Request # 34 | Downloading Historical Daily chart data for QMJ09. Starting date: 2009-03-18. Service: tda | 2016-10-11 15:23:55 HD Request # 34 | Using user Barchart Historical data account. | 2016-10-11 15:23:55 HD Request # 34 | Requesting historical Daily data for QMJ09 starting at 2009-03-17 | 2016-10-11 15:23:55 HD Request # 34 | Receiving historical Daily data for QMJ09 starting at 2009-03-18 | 2016-10-11 15:23:56 HD Request # 34 | Writing historical Daily data to the file QMJ09.dly | 2016-10-11 15:23:56 HD Request # 34 | Received 3 records from 2009-03-18 00:00:00 to 2009-03-19 00:00:00 (2.0 days) and wrote 2 records for QMJ09 | 2016-10-11 15:23:56 HD Request # 34 | Daily download COMPLETE for QMJ09. Completion time: 0s. Unique request ID: 31 | 2016-10-11 15:23:56 Removed historical data download ID 31 | 2016-10-11 15:23:56 Mapping QMK09 to QMK09. Service code: nymex | 2016-10-11 15:23:56 HD Request # 35 | Downloading Historical Daily chart data for QMK09. Starting date: 2009-04-17. Service: tda | 2016-10-11 15:23:56 HD Request # 35 | Using user Barchart Historical data account. | 2016-10-11 15:23:56 HD Request # 35 | Requesting historical Daily data for QMK09 starting at 2009-04-16 | 2016-10-11 15:23:56 HD Request # 35 | Receiving historical Daily data for QMK09 starting at 2009-04-17 | 2016-10-11 15:23:56 HD Request # 35 | Writing historical Daily data to the file QMK09.dly | 2016-10-11 15:23:56 HD Request # 35 | Received 3 records from 2009-04-17 00:00:00 to 2009-04-20 00:00:00 (4.0 days) and wrote 2 records for QMK09 | 2016-10-11 15:23:56 HD Request # 35 | Daily download COMPLETE for QMK09. Completion time: 1s. Unique request ID: 32 | 2016-10-11 15:23:56 Removed historical data download ID 32 | 2016-10-11 15:23:56 Mapping QMM09 to QMM09. Service code: nymex | 2016-10-11 15:23:56 HD Request # 36 | Downloading Historical Daily chart data for QMM09. Starting date: 2009-05-15. Service: tda | 2016-10-11 15:23:56 HD Request # 36 | Using user Barchart Historical data account. | 2016-10-11 15:23:56 HD Request # 36 | Requesting historical Daily data for QMM09 starting at 2009-05-14 | 2016-10-11 15:23:56 HD Request # 36 | Receiving historical Daily data for QMM09 starting at 2009-05-15 | 2016-10-11 15:23:56 HD Request # 36 | Writing historical Daily data to the file QMM09.dly | 2016-10-11 15:23:56 HD Request # 36 | Received 3 records from 2009-05-15 00:00:00 to 2009-05-18 00:00:00 (4.0 days) and wrote 2 records for QMM09 | 2016-10-11 15:23:56 HD Request # 36 | Daily download COMPLETE for QMM09. Completion time: 0s. Unique request ID: 33 | 2016-10-11 15:23:56 Removed historical data download ID 33 | 2016-10-11 15:23:56 Mapping QMN09 to QMN09. Service code: nymex | 2016-10-11 15:23:56 HD Request # 37 | Downloading Historical Daily chart data for QMN09. Starting date: 2009-06-18. Service: tda | 2016-10-11 15:23:56 HD Request # 37 | Using user Barchart Historical data account. | 2016-10-11 15:23:56 HD Request # 37 | Requesting historical Daily data for QMN09 starting at 2009-06-17 | 2016-10-11 15:23:56 HD Request # 37 | Receiving historical Daily data for QMN09 starting at 2009-06-18 | 2016-10-11 15:23:57 HD Request # 37 | Writing historical Daily data to the file QMN09.dly | 2016-10-11 15:23:57 HD Request # 37 | Received 3 records from 2009-06-18 00:00:00 to 2009-06-19 00:00:00 (2.0 days) and wrote 2 records for QMN09 | 2016-10-11 15:23:57 HD Request # 37 | Daily download COMPLETE for QMN09. Completion time: 0s. Unique request ID: 34 | 2016-10-11 15:23:57 Removed historical data download ID 34 | 2016-10-11 15:23:57 Mapping QMQ09 to QMQ09. Service code: nymex | 2016-10-11 15:23:57 HD Request # 38 | Downloading Historical Daily chart data for QMQ09. Starting date: 2009-07-17. Service: tda | 2016-10-11 15:23:57 HD Request # 38 | Using user Barchart Historical data account. | 2016-10-11 15:23:57 HD Request # 38 | Requesting historical Daily data for QMQ09 starting at 2009-07-16 | 2016-10-11 15:23:57 HD Request # 38 | Receiving historical Daily data for QMQ09 starting at 2009-07-17 | 2016-10-11 15:23:57 HD Request # 38 | Writing historical Daily data to the file QMQ09.dly | 2016-10-11 15:23:57 HD Request # 38 | Received 3 records from 2009-07-17 00:00:00 to 2009-07-20 00:00:00 (4.0 days) and wrote 2 records for QMQ09 | 2016-10-11 15:23:57 HD Request # 38 | Daily download COMPLETE for QMQ09. Completion time: 0s. Unique request ID: 35 | 2016-10-11 15:23:57 Removed historical data download ID 35 | 2016-10-11 15:23:57 Mapping QMU09 to QMU09. Service code: nymex | 2016-10-11 15:23:57 HD Request # 39 | Downloading Historical Daily chart data for QMU09. Starting date: 2009-08-18. Service: tda | 2016-10-11 15:23:57 HD Request # 39 | Using user Barchart Historical data account. | 2016-10-11 15:23:57 HD Request # 39 | Requesting historical Daily data for QMU09 starting at 2009-08-17 | 2016-10-11 15:23:57 HD Request # 39 | Receiving historical Daily data for QMU09 starting at 2009-08-18 | 2016-10-11 15:23:58 HD Request # 39 | Writing historical Daily data to the file QMU09.dly | 2016-10-11 15:23:58 HD Request # 39 | Received 3 records from 2009-08-18 00:00:00 to 2009-08-19 00:00:00 (2.0 days) and wrote 2 records for QMU09 | 2016-10-11 15:23:58 HD Request # 39 | Daily download COMPLETE for QMU09. Completion time: 0s. Unique request ID: 36 | 2016-10-11 15:23:58 Removed historical data download ID 36 | 2016-10-11 15:23:58 Mapping QMV09 to QMV09. Service code: nymex | 2016-10-11 15:23:58 HD Request # 40 | Downloading Historical Daily chart data for QMV09. Starting date: 2009-09-18. Service: tda | 2016-10-11 15:23:58 HD Request # 40 | Using user Barchart Historical data account. | 2016-10-11 15:23:58 HD Request # 40 | Requesting historical Daily data for QMV09 starting at 2009-09-17 | 2016-10-11 15:23:58 HD Request # 40 | Receiving historical Daily data for QMV09 starting at 2009-09-18 | 2016-10-11 15:23:58 HD Request # 40 | Writing historical Daily data to the file QMV09.dly | 2016-10-11 15:23:58 HD Request # 40 | Received 3 records from 2009-09-18 00:00:00 to 2009-09-21 00:00:00 (4.0 days) and wrote 2 records for QMV09 | 2016-10-11 15:23:58 HD Request # 40 | Daily download COMPLETE for QMV09. Completion time: 1s. Unique request ID: 37 | 2016-10-11 15:23:58 Removed historical data download ID 37 | 2016-10-11 15:23:58 Mapping QMX09 to QMX09. Service code: nymex | 2016-10-11 15:23:58 HD Request # 41 | Downloading Historical Daily chart data for QMX09. Starting date: 2009-10-16. Service: tda | 2016-10-11 15:23:58 HD Request # 41 | Using user Barchart Historical data account. | 2016-10-11 15:23:58 HD Request # 41 | Requesting historical Daily data for QMX09 starting at 2009-10-15 | 2016-10-11 15:23:58 HD Request # 41 | Receiving historical Daily data for QMX09 starting at 2009-10-16 | 2016-10-11 15:23:58 HD Request # 41 | Writing historical Daily data to the file QMX09.dly | 2016-10-11 15:23:58 HD Request # 41 | Received 3 records from 2009-10-16 00:00:00 to 2009-10-19 00:00:00 (4.0 days) and wrote 2 records for QMX09 | 2016-10-11 15:23:58 HD Request # 41 | Daily download COMPLETE for QMX09. Completion time: 0s. Unique request ID: 38 | 2016-10-11 15:23:58 Removed historical data download ID 38 | 2016-10-11 15:23:58 Mapping QMZ09 to QMZ09. Service code: nymex | 2016-10-11 15:23:58 HD Request # 42 | Downloading Historical Daily chart data for QMZ09. Starting date: 2009-11-18. Service: tda | 2016-10-11 15:23:58 HD Request # 42 | Using user Barchart Historical data account. | 2016-10-11 15:23:58 HD Request # 42 | Requesting historical Daily data for QMZ09 starting at 2009-11-17 | 2016-10-11 15:23:58 HD Request # 42 | Receiving historical Daily data for QMZ09 starting at 2009-11-18 | 2016-10-11 15:23:59 HD Request # 42 | Writing historical Daily data to the file QMZ09.dly | 2016-10-11 15:23:59 HD Request # 42 | Received 3 records from 2009-11-18 00:00:00 to 2009-11-19 00:00:00 (2.0 days) and wrote 2 records for QMZ09 | 2016-10-11 15:23:59 HD Request # 42 | Daily download COMPLETE for QMZ09. Completion time: 0s. Unique request ID: 39 | 2016-10-11 15:23:59 Removed historical data download ID 39 | 2016-10-11 15:23:59 Mapping QMF10 to QMF10. Service code: nymex | 2016-10-11 15:23:59 HD Request # 43 | Downloading Historical Daily chart data for QMF10. Starting date: 2009-12-17. Service: tda | 2016-10-11 15:23:59 HD Request # 43 | Using user Barchart Historical data account. | 2016-10-11 15:23:59 HD Request # 43 | Requesting historical Daily data for QMF10 starting at 2009-12-16 | 2016-10-11 15:23:59 HD Request # 43 | Receiving historical Daily data for QMF10 starting at 2009-12-17 | 2016-10-11 15:23:59 HD Request # 43 | Writing historical Daily data to the file QMF10.dly | 2016-10-11 15:23:59 HD Request # 43 | Received 3 records from 2009-12-17 00:00:00 to 2009-12-18 00:00:00 (2.0 days) and wrote 2 records for QMF10 | 2016-10-11 15:23:59 HD Request # 43 | Daily download COMPLETE for QMF10. Completion time: 1s. Unique request ID: 40 | 2016-10-11 15:23:59 Removed historical data download ID 40 | 2016-10-11 15:23:59 Mapping QMG10 to QMG10. Service code: nymex | 2016-10-11 15:23:59 HD Request # 44 | Downloading Historical Daily chart data for QMG10. Starting date: 2010-01-15. Service: tda | 2016-10-11 15:23:59 HD Request # 44 | Using user Barchart Historical data account. | 2016-10-11 15:23:59 HD Request # 44 | Requesting historical Daily data for QMG10 starting at 2010-01-14 | 2016-10-11 15:23:59 HD Request # 44 | Receiving historical Daily data for QMG10 starting at 2010-01-15 | 2016-10-11 15:23:59 HD Request # 44 | Writing historical Daily data to the file QMG10.dly | 2016-10-11 15:23:59 HD Request # 44 | Received 3 records from 2010-01-15 00:00:00 to 2010-01-19 00:00:00 (5.0 days) and wrote 2 records for QMG10 | 2016-10-11 15:23:59 HD Request # 44 | Daily download COMPLETE for QMG10. Completion time: 0s. Unique request ID: 41 | 2016-10-11 15:23:59 Removed historical data download ID 41 | 2016-10-11 15:23:59 Mapping QMH10 to QMH10. Service code: nymex | 2016-10-11 15:23:59 HD Request # 45 | Downloading Historical Daily chart data for QMH10. Starting date: 2010-02-18. Service: tda | 2016-10-11 15:23:59 HD Request # 45 | Using user Barchart Historical data account. | 2016-10-11 15:23:59 HD Request # 45 | Requesting historical Daily data for QMH10 starting at 2010-02-17 | 2016-10-11 15:23:59 HD Request # 45 | Receiving historical Daily data for QMH10 starting at 2010-02-18 | 2016-10-11 15:24:00 HD Request # 45 | Writing historical Daily data to the file QMH10.dly | 2016-10-11 15:24:00 HD Request # 45 | Received 3 records from 2010-02-18 00:00:00 to 2010-02-19 00:00:00 (2.0 days) and wrote 2 records for QMH10 | 2016-10-11 15:24:00 HD Request # 45 | Daily download COMPLETE for QMH10. Completion time: 0s. Unique request ID: 42 | 2016-10-11 15:24:00 Removed historical data download ID 42 | 2016-10-11 15:24:00 Mapping QMJ10 to QMJ10. Service code: nymex | 2016-10-11 15:24:00 HD Request # 46 | Downloading Historical Daily chart data for QMJ10. Starting date: 2010-03-18. Service: tda | 2016-10-11 15:24:00 HD Request # 46 | Using user Barchart Historical data account. | 2016-10-11 15:24:00 HD Request # 46 | Requesting historical Daily data for QMJ10 starting at 2010-03-17 | 2016-10-11 15:24:00 HD Request # 46 | Receiving historical Daily data for QMJ10 starting at 2010-03-18 | 2016-10-11 15:24:00 HD Request # 46 | Writing historical Daily data to the file QMJ10.dly | 2016-10-11 15:24:00 HD Request # 46 | Received 3 records from 2010-03-18 00:00:00 to 2010-03-19 00:00:00 (2.0 days) and wrote 2 records for QMJ10 | 2016-10-11 15:24:00 HD Request # 46 | Daily download COMPLETE for QMJ10. Completion time: 0s. Unique request ID: 43 | 2016-10-11 15:24:00 Removed historical data download ID 43 | 2016-10-11 15:24:00 Mapping QMK10 to QMK10. Service code: nymex | 2016-10-11 15:24:00 HD Request # 47 | Downloading Historical Daily chart data for QMK10. Starting date: 2010-04-16. Service: tda | 2016-10-11 15:24:00 HD Request # 47 | Using user Barchart Historical data account. | 2016-10-11 15:24:00 HD Request # 47 | Requesting historical Daily data for QMK10 starting at 2010-04-15 | 2016-10-11 15:24:00 HD Request # 47 | Receiving historical Daily data for QMK10 starting at 2010-04-16 | 2016-10-11 15:24:01 HD Request # 47 | Writing historical Daily data to the file QMK10.dly | 2016-10-11 15:24:01 HD Request # 47 | Received 3 records from 2010-04-16 00:00:00 to 2010-04-19 00:00:00 (4.0 days) and wrote 2 records for QMK10 | 2016-10-11 15:24:01 HD Request # 47 | Daily download COMPLETE for QMK10. Completion time: 0s. Unique request ID: 44 | 2016-10-11 15:24:01 Removed historical data download ID 44 | 2016-10-11 15:24:01 Mapping QMM10 to QMM10. Service code: nymex | 2016-10-11 15:24:01 HD Request # 48 | Downloading Historical Daily chart data for QMM10. Starting date: 2010-05-18. Service: tda | 2016-10-11 15:24:01 HD Request # 48 | Using user Barchart Historical data account. | 2016-10-11 15:24:01 HD Request # 48 | Requesting historical Daily data for QMM10 starting at 2010-05-17 | 2016-10-11 15:24:01 HD Request # 48 | Receiving historical Daily data for QMM10 starting at 2010-05-18 | 2016-10-11 15:24:01 HD Request # 48 | Writing historical Daily data to the file QMM10.dly | 2016-10-11 15:24:01 HD Request # 48 | Received 3 records from 2010-05-18 00:00:00 to 2010-05-19 00:00:00 (2.0 days) and wrote 2 records for QMM10 | 2016-10-11 15:24:01 HD Request # 48 | Daily download COMPLETE for QMM10. Completion time: 1s. Unique request ID: 45 | 2016-10-11 15:24:01 Removed historical data download ID 45 | 2016-10-11 15:24:01 Mapping QMN10 to QMN10. Service code: nymex | 2016-10-11 15:24:01 HD Request # 49 | Downloading Historical Daily chart data for QMN10. Starting date: 2010-06-18. Service: tda | 2016-10-11 15:24:01 HD Request # 49 | Using user Barchart Historical data account. | 2016-10-11 15:24:01 HD Request # 49 | Requesting historical Daily data for QMN10 starting at 2010-06-17 | 2016-10-11 15:24:01 HD Request # 49 | Receiving historical Daily data for QMN10 starting at 2010-06-18 | 2016-10-11 15:24:01 HD Request # 49 | Writing historical Daily data to the file QMN10.dly | 2016-10-11 15:24:01 HD Request # 49 | Received 3 records from 2010-06-18 00:00:00 to 2010-06-21 00:00:00 (4.0 days) and wrote 2 records for QMN10 | 2016-10-11 15:24:01 HD Request # 49 | Daily download COMPLETE for QMN10. Completion time: 0s. Unique request ID: 46 | 2016-10-11 15:24:01 Removed historical data download ID 46 | 2016-10-11 15:24:01 Mapping QMQ10 to QMQ10. Service code: nymex | 2016-10-11 15:24:01 HD Request # 50 | Downloading Historical Daily chart data for QMQ10. Starting date: 2010-07-16. Service: tda | 2016-10-11 15:24:01 HD Request # 50 | Using user Barchart Historical data account. | 2016-10-11 15:24:01 HD Request # 50 | Requesting historical Daily data for QMQ10 starting at 2010-07-15 | 2016-10-11 15:24:01 HD Request # 50 | Receiving historical Daily data for QMQ10 starting at 2010-07-16 | 2016-10-11 15:24:02 HD Request # 50 | Writing historical Daily data to the file QMQ10.dly | 2016-10-11 15:24:02 HD Request # 50 | Received 3 records from 2010-07-16 00:00:00 to 2010-07-19 00:00:00 (4.0 days) and wrote 2 records for QMQ10 | 2016-10-11 15:24:02 HD Request # 50 | Daily download COMPLETE for QMQ10. Completion time: 0s. Unique request ID: 47 | 2016-10-11 15:24:02 Removed historical data download ID 47 | 2016-10-11 15:24:02 Mapping QMU10 to QMU10. Service code: nymex | 2016-10-11 15:24:02 HD Request # 51 | Downloading Historical Daily chart data for QMU10. Starting date: 2010-08-18. Service: tda | 2016-10-11 15:24:02 HD Request # 51 | Using user Barchart Historical data account. | 2016-10-11 15:24:02 HD Request # 51 | Requesting historical Daily data for QMU10 starting at 2010-08-17 | 2016-10-11 15:24:02 HD Request # 51 | Receiving historical Daily data for QMU10 starting at 2010-08-18 | 2016-10-11 15:24:02 HD Request # 51 | Writing historical Daily data to the file QMU10.dly | 2016-10-11 15:24:02 HD Request # 51 | Received 3 records from 2010-08-18 00:00:00 to 2010-08-19 00:00:00 (2.0 days) and wrote 2 records for QMU10 | 2016-10-11 15:24:02 HD Request # 51 | Daily download COMPLETE for QMU10. Completion time: 0s. Unique request ID: 48 | 2016-10-11 15:24:02 Removed historical data download ID 48 | 2016-10-11 15:24:02 Mapping QMV10 to QMV10. Service code: nymex | 2016-10-11 15:24:02 HD Request # 52 | Downloading Historical Daily chart data for QMV10. Starting date: 2010-09-17. Service: tda | 2016-10-11 15:24:02 HD Request # 52 | Using user Barchart Historical data account. | 2016-10-11 15:24:02 HD Request # 52 | Requesting historical Daily data for QMV10 starting at 2010-09-16 | 2016-10-11 15:24:02 HD Request # 52 | Receiving historical Daily data for QMV10 starting at 2010-09-17 | 2016-10-11 15:24:03 HD Request # 52 | Writing historical Daily data to the file QMV10.dly | 2016-10-11 15:24:03 HD Request # 52 | Received 3 records from 2010-09-17 00:00:00 to 2010-09-20 00:00:00 (4.0 days) and wrote 2 records for QMV10 | 2016-10-11 15:24:03 HD Request # 52 | Daily download COMPLETE for QMV10. Completion time: 1s. Unique request ID: 49 | 2016-10-11 15:24:03 Removed historical data download ID 49 | 2016-10-11 15:24:03 Mapping QMX10 to QMX10. Service code: nymex | 2016-10-11 15:24:03 HD Request # 53 | Downloading Historical Daily chart data for QMX10. Starting date: 2010-10-18. Service: tda | 2016-10-11 15:24:03 HD Request # 53 | Using user Barchart Historical data account. | 2016-10-11 15:24:03 HD Request # 53 | Requesting historical Daily data for QMX10 starting at 2010-10-17 | 2016-10-11 15:24:03 HD Request # 53 | Receiving historical Daily data for QMX10 starting at 2010-10-18 | 2016-10-11 15:24:03 HD Request # 53 | Writing historical Daily data to the file QMX10.dly | 2016-10-11 15:24:03 HD Request # 53 | Received 2 records from 2010-10-18 00:00:00 to 2010-10-19 00:00:00 (2.0 days) and wrote 2 records for QMX10 | 2016-10-11 15:24:03 HD Request # 53 | Daily download COMPLETE for QMX10. Completion time: 0s. Unique request ID: 50 | 2016-10-11 15:24:03 Removed historical data download ID 50 | 2016-10-11 15:24:03 Mapping QMZ10 to QMZ10. Service code: nymex | 2016-10-11 15:24:03 HD Request # 54 | Downloading Historical Daily chart data for QMZ10. Starting date: 2010-11-17. Service: tda | 2016-10-11 15:24:03 HD Request # 54 | Using user Barchart Historical data account. | 2016-10-11 15:24:03 HD Request # 54 | Requesting historical Daily data for QMZ10 starting at 2010-11-16 | 2016-10-11 15:24:03 HD Request # 54 | Receiving historical Daily data for QMZ10 starting at 2010-11-17 | 2016-10-11 15:24:04 HD Request # 54 | Writing historical Daily data to the file QMZ10.dly | 2016-10-11 15:24:04 HD Request # 54 | Received 3 records from 2010-11-17 00:00:00 to 2010-11-18 00:00:00 (2.0 days) and wrote 2 records for QMZ10 | 2016-10-11 15:24:04 HD Request # 54 | Daily download COMPLETE for QMZ10. Completion time: 1s. Unique request ID: 51 | 2016-10-11 15:24:04 Removed historical data download ID 51 | 2016-10-11 15:24:04 Mapping QMF11 to QMF11. Service code: nymex | 2016-10-11 15:24:04 HD Request # 55 | Downloading Historical Daily chart data for QMF11. Starting date: 2010-12-16. Service: tda | 2016-10-11 15:24:04 HD Request # 55 | Using user Barchart Historical data account. | 2016-10-11 15:24:04 HD Request # 55 | Requesting historical Daily data for QMF11 starting at 2010-12-15 | 2016-10-11 15:24:04 HD Request # 55 | Receiving historical Daily data for QMF11 starting at 2010-12-16 | 2016-10-11 15:24:04 HD Request # 55 | Writing historical Daily data to the file QMF11.dly | 2016-10-11 15:24:04 HD Request # 55 | Received 3 records from 2010-12-16 00:00:00 to 2010-12-17 00:00:00 (2.0 days) and wrote 2 records for QMF11 | 2016-10-11 15:24:04 HD Request # 55 | Daily download COMPLETE for QMF11. Completion time: 0s. Unique request ID: 52 | 2016-10-11 15:24:04 Removed historical data download ID 52 | 2016-10-11 15:24:04 Mapping QMG11 to QMG11. Service code: nymex | 2016-10-11 15:24:04 HD Request # 56 | Downloading Historical Daily chart data for QMG11. Starting date: 2011-01-18. Service: tda | 2016-10-11 15:24:04 HD Request # 56 | Using user Barchart Historical data account. | 2016-10-11 15:24:04 HD Request # 56 | Requesting historical Daily data for QMG11 starting at 2011-01-17 | 2016-10-11 15:24:04 HD Request # 56 | Receiving historical Daily data for QMG11 starting at 2011-01-18 | 2016-10-11 15:24:05 HD Request # 56 | Writing historical Daily data to the file QMG11.dly | 2016-10-11 15:24:05 HD Request # 56 | Received 2 records from 2011-01-18 00:00:00 to 2011-01-19 00:00:00 (2.0 days) and wrote 2 records for QMG11 | 2016-10-11 15:24:05 HD Request # 56 | Daily download COMPLETE for QMG11. Completion time: 0s. Unique request ID: 53 | 2016-10-11 15:24:05 Removed historical data download ID 53 | 2016-10-11 15:24:05 Mapping QMH11 to QMH11. Service code: nymex | 2016-10-11 15:24:05 HD Request # 57 | Downloading Historical Daily chart data for QMH11. Starting date: 2011-02-17. Service: tda | 2016-10-11 15:24:05 HD Request # 57 | Using user Barchart Historical data account. | 2016-10-11 15:24:05 HD Request # 57 | Requesting historical Daily data for QMH11 starting at 2011-02-16 | 2016-10-11 15:24:05 HD Request # 57 | Receiving historical Daily data for QMH11 starting at 2011-02-17 | 2016-10-11 15:24:05 HD Request # 57 | Writing historical Daily data to the file QMH11.dly | 2016-10-11 15:24:05 HD Request # 57 | Received 3 records from 2011-02-17 00:00:00 to 2011-02-18 00:00:00 (2.0 days) and wrote 2 records for QMH11 | 2016-10-11 15:24:05 HD Request # 57 | Daily download COMPLETE for QMH11. Completion time: 0s. Unique request ID: 54 | 2016-10-11 15:24:05 Removed historical data download ID 54 | 2016-10-11 15:24:05 Mapping QMJ11 to QMJ11. Service code: nymex | 2016-10-11 15:24:05 HD Request # 58 | Downloading Historical Daily chart data for QMJ11. Starting date: 2011-03-18. Service: tda | 2016-10-11 15:24:05 HD Request # 58 | Using user Barchart Historical data account. | 2016-10-11 15:24:05 HD Request # 58 | Requesting historical Daily data for QMJ11 starting at 2011-03-17 | 2016-10-11 15:24:05 HD Request # 58 | Receiving historical Daily data for QMJ11 starting at 2011-03-18 | 2016-10-11 15:24:06 HD Request # 58 | Writing historical Daily data to the file QMJ11.dly | 2016-10-11 15:24:06 HD Request # 58 | Received 3 records from 2011-03-18 00:00:00 to 2011-03-21 00:00:00 (4.0 days) and wrote 2 records for QMJ11 | 2016-10-11 15:24:06 HD Request # 58 | Daily download COMPLETE for QMJ11. Completion time: 0s. Unique request ID: 55 | 2016-10-11 15:24:06 Removed historical data download ID 55 | 2016-10-11 15:24:06 Mapping QMK11 to QMK11. Service code: nymex | 2016-10-11 15:24:06 HD Request # 59 | Downloading Historical Daily chart data for QMK11. Starting date: 2011-04-15. Service: tda | 2016-10-11 15:24:06 HD Request # 59 | Using user Barchart Historical data account. | 2016-10-11 15:24:06 HD Request # 59 | Requesting historical Daily data for QMK11 starting at 2011-04-14 | 2016-10-11 15:24:06 HD Request # 59 | Receiving historical Daily data for QMK11 starting at 2011-04-15 | 2016-10-11 15:24:06 HD Request # 59 | Writing historical Daily data to the file QMK11.dly | 2016-10-11 15:24:06 HD Request # 59 | Received 3 records from 2011-04-15 00:00:00 to 2011-04-18 00:00:00 (4.0 days) and wrote 2 records for QMK11 | 2016-10-11 15:24:06 HD Request # 59 | Daily download COMPLETE for QMK11. Completion time: 1s. Unique request ID: 56 | 2016-10-11 15:24:06 Removed historical data download ID 56 | 2016-10-11 15:24:06 Mapping QMM11 to QMM11. Service code: nymex | 2016-10-11 15:24:06 HD Request # 60 | Downloading Historical Daily chart data for QMM11. Starting date: 2011-05-18. Service: tda | 2016-10-11 15:24:06 HD Request # 60 | Using user Barchart Historical data account. | 2016-10-11 15:24:06 HD Request # 60 | Requesting historical Daily data for QMM11 starting at 2011-05-17 | 2016-10-11 15:24:06 HD Request # 60 | Receiving historical Daily data for QMM11 starting at 2011-05-18 | 2016-10-11 15:24:06 HD Request # 60 | Writing historical Daily data to the file QMM11.dly | 2016-10-11 15:24:06 HD Request # 60 | Received 3 records from 2011-05-18 00:00:00 to 2011-05-19 00:00:00 (2.0 days) and wrote 2 records for QMM11 | 2016-10-11 15:24:06 HD Request # 60 | Daily download COMPLETE for QMM11. Completion time: 0s. Unique request ID: 57 | 2016-10-11 15:24:06 Removed historical data download ID 57 | 2016-10-11 15:24:06 Mapping QMN11 to QMN11. Service code: nymex | 2016-10-11 15:24:06 HD Request # 61 | Downloading Historical Daily chart data for QMN11. Starting date: 2011-06-17. Service: tda | 2016-10-11 15:24:06 HD Request # 61 | Using user Barchart Historical data account. | 2016-10-11 15:24:06 HD Request # 61 | Requesting historical Daily data for QMN11 starting at 2011-06-16 | 2016-10-11 15:24:06 HD Request # 61 | Receiving historical Daily data for QMN11 starting at 2011-06-17 | 2016-10-11 15:24:07 HD Request # 61 | Writing historical Daily data to the file QMN11.dly | 2016-10-11 15:24:07 HD Request # 61 | Received 3 records from 2011-06-17 00:00:00 to 2011-06-20 00:00:00 (4.0 days) and wrote 2 records for QMN11 | 2016-10-11 15:24:07 HD Request # 61 | Daily download COMPLETE for QMN11. Completion time: 1s. Unique request ID: 58 | 2016-10-11 15:24:07 Removed historical data download ID 58 | 2016-10-11 15:24:07 Mapping QMQ11 to QMQ11. Service code: nymex | 2016-10-11 15:24:07 HD Request # 62 | Downloading Historical Daily chart data for QMQ11. Starting date: 2011-07-18. Service: tda | 2016-10-11 15:24:07 HD Request # 62 | Using user Barchart Historical data account. | 2016-10-11 15:24:07 HD Request # 62 | Requesting historical Daily data for QMQ11 starting at 2011-07-17 | 2016-10-11 15:24:07 HD Request # 62 | Receiving historical Daily data for QMQ11 starting at 2011-07-18 | 2016-10-11 15:24:07 HD Request # 62 | Writing historical Daily data to the file QMQ11.dly | 2016-10-11 15:24:07 HD Request # 62 | Received 2 records from 2011-07-18 00:00:00 to 2011-07-19 00:00:00 (2.0 days) and wrote 2 records for QMQ11 | 2016-10-11 15:24:07 HD Request # 62 | Daily download COMPLETE for QMQ11. Completion time: 0s. Unique request ID: 59 | 2016-10-11 15:24:07 Removed historical data download ID 59 | 2016-10-11 15:24:07 Mapping QMU11 to QMU11. Service code: nymex | 2016-10-11 15:24:07 HD Request # 63 | Downloading Historical Daily chart data for QMU11. Starting date: 2011-08-18. Service: tda | 2016-10-11 15:24:07 HD Request # 63 | Using user Barchart Historical data account. | 2016-10-11 15:24:07 HD Request # 63 | Requesting historical Daily data for QMU11 starting at 2011-08-17 | 2016-10-11 15:24:07 HD Request # 63 | Receiving historical Daily data for QMU11 starting at 2011-08-18 | 2016-10-11 15:24:08 HD Request # 63 | Writing historical Daily data to the file QMU11.dly | 2016-10-11 15:24:08 HD Request # 63 | Received 3 records from 2011-08-18 00:00:00 to 2011-08-19 00:00:00 (2.0 days) and wrote 2 records for QMU11 | 2016-10-11 15:24:08 HD Request # 63 | Daily download COMPLETE for QMU11. Completion time: 0s. Unique request ID: 60 | 2016-10-11 15:24:08 Removed historical data download ID 60 | 2016-10-11 15:24:08 Mapping QMV11 to QMV11. Service code: nymex | 2016-10-11 15:24:08 HD Request # 64 | Downloading Historical Daily chart data for QMV11. Starting date: 2011-09-16. Service: tda | 2016-10-11 15:24:08 HD Request # 64 | Using user Barchart Historical data account. | 2016-10-11 15:24:08 HD Request # 64 | Requesting historical Daily data for QMV11 starting at 2011-09-15 | 2016-10-11 15:24:08 HD Request # 64 | Receiving historical Daily data for QMV11 starting at 2011-09-16 | 2016-10-11 15:24:08 HD Request # 64 | Writing historical Daily data to the file QMV11.dly | 2016-10-11 15:24:08 HD Request # 64 | Received 3 records from 2011-09-16 00:00:00 to 2011-09-19 00:00:00 (4.0 days) and wrote 2 records for QMV11 | 2016-10-11 15:24:08 HD Request # 64 | Daily download COMPLETE for QMV11. Completion time: 0s. Unique request ID: 61 | 2016-10-11 15:24:08 Removed historical data download ID 61 | 2016-10-11 15:24:08 Mapping QMX11 to QMX11. Service code: nymex | 2016-10-11 15:24:08 HD Request # 65 | Downloading Historical Daily chart data for QMX11. Starting date: 2011-10-18. Service: tda | 2016-10-11 15:24:08 HD Request # 65 | Using user Barchart Historical data account. | 2016-10-11 15:24:08 HD Request # 65 | Requesting historical Daily data for QMX11 starting at 2011-10-17 | 2016-10-11 15:24:08 HD Request # 65 | Receiving historical Daily data for QMX11 starting at 2011-10-18 | 2016-10-11 15:24:08 HD Request # 65 | Writing historical Daily data to the file QMX11.dly | 2016-10-11 15:24:08 HD Request # 65 | Received 3 records from 2011-10-18 00:00:00 to 2011-10-19 00:00:00 (2.0 days) and wrote 2 records for QMX11 | 2016-10-11 15:24:08 HD Request # 65 | Daily download COMPLETE for QMX11. Completion time: 0s. Unique request ID: 62 | 2016-10-11 15:24:08 Removed historical data download ID 62 | 2016-10-11 15:24:08 Mapping QMZ11 to QMZ11. Service code: nymex | 2016-10-11 15:24:08 HD Request # 66 | Downloading Historical Daily chart data for QMZ11. Starting date: 2011-11-16. Service: tda | 2016-10-11 15:24:08 HD Request # 66 | Using user Barchart Historical data account. | 2016-10-11 15:24:08 HD Request # 66 | Requesting historical Daily data for QMZ11 starting at 2011-11-15 | 2016-10-11 15:24:08 HD Request # 66 | Receiving historical Daily data for QMZ11 starting at 2011-11-16 | 2016-10-11 15:24:09 HD Request # 66 | Writing historical Daily data to the file QMZ11.dly | 2016-10-11 15:24:09 HD Request # 66 | Received 3 records from 2011-11-16 00:00:00 to 2011-11-17 00:00:00 (2.0 days) and wrote 2 records for QMZ11 | 2016-10-11 15:24:09 HD Request # 66 | Daily download COMPLETE for QMZ11. Completion time: 0s. Unique request ID: 63 | 2016-10-11 15:24:09 Removed historical data download ID 63 | 2016-10-11 15:24:09 Mapping QMF12 to QMF12. Service code: nymex | 2016-10-11 15:24:09 HD Request # 67 | Downloading Historical Daily chart data for QMF12. Starting date: 2011-12-16. Service: tda | 2016-10-11 15:24:09 HD Request # 67 | Using user Barchart Historical data account. | 2016-10-11 15:24:09 HD Request # 67 | Requesting historical Daily data for QMF12 starting at 2011-12-15 | 2016-10-11 15:24:09 HD Request # 67 | Receiving historical Daily data for QMF12 starting at 2011-12-16 | 2016-10-11 15:24:09 HD Request # 67 | Writing historical Daily data to the file QMF12.dly | 2016-10-11 15:24:09 HD Request # 67 | Received 3 records from 2011-12-16 00:00:00 to 2011-12-19 00:00:00 (4.0 days) and wrote 2 records for QMF12 | 2016-10-11 15:24:09 HD Request # 67 | Daily download COMPLETE for QMF12. Completion time: 1s. Unique request ID: 64 | 2016-10-11 15:24:09 Removed historical data download ID 64 | 2016-10-11 15:24:09 Mapping QMG12 to QMG12. Service code: nymex | 2016-10-11 15:24:09 HD Request # 68 | Downloading Historical Daily chart data for QMG12. Starting date: 2012-01-18. Service: tda | 2016-10-11 15:24:09 HD Request # 68 | Using user Barchart Historical data account. | 2016-10-11 15:24:09 HD Request # 68 | Requesting historical Daily data for QMG12 starting at 2012-01-17 | 2016-10-11 15:24:09 HD Request # 68 | Receiving historical Daily data for QMG12 starting at 2012-01-18 | 2016-10-11 15:24:09 HD Request # 68 | Writing historical Daily data to the file QMG12.dly | 2016-10-11 15:24:09 HD Request # 68 | Received 3 records from 2012-01-18 00:00:00 to 2012-01-19 00:00:00 (2.0 days) and wrote 2 records for QMG12 | 2016-10-11 15:24:09 HD Request # 68 | Daily download COMPLETE for QMG12. Completion time: 0s. Unique request ID: 65 | 2016-10-11 15:24:09 Removed historical data download ID 65 | 2016-10-11 15:24:09 Mapping QMH12 to QMH12. Service code: nymex | 2016-10-11 15:24:09 HD Request # 69 | Downloading Historical Daily chart data for QMH12. Starting date: 2012-02-16. Service: tda | 2016-10-11 15:24:09 HD Request # 69 | Using user Barchart Historical data account. | 2016-10-11 15:24:09 HD Request # 69 | Requesting historical Daily data for QMH12 starting at 2012-02-15 | 2016-10-11 15:24:09 HD Request # 69 | Receiving historical Daily data for QMH12 starting at 2012-02-16 | 2016-10-11 15:24:10 HD Request # 69 | Writing historical Daily data to the file QMH12.dly | 2016-10-11 15:24:10 HD Request # 69 | Received 3 records from 2012-02-16 00:00:00 to 2012-02-17 00:00:00 (2.0 days) and wrote 2 records for QMH12 | 2016-10-11 15:24:10 HD Request # 69 | Daily download COMPLETE for QMH12. Completion time: 0s. Unique request ID: 66 | 2016-10-11 15:24:10 Removed historical data download ID 66 | 2016-10-11 15:24:10 Mapping QMJ12 to QMJ12. Service code: nymex | 2016-10-11 15:24:10 HD Request # 70 | Downloading Historical Daily chart data for QMJ12. Starting date: 2012-03-16. Service: tda | 2016-10-11 15:24:10 HD Request # 70 | Using user Barchart Historical data account. | 2016-10-11 15:24:10 HD Request # 70 | Requesting historical Daily data for QMJ12 starting at 2012-03-15 | 2016-10-11 15:24:10 HD Request # 70 | Receiving historical Daily data for QMJ12 starting at 2012-03-16 | 2016-10-11 15:24:10 HD Request # 70 | Writing historical Daily data to the file QMJ12.dly | 2016-10-11 15:24:10 HD Request # 70 | Received 3 records from 2012-03-16 00:00:00 to 2012-03-19 00:00:00 (4.0 days) and wrote 2 records for QMJ12 | 2016-10-11 15:24:10 HD Request # 70 | Daily download COMPLETE for QMJ12. Completion time: 0s. Unique request ID: 67 | 2016-10-11 15:24:10 Removed historical data download ID 67 | 2016-10-11 15:24:10 Mapping QMK12 to QMK12. Service code: nymex | 2016-10-11 15:24:10 HD Request # 71 | Downloading Historical Daily chart data for QMK12. Starting date: 2012-04-18. Service: tda | 2016-10-11 15:24:10 HD Request # 71 | Using user Barchart Historical data account. | 2016-10-11 15:24:10 HD Request # 71 | Requesting historical Daily data for QMK12 starting at 2012-04-17 | 2016-10-11 15:24:10 HD Request # 71 | Receiving historical Daily data for QMK12 starting at 2012-04-18 | 2016-10-11 15:24:10 HD Request # 71 | Writing historical Daily data to the file QMK12.dly | 2016-10-11 15:24:10 HD Request # 71 | Received 3 records from 2012-04-18 00:00:00 to 2012-04-19 00:00:00 (2.0 days) and wrote 2 records for QMK12 | 2016-10-11 15:24:10 HD Request # 71 | Daily download COMPLETE for QMK12. Completion time: 0s. Unique request ID: 68 | 2016-10-11 15:24:10 Removed historical data download ID 68 | 2016-10-11 15:24:10 Mapping QMM12 to QMM12. Service code: nymex | 2016-10-11 15:24:10 HD Request # 72 | Downloading Historical Daily chart data for QMM12. Starting date: 2012-05-18. Service: tda | 2016-10-11 15:24:10 HD Request # 72 | Using user Barchart Historical data account. | 2016-10-11 15:24:10 HD Request # 72 | Requesting historical Daily data for QMM12 starting at 2012-05-17 | 2016-10-11 15:24:10 HD Request # 72 | Receiving historical Daily data for QMM12 starting at 2012-05-18 | 2016-10-11 15:24:11 HD Request # 72 | Writing historical Daily data to the file QMM12.dly | 2016-10-11 15:24:11 HD Request # 72 | Received 3 records from 2012-05-18 00:00:00 to 2012-05-21 00:00:00 (4.0 days) and wrote 2 records for QMM12 | 2016-10-11 15:24:11 HD Request # 72 | Daily download COMPLETE for QMM12. Completion time: 1s. Unique request ID: 69 | 2016-10-11 15:24:11 Removed historical data download ID 69 | 2016-10-11 15:24:11 Mapping QMN12 to QMN12. Service code: nymex | 2016-10-11 15:24:11 HD Request # 73 | Downloading Historical Daily chart data for QMN12. Starting date: 2012-06-18. Service: tda | 2016-10-11 15:24:11 HD Request # 73 | Using user Barchart Historical data account. | 2016-10-11 15:24:11 HD Request # 73 | Requesting historical Daily data for QMN12 starting at 2012-06-17 | 2016-10-11 15:24:11 HD Request # 73 | Receiving historical Daily data for QMN12 starting at 2012-06-18 | 2016-10-11 15:24:11 HD Request # 73 | Writing historical Daily data to the file QMN12.dly | 2016-10-11 15:24:11 HD Request # 73 | Received 2 records from 2012-06-18 00:00:00 to 2012-06-19 00:00:00 (2.0 days) and wrote 2 records for QMN12 | 2016-10-11 15:24:11 HD Request # 73 | Daily download COMPLETE for QMN12. Completion time: 0s. Unique request ID: 70 | 2016-10-11 15:24:11 Removed historical data download ID 70 | 2016-10-11 15:24:11 Mapping QMQ12 to QMQ12. Service code: nymex | 2016-10-11 15:24:11 HD Request # 74 | Downloading Historical Daily chart data for QMQ12. Starting date: 2012-07-18. Service: tda | 2016-10-11 15:24:11 HD Request # 74 | Using user Barchart Historical data account. | 2016-10-11 15:24:11 HD Request # 74 | Requesting historical Daily data for QMQ12 starting at 2012-07-17 | 2016-10-11 15:24:11 HD Request # 74 | Receiving historical Daily data for QMQ12 starting at 2012-07-18 | 2016-10-11 15:24:12 HD Request # 74 | Writing historical Daily data to the file QMQ12.dly | 2016-10-11 15:24:12 HD Request # 74 | Received 3 records from 2012-07-18 00:00:00 to 2012-07-19 00:00:00 (2.0 days) and wrote 2 records for QMQ12 | 2016-10-11 15:24:12 HD Request # 74 | Daily download COMPLETE for QMQ12. Completion time: 0s. Unique request ID: 71 | 2016-10-11 15:24:12 Removed historical data download ID 71 | 2016-10-11 15:24:12 Mapping QMU12 to QMU12. Service code: nymex | 2016-10-11 15:24:12 HD Request # 75 | Downloading Historical Daily chart data for QMU12. Starting date: 2012-08-17. Service: tda | 2016-10-11 15:24:12 HD Request # 75 | Using user Barchart Historical data account. | 2016-10-11 15:24:12 HD Request # 75 | Requesting historical Daily data for QMU12 starting at 2012-08-16 | 2016-10-11 15:24:12 HD Request # 75 | Receiving historical Daily data for QMU12 starting at 2012-08-17 | 2016-10-11 15:24:12 HD Request # 75 | Writing historical Daily data to the file QMU12.dly | 2016-10-11 15:24:12 HD Request # 75 | Received 3 records from 2012-08-17 00:00:00 to 2012-08-20 00:00:00 (4.0 days) and wrote 2 records for QMU12 | 2016-10-11 15:24:12 HD Request # 75 | Daily download COMPLETE for QMU12. Completion time: 1s. Unique request ID: 72 | 2016-10-11 15:24:12 Removed historical data download ID 72 | 2016-10-11 15:24:12 Mapping QMV12 to QMV12. Service code: nymex | 2016-10-11 15:24:12 HD Request # 76 | Downloading Historical Daily chart data for QMV12. Starting date: 2012-09-18. Service: tda | 2016-10-11 15:24:12 HD Request # 76 | Using user Barchart Historical data account. | 2016-10-11 15:24:12 HD Request # 76 | Requesting historical Daily data for QMV12 starting at 2012-09-17 | 2016-10-11 15:24:12 HD Request # 76 | Receiving historical Daily data for QMV12 starting at 2012-09-18 | 2016-10-11 15:24:13 HD Request # 76 | Writing historical Daily data to the file QMV12.dly | 2016-10-11 15:24:13 HD Request # 76 | Received 3 records from 2012-09-18 00:00:00 to 2012-09-19 00:00:00 (2.0 days) and wrote 2 records for QMV12 | 2016-10-11 15:24:13 HD Request # 76 | Daily download COMPLETE for QMV12. Completion time: 0s. Unique request ID: 73 | 2016-10-11 15:24:13 Removed historical data download ID 73 | 2016-10-11 15:24:13 Mapping QMX12 to QMX12. Service code: nymex | 2016-10-11 15:24:13 HD Request # 77 | Downloading Historical Daily chart data for QMX12. Starting date: 2012-10-18. Service: tda | 2016-10-11 15:24:13 HD Request # 77 | Using user Barchart Historical data account. | 2016-10-11 15:24:13 HD Request # 77 | Requesting historical Daily data for QMX12 starting at 2012-10-17 | 2016-10-11 15:24:13 HD Request # 77 | Receiving historical Daily data for QMX12 starting at 2012-10-18 | 2016-10-11 15:24:13 HD Request # 77 | Writing historical Daily data to the file QMX12.dly | 2016-10-11 15:24:13 HD Request # 77 | Received 3 records from 2012-10-18 00:00:00 to 2012-10-19 00:00:00 (2.0 days) and wrote 2 records for QMX12 | 2016-10-11 15:24:13 HD Request # 77 | Daily download COMPLETE for QMX12. Completion time: 0s. Unique request ID: 74 | 2016-10-11 15:24:13 Removed historical data download ID 74 | 2016-10-11 15:24:13 Mapping QMZ12 to QMZ12. Service code: nymex | 2016-10-11 15:24:13 HD Request # 78 | Downloading Historical Daily chart data for QMZ12. Starting date: 2012-11-14. Service: tda | 2016-10-11 15:24:13 HD Request # 78 | Using user Barchart Historical data account. | 2016-10-11 15:24:13 HD Request # 78 | Requesting historical Daily data for QMZ12 starting at 2012-11-13 | 2016-10-11 15:24:13 HD Request # 78 | Receiving historical Daily data for QMZ12 starting at 2012-11-14 | 2016-10-11 15:24:13 HD Request # 78 | Writing historical Daily data to the file QMZ12.dly | 2016-10-11 15:24:13 HD Request # 78 | Received 3 records from 2012-11-14 00:00:00 to 2012-11-15 00:00:00 (2.0 days) and wrote 2 records for QMZ12 | 2016-10-11 15:24:13 HD Request # 78 | Daily download COMPLETE for QMZ12. Completion time: 0s. Unique request ID: 75 | 2016-10-11 15:24:13 Removed historical data download ID 75 | 2016-10-11 15:24:13 Mapping QMF13 to QMF13. Service code: nymex | 2016-10-11 15:24:13 HD Request # 79 | Downloading Historical Daily chart data for QMF13. Starting date: 2012-12-17. Service: tda | 2016-10-11 15:24:13 HD Request # 79 | Using user Barchart Historical data account. | 2016-10-11 15:24:13 HD Request # 79 | Requesting historical Daily data for QMF13 starting at 2012-12-16 | 2016-10-11 15:24:13 HD Request # 79 | Receiving historical Daily data for QMF13 starting at 2012-12-17 | 2016-10-11 15:24:14 HD Request # 79 | Writing historical Daily data to the file QMF13.dly | 2016-10-11 15:24:14 HD Request # 79 | Received 2 records from 2012-12-17 00:00:00 to 2012-12-18 00:00:00 (2.0 days) and wrote 2 records for QMF13 | 2016-10-11 15:24:14 HD Request # 79 | Daily download COMPLETE for QMF13. Completion time: 1s. Unique request ID: 76 | 2016-10-11 15:24:14 Removed historical data download ID 76 | 2016-10-11 15:24:14 Mapping QMG13 to QMG13. Service code: nymex | 2016-10-11 15:24:14 HD Request # 80 | Downloading Historical Daily chart data for QMG13. Starting date: 2013-01-17. Service: tda | 2016-10-11 15:24:14 HD Request # 80 | Using user Barchart Historical data account. | 2016-10-11 15:24:14 HD Request # 80 | Requesting historical Daily data for QMG13 starting at 2013-01-16 | 2016-10-11 15:24:14 HD Request # 80 | Receiving historical Daily data for QMG13 starting at 2013-01-17 | 2016-10-11 15:24:14 HD Request # 80 | Writing historical Daily data to the file QMG13.dly | 2016-10-11 15:24:14 HD Request # 80 | Received 3 records from 2013-01-17 00:00:00 to 2013-01-18 00:00:00 (2.0 days) and wrote 2 records for QMG13 | 2016-10-11 15:24:14 HD Request # 80 | Daily download COMPLETE for QMG13. Completion time: 0s. Unique request ID: 77 | 2016-10-11 15:24:14 Removed historical data download ID 77 | 2016-10-11 15:24:14 Mapping QMH13 to QMH13. Service code: nymex | 2016-10-11 15:24:14 HD Request # 81 | Downloading Historical Daily chart data for QMH13. Starting date: 2013-02-15. Service: tda | 2016-10-11 15:24:14 HD Request # 81 | Using user Barchart Historical data account. | 2016-10-11 15:24:14 HD Request # 81 | Requesting historical Daily data for QMH13 starting at 2013-02-14 | 2016-10-11 15:24:14 HD Request # 81 | Receiving historical Daily data for QMH13 starting at 2013-02-15 | 2016-10-11 15:24:15 HD Request # 81 | Writing historical Daily data to the file QMH13.dly | 2016-10-11 15:24:15 HD Request # 81 | Received 3 records from 2013-02-15 00:00:00 to 2013-02-19 00:00:00 (5.0 days) and wrote 2 records for QMH13 | 2016-10-11 15:24:15 HD Request # 81 | Daily download COMPLETE for QMH13. Completion time: 1s. Unique request ID: 78 | 2016-10-11 15:24:15 Removed historical data download ID 78 | 2016-10-11 15:24:15 Mapping QMJ13 to QMJ13. Service code: nymex | 2016-10-11 15:24:15 HD Request # 82 | Downloading Historical Daily chart data for QMJ13. Starting date: 2013-03-18. Service: tda | 2016-10-11 15:24:15 HD Request # 82 | Using user Barchart Historical data account. | 2016-10-11 15:24:15 HD Request # 82 | Requesting historical Daily data for QMJ13 starting at 2013-03-17 | 2016-10-11 15:24:15 HD Request # 82 | Receiving historical Daily data for QMJ13 starting at 2013-03-18 | 2016-10-11 15:24:15 HD Request # 82 | Writing historical Daily data to the file QMJ13.dly | 2016-10-11 15:24:15 HD Request # 82 | Received 2 records from 2013-03-18 00:00:00 to 2013-03-19 00:00:00 (2.0 days) and wrote 2 records for QMJ13 | 2016-10-11 15:24:15 HD Request # 82 | Daily download COMPLETE for QMJ13. Completion time: 0s. Unique request ID: 79 | 2016-10-11 15:24:15 Removed historical data download ID 79 | 2016-10-11 15:24:15 Mapping QMK13 to QMK13. Service code: nymex | 2016-10-11 15:24:15 HD Request # 83 | Downloading Historical Daily chart data for QMK13. Starting date: 2013-04-18. Service: tda | 2016-10-11 15:24:15 HD Request # 83 | Using user Barchart Historical data account. | 2016-10-11 15:24:15 HD Request # 83 | Requesting historical Daily data for QMK13 starting at 2013-04-17 | 2016-10-11 15:24:15 HD Request # 83 | Receiving historical Daily data for QMK13 starting at 2013-04-18 | 2016-10-11 15:24:16 HD Request # 83 | Writing historical Daily data to the file QMK13.dly | 2016-10-11 15:24:16 HD Request # 83 | Received 3 records from 2013-04-18 00:00:00 to 2013-04-19 00:00:00 (2.0 days) and wrote 2 records for QMK13 | 2016-10-11 15:24:16 HD Request # 83 | Daily download COMPLETE for QMK13. Completion time: 0s. Unique request ID: 80 | 2016-10-11 15:24:16 Removed historical data download ID 80 | 2016-10-11 15:24:16 Mapping QMM13 to QMM13. Service code: nymex | 2016-10-11 15:24:16 HD Request # 84 | Downloading Historical Daily chart data for QMM13. Starting date: 2013-05-17. Service: tda | 2016-10-11 15:24:16 HD Request # 84 | Using user Barchart Historical data account. | 2016-10-11 15:24:16 HD Request # 84 | Requesting historical Daily data for QMM13 starting at 2013-05-16 | 2016-10-11 15:24:16 HD Request # 84 | Receiving historical Daily data for QMM13 starting at 2013-05-17 | 2016-10-11 15:24:16 HD Request # 84 | Writing historical Daily data to the file QMM13.dly | 2016-10-11 15:24:16 HD Request # 84 | Received 3 records from 2013-05-17 00:00:00 to 2013-05-20 00:00:00 (4.0 days) and wrote 2 records for QMM13 | 2016-10-11 15:24:16 HD Request # 84 | Daily download COMPLETE for QMM13. Completion time: 0s. Unique request ID: 81 | 2016-10-11 15:24:16 Removed historical data download ID 81 | 2016-10-11 15:24:16 Mapping QMN13 to QMN13. Service code: nymex | 2016-10-11 15:24:16 HD Request # 85 | Downloading Historical Daily chart data for QMN13. Starting date: 2013-06-18. Service: tda | 2016-10-11 15:24:16 HD Request # 85 | Using user Barchart Historical data account. | 2016-10-11 15:24:16 HD Request # 85 | Requesting historical Daily data for QMN13 starting at 2013-06-17 | 2016-10-11 15:24:16 HD Request # 85 | Receiving historical Daily data for QMN13 starting at 2013-06-18 | 2016-10-11 15:24:17 HD Request # 85 | Writing historical Daily data to the file QMN13.dly | 2016-10-11 15:24:17 HD Request # 85 | Received 3 records from 2013-06-18 00:00:00 to 2013-06-19 00:00:00 (2.0 days) and wrote 2 records for QMN13 | 2016-10-11 15:24:17 HD Request # 85 | Daily download COMPLETE for QMN13. Completion time: 1s. Unique request ID: 82 | 2016-10-11 15:24:17 Removed historical data download ID 82 | 2016-10-11 15:24:17 Mapping QMQ13 to QMQ13. Service code: nymex | 2016-10-11 15:24:17 HD Request # 86 | Downloading Historical Daily chart data for QMQ13. Starting date: 2013-07-18. Service: tda | 2016-10-11 15:24:17 HD Request # 86 | Using user Barchart Historical data account. | 2016-10-11 15:24:17 HD Request # 86 | Requesting historical Daily data for QMQ13 starting at 2013-07-17 | 2016-10-11 15:24:17 HD Request # 86 | Receiving historical Daily data for QMQ13 starting at 2013-07-18 | 2016-10-11 15:24:17 HD Request # 86 | Writing historical Daily data to the file QMQ13.dly | 2016-10-11 15:24:17 HD Request # 86 | Received 3 records from 2013-07-18 00:00:00 to 2013-07-19 00:00:00 (2.0 days) and wrote 2 records for QMQ13 | 2016-10-11 15:24:17 HD Request # 86 | Daily download COMPLETE for QMQ13. Completion time: 0s. Unique request ID: 83 | 2016-10-11 15:24:17 Removed historical data download ID 83 | 2016-10-11 15:24:17 Mapping QMU13 to QMU13. Service code: nymex | 2016-10-11 15:24:17 HD Request # 87 | Downloading Historical Daily chart data for QMU13. Starting date: 2013-08-16. Service: tda | 2016-10-11 15:24:17 HD Request # 87 | Using user Barchart Historical data account. | 2016-10-11 15:24:17 HD Request # 87 | Requesting historical Daily data for QMU13 starting at 2013-08-15 | 2016-10-11 15:24:17 HD Request # 87 | Receiving historical Daily data for QMU13 starting at 2013-08-16 | 2016-10-11 15:24:18 HD Request # 87 | Writing historical Daily data to the file QMU13.dly | 2016-10-11 15:24:18 HD Request # 87 | Received 3 records from 2013-08-16 00:00:00 to 2013-08-19 00:00:00 (4.0 days) and wrote 2 records for QMU13 | 2016-10-11 15:24:18 HD Request # 87 | Daily download COMPLETE for QMU13. Completion time: 1s. Unique request ID: 84 | 2016-10-11 15:24:18 Removed historical data download ID 84 | 2016-10-11 15:24:18 Mapping QMV13 to QMV13. Service code: nymex | 2016-10-11 15:24:18 HD Request # 88 | Downloading Historical Daily chart data for QMV13. Starting date: 2013-09-18. Service: tda | 2016-10-11 15:24:18 HD Request # 88 | Using user Barchart Historical data account. | 2016-10-11 15:24:18 HD Request # 88 | Requesting historical Daily data for QMV13 starting at 2013-09-17 | 2016-10-11 15:24:18 HD Request # 88 | Receiving historical Daily data for QMV13 starting at 2013-09-18 | 2016-10-11 15:24:18 HD Request # 88 | Writing historical Daily data to the file QMV13.dly | 2016-10-11 15:24:18 HD Request # 88 | Received 3 records from 2013-09-18 00:00:00 to 2013-09-19 00:00:00 (2.0 days) and wrote 2 records for QMV13 | 2016-10-11 15:24:18 HD Request # 88 | Daily download COMPLETE for QMV13. Completion time: 0s. Unique request ID: 85 | 2016-10-11 15:24:18 Removed historical data download ID 85 | 2016-10-11 15:24:18 Mapping QMX13 to QMX13. Service code: nymex | 2016-10-11 15:24:18 HD Request # 89 | Downloading Historical Daily chart data for QMX13. Starting date: 2013-10-18. Service: tda | 2016-10-11 15:24:18 HD Request # 89 | Using user Barchart Historical data account. | 2016-10-11 15:24:18 HD Request # 89 | Requesting historical Daily data for QMX13 starting at 2013-10-17 | 2016-10-11 15:24:18 HD Request # 89 | Receiving historical Daily data for QMX13 starting at 2013-10-18 | 2016-10-11 15:24:19 HD Request # 89 | Writing historical Daily data to the file QMX13.dly | 2016-10-11 15:24:19 HD Request # 89 | Received 3 records from 2013-10-18 00:00:00 to 2013-10-21 00:00:00 (4.0 days) and wrote 2 records for QMX13 | 2016-10-11 15:24:19 HD Request # 89 | Daily download COMPLETE for QMX13. Completion time: 0s. Unique request ID: 86 | 2016-10-11 15:24:19 Removed historical data download ID 86 | 2016-10-11 15:24:19 Mapping QMZ13 to QMZ13. Service code: nymex | 2016-10-11 15:24:19 HD Request # 90 | Downloading Historical Daily chart data for QMZ13. Starting date: 2013-11-18. Service: tda | 2016-10-11 15:24:19 HD Request # 90 | Using user Barchart Historical data account. | 2016-10-11 15:24:19 HD Request # 90 | Requesting historical Daily data for QMZ13 starting at 2013-11-17 | 2016-10-11 15:24:19 HD Request # 90 | Receiving historical Daily data for QMZ13 starting at 2013-11-18 | 2016-10-11 15:24:19 HD Request # 90 | Writing historical Daily data to the file QMZ13.dly | 2016-10-11 15:24:19 HD Request # 90 | Received 2 records from 2013-11-18 00:00:00 to 2013-11-19 00:00:00 (2.0 days) and wrote 2 records for QMZ13 | 2016-10-11 15:24:19 HD Request # 90 | Daily download COMPLETE for QMZ13. Completion time: 0s. Unique request ID: 87 | 2016-10-11 15:24:19 Removed historical data download ID 87 | 2016-10-11 15:24:19 Mapping QMF14 to QMF14. Service code: nymex | 2016-10-11 15:24:19 HD Request # 91 | Downloading Historical Daily chart data for QMF14. Starting date: 2013-12-17. Service: tda | 2016-10-11 15:24:19 HD Request # 91 | Using user Barchart Historical data account. | 2016-10-11 15:24:19 HD Request # 91 | Requesting historical Daily data for QMF14 starting at 2013-12-16 | 2016-10-11 15:24:19 HD Request # 91 | Receiving historical Daily data for QMF14 starting at 2013-12-17 | 2016-10-11 15:24:19 HD Request # 91 | Writing historical Daily data to the file QMF14.dly | 2016-10-11 15:24:19 HD Request # 91 | Received 3 records from 2013-12-17 00:00:00 to 2013-12-18 00:00:00 (2.0 days) and wrote 2 records for QMF14 | 2016-10-11 15:24:19 HD Request # 91 | Daily download COMPLETE for QMF14. Completion time: 0s. Unique request ID: 88 | 2016-10-11 15:24:19 Removed historical data download ID 88 | 2016-10-11 15:24:19 Mapping QMG14 to QMG14. Service code: nymex | 2016-10-11 15:24:19 HD Request # 92 | Downloading Historical Daily chart data for QMG14. Starting date: 2014-01-16. Service: tda | 2016-10-11 15:24:19 HD Request # 92 | Using user Barchart Historical data account. | 2016-10-11 15:24:19 HD Request # 92 | Requesting historical Daily data for QMG14 starting at 2014-01-15 | 2016-10-11 15:24:19 HD Request # 92 | Receiving historical Daily data for QMG14 starting at 2014-01-16 | 2016-10-11 15:24:20 HD Request # 92 | Writing historical Daily data to the file QMG14.dly | 2016-10-11 15:24:20 HD Request # 92 | Received 3 records from 2014-01-16 00:00:00 to 2014-01-17 00:00:00 (2.0 days) and wrote 2 records for QMG14 | 2016-10-11 15:24:20 HD Request # 92 | Daily download COMPLETE for QMG14. Completion time: 1s. Unique request ID: 89 | 2016-10-11 15:24:20 Removed historical data download ID 89 | 2016-10-11 15:24:20 Mapping QMH14 to QMH14. Service code: nymex | 2016-10-11 15:24:20 HD Request # 93 | Downloading Historical Daily chart data for QMH14. Starting date: 2014-02-18. Service: tda | 2016-10-11 15:24:20 HD Request # 93 | Using user Barchart Historical data account. | 2016-10-11 15:24:20 HD Request # 93 | Requesting historical Daily data for QMH14 starting at 2014-02-17 | 2016-10-11 15:24:20 HD Request # 93 | Receiving historical Daily data for QMH14 starting at 2014-02-18 | 2016-10-11 15:24:21 HD Request # 93 | Writing historical Daily data to the file QMH14.dly | 2016-10-11 15:24:21 HD Request # 93 | Received 2 records from 2014-02-18 00:00:00 to 2014-02-19 00:00:00 (2.0 days) and wrote 2 records for QMH14 | 2016-10-11 15:24:21 HD Request # 93 | Daily download COMPLETE for QMH14. Completion time: 0s. Unique request ID: 90 | 2016-10-11 15:24:21 Removed historical data download ID 90 | 2016-10-11 15:24:21 Mapping QMJ14 to QMJ14. Service code: nymex | 2016-10-11 15:24:21 HD Request # 94 | Downloading Historical Daily chart data for QMJ14. Starting date: 2014-03-18. Service: tda | 2016-10-11 15:24:21 HD Request # 94 | Using user Barchart Historical data account. | 2016-10-11 15:24:21 HD Request # 94 | Requesting historical Daily data for QMJ14 starting at 2014-03-17 | 2016-10-11 15:24:21 HD Request # 94 | Receiving historical Daily data for QMJ14 starting at 2014-03-18 | 2016-10-11 15:24:21 HD Request # 94 | Writing historical Daily data to the file QMJ14.dly | 2016-10-11 15:24:21 HD Request # 94 | Received 3 records from 2014-03-18 00:00:00 to 2014-03-19 00:00:00 (2.0 days) and wrote 2 records for QMJ14 | 2016-10-11 15:24:21 HD Request # 94 | Daily download COMPLETE for QMJ14. Completion time: 0s. Unique request ID: 91 | 2016-10-11 15:24:21 Removed historical data download ID 91 | 2016-10-11 15:24:21 Mapping QMK14 to QMK14. Service code: nymex | 2016-10-11 15:24:21 HD Request # 95 | Downloading Historical Daily chart data for QMK14. Starting date: 2014-04-17. Service: tda | 2016-10-11 15:24:21 HD Request # 95 | Using user Barchart Historical data account. | 2016-10-11 15:24:21 HD Request # 95 | Requesting historical Daily data for QMK14 starting at 2014-04-16 | 2016-10-11 15:24:21 HD Request # 95 | Receiving historical Daily data for QMK14 starting at 2014-04-17 | 2016-10-11 15:24:21 HD Request # 95 | Writing historical Daily data to the file QMK14.dly | 2016-10-11 15:24:21 HD Request # 95 | Received 3 records from 2014-04-17 00:00:00 to 2014-04-21 00:00:00 (5.0 days) and wrote 2 records for QMK14 | 2016-10-11 15:24:21 HD Request # 95 | Daily download COMPLETE for QMK14. Completion time: 0s. Unique request ID: 92 | 2016-10-11 15:24:21 Removed historical data download ID 92 | 2016-10-11 15:24:21 Mapping QMM14 to QMM14. Service code: nymex | 2016-10-11 15:24:21 HD Request # 96 | Downloading Historical Daily chart data for QMM14. Starting date: 2014-05-16. Service: tda | 2016-10-11 15:24:21 HD Request # 96 | Using user Barchart Historical data account. | 2016-10-11 15:24:21 HD Request # 96 | Requesting historical Daily data for QMM14 starting at 2014-05-15 | 2016-10-11 15:24:21 HD Request # 96 | Receiving historical Daily data for QMM14 starting at 2014-05-16 | 2016-10-11 15:24:22 HD Request # 96 | Writing historical Daily data to the file QMM14.dly | 2016-10-11 15:24:22 HD Request # 96 | Received 3 records from 2014-05-16 00:00:00 to 2014-05-19 00:00:00 (4.0 days) and wrote 2 records for QMM14 | 2016-10-11 15:24:22 HD Request # 96 | Daily download COMPLETE for QMM14. Completion time: 0s. Unique request ID: 93 | 2016-10-11 15:24:22 Removed historical data download ID 93 | 2016-10-11 15:24:22 Mapping QMN14 to QMN14. Service code: nymex | 2016-10-11 15:24:22 HD Request # 97 | Downloading Historical Daily chart data for QMN14. Starting date: 2014-06-18. Service: tda | 2016-10-11 15:24:22 HD Request # 97 | Using user Barchart Historical data account. | 2016-10-11 15:24:22 HD Request # 97 | Requesting historical Daily data for QMN14 starting at 2014-06-17 | 2016-10-11 15:24:22 HD Request # 97 | Receiving historical Daily data for QMN14 starting at 2014-06-18 | 2016-10-11 15:24:22 HD Request # 97 | Writing historical Daily data to the file QMN14.dly | 2016-10-11 15:24:22 HD Request # 97 | Received 3 records from 2014-06-18 00:00:00 to 2014-06-19 00:00:00 (2.0 days) and wrote 2 records for QMN14 | 2016-10-11 15:24:22 HD Request # 97 | Daily download COMPLETE for QMN14. Completion time: 0s. Unique request ID: 94 | 2016-10-11 15:24:22 Removed historical data download ID 94 | 2016-10-11 15:24:22 Mapping QMQ14 to QMQ14. Service code: nymex | 2016-10-11 15:24:22 HD Request # 98 | Downloading Historical Daily chart data for QMQ14. Starting date: 2014-07-18. Service: tda | 2016-10-11 15:24:22 HD Request # 98 | Using user Barchart Historical data account. | 2016-10-11 15:24:22 HD Request # 98 | Requesting historical Daily data for QMQ14 starting at 2014-07-17 | 2016-10-11 15:24:22 HD Request # 98 | Receiving historical Daily data for QMQ14 starting at 2014-07-18 | 2016-10-11 15:24:22 HD Request # 98 | Writing historical Daily data to the file QMQ14.dly | 2016-10-11 15:24:22 HD Request # 98 | Received 3 records from 2014-07-18 00:00:00 to 2014-07-21 00:00:00 (4.0 days) and wrote 2 records for QMQ14 | 2016-10-11 15:24:22 HD Request # 98 | Daily download COMPLETE for QMQ14. Completion time: 1s. Unique request ID: 95 | 2016-10-11 15:24:22 Removed historical data download ID 95 | 2016-10-11 15:24:22 Mapping QMU14 to QMU14. Service code: nymex | 2016-10-11 15:24:22 HD Request # 99 | Downloading Historical Daily chart data for QMU14. Starting date: 2014-08-18. Service: tda | 2016-10-11 15:24:22 HD Request # 99 | Using user Barchart Historical data account. | 2016-10-11 15:24:22 HD Request # 99 | Requesting historical Daily data for QMU14 starting at 2014-08-17 | 2016-10-11 15:24:22 HD Request # 99 | Receiving historical Daily data for QMU14 starting at 2014-08-18 | 2016-10-11 15:24:23 HD Request # 99 | Writing historical Daily data to the file QMU14.dly | 2016-10-11 15:24:23 HD Request # 99 | Received 2 records from 2014-08-18 00:00:00 to 2014-08-19 00:00:00 (2.0 days) and wrote 2 records for QMU14 | 2016-10-11 15:24:23 HD Request # 99 | Daily download COMPLETE for QMU14. Completion time: 0s. Unique request ID: 96 | 2016-10-11 15:24:23 Removed historical data download ID 96 | 2016-10-11 15:24:23 Mapping QMV14 to QMV14. Service code: nymex | 2016-10-11 15:24:23 HD Request # 100 | Downloading Historical Daily chart data for QMV14. Starting date: 2014-09-18. Service: tda | 2016-10-11 15:24:23 HD Request # 100 | Using user Barchart Historical data account. | 2016-10-11 15:24:23 HD Request # 100 | Requesting historical Daily data for QMV14 starting at 2014-09-17 | 2016-10-11 15:24:23 HD Request # 100 | Receiving historical Daily data for QMV14 starting at 2014-09-18 | 2016-10-11 15:24:23 HD Request # 100 | Writing historical Daily data to the file QMV14.dly | 2016-10-11 15:24:23 HD Request # 100 | Received 3 records from 2014-09-18 00:00:00 to 2014-09-19 00:00:00 (2.0 days) and wrote 2 records for QMV14 | 2016-10-11 15:24:23 HD Request # 100 | Daily download COMPLETE for QMV14. Completion time: 1s. Unique request ID: 97 | 2016-10-11 15:24:23 Removed historical data download ID 97 | 2016-10-11 15:24:23 Mapping QMX14 to QMX14. Service code: nymex | 2016-10-11 15:24:23 HD Request # 101 | Downloading Historical Daily chart data for QMX14. Starting date: 2014-10-17. Service: tda | 2016-10-11 15:24:23 HD Request # 101 | Using user Barchart Historical data account. | 2016-10-11 15:24:23 HD Request # 101 | Requesting historical Daily data for QMX14 starting at 2014-10-16 | 2016-10-11 15:24:23 HD Request # 101 | Receiving historical Daily data for QMX14 starting at 2014-10-17 | 2016-10-11 15:24:23 HD Request # 101 | Writing historical Daily data to the file QMX14.dly | 2016-10-11 15:24:23 HD Request # 101 | Received 3 records from 2014-10-17 00:00:00 to 2014-10-20 00:00:00 (4.0 days) and wrote 2 records for QMX14 | 2016-10-11 15:24:23 HD Request # 101 | Daily download COMPLETE for QMX14. Completion time: 0s. Unique request ID: 98 | 2016-10-11 15:24:23 Removed historical data download ID 98 | 2016-10-11 15:24:23 Mapping QMZ14 to QMZ14. Service code: nymex | 2016-10-11 15:24:23 HD Request # 102 | Downloading Historical Daily chart data for QMZ14. Starting date: 2014-11-18. Service: tda | 2016-10-11 15:24:23 HD Request # 102 | Using user Barchart Historical data account. | 2016-10-11 15:24:23 HD Request # 102 | Requesting historical Daily data for QMZ14 starting at 2014-11-17 | 2016-10-11 15:24:23 HD Request # 102 | Receiving historical Daily data for QMZ14 starting at 2014-11-18 | 2016-10-11 15:24:24 HD Request # 102 | Writing historical Daily data to the file QMZ14.dly | 2016-10-11 15:24:24 HD Request # 102 | Received 3 records from 2014-11-18 00:00:00 to 2014-11-19 00:00:00 (2.0 days) and wrote 2 records for QMZ14 | 2016-10-11 15:24:24 HD Request # 102 | Daily download COMPLETE for QMZ14. Completion time: 0s. Unique request ID: 99 | 2016-10-11 15:24:24 Removed historical data download ID 99 | 2016-10-11 15:24:24 Mapping QMF15 to QMF15. Service code: nymex | 2016-10-11 15:24:24 HD Request # 103 | Downloading Historical Daily chart data for QMF15. Starting date: 2014-12-17. Service: tda | 2016-10-11 15:24:24 HD Request # 103 | Using user Barchart Historical data account. | 2016-10-11 15:24:24 HD Request # 103 | Requesting historical Daily data for QMF15 starting at 2014-12-16 | 2016-10-11 15:24:24 HD Request # 103 | Receiving historical Daily data for QMF15 starting at 2014-12-17 | 2016-10-11 15:24:24 HD Request # 103 | Writing historical Daily data to the file QMF15.dly | 2016-10-11 15:24:24 HD Request # 103 | Received 3 records from 2014-12-17 00:00:00 to 2014-12-18 00:00:00 (2.0 days) and wrote 2 records for QMF15 | 2016-10-11 15:24:24 HD Request # 103 | Daily download COMPLETE for QMF15. Completion time: 0s. Unique request ID: 100 | 2016-10-11 15:24:24 Removed historical data download ID 100 | 2016-10-11 15:24:24 HTTP connection to ds01.ddfplus.com:80 (7) | Closed. No error. | 2016-10-11 15:24:24 HTTP connection to ds01.ddfplus.com:80 (7) | Shutdown and closed. | 2016-10-11 15:24:24 Mapping QMG15 to QMG15. Service code: nymex | 2016-10-11 15:24:24 HD Request # 104 | Downloading Historical Daily chart data for QMG15. Starting date: 2015-01-15. Service: tda | 2016-10-11 15:24:24 HD Request # 104 | Using user Barchart Historical data account. | 2016-10-11 15:24:24 HD Request # 104 | Requesting historical Daily data for QMG15 starting at 2015-01-14 | 2016-10-11 15:24:24 HTTP connection to ds01.ddfplus.com:80 (0) | Resolved address ds01.ddfplus.com to IP 8.18.161.123. | 2016-10-11 15:24:24 HTTP connection to ds01.ddfplus.com:80 (9) | Connected. | 2016-10-11 15:24:24 HD Request # 104 | Receiving historical Daily data for QMG15 starting at 2015-01-15 | 2016-10-11 15:24:24 HD Request # 104 | Writing historical Daily data to the file QMG15.dly | 2016-10-11 15:24:24 HD Request # 104 | Received 3 records from 2015-01-15 00:00:00 to 2015-01-16 00:00:00 (2.0 days) and wrote 2 records for QMG15 | 2016-10-11 15:24:24 HD Request # 104 | Daily download COMPLETE for QMG15. Completion time: 0s. Unique request ID: 101 | 2016-10-11 15:24:24 Removed historical data download ID 101 | 2016-10-11 15:24:24 Mapping QMH15 to QMH15. Service code: nymex | 2016-10-11 15:24:24 HD Request # 105 | Downloading Historical Daily chart data for QMH15. Starting date: 2015-02-18. Service: tda | 2016-10-11 15:24:24 HD Request # 105 | Using user Barchart Historical data account. | 2016-10-11 15:24:24 HD Request # 105 | Requesting historical Daily data for QMH15 starting at 2015-02-17 | 2016-10-11 15:24:24 HD Request # 105 | Receiving historical Daily data for QMH15 starting at 2015-02-18 | 2016-10-11 15:24:25 HD Request # 105 | Writing historical Daily data to the file QMH15.dly | 2016-10-11 15:24:25 HD Request # 105 | Received 3 records from 2015-02-18 00:00:00 to 2015-02-19 00:00:00 (2.0 days) and wrote 2 records for QMH15 | 2016-10-11 15:24:25 HD Request # 105 | Daily download COMPLETE for QMH15. Completion time: 0s. Unique request ID: 102 | 2016-10-11 15:24:25 Removed historical data download ID 102 | 2016-10-11 15:24:25 Mapping QMJ15 to QMJ15. Service code: nymex | 2016-10-11 15:24:25 HD Request # 106 | Downloading Historical Daily chart data for QMJ15. Starting date: 2015-03-18. Service: tda | 2016-10-11 15:24:25 HD Request # 106 | Using user Barchart Historical data account. | 2016-10-11 15:24:25 HD Request # 106 | Requesting historical Daily data for QMJ15 starting at 2015-03-17 | 2016-10-11 15:24:25 HD Request # 106 | Receiving historical Daily data for QMJ15 starting at 2015-03-18 | 2016-10-11 15:24:25 HD Request # 106 | Writing historical Daily data to the file QMJ15.dly | 2016-10-11 15:24:25 HD Request # 106 | Received 3 records from 2015-03-18 00:00:00 to 2015-03-19 00:00:00 (2.0 days) and wrote 2 records for QMJ15 | 2016-10-11 15:24:25 HD Request # 106 | Daily download COMPLETE for QMJ15. Completion time: 1s. Unique request ID: 103 | 2016-10-11 15:24:25 Removed historical data download ID 103 | 2016-10-11 15:24:25 Mapping QMK15 to QMK15. Service code: nymex | 2016-10-11 15:24:25 HD Request # 107 | Downloading Historical Daily chart data for QMK15. Starting date: 2015-04-17. Service: tda | 2016-10-11 15:24:25 HD Request # 107 | Using user Barchart Historical data account. | 2016-10-11 15:24:25 HD Request # 107 | Requesting historical Daily data for QMK15 starting at 2015-04-16 | 2016-10-11 15:24:25 HD Request # 107 | Receiving historical Daily data for QMK15 starting at 2015-04-17 | 2016-10-11 15:24:25 HD Request # 107 | Writing historical Daily data to the file QMK15.dly | 2016-10-11 15:24:25 HD Request # 107 | Received 3 records from 2015-04-17 00:00:00 to 2015-04-20 00:00:00 (4.0 days) and wrote 2 records for QMK15 | 2016-10-11 15:24:25 HD Request # 107 | Daily download COMPLETE for QMK15. Completion time: 0s. Unique request ID: 104 | 2016-10-11 15:24:25 Removed historical data download ID 104 | 2016-10-11 15:24:25 Mapping QMM15 to QMM15. Service code: nymex | 2016-10-11 15:24:25 HD Request # 108 | Downloading Historical Daily chart data for QMM15. Starting date: 2015-05-15. Service: tda | 2016-10-11 15:24:25 HD Request # 108 | Using user Barchart Historical data account. | 2016-10-11 15:24:25 HD Request # 108 | Requesting historical Daily data for QMM15 starting at 2015-05-14 | 2016-10-11 15:24:25 HD Request # 108 | Receiving historical Daily data for QMM15 starting at 2015-05-15 | 2016-10-11 15:24:26 HD Request # 108 | Writing historical Daily data to the file QMM15.dly | 2016-10-11 15:24:26 HD Request # 108 | Received 3 records from 2015-05-15 00:00:00 to 2015-05-18 00:00:00 (4.0 days) and wrote 2 records for QMM15 | 2016-10-11 15:24:26 HD Request # 108 | Daily download COMPLETE for QMM15. Completion time: 0s. Unique request ID: 105 | 2016-10-11 15:24:26 Removed historical data download ID 105 | 2016-10-11 15:24:26 Mapping QMN15 to QMN15. Service code: nymex | 2016-10-11 15:24:26 HD Request # 109 | Downloading Historical Daily chart data for QMN15. Starting date: 2015-06-18. Service: tda | 2016-10-11 15:24:26 HD Request # 109 | Using user Barchart Historical data account. | 2016-10-11 15:24:26 HD Request # 109 | Requesting historical Daily data for QMN15 starting at 2015-06-17 | 2016-10-11 15:24:26 HD Request # 109 | Receiving historical Daily data for QMN15 starting at 2015-06-18 | 2016-10-11 15:24:26 HD Request # 109 | Writing historical Daily data to the file QMN15.dly | 2016-10-11 15:24:26 HD Request # 109 | Received 3 records from 2015-06-18 00:00:00 to 2015-06-19 00:00:00 (2.0 days) and wrote 2 records for QMN15 | 2016-10-11 15:24:26 HD Request # 109 | Daily download COMPLETE for QMN15. Completion time: 1s. Unique request ID: 106 | 2016-10-11 15:24:26 Removed historical data download ID 106 | 2016-10-11 15:24:26 Mapping QMQ15 to QMQ15. Service code: nymex | 2016-10-11 15:24:26 HD Request # 110 | Downloading Historical Daily chart data for QMQ15. Starting date: 2015-07-17. Service: tda | 2016-10-11 15:24:26 HD Request # 110 | Using user Barchart Historical data account. | 2016-10-11 15:24:26 HD Request # 110 | Requesting historical Daily data for QMQ15 starting at 2015-07-16 | 2016-10-11 15:24:26 HD Request # 110 | Receiving historical Daily data for QMQ15 starting at 2015-07-17 | 2016-10-11 15:24:26 HD Request # 110 | Writing historical Daily data to the file QMQ15.dly | 2016-10-11 15:24:26 HD Request # 110 | Received 3 records from 2015-07-17 00:00:00 to 2015-07-20 00:00:00 (4.0 days) and wrote 2 records for QMQ15 | 2016-10-11 15:24:26 HD Request # 110 | Daily download COMPLETE for QMQ15. Completion time: 0s. Unique request ID: 107 | 2016-10-11 15:24:26 Removed historical data download ID 107 | 2016-10-11 15:24:26 Mapping QMU15 to QMU15. Service code: nymex | 2016-10-11 15:24:26 HD Request # 111 | Downloading Historical Daily chart data for QMU15. Starting date: 2015-08-18. Service: tda | 2016-10-11 15:24:26 HD Request # 111 | Using user Barchart Historical data account. | 2016-10-11 15:24:26 HD Request # 111 | Requesting historical Daily data for QMU15 starting at 2015-08-17 | 2016-10-11 15:24:26 HD Request # 111 | Receiving historical Daily data for QMU15 starting at 2015-08-18 | 2016-10-11 15:24:27 HD Request # 111 | Writing historical Daily data to the file QMU15.dly | 2016-10-11 15:24:27 HD Request # 111 | Received 3 records from 2015-08-18 00:00:00 to 2015-08-19 00:00:00 (2.0 days) and wrote 2 records for QMU15 | 2016-10-11 15:24:27 HD Request # 111 | Daily download COMPLETE for QMU15. Completion time: 0s. Unique request ID: 108 | 2016-10-11 15:24:27 Removed historical data download ID 108 | 2016-10-11 15:24:27 Mapping QMV15 to QMV15. Service code: nymex | 2016-10-11 15:24:27 HD Request # 112 | Downloading Historical Daily chart data for QMV15. Starting date: 2015-09-18. Service: tda | 2016-10-11 15:24:27 HD Request # 112 | Using user Barchart Historical data account. | 2016-10-11 15:24:27 HD Request # 112 | Requesting historical Daily data for QMV15 starting at 2015-09-17 | 2016-10-11 15:24:27 HD Request # 112 | Receiving historical Daily data for QMV15 starting at 2015-09-18 | 2016-10-11 15:24:27 HD Request # 112 | Writing historical Daily data to the file QMV15.dly | 2016-10-11 15:24:27 HD Request # 112 | Received 3 records from 2015-09-18 00:00:00 to 2015-09-21 00:00:00 (4.0 days) and wrote 2 records for QMV15 | 2016-10-11 15:24:27 HD Request # 112 | Daily download COMPLETE for QMV15. Completion time: 0s. Unique request ID: 109 | 2016-10-11 15:24:27 Removed historical data download ID 109 | 2016-10-11 15:24:27 Mapping QMX15 to QMX15. Service code: nymex | 2016-10-11 15:24:27 HD Request # 113 | Downloading Historical Daily chart data for QMX15. Starting date: 2015-10-16. Service: tda | 2016-10-11 15:24:27 HD Request # 113 | Using user Barchart Historical data account. | 2016-10-11 15:24:27 HD Request # 113 | Requesting historical Daily data for QMX15 starting at 2015-10-15 | 2016-10-11 15:24:27 HD Request # 113 | Receiving historical Daily data for QMX15 starting at 2015-10-16 | 2016-10-11 15:24:27 HD Request # 113 | Writing historical Daily data to the file QMX15.dly | 2016-10-11 15:24:27 HD Request # 113 | Received 3 records from 2015-10-16 00:00:00 to 2015-10-19 00:00:00 (4.0 days) and wrote 2 records for QMX15 | 2016-10-11 15:24:27 HD Request # 113 | Daily download COMPLETE for QMX15. Completion time: 0s. Unique request ID: 110 | 2016-10-11 15:24:27 Removed historical data download ID 110 | 2016-10-11 15:24:27 Mapping QMZ15 to QMZ15. Service code: nymex | 2016-10-11 15:24:27 HD Request # 114 | Downloading Historical Daily chart data for QMZ15. Starting date: 2015-11-18. Service: tda | 2016-10-11 15:24:27 HD Request # 114 | Using user Barchart Historical data account. | 2016-10-11 15:24:27 HD Request # 114 | Requesting historical Daily data for QMZ15 starting at 2015-11-17 | 2016-10-11 15:24:27 HD Request # 114 | Receiving historical Daily data for QMZ15 starting at 2015-11-18 | 2016-10-11 15:24:28 HD Request # 114 | Writing historical Daily data to the file QMZ15.dly | 2016-10-11 15:24:28 HD Request # 114 | Received 3 records from 2015-11-18 00:00:00 to 2015-11-19 00:00:00 (2.0 days) and wrote 2 records for QMZ15 | 2016-10-11 15:24:28 HD Request # 114 | Daily download COMPLETE for QMZ15. Completion time: 0s. Unique request ID: 111 | 2016-10-11 15:24:28 Removed historical data download ID 111 | 2016-10-11 15:24:28 Mapping QMF16 to QMF16. Service code: nymex | 2016-10-11 15:24:28 HD Request # 115 | Downloading Historical Daily chart data for QMF16. Starting date: 2015-12-17. Service: tda | 2016-10-11 15:24:28 HD Request # 115 | Using user Barchart Historical data account. | 2016-10-11 15:24:28 HD Request # 115 | Requesting historical Daily data for QMF16 starting at 2015-12-16 | 2016-10-11 15:24:28 HD Request # 115 | Receiving historical Daily data for QMF16 starting at 2015-12-17 | 2016-10-11 15:24:28 HD Request # 115 | Writing historical Daily data to the file QMF16.dly | 2016-10-11 15:24:28 HD Request # 115 | Received 3 records from 2015-12-17 00:00:00 to 2015-12-18 00:00:00 (2.0 days) and wrote 2 records for QMF16 | 2016-10-11 15:24:28 HD Request # 115 | Daily download COMPLETE for QMF16. Completion time: 1s. Unique request ID: 112 | 2016-10-11 15:24:28 Removed historical data download ID 112 | 2016-10-11 15:24:28 Mapping QMG16 to QMG16. Service code: nymex | 2016-10-11 15:24:28 HD Request # 116 | Downloading Historical Daily chart data for QMG16. Starting date: 2016-01-15. Service: tda | 2016-10-11 15:24:28 HD Request # 116 | Using user Barchart Historical data account. | 2016-10-11 15:24:28 HD Request # 116 | Requesting historical Daily data for QMG16 starting at 2016-01-14 | 2016-10-11 15:24:28 HD Request # 116 | Receiving historical Daily data for QMG16 starting at 2016-01-15 | 2016-10-11 15:24:29 HD Request # 116 | Writing historical Daily data to the file QMG16.dly | 2016-10-11 15:24:29 HD Request # 116 | Received 3 records from 2016-01-15 00:00:00 to 2016-01-19 00:00:00 (5.0 days) and wrote 2 records for QMG16 | 2016-10-11 15:24:29 HD Request # 116 | Daily download COMPLETE for QMG16. Completion time: 0s. Unique request ID: 113 | 2016-10-11 15:24:29 Removed historical data download ID 113 | 2016-10-11 15:24:29 Mapping QMH16 to QMH16. Service code: nymex | 2016-10-11 15:24:29 HD Request # 117 | Downloading Historical Daily chart data for QMH16. Starting date: 2016-02-18. Service: tda | 2016-10-11 15:24:29 HD Request # 117 | Using user Barchart Historical data account. | 2016-10-11 15:24:29 HD Request # 117 | Requesting historical Daily data for QMH16 starting at 2016-02-17 | 2016-10-11 15:24:29 HD Request # 117 | Receiving historical Daily data for QMH16 starting at 2016-02-18 | 2016-10-11 15:24:29 HD Request # 117 | Writing historical Daily data to the file QMH16.dly | 2016-10-11 15:24:29 HD Request # 117 | Received 3 records from 2016-02-18 00:00:00 to 2016-02-19 00:00:00 (2.0 days) and wrote 2 records for QMH16 | 2016-10-11 15:24:29 HD Request # 117 | Daily download COMPLETE for QMH16. Completion time: 0s. Unique request ID: 114 | 2016-10-11 15:24:29 Removed historical data download ID 114 | 2016-10-11 15:24:29 Mapping QMJ16 to QMJ16. Service code: nymex | 2016-10-11 15:24:29 HD Request # 118 | Downloading Historical Daily chart data for QMJ16. Starting date: 2016-03-17. Service: tda | 2016-10-11 15:24:29 HD Request # 118 | Using user Barchart Historical data account. | 2016-10-11 15:24:29 HD Request # 118 | Requesting historical Daily data for QMJ16 starting at 2016-03-16 | 2016-10-11 15:24:29 HD Request # 118 | Receiving historical Daily data for QMJ16 starting at 2016-03-17 | 2016-10-11 15:24:29 HD Request # 118 | Writing historical Daily data to the file QMJ16.dly | 2016-10-11 15:24:29 HD Request # 118 | Received 3 records from 2016-03-17 00:00:00 to 2016-03-18 00:00:00 (2.0 days) and wrote 2 records for QMJ16 | 2016-10-11 15:24:29 HD Request # 118 | Daily download COMPLETE for QMJ16. Completion time: 0s. Unique request ID: 115 | 2016-10-11 15:24:29 Removed historical data download ID 115 | 2016-10-11 15:24:29 Mapping QMK16 to QMK16. Service code: nymex | 2016-10-11 15:24:29 HD Request # 119 | Downloading Historical Daily chart data for QMK16. Starting date: 2016-04-18. Service: tda | 2016-10-11 15:24:29 HD Request # 119 | Using user Barchart Historical data account. | 2016-10-11 15:24:29 HD Request # 119 | Requesting historical Daily data for QMK16 starting at 2016-04-17 | 2016-10-11 15:24:29 HD Request # 119 | Receiving historical Daily data for QMK16 starting at 2016-04-18 | 2016-10-11 15:24:30 HD Request # 119 | Writing historical Daily data to the file QMK16.dly | 2016-10-11 15:24:30 HD Request # 119 | Received 2 records from 2016-04-18 00:00:00 to 2016-04-19 00:00:00 (2.0 days) and wrote 2 records for QMK16 | 2016-10-11 15:24:30 HD Request # 119 | Daily download COMPLETE for QMK16. Completion time: 0s. Unique request ID: 116 | 2016-10-11 15:24:30 Removed historical data download ID 116 | 2016-10-11 15:24:30 Mapping QMM16 to QMM16. Service code: nymex | 2016-10-11 15:24:30 HD Request # 120 | Downloading Historical Daily chart data for QMM16. Starting date: 2016-05-18. Service: tda | 2016-10-11 15:24:30 HD Request # 120 | Using user Barchart Historical data account. | 2016-10-11 15:24:30 HD Request # 120 | Requesting historical Daily data for QMM16 starting at 2016-05-17 | 2016-10-11 15:24:30 HD Request # 120 | Receiving historical Daily data for QMM16 starting at 2016-05-18 | 2016-10-11 15:24:30 HD Request # 120 | Writing historical Daily data to the file QMM16.dly | 2016-10-11 15:24:30 HD Request # 120 | Received 3 records from 2016-05-18 00:00:00 to 2016-05-19 00:00:00 (2.0 days) and wrote 2 records for QMM16 | 2016-10-11 15:24:30 HD Request # 120 | Daily download COMPLETE for QMM16. Completion time: 1s. Unique request ID: 117 | 2016-10-11 15:24:30 Removed historical data download ID 117 | 2016-10-11 15:24:30 Mapping QMN16 to QMN16. Service code: nymex | 2016-10-11 15:24:30 HD Request # 121 | Downloading Historical Daily chart data for QMN16. Starting date: 2016-06-17. Service: tda | 2016-10-11 15:24:30 HD Request # 121 | Using user Barchart Historical data account. | 2016-10-11 15:24:30 HD Request # 121 | Requesting historical Daily data for QMN16 starting at 2016-06-16 | 2016-10-11 15:24:30 HD Request # 121 | Receiving historical Daily data for QMN16 starting at 2016-06-17 | 2016-10-11 15:24:30 HD Request # 121 | Writing historical Daily data to the file QMN16.dly | 2016-10-11 15:24:30 HD Request # 121 | Received 3 records from 2016-06-17 00:00:00 to 2016-06-20 00:00:00 (4.0 days) and wrote 2 records for QMN16 | 2016-10-11 15:24:30 HD Request # 121 | Daily download COMPLETE for QMN16. Completion time: 0s. Unique request ID: 118 | 2016-10-11 15:24:30 Removed historical data download ID 118 | 2016-10-11 15:24:30 Mapping QMQ16 to QMQ16. Service code: nymex | 2016-10-11 15:24:30 HD Request # 122 | Downloading Historical Daily chart data for QMQ16. Starting date: 2016-07-18. Service: tda | 2016-10-11 15:24:30 HD Request # 122 | Using user Barchart Historical data account. | 2016-10-11 15:24:30 HD Request # 122 | Requesting historical Daily data for QMQ16 starting at 2016-07-17 | 2016-10-11 15:24:30 HD Request # 122 | Receiving historical Daily data for QMQ16 starting at 2016-07-18 | 2016-10-11 15:24:31 HD Request # 122 | Writing historical Daily data to the file QMQ16.dly | 2016-10-11 15:24:31 HD Request # 122 | Received 2 records from 2016-07-18 00:00:00 to 2016-07-19 00:00:00 (2.0 days) and wrote 2 records for QMQ16 | 2016-10-11 15:24:31 HD Request # 122 | Daily download COMPLETE for QMQ16. Completion time: 0s. Unique request ID: 119 | 2016-10-11 15:24:31 Removed historical data download ID 119 | 2016-10-11 15:24:31 HD Request # 123 | Downloading Historical Daily chart data for QMU16. Starting date: 2016-08-18. Service: tda | 2016-10-11 15:24:31 HD Request # 123 | Using user Barchart Historical data account. | 2016-10-11 15:24:31 HD Request # 123 | Requesting historical Daily data for QMU16 starting at 2016-08-17 | 2016-10-11 15:24:31 HD Request # 123 | Receiving historical Daily data for QMU16 starting at 2016-08-18 | 2016-10-11 15:24:31 HD Request # 123 | Writing historical Daily data to the file QMU16.dly | 2016-10-11 15:24:31 HD Request # 123 | Received 3 records from 2016-08-18 00:00:00 to 2016-08-19 00:00:00 (2.0 days) and wrote 2 records for QMU16 | 2016-10-11 15:24:31 HD Request # 123 | Daily download COMPLETE for QMU16. Completion time: 0s. Unique request ID: 120 | 2016-10-11 15:24:31 Removed historical data download ID 120 | 2016-10-11 15:24:31 HD Request # 124 | Downloading Historical Daily chart data for QMV16. Starting date: 2016-09-16. Service: tda | 2016-10-11 15:24:31 HD Request # 124 | Using user Barchart Historical data account. | 2016-10-11 15:24:31 HD Request # 124 | Requesting historical Daily data for QMV16 starting at 2016-09-15 | 2016-10-11 15:24:31 HD Request # 124 | Receiving historical Daily data for QMV16 starting at 2016-09-16 | 2016-10-11 15:24:31 HD Request # 124 | Writing historical Daily data to the file QMV16.dly | 2016-10-11 15:24:31 HD Request # 124 | Received 3 records from 2016-09-16 00:00:00 to 2016-09-19 00:00:00 (4.0 days) and wrote 2 records for QMV16 | 2016-10-11 15:24:31 HD Request # 124 | Daily download COMPLETE for QMV16. Completion time: 1s. Unique request ID: 121 | 2016-10-11 15:24:31 Removed historical data download ID 121 | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Reloading chart. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Performing continuous futures contract back adjustment calculations. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMV06 Open price on 2006-09-20 is 63.9. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMX06 Open price on 2006-09-20 is 62.15. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMV06 price difference to QMX06 is -1.75. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMX06 Open price on 2006-10-20 is 57.8. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMZ06 Open price on 2006-10-20 is 60.6. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMX06 price difference to QMZ06 is 2.8. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMZ06 Open price on 2006-11-21 is 58.75. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMF07 Open price on 2006-11-21 is 58.95. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMZ06 price difference to QMF07 is 0.2. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMF07 Open price on 2006-12-20 is 63.25. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMG07 Open price on 2006-12-20 is 63.4. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMF07 price difference to QMG07 is 0.15. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMG07 Open price on 2007-01-22 is 50.475. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMH07 Open price on 2007-01-22 is 53.575. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMG07 price difference to QMH07 is 3.1. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMH07 Open price on 2007-02-20 is 58. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMJ07 Open price on 2007-02-20 is 59.55. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMH07 price difference to QMJ07 is 1.55. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMJ07 Open price on 2007-03-20 is 57.25. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMK07 Open price on 2007-03-20 is 59.9. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMJ07 price difference to QMK07 is 2.65. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMK07 Open price on 2007-04-20 is 62.625. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMM07 Open price on 2007-04-20 is 63.075. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMK07 price difference to QMM07 is 0.45. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMM07 Open price on 2007-05-22 is 64.95. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMN07 Open price on 2007-05-22 is 66.825. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMM07 price difference to QMN07 is 1.875. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMN07 Open price on 2007-06-20 is 69.1. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMQ07 Open price on 2007-06-20 is 69.425. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMN07 price difference to QMQ07 is 0.325. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMQ07 Open price on 2007-07-20 is 74.875. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMU07 Open price on 2007-07-20 is 76.1. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMQ07 price difference to QMU07 is 1.225. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMU07 Open price on 2007-08-21 is 71.95. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMV07 Open price on 2007-08-21 is 70.95. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMU07 price difference to QMV07 is -1. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMV07 Open price on 2007-09-20 is 82.2. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMX07 Open price on 2007-09-20 is 80.525. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMV07 price difference to QMX07 is -1.675. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMX07 Open price on 2007-10-22 is 89.775. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMZ07 Open price on 2007-10-22 is 86.875. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMX07 price difference to QMZ07 is -2.9. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMZ07 Open price on 2007-11-20 is 94.1. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMF08 Open price on 2007-11-20 is 94.825. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMZ07 price difference to QMF08 is 0.725. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMF08 Open price on 2007-12-20 is 91.375. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMG08 Open price on 2007-12-20 is 91.4. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMF08 price difference to QMG08 is 0.025. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMG08 Open price on 2008-01-22 is 89.85. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMH08 Open price on 2008-01-22 is 89.8. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMG08 price difference to QMH08 is -0.05. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMH08 Open price on 2008-02-20 is 95.4. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMJ08 Open price on 2008-02-20 is 99.55. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMH08 price difference to QMJ08 is 4.15. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMJ08 Open price on 2008-03-20 is 106. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMK08 Open price on 2008-03-20 is 102.1. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMJ08 price difference to QMK08 is -3.9. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMK08 Open price on 2008-04-22 is 116.625. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMM08 Open price on 2008-04-22 is 116.675. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMK08 price difference to QMM08 is 0.05. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMM08 Open price on 2008-05-20 is 126.3. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMN08 Open price on 2008-05-20 is 126.825. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMM08 price difference to QMN08 is 0.525. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMN08 Open price on 2008-06-20 is 136.1. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMQ08 Open price on 2008-06-20 is 132.275. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMN08 price difference to QMQ08 is -3.825. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMQ08 Open price on 2008-07-22 is 129.125. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMU08 Open price on 2008-07-22 is 131.9. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMQ08 price difference to QMU08 is 2.775. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMU08 Open price on 2008-08-20 is 113.175. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMV08 Open price on 2008-08-20 is 115.15. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMU08 price difference to QMV08 is 1.975. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMV08 Open price on 2008-09-22 is 98.05. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMX08 Open price on 2008-09-22 is 102.15. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMV08 price difference to QMX08 is 4.1. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMX08 Open price on 2008-10-21 is 72.3. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMZ08 Open price on 2008-10-21 is 75.8. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMX08 price difference to QMZ08 is 3.5. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMZ08 Open price on 2008-11-20 is 54.5. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMF09 Open price on 2008-11-20 is 53.6. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMZ08 price difference to QMF09 is -0.9. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMF09 Open price on 2008-12-22 is 40.2. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMG09 Open price on 2008-12-22 is 42.7. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMF09 price difference to QMG09 is 2.5. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMG09 Open price on 2009-01-20 is 35.4. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMH09 Open price on 2009-01-20 is 42.575. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMG09 price difference to QMH09 is 7.175. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMH09 Open price on 2009-02-20 is 34.75. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMJ09 Open price on 2009-02-20 is 39.55. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMH09 price difference to QMJ09 is 4.8. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMJ09 Open price on 2009-03-20 is 49.8. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMK09 Open price on 2009-03-20 is 51.775. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMJ09 price difference to QMK09 is 1.975. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMK09 Open price on 2009-04-21 is 50.05. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMM09 Open price on 2009-04-21 is 48.3. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMK09 price difference to QMM09 is -1.75. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMM09 Open price on 2009-05-20 is 56.425. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMN09 Open price on 2009-05-20 is 60.225. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMM09 price difference to QMN09 is 3.8. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMN09 Open price on 2009-06-22 is 71.45. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMQ09 Open price on 2009-06-22 is 70.15. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMN09 price difference to QMQ09 is -1.3. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMQ09 Open price on 2009-07-21 is 63.525. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMU09 Open price on 2009-07-21 is 65.4. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMQ09 price difference to QMU09 is 1.875. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMU09 Open price on 2009-08-20 is 70.225. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMV09 Open price on 2009-08-20 is 73.5. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMU09 price difference to QMV09 is 3.275. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMV09 Open price on 2009-09-22 is 72.05. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMX09 Open price on 2009-09-22 is 69.875. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMV09 price difference to QMX09 is -2.175. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMX09 Open price on 2009-10-20 is 78.85. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMZ09 Open price on 2009-10-20 is 80. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMX09 price difference to QMZ09 is 1.15. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMZ09 Open price on 2009-11-20 is 79.7. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMF10 Open price on 2009-11-20 is 78.475. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMZ09 price difference to QMF10 is -1.225. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMF10 Open price on 2009-12-22 is 72.85. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMG10 Open price on 2009-12-22 is 73.5. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMF10 price difference to QMG10 is 0.65. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMG10 Open price on 2010-01-20 is 77.825. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMH10 Open price on 2010-01-20 is 79.175. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMG10 price difference to QMH10 is 1.35. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMH10 Open price on 2010-02-22 is 78.325. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMJ10 Open price on 2010-02-22 is 80.3. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMH10 price difference to QMJ10 is 1.975. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMJ10 Open price on 2010-03-22 is 82.2. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMK10 Open price on 2010-03-22 is 80.875. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMJ10 price difference to QMK10 is -1.325. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMK10 Open price on 2010-04-20 is 82.975. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMM10 Open price on 2010-04-20 is 83.275. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMK10 price difference to QMM10 is 0.3. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMM10 Open price on 2010-05-20 is 69.025. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMN10 Open price on 2010-05-20 is 72.825. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMM10 price difference to QMN10 is 3.8. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMN10 Open price on 2010-06-22 is 77.9. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMQ10 Open price on 2010-06-22 is 78.175. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMN10 price difference to QMQ10 is 0.275. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMQ10 Open price on 2010-07-20 is 75.625. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMU10 Open price on 2010-07-20 is 76.725. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMQ10 price difference to QMU10 is 1.1. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMU10 Open price on 2010-08-20 is 75.2. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMV10 Open price on 2010-08-20 is 74.8. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMU10 price difference to QMV10 is -0.4. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMV10 Open price on 2010-09-21 is 73.575. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMX10 Open price on 2010-09-21 is 76.25. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMV10 price difference to QMX10 is 2.675. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMX10 Open price on 2010-10-20 is 82.95. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMZ10 Open price on 2010-10-20 is 79.975. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMX10 price difference to QMZ10 is -2.975. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMZ10 Open price on 2010-11-22 is 80.4. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMF11 Open price on 2010-11-22 is 82.2. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMZ10 price difference to QMF11 is 1.8. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMF11 Open price on 2010-12-21 is 87.925. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMG11 Open price on 2010-12-21 is 89.175. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMF11 price difference to QMG11 is 1.25. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMG11 Open price on 2011-01-20 is 91.225. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMH11 Open price on 2011-01-20 is 91.6. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMG11 price difference to QMH11 is 0.375. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMH11 Open price on 2011-02-22 is 86.45. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMJ11 Open price on 2011-02-22 is 90.1. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMH11 price difference to QMJ11 is 3.65. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMJ11 Open price on 2011-03-22 is 102.05. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMK11 Open price on 2011-03-22 is 102.7. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMJ11 price difference to QMK11 is 0.65. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMK11 Open price on 2011-04-20 is 109.35. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMM11 Open price on 2011-04-20 is 108.425. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMK11 price difference to QMM11 is -0.925. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMM11 Open price on 2011-05-20 is 99.675. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMN11 Open price on 2011-05-20 is 99.1. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMM11 price difference to QMN11 is -0.575. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMN11 Open price on 2011-06-21 is 92.875. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMQ11 Open price on 2011-06-21 is 93.825. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMN11 price difference to QMQ11 is 0.95. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMQ11 Open price on 2011-07-20 is 96.125. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMU11 Open price on 2011-07-20 is 98.475. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMQ11 price difference to QMU11 is 2.35. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMU11 Open price on 2011-08-22 is 81.45. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMV11 Open price on 2011-08-22 is 82.4. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMU11 price difference to QMV11 is 0.95. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMV11 Open price on 2011-09-20 is 87.25. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMX11 Open price on 2011-09-20 is 86. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMV11 price difference to QMX11 is -1.25. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMX11 Open price on 2011-10-20 is 88.2. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMZ11 Open price on 2011-10-20 is 86.2. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMX11 price difference to QMZ11 is -2. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMZ11 Open price on 2011-11-22 is 101.675. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMF12 Open price on 2011-11-22 is 97.125. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMZ11 price difference to QMF12 is -4.55. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMF12 Open price on 2011-12-20 is 93.625. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMG12 Open price on 2011-12-20 is 94.275. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMF12 price difference to QMG12 is 0.65. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMG12 Open price on 2012-01-20 is 101.1. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMH12 Open price on 2012-01-20 is 100.575. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMG12 price difference to QMH12 is -0.525. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMH12 Open price on 2012-02-21 is 102.3. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMJ12 Open price on 2012-02-21 is 104.55. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMH12 price difference to QMJ12 is 2.25. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMJ12 Open price on 2012-03-20 is 107.225. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMK12 Open price on 2012-03-20 is 108.35. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMJ12 price difference to QMK12 is 1.125. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMK12 Open price on 2012-04-20 is 102.75. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMM12 Open price on 2012-04-20 is 103. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMK12 price difference to QMM12 is 0.25. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMM12 Open price on 2012-05-22 is 91.35. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMN12 Open price on 2012-05-22 is 93. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMM12 price difference to QMN12 is 1.65. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMN12 Open price on 2012-06-20 is 83. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMQ12 Open price on 2012-06-20 is 84.25. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMN12 price difference to QMQ12 is 1.25. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMQ12 Open price on 2012-07-20 is 89.975. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMU12 Open price on 2012-07-20 is 92.6. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMQ12 price difference to QMU12 is 2.625. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMU12 Open price on 2012-08-21 is 96.375. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMV12 Open price on 2012-08-21 is 96.175. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMU12 price difference to QMV12 is -0.2. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMV12 Open price on 2012-09-20 is 95.525. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMX12 Open price on 2012-09-20 is 92.25. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMV12 price difference to QMX12 is -3.275. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMX12 Open price on 2012-10-22 is 92.05. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMZ12 Open price on 2012-10-22 is 90.175. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMX12 price difference to QMZ12 is -1.875. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMZ12 Open price on 2012-11-20 is 86.35. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMF13 Open price on 2012-11-20 is 89.1. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMZ12 price difference to QMF13 is 2.75. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMF13 Open price on 2012-12-20 is 87.4. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMG13 Open price on 2012-12-20 is 89.625. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMF13 price difference to QMG13 is 2.225. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMG13 Open price on 2013-01-22 is 95.2. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMH13 Open price on 2013-01-22 is 95.75. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMG13 price difference to QMH13 is 0.55. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMH13 Open price on 2013-02-20 is 95.95. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMJ13 Open price on 2013-02-20 is 97.1. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMH13 price difference to QMJ13 is 1.15. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMJ13 Open price on 2013-03-20 is 93.925. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMK13 Open price on 2013-03-20 is 92.45. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMJ13 price difference to QMK13 is -1.475. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMK13 Open price on 2013-04-22 is 88.275. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMM13 Open price on 2013-04-22 is 88.1. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMK13 price difference to QMM13 is -0.175. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMM13 Open price on 2013-05-21 is 96.15. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMN13 Open price on 2013-05-21 is 96.875. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMM13 price difference to QMN13 is 0.725. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMN13 Open price on 2013-06-20 is 98.575. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMQ13 Open price on 2013-06-20 is 98.2. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMN13 price difference to QMQ13 is -0.375. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMQ13 Open price on 2013-07-22 is 108.075. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMU13 Open price on 2013-07-22 is 108.025. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMQ13 price difference to QMU13 is -0.05. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMU13 Open price on 2013-08-20 is 107.625. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMV13 Open price on 2013-08-20 is 106.7. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMU13 price difference to QMV13 is -0.925. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMV13 Open price on 2013-09-20 is 108.425. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMX13 Open price on 2013-09-20 is 105.775. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMV13 price difference to QMX13 is -2.65. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMX13 Open price on 2013-10-22 is 100.8. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMZ13 Open price on 2013-10-22 is 99.55. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMX13 price difference to QMZ13 is -1.25. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMZ13 Open price on 2013-11-20 is 93.075. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMF14 Open price on 2013-11-20 is 93.875. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMZ13 price difference to QMF14 is 0.8. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMF14 Open price on 2013-12-20 is 97.325. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMG14 Open price on 2013-12-20 is 98.675. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMF14 price difference to QMG14 is 1.35. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMG14 Open price on 2014-01-21 is 94.1. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMH14 Open price on 2014-01-21 is 94.25. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMG14 price difference to QMH14 is 0.15. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMH14 Open price on 2014-02-20 is 103.1. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMJ14 Open price on 2014-02-20 is 102.9. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMH14 price difference to QMJ14 is -0.2. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMJ14 Open price on 2014-03-20 is 99.475. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMK14 Open price on 2014-03-20 is 99.15. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMJ14 price difference to QMK14 is -0.325. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMK14 Open price on 2014-04-22 is 104.45. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMM14 Open price on 2014-04-22 is 103.625. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMK14 price difference to QMM14 is -0.825. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMM14 Open price on 2014-05-20 is 102.025. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMN14 Open price on 2014-05-20 is 102.1. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMM14 price difference to QMN14 is 0.075. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMN14 Open price on 2014-06-20 is 106.05. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMQ14 Open price on 2014-06-20 is 106.075. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMN14 price difference to QMQ14 is 0.025. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMQ14 Open price on 2014-07-22 is 102.95. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMU14 Open price on 2014-07-22 is 102.75. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMQ14 price difference to QMU14 is -0.2. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMU14 Open price on 2014-08-20 is 96.6. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMV14 Open price on 2014-08-20 is 92.85. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMU14 price difference to QMV14 is -3.75. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMV14 Open price on 2014-09-22 is 92.975. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMX14 Open price on 2014-09-22 is 91.625. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMV14 price difference to QMX14 is -1.35. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMX14 Open price on 2014-10-21 is 83.1. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMZ14 Open price on 2014-10-21 is 81.85. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMX14 price difference to QMZ14 is -1.25. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMZ14 Open price on 2014-11-20 is 74.225. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMF15 Open price on 2014-11-20 is 74.325. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMZ14 price difference to QMF15 is 0.1. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMF15 Open price on 2014-12-22 is 55.8. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMG15 Open price on 2014-12-22 is 57.675. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMF15 price difference to QMG15 is 1.875. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMG15 Open price on 2015-01-20 is 46.25. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMH15 Open price on 2015-01-20 is 49.125. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMG15 price difference to QMH15 is 2.875. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMH15 Open price on 2015-02-20 is 50.575. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMJ15 Open price on 2015-02-20 is 52.175. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMH15 price difference to QMJ15 is 1.6. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMJ15 Open price on 2015-03-20 is 44.575. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMK15 Open price on 2015-03-20 is 45.6. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMJ15 price difference to QMK15 is 1.025. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMK15 Open price on 2015-04-21 is 56.075. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMM15 Open price on 2015-04-21 is 57.925. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMK15 price difference to QMM15 is 1.85. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMM15 Open price on 2015-05-20 is 59.85. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMN15 Open price on 2015-05-20 is 58.325. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMM15 price difference to QMN15 is -1.525. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMN15 Open price on 2015-06-22 is 60.45. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMQ15 Open price on 2015-06-22 is 59.75. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMN15 price difference to QMQ15 is -0.7. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMQ15 Open price on 2015-07-21 is 50.725. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMU15 Open price on 2015-07-21 is 50.25. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMQ15 price difference to QMU15 is -0.475. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMU15 Open price on 2015-08-20 is 42.425. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMV15 Open price on 2015-08-20 is 40.95. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMU15 price difference to QMV15 is -1.475. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMV15 Open price on 2015-09-22 is 44.85. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMX15 Open price on 2015-09-22 is 46.7. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMV15 price difference to QMX15 is 1.85. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMX15 Open price on 2015-10-20 is 47.1. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMZ15 Open price on 2015-10-20 is 46.575. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMX15 price difference to QMZ15 is -0.525. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMZ15 Open price on 2015-11-20 is 40.7. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMF16 Open price on 2015-11-20 is 41.875. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMZ15 price difference to QMF16 is 1.175. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMF16 Open price on 2015-12-22 is 34.8. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMG16 Open price on 2015-12-22 is 35.85. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMF16 price difference to QMG16 is 1.05. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMG16 Open price on 2016-01-20 is 29.35. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMH16 Open price on 2016-01-20 is 29.475. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMG16 price difference to QMH16 is 0.125. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMH16 Open price on 2016-02-22 is 30.675. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMJ16 Open price on 2016-02-22 is 31.95. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMH16 price difference to QMJ16 is 1.275. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMJ16 Open price on 2016-03-22 is 40.25. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMK16 Open price on 2016-03-22 is 41.6. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMJ16 price difference to QMK16 is 1.35. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMK16 Open price on 2016-04-20 is 39.975. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMM16 Open price on 2016-04-20 is 42.35. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMK16 price difference to QMM16 is 2.375. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMM16 Open price on 2016-05-20 is 47.9. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMN16 Open price on 2016-05-20 is 48.725. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMM16 price difference to QMN16 is 0.825. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMN16 Open price on 2016-06-21 is 48.35. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMQ16 Open price on 2016-06-21 is 49.775. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMN16 price difference to QMQ16 is 1.425. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMQ16 Open price on 2016-07-20 is 45.175. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMU16 Open price on 2016-07-20 is 45.475. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMQ16 price difference to QMU16 is 0.3. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMU16 Open price on 2016-08-22 is 48.375. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMV16 Open price on 2016-08-22 is 49.05. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMU16 price difference to QMV16 is 0.675. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMV16 Open price on 2016-09-20 is 43.2. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMX16 Open price on 2016-09-20 is 43.75. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMV16 price difference to QMX16 is 0.55. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMX16 Open price on 2016-10-11 is 51.125. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMZ16 Open price on 2016-10-11 is 51.65. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | QMX16 price difference to QMZ16 is 0.525. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMV06 is 63.4. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMX06 is 65.15. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMZ06 is 62.35. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMF07 is 62.15. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMG07 is 62. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMH07 is 58.9. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMJ07 is 57.35. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMK07 is 54.7. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMM07 is 54.25. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMN07 is 52.375. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMQ07 is 52.05. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMU07 is 50.825. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMV07 is 51.825. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMX07 is 53.5. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMZ07 is 56.4. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMF08 is 55.675. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMG08 is 55.65. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMH08 is 55.7. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMJ08 is 51.55. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMK08 is 55.45. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMM08 is 55.4. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMN08 is 54.875. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMQ08 is 58.7. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMU08 is 55.925. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMV08 is 53.95. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMX08 is 49.85. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMZ08 is 46.35. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMF09 is 47.25. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMG09 is 44.75. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMH09 is 37.575. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMJ09 is 32.775. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMK09 is 30.8. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMM09 is 32.55. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMN09 is 28.75. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMQ09 is 30.05. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMU09 is 28.175. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMV09 is 24.9. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMX09 is 27.075. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMZ09 is 25.925. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMF10 is 27.15. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMG10 is 26.5. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMH10 is 25.15. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMJ10 is 23.175. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMK10 is 24.5. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMM10 is 24.2. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMN10 is 20.4. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMQ10 is 20.125. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMU10 is 19.025. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMV10 is 19.425. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMX10 is 16.75. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMZ10 is 19.725. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMF11 is 17.925. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMG11 is 16.675. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMH11 is 16.3. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMJ11 is 12.65. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMK11 is 12. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMM11 is 12.925. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMN11 is 13.5. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMQ11 is 12.55. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMU11 is 10.2. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMV11 is 9.25. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMX11 is 10.5. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMZ11 is 12.5. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMF12 is 17.05. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMG12 is 16.4. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMH12 is 16.925. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMJ12 is 14.675. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMK12 is 13.55. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMM12 is 13.3. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMN12 is 11.65. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMQ12 is 10.4. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMU12 is 7.775. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMV12 is 7.975. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMX12 is 11.25. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMZ12 is 13.125. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMF13 is 10.375. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMG13 is 8.15. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMH13 is 7.6. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMJ13 is 6.45. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMK13 is 7.925. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMM13 is 8.1. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMN13 is 7.375. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMQ13 is 7.75. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMU13 is 7.8. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMV13 is 8.725. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMX13 is 11.375. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMZ13 is 12.625. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMF14 is 11.825. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMG14 is 10.475. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMH14 is 10.325. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMJ14 is 10.525. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMK14 is 10.85. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMM14 is 11.675. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMN14 is 11.6. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMQ14 is 11.575. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMU14 is 11.775. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMV14 is 15.525. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMX14 is 16.875. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMZ14 is 18.125. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMF15 is 18.025. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMG15 is 16.15. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMH15 is 13.275. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMJ15 is 11.675. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMK15 is 10.65. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMM15 is 8.8. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMN15 is 10.325. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMQ15 is 11.025. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMU15 is 11.5. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMV15 is 12.975. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMX15 is 11.125. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMZ15 is 11.65. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMF16 is 10.475. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMG16 is 9.425. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMH16 is 9.3. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMJ16 is 8.025. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMK16 is 6.675. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMM16 is 4.3. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMN16 is 3.475. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMQ16 is 2.05. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMU16 is 1.75. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMV16 is 1.075. | 2016-10-11 15:24:31 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMX16 is 0.525. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | Reloading chart. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | Performing continuous futures contract back adjustment calculations. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMV15 Open price on 2015-09-22 is 44.85. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMX15 Open price on 2015-09-22 is 46.7. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMV15 price difference to QMX15 is 1.85. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMX15 Open price on 2015-10-20 is 47.1. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMZ15 Open price on 2015-10-20 is 46.575. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMX15 price difference to QMZ15 is -0.525. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMZ15 Open price on 2015-11-20 is 40.7. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMF16 Open price on 2015-11-20 is 41.875. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMZ15 price difference to QMF16 is 1.175. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMF16 Open price on 2015-12-22 is 34.8. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMG16 Open price on 2015-12-22 is 35.85. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMF16 price difference to QMG16 is 1.05. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMG16 Open price on 2016-01-20 is 29.35. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMH16 Open price on 2016-01-20 is 29.475. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMG16 price difference to QMH16 is 0.125. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMH16 Open price on 2016-02-22 is 30.675. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMJ16 Open price on 2016-02-22 is 31.95. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMH16 price difference to QMJ16 is 1.275. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMJ16 Open price on 2016-03-22 is 40.25. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMK16 Open price on 2016-03-22 is 41.6. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMJ16 price difference to QMK16 is 1.35. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMK16 Open price on 2016-04-20 is 39.975. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMM16 Open price on 2016-04-20 is 42.35. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMK16 price difference to QMM16 is 2.375. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMM16 Open price on 2016-05-20 is 47.9. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMN16 Open price on 2016-05-20 is 48.725. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMM16 price difference to QMN16 is 0.825. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMN16 Open price on 2016-06-21 is 48.35. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMQ16 Open price on 2016-06-21 is 49.775. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMN16 price difference to QMQ16 is 1.425. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMQ16 Open price on 2016-07-20 is 45.175. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMU16 Open price on 2016-07-20 is 45.475. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMQ16 price difference to QMU16 is 0.3. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMU16 Open price on 2016-08-22 is 48.375. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMV16 Open price on 2016-08-22 is 49.05. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMU16 price difference to QMV16 is 0.675. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMV16 Open price on 2016-09-20 is 43.2. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMX16 Open price on 2016-09-20 is 43.75. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMV16 price difference to QMX16 is 0.55. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMX16 Open price on 2016-10-11 is 51.125. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMZ16 Open price on 2016-10-11 is 51.65. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | QMX16 price difference to QMZ16 is 0.525. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | Back adjust amount for symbol QMV15 is 12.975. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | Back adjust amount for symbol QMX15 is 11.125. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | Back adjust amount for symbol QMZ15 is 11.65. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | Back adjust amount for symbol QMF16 is 10.475. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | Back adjust amount for symbol QMG16 is 9.425. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | Back adjust amount for symbol QMH16 is 9.3. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | Back adjust amount for symbol QMJ16 is 8.025. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | Back adjust amount for symbol QMK16 is 6.675. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | Back adjust amount for symbol QMM16 is 4.3. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | Back adjust amount for symbol QMN16 is 3.475. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | Back adjust amount for symbol QMQ16 is 2.05. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | Back adjust amount for symbol QMU16 is 1.75. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | Back adjust amount for symbol QMV16 is 1.075. | 2016-10-11 15:24:31 QMZ16 [CB] Daily #2 | Back adjust amount for symbol QMX16 is 0.525. | 2016-10-11 15:24:31 QMZ16 [CB] 30 Min #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2016-10-11 15:24:34 QMZ16 [CB] 30 Min #3 | Reloading chart. | 2016-10-11 15:24:34 QMZ16 [CB] 30 Min #3 | Performing continuous futures contract back adjustment calculations. | 2016-10-11 15:24:34 QMZ16 [CB] 30 Min #3 | QMN16 Open price on 2016-06-21 is 48.35. | 2016-10-11 15:24:34 QMZ16 [CB] 30 Min #3 | QMQ16 Open price on 2016-06-21 is 49.775. | 2016-10-11 15:24:34 QMZ16 [CB] 30 Min #3 | QMN16 price difference to QMQ16 is 1.425. | 2016-10-11 15:24:34 QMZ16 [CB] 30 Min #3 | QMQ16 Open price on 2016-07-20 is 45.175. | 2016-10-11 15:24:34 QMZ16 [CB] 30 Min #3 | QMU16 Open price on 2016-07-20 is 45.475. | 2016-10-11 15:24:34 QMZ16 [CB] 30 Min #3 | QMQ16 price difference to QMU16 is 0.3. | 2016-10-11 15:24:34 QMZ16 [CB] 30 Min #3 | QMU16 Open price on 2016-08-22 is 48.375. | 2016-10-11 15:24:34 QMZ16 [CB] 30 Min #3 | QMV16 Open price on 2016-08-22 is 49.05. | 2016-10-11 15:24:34 QMZ16 [CB] 30 Min #3 | QMU16 price difference to QMV16 is 0.675. | 2016-10-11 15:24:34 QMZ16 [CB] 30 Min #3 | QMV16 Open price on 2016-09-20 is 43.2. | 2016-10-11 15:24:34 QMZ16 [CB] 30 Min #3 | QMX16 Open price on 2016-09-20 is 43.75. | 2016-10-11 15:24:34 QMZ16 [CB] 30 Min #3 | QMV16 price difference to QMX16 is 0.55. | 2016-10-11 15:24:34 QMZ16 [CB] 30 Min #3 | QMX16 Open price on 2016-10-11 is 51.125. | 2016-10-11 15:24:34 QMZ16 [CB] 30 Min #3 | QMZ16 Open price on 2016-10-11 is 51.65. | 2016-10-11 15:24:34 QMZ16 [CB] 30 Min #3 | QMX16 price difference to QMZ16 is 0.525. | 2016-10-11 15:24:34 QMZ16 [CB] 30 Min #3 | Back adjust amount for symbol QMN16 is 3.475. | 2016-10-11 15:24:34 QMZ16 [CB] 30 Min #3 | Back adjust amount for symbol QMQ16 is 2.05. | 2016-10-11 15:24:34 QMZ16 [CB] 30 Min #3 | Back adjust amount for symbol QMU16 is 1.75. | 2016-10-11 15:24:34 QMZ16 [CB] 30 Min #3 | Back adjust amount for symbol QMV16 is 1.075. | 2016-10-11 15:24:34 QMZ16 [CB] 30 Min #3 | Back adjust amount for symbol QMX16 is 0.525. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Reloading chart. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMV06 to next contract occurs at 2006-09-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMX06 to next contract occurs at 2006-10-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMZ06 to next contract occurs at 2006-11-21. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMF07 to next contract occurs at 2006-12-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMG07 to next contract occurs at 2007-01-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMH07 to next contract occurs at 2007-02-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMJ07 to next contract occurs at 2007-03-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMK07 to next contract occurs at 2007-04-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMM07 to next contract occurs at 2007-05-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMN07 to next contract occurs at 2007-06-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMQ07 to next contract occurs at 2007-07-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMU07 to next contract occurs at 2007-08-21. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMV07 to next contract occurs at 2007-09-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMX07 to next contract occurs at 2007-10-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMZ07 to next contract occurs at 2007-11-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMF08 to next contract occurs at 2007-12-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMG08 to next contract occurs at 2008-01-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMH08 to next contract occurs at 2008-02-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMJ08 to next contract occurs at 2008-03-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMK08 to next contract occurs at 2008-04-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMM08 to next contract occurs at 2008-05-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMN08 to next contract occurs at 2008-06-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMQ08 to next contract occurs at 2008-07-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMU08 to next contract occurs at 2008-08-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMV08 to next contract occurs at 2008-09-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMX08 to next contract occurs at 2008-10-21. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMZ08 to next contract occurs at 2008-11-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMF09 to next contract occurs at 2008-12-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMG09 to next contract occurs at 2009-01-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMH09 to next contract occurs at 2009-02-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMJ09 to next contract occurs at 2009-03-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMK09 to next contract occurs at 2009-04-21. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMM09 to next contract occurs at 2009-05-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMN09 to next contract occurs at 2009-06-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMQ09 to next contract occurs at 2009-07-21. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMU09 to next contract occurs at 2009-08-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMV09 to next contract occurs at 2009-09-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMX09 to next contract occurs at 2009-10-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMZ09 to next contract occurs at 2009-11-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMF10 to next contract occurs at 2009-12-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMG10 to next contract occurs at 2010-01-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMH10 to next contract occurs at 2010-02-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMJ10 to next contract occurs at 2010-03-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMK10 to next contract occurs at 2010-04-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMM10 to next contract occurs at 2010-05-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMN10 to next contract occurs at 2010-06-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMQ10 to next contract occurs at 2010-07-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMU10 to next contract occurs at 2010-08-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMV10 to next contract occurs at 2010-09-21. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMX10 to next contract occurs at 2010-10-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMZ10 to next contract occurs at 2010-11-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMF11 to next contract occurs at 2010-12-21. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMG11 to next contract occurs at 2011-01-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMH11 to next contract occurs at 2011-02-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMJ11 to next contract occurs at 2011-03-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMK11 to next contract occurs at 2011-04-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMM11 to next contract occurs at 2011-05-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMN11 to next contract occurs at 2011-06-21. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMQ11 to next contract occurs at 2011-07-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMU11 to next contract occurs at 2011-08-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMV11 to next contract occurs at 2011-09-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMX11 to next contract occurs at 2011-10-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMZ11 to next contract occurs at 2011-11-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMF12 to next contract occurs at 2011-12-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMG12 to next contract occurs at 2012-01-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMH12 to next contract occurs at 2012-02-21. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMJ12 to next contract occurs at 2012-03-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMK12 to next contract occurs at 2012-04-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMM12 to next contract occurs at 2012-05-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMN12 to next contract occurs at 2012-06-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMQ12 to next contract occurs at 2012-07-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMU12 to next contract occurs at 2012-08-21. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMV12 to next contract occurs at 2012-09-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMX12 to next contract occurs at 2012-10-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMZ12 to next contract occurs at 2012-11-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMF13 to next contract occurs at 2012-12-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMG13 to next contract occurs at 2013-01-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMH13 to next contract occurs at 2013-02-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMJ13 to next contract occurs at 2013-03-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMK13 to next contract occurs at 2013-04-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMM13 to next contract occurs at 2013-05-21. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMN13 to next contract occurs at 2013-06-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMQ13 to next contract occurs at 2013-07-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMU13 to next contract occurs at 2013-08-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMV13 to next contract occurs at 2013-09-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMX13 to next contract occurs at 2013-10-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMZ13 to next contract occurs at 2013-11-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMF14 to next contract occurs at 2013-12-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMG14 to next contract occurs at 2014-01-21. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMH14 to next contract occurs at 2014-02-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMJ14 to next contract occurs at 2014-03-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMK14 to next contract occurs at 2014-04-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMM14 to next contract occurs at 2014-05-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMN14 to next contract occurs at 2014-06-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMQ14 to next contract occurs at 2014-07-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMU14 to next contract occurs at 2014-08-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMV14 to next contract occurs at 2014-09-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMX14 to next contract occurs at 2014-10-21. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMZ14 to next contract occurs at 2014-11-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMF15 to next contract occurs at 2014-12-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMG15 to next contract occurs at 2015-01-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMH15 to next contract occurs at 2015-02-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMJ15 to next contract occurs at 2015-03-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMK15 to next contract occurs at 2015-04-21. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMM15 to next contract occurs at 2015-05-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMN15 to next contract occurs at 2015-06-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMQ15 to next contract occurs at 2015-07-21. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMU15 to next contract occurs at 2015-08-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMV15 to next contract occurs at 2015-09-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMX15 to next contract occurs at 2015-10-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMZ15 to next contract occurs at 2015-11-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMF16 to next contract occurs at 2015-12-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMG16 to next contract occurs at 2016-01-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMH16 to next contract occurs at 2016-02-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMJ16 to next contract occurs at 2016-03-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMK16 to next contract occurs at 2016-04-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMM16 to next contract occurs at 2016-05-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMN16 to next contract occurs at 2016-06-21. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMQ16 to next contract occurs at 2016-07-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMU16 to next contract occurs at 2016-08-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMV16 to next contract occurs at 2016-09-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMX16 to next contract occurs at 2016-10-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Date rule based rollover from QMZ16 to next contract occurs at 2016-11-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMV06 for the date range from 2006-08-22 to 2006-09-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMV06 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMX06 for the date range from 2006-09-20 to 2006-10-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMX06 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMZ06 for the date range from 2006-10-20 to 2006-11-21. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMZ06 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMF07 for the date range from 2006-11-21 to 2006-12-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMF07 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMG07 for the date range from 2006-12-20 to 2007-01-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMG07 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMH07 for the date range from 2007-01-22 to 2007-02-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMH07 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMJ07 for the date range from 2007-02-20 to 2007-03-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMJ07 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMK07 for the date range from 2007-03-20 to 2007-04-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMK07 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMM07 for the date range from 2007-04-20 to 2007-05-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMM07 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMN07 for the date range from 2007-05-22 to 2007-06-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMN07 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMQ07 for the date range from 2007-06-20 to 2007-07-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMQ07 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMU07 for the date range from 2007-07-20 to 2007-08-21. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMU07 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMV07 for the date range from 2007-08-21 to 2007-09-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMV07 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMX07 for the date range from 2007-09-20 to 2007-10-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMX07 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMZ07 for the date range from 2007-10-22 to 2007-11-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMZ07 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMF08 for the date range from 2007-11-20 to 2007-12-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMF08 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMG08 for the date range from 2007-12-20 to 2008-01-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMG08 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMH08 for the date range from 2008-01-22 to 2008-02-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMH08 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMJ08 for the date range from 2008-02-20 to 2008-03-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMJ08 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMK08 for the date range from 2008-03-20 to 2008-04-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMK08 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMM08 for the date range from 2008-04-22 to 2008-05-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMM08 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMN08 for the date range from 2008-05-20 to 2008-06-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMN08 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMQ08 for the date range from 2008-06-20 to 2008-07-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMQ08 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMU08 for the date range from 2008-07-22 to 2008-08-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMU08 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMV08 for the date range from 2008-08-20 to 2008-09-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMV08 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMX08 for the date range from 2008-09-22 to 2008-10-21. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMX08 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMZ08 for the date range from 2008-10-21 to 2008-11-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMZ08 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMF09 for the date range from 2008-11-20 to 2008-12-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMF09 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMG09 for the date range from 2008-12-22 to 2009-01-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMG09 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMH09 for the date range from 2009-01-20 to 2009-02-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMH09 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMJ09 for the date range from 2009-02-20 to 2009-03-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMJ09 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMK09 for the date range from 2009-03-20 to 2009-04-21. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMK09 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMM09 for the date range from 2009-04-21 to 2009-05-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMM09 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMN09 for the date range from 2009-05-20 to 2009-06-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMN09 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMQ09 for the date range from 2009-06-22 to 2009-07-21. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMQ09 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMU09 for the date range from 2009-07-21 to 2009-08-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMU09 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMV09 for the date range from 2009-08-20 to 2009-09-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMV09 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMX09 for the date range from 2009-09-22 to 2009-10-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMX09 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMZ09 for the date range from 2009-10-20 to 2009-11-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMZ09 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMF10 for the date range from 2009-11-20 to 2009-12-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMF10 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMG10 for the date range from 2009-12-22 to 2010-01-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMG10 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMH10 for the date range from 2010-01-20 to 2010-02-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMH10 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMJ10 for the date range from 2010-02-22 to 2010-03-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMJ10 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMK10 for the date range from 2010-03-22 to 2010-04-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMK10 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMM10 for the date range from 2010-04-20 to 2010-05-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMM10 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMN10 for the date range from 2010-05-20 to 2010-06-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMN10 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMQ10 for the date range from 2010-06-22 to 2010-07-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMQ10 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMU10 for the date range from 2010-07-20 to 2010-08-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMU10 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMV10 for the date range from 2010-08-20 to 2010-09-21. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMV10 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMX10 for the date range from 2010-09-21 to 2010-10-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMX10 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMZ10 for the date range from 2010-10-20 to 2010-11-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMZ10 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMF11 for the date range from 2010-11-22 to 2010-12-21. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMF11 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMG11 for the date range from 2010-12-21 to 2011-01-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMG11 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMH11 for the date range from 2011-01-20 to 2011-02-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMH11 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMJ11 for the date range from 2011-02-22 to 2011-03-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMJ11 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMK11 for the date range from 2011-03-22 to 2011-04-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMK11 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMM11 for the date range from 2011-04-20 to 2011-05-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMM11 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMN11 for the date range from 2011-05-20 to 2011-06-21. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMN11 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMQ11 for the date range from 2011-06-21 to 2011-07-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMQ11 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMU11 for the date range from 2011-07-20 to 2011-08-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMU11 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMV11 for the date range from 2011-08-22 to 2011-09-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMV11 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMX11 for the date range from 2011-09-20 to 2011-10-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMX11 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMZ11 for the date range from 2011-10-20 to 2011-11-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMZ11 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMF12 for the date range from 2011-11-22 to 2011-12-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMF12 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMG12 for the date range from 2011-12-20 to 2012-01-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMG12 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMH12 for the date range from 2012-01-20 to 2012-02-21. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMH12 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMJ12 for the date range from 2012-02-21 to 2012-03-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMJ12 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMK12 for the date range from 2012-03-20 to 2012-04-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMK12 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMM12 for the date range from 2012-04-20 to 2012-05-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMM12 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMN12 for the date range from 2012-05-22 to 2012-06-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMN12 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMQ12 for the date range from 2012-06-20 to 2012-07-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMQ12 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMU12 for the date range from 2012-07-20 to 2012-08-21. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMU12 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMV12 for the date range from 2012-08-21 to 2012-09-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMV12 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMX12 for the date range from 2012-09-20 to 2012-10-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMX12 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMZ12 for the date range from 2012-10-22 to 2012-11-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMZ12 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMF13 for the date range from 2012-11-20 to 2012-12-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMF13 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMG13 for the date range from 2012-12-20 to 2013-01-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMG13 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMH13 for the date range from 2013-01-22 to 2013-02-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMH13 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMJ13 for the date range from 2013-02-20 to 2013-03-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMJ13 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMK13 for the date range from 2013-03-20 to 2013-04-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMK13 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMM13 for the date range from 2013-04-22 to 2013-05-21. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMM13 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMN13 for the date range from 2013-05-21 to 2013-06-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMN13 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMQ13 for the date range from 2013-06-20 to 2013-07-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMQ13 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMU13 for the date range from 2013-07-22 to 2013-08-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMU13 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMV13 for the date range from 2013-08-20 to 2013-09-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMV13 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMX13 for the date range from 2013-09-20 to 2013-10-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMX13 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMZ13 for the date range from 2013-10-22 to 2013-11-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMZ13 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMF14 for the date range from 2013-11-20 to 2013-12-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMF14 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMG14 for the date range from 2013-12-20 to 2014-01-21. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMG14 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMH14 for the date range from 2014-01-21 to 2014-02-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMH14 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMJ14 for the date range from 2014-02-20 to 2014-03-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMJ14 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMK14 for the date range from 2014-03-20 to 2014-04-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMK14 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMM14 for the date range from 2014-04-22 to 2014-05-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMM14 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMN14 for the date range from 2014-05-20 to 2014-06-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMN14 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMQ14 for the date range from 2014-06-20 to 2014-07-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMQ14 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMU14 for the date range from 2014-07-22 to 2014-08-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMU14 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMV14 for the date range from 2014-08-20 to 2014-09-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMV14 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMX14 for the date range from 2014-09-22 to 2014-10-21. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMX14 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMZ14 for the date range from 2014-10-21 to 2014-11-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMZ14 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMF15 for the date range from 2014-11-20 to 2014-12-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMF15 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMG15 for the date range from 2014-12-22 to 2015-01-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMG15 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMH15 for the date range from 2015-01-20 to 2015-02-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMH15 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMJ15 for the date range from 2015-02-20 to 2015-03-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMJ15 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMK15 for the date range from 2015-03-20 to 2015-04-21. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMK15 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMM15 for the date range from 2015-04-21 to 2015-05-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMM15 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMN15 for the date range from 2015-05-20 to 2015-06-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMN15 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMQ15 for the date range from 2015-06-22 to 2015-07-21. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMQ15 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMU15 for the date range from 2015-07-21 to 2015-08-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMU15 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMV15 for the date range from 2015-08-20 to 2015-09-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMV15 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMX15 for the date range from 2015-09-22 to 2015-10-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMX15 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMZ15 for the date range from 2015-10-20 to 2015-11-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMZ15 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMF16 for the date range from 2015-11-20 to 2015-12-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMF16 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMG16 for the date range from 2015-12-22 to 2016-01-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMG16 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMH16 for the date range from 2016-01-20 to 2016-02-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMH16 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMJ16 for the date range from 2016-02-22 to 2016-03-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMJ16 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMK16 for the date range from 2016-03-22 to 2016-04-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMK16 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMM16 for the date range from 2016-04-20 to 2016-05-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMM16 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMN16 for the date range from 2016-05-20 to 2016-06-21. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMN16 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMQ16 for the date range from 2016-06-21 to 2016-07-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMQ16 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMU16 for the date range from 2016-07-20 to 2016-08-22. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMU16 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMV16 for the date range from 2016-08-22 to 2016-09-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Skipping Daily data download for symbol QMV16 since download was already done in last 24 hours. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMX16 for the date range from 2016-09-20 to 2016-10-11. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Checking Daily data file for symbol QMZ16 for the date range from 2016-10-11 to 2016-10-11. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMZ16.dly. Date: 2016-10-11, Price: 51.525. Date: 2016-10-11, Price: 51.525 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMX16.dly. Date: 2016-09-20, Price: 44.05. Date: 2016-10-10, Price: 51.35 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMV16.dly. Date: 2016-08-22, Price: 47.41. Date: 2016-09-19, Price: 43.3 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMU16.dly. Date: 2016-07-20, Price: 45.75. Date: 2016-08-19, Price: 48.52 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMQ16.dly. Date: 2016-06-21, Price: 49.85. Date: 2016-07-19, Price: 44.65 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMN16.dly. Date: 2016-05-20, Price: 48.4. Date: 2016-06-20, Price: 49.375 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMM16.dly. Date: 2016-04-20, Price: 44.175. Date: 2016-05-19, Price: 48.15 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMK16.dly. Date: 2016-03-22, Price: 41.45. Date: 2016-04-19, Price: 41.075 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMJ16.dly. Date: 2016-02-22, Price: 33.4. Date: 2016-03-21, Price: 39.45 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMH16.dly. Date: 2016-01-20, Price: 28.35. Date: 2016-02-19, Price: 29.64 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMG16.dly. Date: 2015-12-22, Price: 36.15. Date: 2016-01-19, Price: 28.45 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMF16.dly. Date: 2015-11-20, Price: 41.9. Date: 2015-12-21, Price: 34.725 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMZ15.dly. Date: 2015-10-20, Price: 46.29. Date: 2015-11-19, Price: 40.54 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMX15.dly. Date: 2015-09-22, Price: 46.36. Date: 2015-10-19, Price: 45.89 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMV15.dly. Date: 2015-08-20, Price: 41.32. Date: 2015-09-21, Price: 46.68 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMU15.dly. Date: 2015-07-21, Price: 50.86. Date: 2015-08-19, Price: 40.8 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMQ15.dly. Date: 2015-06-22, Price: 60.375. Date: 2015-07-20, Price: 50.15 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMN15.dly. Date: 2015-05-20, Price: 58.975. Date: 2015-06-19, Price: 59.6 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMM15.dly. Date: 2015-04-21, Price: 56.6. Date: 2015-05-19, Price: 59.425 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMK15.dly. Date: 2015-03-20, Price: 46.575. Date: 2015-04-20, Price: 56.375 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMJ15.dly. Date: 2015-02-20, Price: 50.8. Date: 2015-03-19, Price: 43.95 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMH15.dly. Date: 2015-01-20, Price: 46.475. Date: 2015-02-19, Price: 51.15 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMG15.dly. Date: 2014-12-22, Price: 55.25. Date: 2015-01-19, Price: 48.7 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMF15.dly. Date: 2014-11-20, Price: 75.85. Date: 2014-12-19, Price: 54.1 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMZ14.dly. Date: 2014-10-21, Price: 82.5. Date: 2014-11-19, Price: 74.575 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMX14.dly. Date: 2014-09-22, Price: 90.875. Date: 2014-10-20, Price: 82.7 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMV14.dly. Date: 2014-08-20, Price: 93.45. Date: 2014-09-19, Price: 92.4 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMU14.dly. Date: 2014-07-22, Price: 102.4. Date: 2014-08-19, Price: 94.475 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMQ14.dly. Date: 2014-06-20, Price: 106.825. Date: 2014-07-21, Price: 104.6 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMN14.dly. Date: 2014-05-20, Price: 102.325. Date: 2014-06-19, Price: 106.425 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMM14.dly. Date: 2014-04-22, Price: 101.75. Date: 2014-05-19, Price: 102.6 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMK14.dly. Date: 2014-03-20, Price: 98.9. Date: 2014-04-21, Price: 104.375 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMJ14.dly. Date: 2014-02-20, Price: 102.75. Date: 2014-03-19, Price: 100.375 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMH14.dly. Date: 2014-01-21, Price: 94.975. Date: 2014-02-19, Price: 103.3 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMG14.dly. Date: 2013-12-20, Price: 99.325. Date: 2014-01-20, Price: 94.375 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMF14.dly. Date: 2013-11-20, Price: 93.85. Date: 2013-12-19, Price: 97.8 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMZ13.dly. Date: 2013-10-22, Price: 98.3. Date: 2013-11-19, Price: 93.35 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMX13.dly. Date: 2013-09-20, Price: 104.75. Date: 2013-10-21, Price: 99.225 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMV13.dly. Date: 2013-08-20, Price: 105.1. Date: 2013-09-19, Price: 106.4 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMU13.dly. Date: 2013-07-22, Price: 106.95. Date: 2013-08-19, Price: 107.1 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMQ13.dly. Date: 2013-06-20, Price: 95.15. Date: 2013-07-19, Price: 108.05 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMN13.dly. Date: 2013-05-21, Price: 96.175. Date: 2013-06-19, Price: 98.25 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMM13.dly. Date: 2013-04-22, Price: 89.2. Date: 2013-05-20, Price: 96.7 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMK13.dly. Date: 2013-03-20, Price: 93.5. Date: 2013-04-19, Price: 88 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMJ13.dly. Date: 2013-02-20, Price: 95.225. Date: 2013-03-19, Price: 92.15 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMH13.dly. Date: 2013-01-22, Price: 96.675. Date: 2013-02-19, Price: 96.65 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMG13.dly. Date: 2012-12-20, Price: 90.125. Date: 2013-01-21, Price: 95.55 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMF13.dly. Date: 2012-11-20, Price: 86.75. Date: 2012-12-19, Price: 87.925 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMZ12.dly. Date: 2012-10-22, Price: 88.65. Date: 2012-11-19, Price: 85.45 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMX12.dly. Date: 2012-09-20, Price: 92.425. Date: 2012-10-19, Price: 90.05 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMV12.dly. Date: 2012-08-21, Price: 96.85. Date: 2012-09-19, Price: 91.975 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMU12.dly. Date: 2012-07-20, Price: 91.825. Date: 2012-08-20, Price: 95.975 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMQ12.dly. Date: 2012-06-20, Price: 81.45. Date: 2012-07-19, Price: 92.65 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMN12.dly. Date: 2012-05-22, Price: 91.85. Date: 2012-06-19, Price: 84.025 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMM12.dly. Date: 2012-04-20, Price: 103.875. Date: 2012-05-21, Price: 92.575 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMK12.dly. Date: 2012-03-20, Price: 106.075. Date: 2012-04-19, Price: 102.275 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMJ12.dly. Date: 2012-02-21, Price: 106.25. Date: 2012-03-19, Price: 108.1 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMH12.dly. Date: 2012-01-20, Price: 98.325. Date: 2012-02-20, Price: 103.25 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMG12.dly. Date: 2011-12-20, Price: 97.25. Date: 2012-01-19, Price: 100.4 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMF12.dly. Date: 2011-11-22, Price: 98. Date: 2011-12-19, Price: 93.875 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMZ11.dly. Date: 2011-10-20, Price: 86.075. Date: 2011-11-21, Price: 98.825 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMX11.dly. Date: 2011-09-20, Price: 86.925. Date: 2011-10-19, Price: 86.1 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMV11.dly. Date: 2011-08-22, Price: 84.425. Date: 2011-09-19, Price: 85.7 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMU11.dly. Date: 2011-07-20, Price: 98.4. Date: 2011-08-19, Price: 82.25 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMQ11.dly. Date: 2011-06-21, Price: 94.175. Date: 2011-07-19, Price: 97.5 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMN11.dly. Date: 2011-05-20, Price: 100.1. Date: 2011-06-20, Price: 93.25 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMM11.dly. Date: 2011-04-20, Price: 111.45. Date: 2011-05-19, Price: 98.45 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMK11.dly. Date: 2011-03-22, Price: 104.975. Date: 2011-04-19, Price: 107.125 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMJ11.dly. Date: 2011-02-22, Price: 95.425. Date: 2011-03-21, Price: 102.325 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMH11.dly. Date: 2011-01-20, Price: 89.6. Date: 2011-02-21, Price: 86.2 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMG11.dly. Date: 2010-12-21, Price: 89.825. Date: 2011-01-19, Price: 90.85 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMF11.dly. Date: 2010-11-22, Price: 81.75. Date: 2010-12-20, Price: 88.025 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMZ10.dly. Date: 2010-10-20, Price: 82.55. Date: 2010-11-19, Price: 81.85 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMX10.dly. Date: 2010-09-21, Price: 74.975. Date: 2010-10-19, Price: 79.5 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMV10.dly. Date: 2010-08-20, Price: 73.825. Date: 2010-09-20, Price: 74.85 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMU10.dly. Date: 2010-07-20, Price: 77.575. Date: 2010-08-19, Price: 74.425 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMQ10.dly. Date: 2010-06-22, Price: 77.85. Date: 2010-07-19, Price: 76.55 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMQ10.dly has a volume of 0 at 2010-07-19. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMN10.dly. Date: 2010-05-20, Price: 70.8. Date: 2010-06-21, Price: 77.825 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMN10.dly has a volume of 0 at 2010-06-21. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMM10.dly. Date: 2010-04-20, Price: 83.85. Date: 2010-05-19, Price: 69.875 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMM10.dly has a volume of 0 at 2010-05-19. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMK10.dly. Date: 2010-03-22, Price: 81.6. Date: 2010-04-19, Price: 81.45 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMK10.dly has a volume of 0 at 2010-04-19. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMJ10.dly. Date: 2010-02-22, Price: 80.3. Date: 2010-03-19, Price: 80.675 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMJ10.dly has a volume of 0 at 2010-03-19. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMH10.dly. Date: 2010-01-20, Price: 77.75. Date: 2010-02-19, Price: 79.8 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMH10.dly has a volume of 0 at 2010-02-19. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMG10.dly. Date: 2009-12-22, Price: 74.4. Date: 2010-01-19, Price: 79.025 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMG10.dly has a volume of 0 at 2010-01-19. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMF10.dly. Date: 2009-11-20, Price: 77.475. Date: 2009-12-21, Price: 73.35 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMF10.dly has a volume of 0 at 2009-12-21. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMZ09.dly. Date: 2009-10-20, Price: 79.12. Date: 2009-11-19, Price: 77.45 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMZ09.dly has a volume of 0 at 2009-11-19. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMX09.dly. Date: 2009-09-22, Price: 71.76. Date: 2009-10-19, Price: 79.61 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMX09.dly has a volume of 0 at 2009-10-19. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMV09.dly. Date: 2009-08-20, Price: 72.91. Date: 2009-09-21, Price: 69.71 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMV09.dly has a volume of 0 at 2009-09-21. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMU09.dly. Date: 2009-07-21, Price: 65.61. Date: 2009-08-19, Price: 72.42001 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMU09.dly has a volume of 0 at 2009-08-19. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMQ09.dly. Date: 2009-06-22, Price: 67.5. Date: 2009-07-20, Price: 63.98 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMQ09.dly has a volume of 0 at 2009-07-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMN09.dly. Date: 2009-05-20, Price: 62.04. Date: 2009-06-19, Price: 69.55 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMN09.dly has a volume of 0 at 2009-06-19. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMM09.dly. Date: 2009-04-21, Price: 48.55. Date: 2009-05-19, Price: 59.03 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMM09.dly has a volume of 0 at 2009-05-19. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMK09.dly. Date: 2009-03-20, Price: 52.07. Date: 2009-04-20, Price: 45.88 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMK09.dly has a volume of 0 at 2009-04-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMJ09.dly. Date: 2009-02-20, Price: 40.03. Date: 2009-03-19, Price: 51.61 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMJ09.dly has a volume of 0 at 2009-03-19. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMH09.dly. Date: 2009-01-20, Price: 40.84. Date: 2009-02-19, Price: 39.48 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMH09.dly has a volume of 0 at 2009-02-19. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMG09.dly. Date: 2008-12-22, Price: 39.91. Date: 2009-01-19, Price: 36.51 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMF09.dly. Date: 2008-11-20, Price: 49.42. Date: 2008-12-19, Price: 36.22 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMF09.dly has a volume of 0 at 2008-12-19. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMZ08.dly. Date: 2008-10-21, Price: 72.18. Date: 2008-11-19, Price: 53.62 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMZ08.dly has a volume of 0 at 2008-11-19. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMX08.dly. Date: 2008-09-22, Price: 109.37. Date: 2008-10-20, Price: 74.25 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMX08.dly has a volume of 0 at 2008-10-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMV08.dly. Date: 2008-08-20, Price: 115.56. Date: 2008-09-19, Price: 104.55 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMV08.dly has a volume of 0 at 2008-09-19. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMU08.dly. Date: 2008-07-22, Price: 128.42. Date: 2008-08-19, Price: 114.53 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMU08.dly has a volume of 0 at 2008-08-19. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMQ08.dly. Date: 2008-06-20, Price: 135.36. Date: 2008-07-21, Price: 131.04 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMQ08.dly has a volume of 0 at 2008-07-21. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMN08.dly. Date: 2008-05-20, Price: 128.98. Date: 2008-06-19, Price: 131.93 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMN08.dly has a volume of 0 at 2008-06-19. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMM08.dly. Date: 2008-04-22, Price: 118.07. Date: 2008-05-19, Price: 127.05 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMM08.dly has a volume of 0 at 2008-05-19. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMK08.dly. Date: 2008-03-20, Price: 101.84. Date: 2008-04-21, Price: 117.48 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMK08.dly has a volume of 0 at 2008-04-21. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMJ08.dly. Date: 2008-02-20, Price: 99.7. Date: 2008-03-19, Price: 109.42 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMJ08.dly has a volume of 0 at 2008-03-19. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMH08.dly. Date: 2008-01-22, Price: 89.21. Date: 2008-02-19, Price: 100.01 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMH08.dly has a volume of 0 at 2008-02-19. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMG08.dly. Date: 2007-12-20, Price: 91.06. Date: 2008-01-21, Price: 90.57 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMG08.dly has a volume of 0 at 2008-01-21. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMF08.dly. Date: 2007-11-20, Price: 98.03. Date: 2007-12-19, Price: 90.63 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMF08.dly has a volume of 0 at 2007-12-19. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMZ07.dly. Date: 2007-10-22, Price: 86.02. Date: 2007-11-19, Price: 93.43 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMZ07.dly has a volume of 0 at 2007-11-19. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMX07.dly. Date: 2007-09-20, Price: 81.78. Date: 2007-10-19, Price: 88.6 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMX07.dly has a volume of 0 at 2007-10-19. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMV07.dly. Date: 2007-08-21, Price: 69.57. Date: 2007-09-19, Price: 81.93 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMV07.dly has a volume of 0 at 2007-09-19. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMU07.dly. Date: 2007-07-20, Price: 75.79. Date: 2007-08-20, Price: 71.12 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMU07.dly has a volume of 0 at 2007-08-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMQ07.dly. Date: 2007-06-20, Price: 68.86. Date: 2007-07-19, Price: 75.92001 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMQ07.dly has a volume of 0 at 2007-07-19. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMN07.dly. Date: 2007-05-22, Price: 65.51. Date: 2007-06-19, Price: 69.1 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMN07.dly has a volume of 0 at 2007-06-19. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMM07.dly. Date: 2007-04-20, Price: 64.11. Date: 2007-05-21, Price: 66.27 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMM07.dly has a volume of 0 at 2007-05-21. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMK07.dly. Date: 2007-03-20, Price: 59.25. Date: 2007-04-19, Price: 61.83 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMK07.dly has a volume of 0 at 2007-04-19. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMJ07.dly. Date: 2007-02-20, Price: 58.85. Date: 2007-03-19, Price: 56.59 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMJ07.dly has a volume of 0 at 2007-03-19. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMH07.dly. Date: 2007-01-22, Price: 52.58. Date: 2007-02-19, Price: 59.39 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMH07.dly has a volume of 0 at 2007-02-19. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMG07.dly. Date: 2006-12-20, Price: 63.72. Date: 2007-01-19, Price: 51.99 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMG07.dly has a volume of 0 at 2007-01-19. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMF07.dly. Date: 2006-11-21, Price: 60.17. Date: 2006-12-19, Price: 62.21 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMF07.dly has a volume of 0 at 2006-12-19. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMZ06.dly. Date: 2006-10-20, Price: 59.33. Date: 2006-11-20, Price: 56.26 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMZ06.dly has a volume of 0 at 2006-11-20. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMX06.dly. Date: 2006-09-20, Price: 60.74. Date: 2006-10-19, Price: 58.5 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMX06.dly has a volume of 0 at 2006-10-19. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Price data for daily data file QMV06.dly. Date: 2006-08-22, Price: 73.1. Date: 2006-09-19, Price: 61.66 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | File QMV06.dly has a volume of 0 at 2006-09-19. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Symbols used for continuous contract chart: | 2016-10-11 15:24:34 QMV06 | 2016-10-11 15:24:34 QMX06 | 2016-10-11 15:24:34 QMZ06 | 2016-10-11 15:24:34 QMF07 | 2016-10-11 15:24:34 QMG07 | 2016-10-11 15:24:34 QMH07 | 2016-10-11 15:24:34 QMJ07 | 2016-10-11 15:24:34 QMK07 | 2016-10-11 15:24:34 QMM07 | 2016-10-11 15:24:34 QMN07 | 2016-10-11 15:24:34 QMQ07 | 2016-10-11 15:24:34 QMU07 | 2016-10-11 15:24:34 QMV07 | 2016-10-11 15:24:34 QMX07 | 2016-10-11 15:24:34 QMZ07 | 2016-10-11 15:24:34 QMF08 | 2016-10-11 15:24:34 QMG08 | 2016-10-11 15:24:34 QMH08 | 2016-10-11 15:24:34 QMJ08 | 2016-10-11 15:24:34 QMK08 | 2016-10-11 15:24:34 QMM08 | 2016-10-11 15:24:34 QMN08 | 2016-10-11 15:24:34 QMQ08 | 2016-10-11 15:24:34 QMU08 | 2016-10-11 15:24:34 QMV08 | 2016-10-11 15:24:34 QMX08 | 2016-10-11 15:24:34 QMZ08 | 2016-10-11 15:24:34 QMF09 | 2016-10-11 15:24:34 QMG09 | 2016-10-11 15:24:34 QMH09 | 2016-10-11 15:24:34 QMJ09 | 2016-10-11 15:24:34 QMK09 | 2016-10-11 15:24:34 QMM09 | 2016-10-11 15:24:34 QMN09 | 2016-10-11 15:24:34 QMQ09 | 2016-10-11 15:24:34 QMU09 | 2016-10-11 15:24:34 QMV09 | 2016-10-11 15:24:34 QMX09 | 2016-10-11 15:24:34 QMZ09 | 2016-10-11 15:24:34 QMF10 | 2016-10-11 15:24:34 QMG10 | 2016-10-11 15:24:34 QMH10 | 2016-10-11 15:24:34 QMJ10 | 2016-10-11 15:24:34 QMK10 | 2016-10-11 15:24:34 QMM10 | 2016-10-11 15:24:34 QMN10 | 2016-10-11 15:24:34 QMQ10 | 2016-10-11 15:24:34 QMU10 | 2016-10-11 15:24:34 QMV10 | 2016-10-11 15:24:34 QMX10 | 2016-10-11 15:24:34 QMZ10 | 2016-10-11 15:24:34 QMF11 | 2016-10-11 15:24:34 QMG11 | 2016-10-11 15:24:34 QMH11 | 2016-10-11 15:24:34 QMJ11 | 2016-10-11 15:24:34 QMK11 | 2016-10-11 15:24:34 QMM11 | 2016-10-11 15:24:34 QMN11 | 2016-10-11 15:24:34 QMQ11 | 2016-10-11 15:24:34 QMU11 | 2016-10-11 15:24:34 QMV11 | 2016-10-11 15:24:34 QMX11 | 2016-10-11 15:24:34 QMZ11 | 2016-10-11 15:24:34 QMF12 | 2016-10-11 15:24:34 QMG12 | 2016-10-11 15:24:34 QMH12 | 2016-10-11 15:24:34 QMJ12 | 2016-10-11 15:24:34 QMK12 | 2016-10-11 15:24:34 QMM12 | 2016-10-11 15:24:34 QMN12 | 2016-10-11 15:24:34 QMQ12 | 2016-10-11 15:24:34 QMU12 | 2016-10-11 15:24:34 QMV12 | 2016-10-11 15:24:34 QMX12 | 2016-10-11 15:24:34 QMZ12 | 2016-10-11 15:24:34 QMF13 | 2016-10-11 15:24:34 QMG13 | 2016-10-11 15:24:34 QMH13 | 2016-10-11 15:24:34 QMJ13 | 2016-10-11 15:24:34 QMK13 | 2016-10-11 15:24:34 QMM13 | 2016-10-11 15:24:34 QMN13 | 2016-10-11 15:24:34 QMQ13 | 2016-10-11 15:24:34 QMU13 | 2016-10-11 15:24:34 QMV13 | 2016-10-11 15:24:34 QMX13 | 2016-10-11 15:24:34 QMZ13 | 2016-10-11 15:24:34 QMF14 | 2016-10-11 15:24:34 QMG14 | 2016-10-11 15:24:34 QMH14 | 2016-10-11 15:24:34 QMJ14 | 2016-10-11 15:24:34 QMK14 | 2016-10-11 15:24:34 QMM14 | 2016-10-11 15:24:34 QMN14 | 2016-10-11 15:24:34 QMQ14 | 2016-10-11 15:24:34 QMU14 | 2016-10-11 15:24:34 QMV14 | 2016-10-11 15:24:34 QMX14 | 2016-10-11 15:24:34 QMZ14 | 2016-10-11 15:24:34 QMF15 | 2016-10-11 15:24:34 QMG15 | 2016-10-11 15:24:34 QMH15 | 2016-10-11 15:24:34 QMJ15 | 2016-10-11 15:24:34 QMK15 | 2016-10-11 15:24:34 QMM15 | 2016-10-11 15:24:34 QMN15 | 2016-10-11 15:24:34 QMQ15 | 2016-10-11 15:24:34 QMU15 | 2016-10-11 15:24:34 QMV15 | 2016-10-11 15:24:34 QMX15 | 2016-10-11 15:24:34 QMZ15 | 2016-10-11 15:24:34 QMF16 | 2016-10-11 15:24:34 QMG16 | 2016-10-11 15:24:34 QMH16 | 2016-10-11 15:24:34 QMJ16 | 2016-10-11 15:24:34 QMK16 | 2016-10-11 15:24:34 QMM16 | 2016-10-11 15:24:34 QMN16 | 2016-10-11 15:24:34 QMQ16 | 2016-10-11 15:24:34 QMU16 | 2016-10-11 15:24:34 QMV16 | 2016-10-11 15:24:34 QMX16 | 2016-10-11 15:24:34 QMZ16 | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Performing continuous futures contract back adjustment calculations. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMV06 Open price on 2006-09-20 is 63.9. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMX06 Open price on 2006-09-20 is 62.15. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMV06 price difference to QMX06 is -1.75. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMX06 Open price on 2006-10-20 is 57.8. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMZ06 Open price on 2006-10-20 is 60.6. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMX06 price difference to QMZ06 is 2.8. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMZ06 Open price on 2006-11-21 is 58.75. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMF07 Open price on 2006-11-21 is 58.95. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMZ06 price difference to QMF07 is 0.2. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMF07 Open price on 2006-12-20 is 63.25. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMG07 Open price on 2006-12-20 is 63.4. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMF07 price difference to QMG07 is 0.15. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMG07 Open price on 2007-01-22 is 50.475. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMH07 Open price on 2007-01-22 is 53.575. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMG07 price difference to QMH07 is 3.1. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMH07 Open price on 2007-02-20 is 58. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMJ07 Open price on 2007-02-20 is 59.55. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMH07 price difference to QMJ07 is 1.55. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMJ07 Open price on 2007-03-20 is 57.25. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMK07 Open price on 2007-03-20 is 59.9. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMJ07 price difference to QMK07 is 2.65. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMK07 Open price on 2007-04-20 is 62.625. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMM07 Open price on 2007-04-20 is 63.075. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMK07 price difference to QMM07 is 0.45. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMM07 Open price on 2007-05-22 is 64.95. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMN07 Open price on 2007-05-22 is 66.825. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMM07 price difference to QMN07 is 1.875. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMN07 Open price on 2007-06-20 is 69.1. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMQ07 Open price on 2007-06-20 is 69.425. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMN07 price difference to QMQ07 is 0.325. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMQ07 Open price on 2007-07-20 is 74.875. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMU07 Open price on 2007-07-20 is 76.1. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMQ07 price difference to QMU07 is 1.225. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMU07 Open price on 2007-08-21 is 71.95. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMV07 Open price on 2007-08-21 is 70.95. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMU07 price difference to QMV07 is -1. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMV07 Open price on 2007-09-20 is 82.2. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMX07 Open price on 2007-09-20 is 80.525. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMV07 price difference to QMX07 is -1.675. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMX07 Open price on 2007-10-22 is 89.775. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMZ07 Open price on 2007-10-22 is 86.875. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMX07 price difference to QMZ07 is -2.9. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMZ07 Open price on 2007-11-20 is 94.1. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMF08 Open price on 2007-11-20 is 94.825. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMZ07 price difference to QMF08 is 0.725. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMF08 Open price on 2007-12-20 is 91.375. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMG08 Open price on 2007-12-20 is 91.4. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMF08 price difference to QMG08 is 0.025. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMG08 Open price on 2008-01-22 is 89.85. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMH08 Open price on 2008-01-22 is 89.8. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMG08 price difference to QMH08 is -0.05. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMH08 Open price on 2008-02-20 is 95.4. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMJ08 Open price on 2008-02-20 is 99.55. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMH08 price difference to QMJ08 is 4.15. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMJ08 Open price on 2008-03-20 is 106. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMK08 Open price on 2008-03-20 is 102.1. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMJ08 price difference to QMK08 is -3.9. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMK08 Open price on 2008-04-22 is 116.625. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMM08 Open price on 2008-04-22 is 116.675. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMK08 price difference to QMM08 is 0.05. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMM08 Open price on 2008-05-20 is 126.3. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMN08 Open price on 2008-05-20 is 126.825. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMM08 price difference to QMN08 is 0.525. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMN08 Open price on 2008-06-20 is 136.1. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMQ08 Open price on 2008-06-20 is 132.275. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMN08 price difference to QMQ08 is -3.825. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMQ08 Open price on 2008-07-22 is 129.125. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMU08 Open price on 2008-07-22 is 131.9. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMQ08 price difference to QMU08 is 2.775. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMU08 Open price on 2008-08-20 is 113.175. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMV08 Open price on 2008-08-20 is 115.15. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMU08 price difference to QMV08 is 1.975. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMV08 Open price on 2008-09-22 is 98.05. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMX08 Open price on 2008-09-22 is 102.15. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMV08 price difference to QMX08 is 4.1. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMX08 Open price on 2008-10-21 is 72.3. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMZ08 Open price on 2008-10-21 is 75.8. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMX08 price difference to QMZ08 is 3.5. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMZ08 Open price on 2008-11-20 is 54.5. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMF09 Open price on 2008-11-20 is 53.6. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMZ08 price difference to QMF09 is -0.9. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMF09 Open price on 2008-12-22 is 40.2. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMG09 Open price on 2008-12-22 is 42.7. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMF09 price difference to QMG09 is 2.5. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMG09 Open price on 2009-01-20 is 35.4. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMH09 Open price on 2009-01-20 is 42.575. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMG09 price difference to QMH09 is 7.175. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMH09 Open price on 2009-02-20 is 34.75. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMJ09 Open price on 2009-02-20 is 39.55. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMH09 price difference to QMJ09 is 4.8. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMJ09 Open price on 2009-03-20 is 49.8. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMK09 Open price on 2009-03-20 is 51.775. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMJ09 price difference to QMK09 is 1.975. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMK09 Open price on 2009-04-21 is 50.05. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMM09 Open price on 2009-04-21 is 48.3. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMK09 price difference to QMM09 is -1.75. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMM09 Open price on 2009-05-20 is 56.425. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMN09 Open price on 2009-05-20 is 60.225. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMM09 price difference to QMN09 is 3.8. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMN09 Open price on 2009-06-22 is 71.45. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMQ09 Open price on 2009-06-22 is 70.15. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMN09 price difference to QMQ09 is -1.3. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMQ09 Open price on 2009-07-21 is 63.525. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMU09 Open price on 2009-07-21 is 65.4. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMQ09 price difference to QMU09 is 1.875. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMU09 Open price on 2009-08-20 is 70.225. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMV09 Open price on 2009-08-20 is 73.5. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMU09 price difference to QMV09 is 3.275. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMV09 Open price on 2009-09-22 is 72.05. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMX09 Open price on 2009-09-22 is 69.875. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMV09 price difference to QMX09 is -2.175. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMX09 Open price on 2009-10-20 is 78.85. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMZ09 Open price on 2009-10-20 is 80. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMX09 price difference to QMZ09 is 1.15. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMZ09 Open price on 2009-11-20 is 79.7. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMF10 Open price on 2009-11-20 is 78.475. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMZ09 price difference to QMF10 is -1.225. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMF10 Open price on 2009-12-22 is 72.85. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMG10 Open price on 2009-12-22 is 73.5. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMF10 price difference to QMG10 is 0.65. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMG10 Open price on 2010-01-20 is 77.825. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMH10 Open price on 2010-01-20 is 79.175. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMG10 price difference to QMH10 is 1.35. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMH10 Open price on 2010-02-22 is 78.325. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMJ10 Open price on 2010-02-22 is 80.3. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMH10 price difference to QMJ10 is 1.975. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMJ10 Open price on 2010-03-22 is 82.2. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMK10 Open price on 2010-03-22 is 80.875. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMJ10 price difference to QMK10 is -1.325. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMK10 Open price on 2010-04-20 is 82.975. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMM10 Open price on 2010-04-20 is 83.275. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMK10 price difference to QMM10 is 0.3. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMM10 Open price on 2010-05-20 is 69.025. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMN10 Open price on 2010-05-20 is 72.825. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMM10 price difference to QMN10 is 3.8. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMN10 Open price on 2010-06-22 is 77.9. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMQ10 Open price on 2010-06-22 is 78.175. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMN10 price difference to QMQ10 is 0.275. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMQ10 Open price on 2010-07-20 is 75.625. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMU10 Open price on 2010-07-20 is 76.725. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMQ10 price difference to QMU10 is 1.1. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMU10 Open price on 2010-08-20 is 75.2. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMV10 Open price on 2010-08-20 is 74.8. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMU10 price difference to QMV10 is -0.4. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMV10 Open price on 2010-09-21 is 73.575. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMX10 Open price on 2010-09-21 is 76.25. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMV10 price difference to QMX10 is 2.675. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMX10 Open price on 2010-10-20 is 82.95. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMZ10 Open price on 2010-10-20 is 79.975. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMX10 price difference to QMZ10 is -2.975. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMZ10 Open price on 2010-11-22 is 80.4. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMF11 Open price on 2010-11-22 is 82.2. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMZ10 price difference to QMF11 is 1.8. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMF11 Open price on 2010-12-21 is 87.925. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMG11 Open price on 2010-12-21 is 89.175. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMF11 price difference to QMG11 is 1.25. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMG11 Open price on 2011-01-20 is 91.225. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMH11 Open price on 2011-01-20 is 91.6. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMG11 price difference to QMH11 is 0.375. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMH11 Open price on 2011-02-22 is 86.45. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMJ11 Open price on 2011-02-22 is 90.1. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMH11 price difference to QMJ11 is 3.65. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMJ11 Open price on 2011-03-22 is 102.05. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMK11 Open price on 2011-03-22 is 102.7. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMJ11 price difference to QMK11 is 0.65. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMK11 Open price on 2011-04-20 is 109.35. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMM11 Open price on 2011-04-20 is 108.425. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMK11 price difference to QMM11 is -0.925. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMM11 Open price on 2011-05-20 is 99.675. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMN11 Open price on 2011-05-20 is 99.1. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMM11 price difference to QMN11 is -0.575. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMN11 Open price on 2011-06-21 is 92.875. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMQ11 Open price on 2011-06-21 is 93.825. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMN11 price difference to QMQ11 is 0.95. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMQ11 Open price on 2011-07-20 is 96.125. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMU11 Open price on 2011-07-20 is 98.475. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMQ11 price difference to QMU11 is 2.35. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMU11 Open price on 2011-08-22 is 81.45. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMV11 Open price on 2011-08-22 is 82.4. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMU11 price difference to QMV11 is 0.95. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMV11 Open price on 2011-09-20 is 87.25. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMX11 Open price on 2011-09-20 is 86. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMV11 price difference to QMX11 is -1.25. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMX11 Open price on 2011-10-20 is 88.2. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMZ11 Open price on 2011-10-20 is 86.2. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMX11 price difference to QMZ11 is -2. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMZ11 Open price on 2011-11-22 is 101.675. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMF12 Open price on 2011-11-22 is 97.125. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMZ11 price difference to QMF12 is -4.55. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMF12 Open price on 2011-12-20 is 93.625. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMG12 Open price on 2011-12-20 is 94.275. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMF12 price difference to QMG12 is 0.65. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMG12 Open price on 2012-01-20 is 101.1. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMH12 Open price on 2012-01-20 is 100.575. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMG12 price difference to QMH12 is -0.525. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMH12 Open price on 2012-02-21 is 102.3. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMJ12 Open price on 2012-02-21 is 104.55. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMH12 price difference to QMJ12 is 2.25. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMJ12 Open price on 2012-03-20 is 107.225. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMK12 Open price on 2012-03-20 is 108.35. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMJ12 price difference to QMK12 is 1.125. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMK12 Open price on 2012-04-20 is 102.75. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMM12 Open price on 2012-04-20 is 103. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMK12 price difference to QMM12 is 0.25. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMM12 Open price on 2012-05-22 is 91.35. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMN12 Open price on 2012-05-22 is 93. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMM12 price difference to QMN12 is 1.65. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMN12 Open price on 2012-06-20 is 83. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMQ12 Open price on 2012-06-20 is 84.25. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMN12 price difference to QMQ12 is 1.25. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMQ12 Open price on 2012-07-20 is 89.975. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMU12 Open price on 2012-07-20 is 92.6. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMQ12 price difference to QMU12 is 2.625. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMU12 Open price on 2012-08-21 is 96.375. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMV12 Open price on 2012-08-21 is 96.175. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMU12 price difference to QMV12 is -0.2. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMV12 Open price on 2012-09-20 is 95.525. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMX12 Open price on 2012-09-20 is 92.25. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMV12 price difference to QMX12 is -3.275. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMX12 Open price on 2012-10-22 is 92.05. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMZ12 Open price on 2012-10-22 is 90.175. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMX12 price difference to QMZ12 is -1.875. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMZ12 Open price on 2012-11-20 is 86.35. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMF13 Open price on 2012-11-20 is 89.1. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMZ12 price difference to QMF13 is 2.75. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMF13 Open price on 2012-12-20 is 87.4. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMG13 Open price on 2012-12-20 is 89.625. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMF13 price difference to QMG13 is 2.225. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMG13 Open price on 2013-01-22 is 95.2. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMH13 Open price on 2013-01-22 is 95.75. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMG13 price difference to QMH13 is 0.55. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMH13 Open price on 2013-02-20 is 95.95. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMJ13 Open price on 2013-02-20 is 97.1. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMH13 price difference to QMJ13 is 1.15. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMJ13 Open price on 2013-03-20 is 93.925. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMK13 Open price on 2013-03-20 is 92.45. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMJ13 price difference to QMK13 is -1.475. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMK13 Open price on 2013-04-22 is 88.275. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMM13 Open price on 2013-04-22 is 88.1. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMK13 price difference to QMM13 is -0.175. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMM13 Open price on 2013-05-21 is 96.15. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMN13 Open price on 2013-05-21 is 96.875. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMM13 price difference to QMN13 is 0.725. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMN13 Open price on 2013-06-20 is 98.575. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMQ13 Open price on 2013-06-20 is 98.2. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMN13 price difference to QMQ13 is -0.375. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMQ13 Open price on 2013-07-22 is 108.075. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMU13 Open price on 2013-07-22 is 108.025. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMQ13 price difference to QMU13 is -0.05. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMU13 Open price on 2013-08-20 is 107.625. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMV13 Open price on 2013-08-20 is 106.7. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMU13 price difference to QMV13 is -0.925. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMV13 Open price on 2013-09-20 is 108.425. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMX13 Open price on 2013-09-20 is 105.775. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMV13 price difference to QMX13 is -2.65. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMX13 Open price on 2013-10-22 is 100.8. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMZ13 Open price on 2013-10-22 is 99.55. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMX13 price difference to QMZ13 is -1.25. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMZ13 Open price on 2013-11-20 is 93.075. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMF14 Open price on 2013-11-20 is 93.875. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMZ13 price difference to QMF14 is 0.8. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMF14 Open price on 2013-12-20 is 97.325. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMG14 Open price on 2013-12-20 is 98.675. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMF14 price difference to QMG14 is 1.35. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMG14 Open price on 2014-01-21 is 94.1. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMH14 Open price on 2014-01-21 is 94.25. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMG14 price difference to QMH14 is 0.15. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMH14 Open price on 2014-02-20 is 103.1. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMJ14 Open price on 2014-02-20 is 102.9. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMH14 price difference to QMJ14 is -0.2. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMJ14 Open price on 2014-03-20 is 99.475. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMK14 Open price on 2014-03-20 is 99.15. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMJ14 price difference to QMK14 is -0.325. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMK14 Open price on 2014-04-22 is 104.45. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMM14 Open price on 2014-04-22 is 103.625. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMK14 price difference to QMM14 is -0.825. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMM14 Open price on 2014-05-20 is 102.025. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMN14 Open price on 2014-05-20 is 102.1. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMM14 price difference to QMN14 is 0.075. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMN14 Open price on 2014-06-20 is 106.05. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMQ14 Open price on 2014-06-20 is 106.075. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMN14 price difference to QMQ14 is 0.025. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMQ14 Open price on 2014-07-22 is 102.95. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMU14 Open price on 2014-07-22 is 102.75. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMQ14 price difference to QMU14 is -0.2. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMU14 Open price on 2014-08-20 is 96.6. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMV14 Open price on 2014-08-20 is 92.85. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMU14 price difference to QMV14 is -3.75. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMV14 Open price on 2014-09-22 is 92.975. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMX14 Open price on 2014-09-22 is 91.625. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMV14 price difference to QMX14 is -1.35. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMX14 Open price on 2014-10-21 is 83.1. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMZ14 Open price on 2014-10-21 is 81.85. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMX14 price difference to QMZ14 is -1.25. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMZ14 Open price on 2014-11-20 is 74.225. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMF15 Open price on 2014-11-20 is 74.325. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMZ14 price difference to QMF15 is 0.1. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMF15 Open price on 2014-12-22 is 55.8. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMG15 Open price on 2014-12-22 is 57.675. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMF15 price difference to QMG15 is 1.875. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMG15 Open price on 2015-01-20 is 46.25. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMH15 Open price on 2015-01-20 is 49.125. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMG15 price difference to QMH15 is 2.875. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMH15 Open price on 2015-02-20 is 50.575. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMJ15 Open price on 2015-02-20 is 52.175. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMH15 price difference to QMJ15 is 1.6. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMJ15 Open price on 2015-03-20 is 44.575. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMK15 Open price on 2015-03-20 is 45.6. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMJ15 price difference to QMK15 is 1.025. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMK15 Open price on 2015-04-21 is 56.075. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMM15 Open price on 2015-04-21 is 57.925. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMK15 price difference to QMM15 is 1.85. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMM15 Open price on 2015-05-20 is 59.85. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMN15 Open price on 2015-05-20 is 58.325. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMM15 price difference to QMN15 is -1.525. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMN15 Open price on 2015-06-22 is 60.45. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMQ15 Open price on 2015-06-22 is 59.75. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMN15 price difference to QMQ15 is -0.7. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMQ15 Open price on 2015-07-21 is 50.725. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMU15 Open price on 2015-07-21 is 50.25. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMQ15 price difference to QMU15 is -0.475. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMU15 Open price on 2015-08-20 is 42.425. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMV15 Open price on 2015-08-20 is 40.95. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMU15 price difference to QMV15 is -1.475. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMV15 Open price on 2015-09-22 is 44.85. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMX15 Open price on 2015-09-22 is 46.7. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMV15 price difference to QMX15 is 1.85. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMX15 Open price on 2015-10-20 is 47.1. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMZ15 Open price on 2015-10-20 is 46.575. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMX15 price difference to QMZ15 is -0.525. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMZ15 Open price on 2015-11-20 is 40.7. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMF16 Open price on 2015-11-20 is 41.875. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMZ15 price difference to QMF16 is 1.175. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMF16 Open price on 2015-12-22 is 34.8. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMG16 Open price on 2015-12-22 is 35.85. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMF16 price difference to QMG16 is 1.05. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMG16 Open price on 2016-01-20 is 29.35. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMH16 Open price on 2016-01-20 is 29.475. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMG16 price difference to QMH16 is 0.125. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMH16 Open price on 2016-02-22 is 30.675. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMJ16 Open price on 2016-02-22 is 31.95. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMH16 price difference to QMJ16 is 1.275. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMJ16 Open price on 2016-03-22 is 40.25. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMK16 Open price on 2016-03-22 is 41.6. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMJ16 price difference to QMK16 is 1.35. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMK16 Open price on 2016-04-20 is 39.975. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMM16 Open price on 2016-04-20 is 42.35. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMK16 price difference to QMM16 is 2.375. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMM16 Open price on 2016-05-20 is 47.9. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMN16 Open price on 2016-05-20 is 48.725. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMM16 price difference to QMN16 is 0.825. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMN16 Open price on 2016-06-21 is 48.35. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMQ16 Open price on 2016-06-21 is 49.775. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMN16 price difference to QMQ16 is 1.425. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMQ16 Open price on 2016-07-20 is 45.175. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMU16 Open price on 2016-07-20 is 45.475. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMQ16 price difference to QMU16 is 0.3. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMU16 Open price on 2016-08-22 is 48.375. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMV16 Open price on 2016-08-22 is 49.05. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMU16 price difference to QMV16 is 0.675. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMV16 Open price on 2016-09-20 is 43.2. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMX16 Open price on 2016-09-20 is 43.75. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMV16 price difference to QMX16 is 0.55. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMX16 Open price on 2016-10-11 is 51.125. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMZ16 Open price on 2016-10-11 is 51.65. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | QMX16 price difference to QMZ16 is 0.525. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMV06 is 63.4. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMX06 is 65.15. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMZ06 is 62.35. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMF07 is 62.15. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMG07 is 62. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMH07 is 58.9. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMJ07 is 57.35. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMK07 is 54.7. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMM07 is 54.25. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMN07 is 52.375. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMQ07 is 52.05. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMU07 is 50.825. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMV07 is 51.825. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMX07 is 53.5. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMZ07 is 56.4. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMF08 is 55.675. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMG08 is 55.65. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMH08 is 55.7. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMJ08 is 51.55. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMK08 is 55.45. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMM08 is 55.4. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMN08 is 54.875. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMQ08 is 58.7. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMU08 is 55.925. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMV08 is 53.95. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMX08 is 49.85. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMZ08 is 46.35. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMF09 is 47.25. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMG09 is 44.75. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMH09 is 37.575. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMJ09 is 32.775. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMK09 is 30.8. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMM09 is 32.55. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMN09 is 28.75. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMQ09 is 30.05. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMU09 is 28.175. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMV09 is 24.9. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMX09 is 27.075. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMZ09 is 25.925. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMF10 is 27.15. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMG10 is 26.5. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMH10 is 25.15. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMJ10 is 23.175. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMK10 is 24.5. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMM10 is 24.2. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMN10 is 20.4. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMQ10 is 20.125. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMU10 is 19.025. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMV10 is 19.425. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMX10 is 16.75. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMZ10 is 19.725. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMF11 is 17.925. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMG11 is 16.675. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMH11 is 16.3. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMJ11 is 12.65. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMK11 is 12. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMM11 is 12.925. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMN11 is 13.5. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMQ11 is 12.55. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMU11 is 10.2. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMV11 is 9.25. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMX11 is 10.5. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMZ11 is 12.5. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMF12 is 17.05. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMG12 is 16.4. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMH12 is 16.925. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMJ12 is 14.675. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMK12 is 13.55. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMM12 is 13.3. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMN12 is 11.65. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMQ12 is 10.4. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMU12 is 7.775. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMV12 is 7.975. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMX12 is 11.25. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMZ12 is 13.125. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMF13 is 10.375. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMG13 is 8.15. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMH13 is 7.6. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMJ13 is 6.45. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMK13 is 7.925. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMM13 is 8.1. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMN13 is 7.375. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMQ13 is 7.75. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMU13 is 7.8. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMV13 is 8.725. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMX13 is 11.375. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMZ13 is 12.625. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMF14 is 11.825. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMG14 is 10.475. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMH14 is 10.325. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMJ14 is 10.525. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMK14 is 10.85. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMM14 is 11.675. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMN14 is 11.6. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMQ14 is 11.575. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMU14 is 11.775. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMV14 is 15.525. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMX14 is 16.875. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMZ14 is 18.125. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMF15 is 18.025. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMG15 is 16.15. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMH15 is 13.275. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMJ15 is 11.675. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMK15 is 10.65. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMM15 is 8.8. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMN15 is 10.325. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMQ15 is 11.025. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMU15 is 11.5. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMV15 is 12.975. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMX15 is 11.125. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMZ15 is 11.65. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMF16 is 10.475. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMG16 is 9.425. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMH16 is 9.3. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMJ16 is 8.025. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMK16 is 6.675. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMM16 is 4.3. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMN16 is 3.475. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMQ16 is 2.05. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMU16 is 1.75. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMV16 is 1.075. | 2016-10-11 15:24:34 QMZ16 [CB] Weekly #1 | Back adjust amount for symbol QMX16 is 0.525. | 2016-10-11 15:24:34 QMZ16 [CB] Daily #2 | Reloading chart. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Date rule based rollover from QMV15 to next contract occurs at 2015-09-22. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Date rule based rollover from QMX15 to next contract occurs at 2015-10-20. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Date rule based rollover from QMZ15 to next contract occurs at 2015-11-20. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Date rule based rollover from QMF16 to next contract occurs at 2015-12-22. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Date rule based rollover from QMG16 to next contract occurs at 2016-01-20. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Date rule based rollover from QMH16 to next contract occurs at 2016-02-22. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Date rule based rollover from QMJ16 to next contract occurs at 2016-03-22. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Date rule based rollover from QMK16 to next contract occurs at 2016-04-20. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Date rule based rollover from QMM16 to next contract occurs at 2016-05-20. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Date rule based rollover from QMN16 to next contract occurs at 2016-06-21. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Date rule based rollover from QMQ16 to next contract occurs at 2016-07-20. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Date rule based rollover from QMU16 to next contract occurs at 2016-08-22. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Date rule based rollover from QMV16 to next contract occurs at 2016-09-20. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Date rule based rollover from QMX16 to next contract occurs at 2016-10-20. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Date rule based rollover from QMZ16 to next contract occurs at 2016-11-22. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Checking Daily data file for symbol QMV15 for the date range from 2015-08-20 to 2015-09-22. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Skipping Daily data download for symbol QMV15 since download was already done in last 24 hours. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Checking Daily data file for symbol QMX15 for the date range from 2015-09-22 to 2015-10-20. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Skipping Daily data download for symbol QMX15 since download was already done in last 24 hours. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Checking Daily data file for symbol QMZ15 for the date range from 2015-10-20 to 2015-11-20. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Skipping Daily data download for symbol QMZ15 since download was already done in last 24 hours. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Checking Daily data file for symbol QMF16 for the date range from 2015-11-20 to 2015-12-22. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Skipping Daily data download for symbol QMF16 since download was already done in last 24 hours. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Checking Daily data file for symbol QMG16 for the date range from 2015-12-22 to 2016-01-20. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Skipping Daily data download for symbol QMG16 since download was already done in last 24 hours. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Checking Daily data file for symbol QMH16 for the date range from 2016-01-20 to 2016-02-22. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Skipping Daily data download for symbol QMH16 since download was already done in last 24 hours. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Checking Daily data file for symbol QMJ16 for the date range from 2016-02-22 to 2016-03-22. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Skipping Daily data download for symbol QMJ16 since download was already done in last 24 hours. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Checking Daily data file for symbol QMK16 for the date range from 2016-03-22 to 2016-04-20. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Skipping Daily data download for symbol QMK16 since download was already done in last 24 hours. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Checking Daily data file for symbol QMM16 for the date range from 2016-04-20 to 2016-05-20. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Skipping Daily data download for symbol QMM16 since download was already done in last 24 hours. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Checking Daily data file for symbol QMN16 for the date range from 2016-05-20 to 2016-06-21. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Skipping Daily data download for symbol QMN16 since download was already done in last 24 hours. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Checking Daily data file for symbol QMQ16 for the date range from 2016-06-21 to 2016-07-20. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Skipping Daily data download for symbol QMQ16 since download was already done in last 24 hours. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Checking Daily data file for symbol QMU16 for the date range from 2016-07-20 to 2016-08-22. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Skipping Daily data download for symbol QMU16 since download was already done in last 24 hours. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Checking Daily data file for symbol QMV16 for the date range from 2016-08-22 to 2016-09-20. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Skipping Daily data download for symbol QMV16 since download was already done in last 24 hours. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Checking Daily data file for symbol QMX16 for the date range from 2016-09-20 to 2016-10-11. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Checking Daily data file for symbol QMZ16 for the date range from 2016-10-11 to 2016-10-11. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Price data for daily data file QMZ16.dly. Date: 2016-10-11, Price: 51.525. Date: 2016-10-11, Price: 51.525 | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Price data for daily data file QMX16.dly. Date: 2016-09-20, Price: 44.05. Date: 2016-10-10, Price: 51.35 | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Price data for daily data file QMV16.dly. Date: 2016-08-22, Price: 47.41. Date: 2016-09-19, Price: 43.3 | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Price data for daily data file QMU16.dly. Date: 2016-07-20, Price: 45.75. Date: 2016-08-19, Price: 48.52 | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Price data for daily data file QMQ16.dly. Date: 2016-06-21, Price: 49.85. Date: 2016-07-19, Price: 44.65 | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Price data for daily data file QMN16.dly. Date: 2016-05-20, Price: 48.4. Date: 2016-06-20, Price: 49.375 | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Price data for daily data file QMM16.dly. Date: 2016-04-20, Price: 44.175. Date: 2016-05-19, Price: 48.15 | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Price data for daily data file QMK16.dly. Date: 2016-03-22, Price: 41.45. Date: 2016-04-19, Price: 41.075 | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Price data for daily data file QMJ16.dly. Date: 2016-02-22, Price: 33.4. Date: 2016-03-21, Price: 39.45 | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Price data for daily data file QMH16.dly. Date: 2016-01-20, Price: 28.35. Date: 2016-02-19, Price: 29.64 | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Price data for daily data file QMG16.dly. Date: 2015-12-22, Price: 36.15. Date: 2016-01-19, Price: 28.45 | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Price data for daily data file QMF16.dly. Date: 2015-11-20, Price: 41.9. Date: 2015-12-21, Price: 34.725 | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Price data for daily data file QMZ15.dly. Date: 2015-10-20, Price: 46.29. Date: 2015-11-19, Price: 40.54 | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Price data for daily data file QMX15.dly. Date: 2015-09-22, Price: 46.36. Date: 2015-10-19, Price: 45.89 | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Price data for daily data file QMV15.dly. Date: 2015-08-20, Price: 41.32. Date: 2015-09-21, Price: 46.68 | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Symbols used for continuous contract chart: | 2016-10-11 15:24:38 QMV15 | 2016-10-11 15:24:38 QMX15 | 2016-10-11 15:24:38 QMZ15 | 2016-10-11 15:24:38 QMF16 | 2016-10-11 15:24:38 QMG16 | 2016-10-11 15:24:38 QMH16 | 2016-10-11 15:24:38 QMJ16 | 2016-10-11 15:24:38 QMK16 | 2016-10-11 15:24:38 QMM16 | 2016-10-11 15:24:38 QMN16 | 2016-10-11 15:24:38 QMQ16 | 2016-10-11 15:24:38 QMU16 | 2016-10-11 15:24:38 QMV16 | 2016-10-11 15:24:38 QMX16 | 2016-10-11 15:24:38 QMZ16 | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Performing continuous futures contract back adjustment calculations. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMV15 Open price on 2015-09-22 is 44.85. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMX15 Open price on 2015-09-22 is 46.7. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMV15 price difference to QMX15 is 1.85. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMX15 Open price on 2015-10-20 is 47.1. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMZ15 Open price on 2015-10-20 is 46.575. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMX15 price difference to QMZ15 is -0.525. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMZ15 Open price on 2015-11-20 is 40.7. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMF16 Open price on 2015-11-20 is 41.875. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMZ15 price difference to QMF16 is 1.175. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMF16 Open price on 2015-12-22 is 34.8. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMG16 Open price on 2015-12-22 is 35.85. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMF16 price difference to QMG16 is 1.05. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMG16 Open price on 2016-01-20 is 29.35. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMH16 Open price on 2016-01-20 is 29.475. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMG16 price difference to QMH16 is 0.125. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMH16 Open price on 2016-02-22 is 30.675. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMJ16 Open price on 2016-02-22 is 31.95. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMH16 price difference to QMJ16 is 1.275. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMJ16 Open price on 2016-03-22 is 40.25. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMK16 Open price on 2016-03-22 is 41.6. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMJ16 price difference to QMK16 is 1.35. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMK16 Open price on 2016-04-20 is 39.975. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMM16 Open price on 2016-04-20 is 42.35. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMK16 price difference to QMM16 is 2.375. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMM16 Open price on 2016-05-20 is 47.9. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMN16 Open price on 2016-05-20 is 48.725. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMM16 price difference to QMN16 is 0.825. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMN16 Open price on 2016-06-21 is 48.35. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMQ16 Open price on 2016-06-21 is 49.775. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMN16 price difference to QMQ16 is 1.425. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMQ16 Open price on 2016-07-20 is 45.175. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMU16 Open price on 2016-07-20 is 45.475. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMQ16 price difference to QMU16 is 0.3. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMU16 Open price on 2016-08-22 is 48.375. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMV16 Open price on 2016-08-22 is 49.05. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMU16 price difference to QMV16 is 0.675. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMV16 Open price on 2016-09-20 is 43.2. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMX16 Open price on 2016-09-20 is 43.75. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMV16 price difference to QMX16 is 0.55. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMX16 Open price on 2016-10-11 is 51.125. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMZ16 Open price on 2016-10-11 is 51.65. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | QMX16 price difference to QMZ16 is 0.525. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Back adjust amount for symbol QMV15 is 12.975. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Back adjust amount for symbol QMX15 is 11.125. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Back adjust amount for symbol QMZ15 is 11.65. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Back adjust amount for symbol QMF16 is 10.475. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Back adjust amount for symbol QMG16 is 9.425. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Back adjust amount for symbol QMH16 is 9.3. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Back adjust amount for symbol QMJ16 is 8.025. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Back adjust amount for symbol QMK16 is 6.675. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Back adjust amount for symbol QMM16 is 4.3. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Back adjust amount for symbol QMN16 is 3.475. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Back adjust amount for symbol QMQ16 is 2.05. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Back adjust amount for symbol QMU16 is 1.75. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Back adjust amount for symbol QMV16 is 1.075. | 2016-10-11 15:24:38 QMZ16 [CB] Daily #2 | Back adjust amount for symbol QMX16 is 0.525. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | Reloading chart. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | Date rule based rollover from QMN16 to next contract occurs at 2016-06-21. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | Date rule based rollover from QMQ16 to next contract occurs at 2016-07-20. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | Date rule based rollover from QMU16 to next contract occurs at 2016-08-22. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | Date rule based rollover from QMV16 to next contract occurs at 2016-09-20. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | Date rule based rollover from QMX16 to next contract occurs at 2016-10-20. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | Date rule based rollover from QMZ16 to next contract occurs at 2016-11-22. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | Intraday data file for QMN16 exists and is empty. Skipping Intraday data download. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | Checking Daily data file for symbol QMN16 for the date range from 2016-05-20 to 2016-06-21. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | Skipping Daily data download for symbol QMN16 since download was already done in last 24 hours. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | Intraday data file for QMQ16 exists and is empty. Skipping Intraday data download. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | Checking Daily data file for symbol QMQ16 for the date range from 2016-06-21 to 2016-07-20. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | Skipping Daily data download for symbol QMQ16 since download was already done in last 24 hours. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | Skipping checking Intraday data file for symbol QMU16 since download was already done in last 24 hours. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | Checking Daily data file for symbol QMU16 for the date range from 2016-07-20 to 2016-08-22. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | Skipping Daily data download for symbol QMU16 since download was already done in last 24 hours. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | Skipping checking Intraday data file for symbol QMV16 since download was already done in last 24 hours. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | Checking Daily data file for symbol QMV16 for the date range from 2016-08-22 to 2016-09-20. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | Skipping Daily data download for symbol QMV16 since download was already done in last 24 hours. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | Checking Intraday data file for symbol QMX16 for the date range from 2016-09-20 to 2016-10-11. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | Checking Daily data file for symbol QMX16 for the date range from 2016-09-20 to 2016-10-11. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | Checking Intraday data file for symbol QMZ16 for the date range from 2016-10-11 to 0. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | Checking Daily data file for symbol QMZ16 for the date range from 2016-10-11 to 2016-10-11. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | Price data for daily data file QMZ16.dly. Date: 2016-10-11, Price: 51.525. Date: 2016-10-11, Price: 51.525 | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | Price data for daily data file QMX16.dly. Date: 2016-09-20, Price: 44.05. Date: 2016-10-10, Price: 51.35 | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | Price data for daily data file QMV16.dly. Date: 2016-08-22, Price: 47.41. Date: 2016-09-19, Price: 43.3 | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | Price data for daily data file QMU16.dly. Date: 2016-07-20, Price: 45.75. Date: 2016-08-19, Price: 48.52 | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | Price data for daily data file QMQ16.dly. Date: 2016-06-21, Price: 49.85. Date: 2016-07-19, Price: 44.65 | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | Price data for daily data file QMN16.dly. Date: 2016-05-20, Price: 48.4. Date: 2016-06-20, Price: 49.375 | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | Symbols used for continuous contract chart: | 2016-10-11 15:24:38 QMN16 | 2016-10-11 15:24:38 QMQ16 | 2016-10-11 15:24:38 QMU16 | 2016-10-11 15:24:38 QMV16 | 2016-10-11 15:24:38 QMX16 | 2016-10-11 15:24:38 QMZ16 | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | Performing continuous futures contract back adjustment calculations. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | QMN16 Open price on 2016-06-21 is 48.35. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | QMQ16 Open price on 2016-06-21 is 49.775. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | QMN16 price difference to QMQ16 is 1.425. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | QMQ16 Open price on 2016-07-20 is 45.175. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | QMU16 Open price on 2016-07-20 is 45.475. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | QMQ16 price difference to QMU16 is 0.3. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | QMU16 Open price on 2016-08-22 is 48.375. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | QMV16 Open price on 2016-08-22 is 49.05. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | QMU16 price difference to QMV16 is 0.675. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | QMV16 Open price on 2016-09-20 is 43.2. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | QMX16 Open price on 2016-09-20 is 43.75. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | QMV16 price difference to QMX16 is 0.55. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | QMX16 Open price on 2016-10-11 is 51.125. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | QMZ16 Open price on 2016-10-11 is 51.65. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | QMX16 price difference to QMZ16 is 0.525. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | Back adjust amount for symbol QMN16 is 3.475. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | Back adjust amount for symbol QMQ16 is 2.05. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | Back adjust amount for symbol QMU16 is 1.75. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | Back adjust amount for symbol QMV16 is 1.075. | 2016-10-11 15:24:38 QMZ16 [CB] 30 Min #3 | Back adjust amount for symbol QMX16 is 0.525. | 2016-10-11 15:24:38 Mapping QMZ16 to QMZ16. Service code: nymex | 2016-10-11 15:24:38 SC Data - All Services | Starting real-time market data updates for: QMZ16. ID: 123 | 2016-10-11 15:24:38 SC Data - All Services | Using username 0 | 2016-10-11 15:24:38 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 443 | 2016-10-11 15:24:38 SC Data - All Services | Requesting security definition data for: QMZ16. ID: 123 | 2016-10-11 15:24:38 HD Request # 125 | Downloading Historical Daily chart data for QMZ16. Starting date: 2016-10-10. Service: tda | 2016-10-11 15:24:38 HD Request # 125 | Using user Barchart Historical data account. | 2016-10-11 15:24:38 HD Request # 125 | Requesting historical Daily data for QMZ16 starting at 2016-10-09 | 2016-10-11 15:24:38 Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-10-11 15:24:38 Socket (10) | Connected. | 2016-10-11 15:24:40 SC Data - All Services | Connected to server. | 2016-10-11 15:24:40 SC Data - All Services | Sending Encoding Request to server | 2016-10-11 15:24:40 SC Data - All Services | Setting DTC Encoding to Binary VLS | 2016-10-11 15:24:40 SC Data - All Services | Sending logon request message. | 2016-10-11 15:24:40 HD Request # 125 | Receiving historical Daily data for QMZ16 starting at 2016-10-10 | 2016-10-11 15:24:40 HD Request # 125 | Writing historical Daily data to the file QMZ16.dly | 2016-10-11 15:24:40 HD Request # 125 | Received 2 records from 2016-10-10 00:00:00 to 2016-10-11 00:00:00 (2.0 days) and wrote 2 records for QMZ16 | 2016-10-11 15:24:40 HD Request # 125 | Daily download COMPLETE for QMZ16. Completion time: 0s. Unique request ID: 124 | 2016-10-11 15:24:40 Removed historical data download ID 124 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Reloading chart. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMV15 to next contract occurs at 2015-09-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMX15 to next contract occurs at 2015-10-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMZ15 to next contract occurs at 2015-11-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMF16 to next contract occurs at 2015-12-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMG16 to next contract occurs at 2016-01-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMH16 to next contract occurs at 2016-02-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMJ16 to next contract occurs at 2016-03-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMK16 to next contract occurs at 2016-04-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMM16 to next contract occurs at 2016-05-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMN16 to next contract occurs at 2016-06-21. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMQ16 to next contract occurs at 2016-07-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMU16 to next contract occurs at 2016-08-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMV16 to next contract occurs at 2016-09-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMX16 to next contract occurs at 2016-10-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMZ16 to next contract occurs at 2016-11-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMV15 for the date range from 2015-08-20 to 2015-09-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Skipping Daily data download for symbol QMV15 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMX15 for the date range from 2015-09-22 to 2015-10-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Skipping Daily data download for symbol QMX15 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMZ15 for the date range from 2015-10-20 to 2015-11-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Skipping Daily data download for symbol QMZ15 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMF16 for the date range from 2015-11-20 to 2015-12-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Skipping Daily data download for symbol QMF16 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMG16 for the date range from 2015-12-22 to 2016-01-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Skipping Daily data download for symbol QMG16 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMH16 for the date range from 2016-01-20 to 2016-02-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Skipping Daily data download for symbol QMH16 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMJ16 for the date range from 2016-02-22 to 2016-03-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Skipping Daily data download for symbol QMJ16 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMK16 for the date range from 2016-03-22 to 2016-04-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Skipping Daily data download for symbol QMK16 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMM16 for the date range from 2016-04-20 to 2016-05-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Skipping Daily data download for symbol QMM16 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMN16 for the date range from 2016-05-20 to 2016-06-21. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Skipping Daily data download for symbol QMN16 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMQ16 for the date range from 2016-06-21 to 2016-07-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Skipping Daily data download for symbol QMQ16 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMU16 for the date range from 2016-07-20 to 2016-08-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Skipping Daily data download for symbol QMU16 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMV16 for the date range from 2016-08-22 to 2016-09-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Skipping Daily data download for symbol QMV16 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMX16 for the date range from 2016-09-20 to 2016-10-11. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMZ16 for the date range from 2016-10-11 to 2016-10-11. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMZ16.dly. Date: 2016-10-11, Price: 51.275. Date: 2016-10-11, Price: 51.275 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMX16.dly. Date: 2016-09-20, Price: 44.05. Date: 2016-10-10, Price: 51.35 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMV16.dly. Date: 2016-08-22, Price: 47.41. Date: 2016-09-19, Price: 43.3 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMU16.dly. Date: 2016-07-20, Price: 45.75. Date: 2016-08-19, Price: 48.52 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMQ16.dly. Date: 2016-06-21, Price: 49.85. Date: 2016-07-19, Price: 44.65 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMN16.dly. Date: 2016-05-20, Price: 48.4. Date: 2016-06-20, Price: 49.375 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMM16.dly. Date: 2016-04-20, Price: 44.175. Date: 2016-05-19, Price: 48.15 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMK16.dly. Date: 2016-03-22, Price: 41.45. Date: 2016-04-19, Price: 41.075 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMJ16.dly. Date: 2016-02-22, Price: 33.4. Date: 2016-03-21, Price: 39.45 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMH16.dly. Date: 2016-01-20, Price: 28.35. Date: 2016-02-19, Price: 29.64 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMG16.dly. Date: 2015-12-22, Price: 36.15. Date: 2016-01-19, Price: 28.45 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMF16.dly. Date: 2015-11-20, Price: 41.9. Date: 2015-12-21, Price: 34.725 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMZ15.dly. Date: 2015-10-20, Price: 46.29. Date: 2015-11-19, Price: 40.54 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMX15.dly. Date: 2015-09-22, Price: 46.36. Date: 2015-10-19, Price: 45.89 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMV15.dly. Date: 2015-08-20, Price: 41.32. Date: 2015-09-21, Price: 46.68 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Symbols used for continuous contract chart: | 2016-10-11 15:24:40 QMV15 | 2016-10-11 15:24:40 QMX15 | 2016-10-11 15:24:40 QMZ15 | 2016-10-11 15:24:40 QMF16 | 2016-10-11 15:24:40 QMG16 | 2016-10-11 15:24:40 QMH16 | 2016-10-11 15:24:40 QMJ16 | 2016-10-11 15:24:40 QMK16 | 2016-10-11 15:24:40 QMM16 | 2016-10-11 15:24:40 QMN16 | 2016-10-11 15:24:40 QMQ16 | 2016-10-11 15:24:40 QMU16 | 2016-10-11 15:24:40 QMV16 | 2016-10-11 15:24:40 QMX16 | 2016-10-11 15:24:40 QMZ16 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Performing continuous futures contract back adjustment calculations. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMV15 Open price on 2015-09-22 is 44.85. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMX15 Open price on 2015-09-22 is 46.7. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMV15 price difference to QMX15 is 1.85. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMX15 Open price on 2015-10-20 is 47.1. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMZ15 Open price on 2015-10-20 is 46.575. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMX15 price difference to QMZ15 is -0.525. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMZ15 Open price on 2015-11-20 is 40.7. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMF16 Open price on 2015-11-20 is 41.875. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMZ15 price difference to QMF16 is 1.175. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMF16 Open price on 2015-12-22 is 34.8. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMG16 Open price on 2015-12-22 is 35.85. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMF16 price difference to QMG16 is 1.05. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMG16 Open price on 2016-01-20 is 29.35. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMH16 Open price on 2016-01-20 is 29.475. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMG16 price difference to QMH16 is 0.125. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMH16 Open price on 2016-02-22 is 30.675. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMJ16 Open price on 2016-02-22 is 31.95. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMH16 price difference to QMJ16 is 1.275. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMJ16 Open price on 2016-03-22 is 40.25. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMK16 Open price on 2016-03-22 is 41.6. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMJ16 price difference to QMK16 is 1.35. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMK16 Open price on 2016-04-20 is 39.975. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMM16 Open price on 2016-04-20 is 42.35. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMK16 price difference to QMM16 is 2.375. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMM16 Open price on 2016-05-20 is 47.9. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMN16 Open price on 2016-05-20 is 48.725. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMM16 price difference to QMN16 is 0.825. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMN16 Open price on 2016-06-21 is 48.35. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMQ16 Open price on 2016-06-21 is 49.775. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMN16 price difference to QMQ16 is 1.425. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMQ16 Open price on 2016-07-20 is 45.175. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMU16 Open price on 2016-07-20 is 45.475. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMQ16 price difference to QMU16 is 0.3. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMU16 Open price on 2016-08-22 is 48.375. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMV16 Open price on 2016-08-22 is 49.05. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMU16 price difference to QMV16 is 0.675. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMV16 Open price on 2016-09-20 is 43.2. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMX16 Open price on 2016-09-20 is 43.75. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMV16 price difference to QMX16 is 0.55. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMX16 Open price on 2016-10-11 is 51.125. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMZ16 Open price on 2016-10-11 is 51.65. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | QMX16 price difference to QMZ16 is 0.525. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMV15 is 12.975. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMX15 is 11.125. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMZ15 is 11.65. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMF16 is 10.475. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMG16 is 9.425. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMH16 is 9.3. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMJ16 is 8.025. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMK16 is 6.675. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMM16 is 4.3. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMN16 is 3.475. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMQ16 is 2.05. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMU16 is 1.75. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMV16 is 1.075. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMX16 is 0.525. | 2016-10-11 15:24:40 SC Data - All Services | Received logon response. | 2016-10-11 15:24:40 SC Data - All Services | Server Name: SC Realtime Server. | 2016-10-11 15:24:40 SC Data - All Services | Server protocol version: 7. Client protocol version: 7 | 2016-10-11 15:24:40 SC Data - All Services | Successfully connected. | 2016-10-11 15:24:40 SC Data - All Services | Restarting real-time data updates for symbol: QMZ16 -> QMZ16 | 2016-10-11 15:24:40 Intraday data recording state for symbol QMZ16 is set to download 'Pending'. | 2016-10-11 15:24:40 Market data subscription status is not known while delaying historical data download for symbol: QMZ16 | 2016-10-11 15:24:40 Delaying start of download for QMZ16 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Reloading chart. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMV06 to next contract occurs at 2006-09-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMX06 to next contract occurs at 2006-10-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMZ06 to next contract occurs at 2006-11-21. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMF07 to next contract occurs at 2006-12-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMG07 to next contract occurs at 2007-01-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMH07 to next contract occurs at 2007-02-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMJ07 to next contract occurs at 2007-03-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMK07 to next contract occurs at 2007-04-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMM07 to next contract occurs at 2007-05-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMN07 to next contract occurs at 2007-06-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMQ07 to next contract occurs at 2007-07-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMU07 to next contract occurs at 2007-08-21. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMV07 to next contract occurs at 2007-09-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMX07 to next contract occurs at 2007-10-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMZ07 to next contract occurs at 2007-11-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMF08 to next contract occurs at 2007-12-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMG08 to next contract occurs at 2008-01-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMH08 to next contract occurs at 2008-02-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMJ08 to next contract occurs at 2008-03-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMK08 to next contract occurs at 2008-04-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMM08 to next contract occurs at 2008-05-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMN08 to next contract occurs at 2008-06-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMQ08 to next contract occurs at 2008-07-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMU08 to next contract occurs at 2008-08-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMV08 to next contract occurs at 2008-09-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMX08 to next contract occurs at 2008-10-21. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMZ08 to next contract occurs at 2008-11-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMF09 to next contract occurs at 2008-12-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMG09 to next contract occurs at 2009-01-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMH09 to next contract occurs at 2009-02-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMJ09 to next contract occurs at 2009-03-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMK09 to next contract occurs at 2009-04-21. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMM09 to next contract occurs at 2009-05-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMN09 to next contract occurs at 2009-06-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMQ09 to next contract occurs at 2009-07-21. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMU09 to next contract occurs at 2009-08-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMV09 to next contract occurs at 2009-09-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMX09 to next contract occurs at 2009-10-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMZ09 to next contract occurs at 2009-11-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMF10 to next contract occurs at 2009-12-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMG10 to next contract occurs at 2010-01-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMH10 to next contract occurs at 2010-02-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMJ10 to next contract occurs at 2010-03-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMK10 to next contract occurs at 2010-04-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMM10 to next contract occurs at 2010-05-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMN10 to next contract occurs at 2010-06-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMQ10 to next contract occurs at 2010-07-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMU10 to next contract occurs at 2010-08-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMV10 to next contract occurs at 2010-09-21. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMX10 to next contract occurs at 2010-10-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMZ10 to next contract occurs at 2010-11-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMF11 to next contract occurs at 2010-12-21. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMG11 to next contract occurs at 2011-01-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMH11 to next contract occurs at 2011-02-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMJ11 to next contract occurs at 2011-03-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMK11 to next contract occurs at 2011-04-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMM11 to next contract occurs at 2011-05-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMN11 to next contract occurs at 2011-06-21. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMQ11 to next contract occurs at 2011-07-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMU11 to next contract occurs at 2011-08-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMV11 to next contract occurs at 2011-09-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMX11 to next contract occurs at 2011-10-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMZ11 to next contract occurs at 2011-11-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMF12 to next contract occurs at 2011-12-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMG12 to next contract occurs at 2012-01-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMH12 to next contract occurs at 2012-02-21. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMJ12 to next contract occurs at 2012-03-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMK12 to next contract occurs at 2012-04-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMM12 to next contract occurs at 2012-05-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMN12 to next contract occurs at 2012-06-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMQ12 to next contract occurs at 2012-07-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMU12 to next contract occurs at 2012-08-21. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMV12 to next contract occurs at 2012-09-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMX12 to next contract occurs at 2012-10-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMZ12 to next contract occurs at 2012-11-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMF13 to next contract occurs at 2012-12-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMG13 to next contract occurs at 2013-01-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMH13 to next contract occurs at 2013-02-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMJ13 to next contract occurs at 2013-03-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMK13 to next contract occurs at 2013-04-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMM13 to next contract occurs at 2013-05-21. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMN13 to next contract occurs at 2013-06-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMQ13 to next contract occurs at 2013-07-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMU13 to next contract occurs at 2013-08-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMV13 to next contract occurs at 2013-09-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMX13 to next contract occurs at 2013-10-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMZ13 to next contract occurs at 2013-11-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMF14 to next contract occurs at 2013-12-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMG14 to next contract occurs at 2014-01-21. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMH14 to next contract occurs at 2014-02-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMJ14 to next contract occurs at 2014-03-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMK14 to next contract occurs at 2014-04-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMM14 to next contract occurs at 2014-05-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMN14 to next contract occurs at 2014-06-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMQ14 to next contract occurs at 2014-07-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMU14 to next contract occurs at 2014-08-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMV14 to next contract occurs at 2014-09-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMX14 to next contract occurs at 2014-10-21. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMZ14 to next contract occurs at 2014-11-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMF15 to next contract occurs at 2014-12-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMG15 to next contract occurs at 2015-01-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMH15 to next contract occurs at 2015-02-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMJ15 to next contract occurs at 2015-03-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMK15 to next contract occurs at 2015-04-21. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMM15 to next contract occurs at 2015-05-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMN15 to next contract occurs at 2015-06-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMQ15 to next contract occurs at 2015-07-21. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMU15 to next contract occurs at 2015-08-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMV15 to next contract occurs at 2015-09-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMX15 to next contract occurs at 2015-10-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMZ15 to next contract occurs at 2015-11-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMF16 to next contract occurs at 2015-12-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMG16 to next contract occurs at 2016-01-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMH16 to next contract occurs at 2016-02-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMJ16 to next contract occurs at 2016-03-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMK16 to next contract occurs at 2016-04-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMM16 to next contract occurs at 2016-05-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMN16 to next contract occurs at 2016-06-21. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMQ16 to next contract occurs at 2016-07-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMU16 to next contract occurs at 2016-08-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMV16 to next contract occurs at 2016-09-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMX16 to next contract occurs at 2016-10-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMZ16 to next contract occurs at 2016-11-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMV06 for the date range from 2006-08-22 to 2006-09-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMV06 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMX06 for the date range from 2006-09-20 to 2006-10-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMX06 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMZ06 for the date range from 2006-10-20 to 2006-11-21. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMZ06 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMF07 for the date range from 2006-11-21 to 2006-12-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMF07 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMG07 for the date range from 2006-12-20 to 2007-01-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMG07 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMH07 for the date range from 2007-01-22 to 2007-02-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMH07 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMJ07 for the date range from 2007-02-20 to 2007-03-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMJ07 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMK07 for the date range from 2007-03-20 to 2007-04-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMK07 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMM07 for the date range from 2007-04-20 to 2007-05-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMM07 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMN07 for the date range from 2007-05-22 to 2007-06-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMN07 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMQ07 for the date range from 2007-06-20 to 2007-07-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMQ07 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMU07 for the date range from 2007-07-20 to 2007-08-21. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMU07 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMV07 for the date range from 2007-08-21 to 2007-09-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMV07 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMX07 for the date range from 2007-09-20 to 2007-10-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMX07 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMZ07 for the date range from 2007-10-22 to 2007-11-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMZ07 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMF08 for the date range from 2007-11-20 to 2007-12-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMF08 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMG08 for the date range from 2007-12-20 to 2008-01-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMG08 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMH08 for the date range from 2008-01-22 to 2008-02-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMH08 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMJ08 for the date range from 2008-02-20 to 2008-03-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMJ08 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMK08 for the date range from 2008-03-20 to 2008-04-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMK08 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMM08 for the date range from 2008-04-22 to 2008-05-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMM08 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMN08 for the date range from 2008-05-20 to 2008-06-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMN08 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMQ08 for the date range from 2008-06-20 to 2008-07-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMQ08 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMU08 for the date range from 2008-07-22 to 2008-08-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMU08 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMV08 for the date range from 2008-08-20 to 2008-09-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMV08 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMX08 for the date range from 2008-09-22 to 2008-10-21. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMX08 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMZ08 for the date range from 2008-10-21 to 2008-11-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMZ08 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMF09 for the date range from 2008-11-20 to 2008-12-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMF09 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMG09 for the date range from 2008-12-22 to 2009-01-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMG09 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMH09 for the date range from 2009-01-20 to 2009-02-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMH09 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMJ09 for the date range from 2009-02-20 to 2009-03-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMJ09 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMK09 for the date range from 2009-03-20 to 2009-04-21. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMK09 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMM09 for the date range from 2009-04-21 to 2009-05-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMM09 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMN09 for the date range from 2009-05-20 to 2009-06-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMN09 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMQ09 for the date range from 2009-06-22 to 2009-07-21. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMQ09 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMU09 for the date range from 2009-07-21 to 2009-08-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMU09 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMV09 for the date range from 2009-08-20 to 2009-09-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMV09 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMX09 for the date range from 2009-09-22 to 2009-10-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMX09 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMZ09 for the date range from 2009-10-20 to 2009-11-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMZ09 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMF10 for the date range from 2009-11-20 to 2009-12-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMF10 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMG10 for the date range from 2009-12-22 to 2010-01-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMG10 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMH10 for the date range from 2010-01-20 to 2010-02-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMH10 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMJ10 for the date range from 2010-02-22 to 2010-03-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMJ10 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMK10 for the date range from 2010-03-22 to 2010-04-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMK10 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMM10 for the date range from 2010-04-20 to 2010-05-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMM10 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMN10 for the date range from 2010-05-20 to 2010-06-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMN10 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMQ10 for the date range from 2010-06-22 to 2010-07-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMQ10 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMU10 for the date range from 2010-07-20 to 2010-08-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMU10 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMV10 for the date range from 2010-08-20 to 2010-09-21. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMV10 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMX10 for the date range from 2010-09-21 to 2010-10-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMX10 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMZ10 for the date range from 2010-10-20 to 2010-11-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMZ10 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMF11 for the date range from 2010-11-22 to 2010-12-21. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMF11 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMG11 for the date range from 2010-12-21 to 2011-01-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMG11 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMH11 for the date range from 2011-01-20 to 2011-02-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMH11 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMJ11 for the date range from 2011-02-22 to 2011-03-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMJ11 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMK11 for the date range from 2011-03-22 to 2011-04-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMK11 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMM11 for the date range from 2011-04-20 to 2011-05-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMM11 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMN11 for the date range from 2011-05-20 to 2011-06-21. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMN11 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMQ11 for the date range from 2011-06-21 to 2011-07-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMQ11 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMU11 for the date range from 2011-07-20 to 2011-08-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMU11 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMV11 for the date range from 2011-08-22 to 2011-09-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMV11 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMX11 for the date range from 2011-09-20 to 2011-10-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMX11 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMZ11 for the date range from 2011-10-20 to 2011-11-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMZ11 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMF12 for the date range from 2011-11-22 to 2011-12-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMF12 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMG12 for the date range from 2011-12-20 to 2012-01-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMG12 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMH12 for the date range from 2012-01-20 to 2012-02-21. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMH12 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMJ12 for the date range from 2012-02-21 to 2012-03-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMJ12 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMK12 for the date range from 2012-03-20 to 2012-04-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMK12 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMM12 for the date range from 2012-04-20 to 2012-05-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMM12 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMN12 for the date range from 2012-05-22 to 2012-06-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMN12 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMQ12 for the date range from 2012-06-20 to 2012-07-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMQ12 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMU12 for the date range from 2012-07-20 to 2012-08-21. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMU12 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMV12 for the date range from 2012-08-21 to 2012-09-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMV12 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMX12 for the date range from 2012-09-20 to 2012-10-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMX12 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMZ12 for the date range from 2012-10-22 to 2012-11-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMZ12 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMF13 for the date range from 2012-11-20 to 2012-12-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMF13 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMG13 for the date range from 2012-12-20 to 2013-01-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMG13 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMH13 for the date range from 2013-01-22 to 2013-02-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMH13 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMJ13 for the date range from 2013-02-20 to 2013-03-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMJ13 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMK13 for the date range from 2013-03-20 to 2013-04-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMK13 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMM13 for the date range from 2013-04-22 to 2013-05-21. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMM13 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMN13 for the date range from 2013-05-21 to 2013-06-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMN13 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMQ13 for the date range from 2013-06-20 to 2013-07-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMQ13 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMU13 for the date range from 2013-07-22 to 2013-08-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMU13 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMV13 for the date range from 2013-08-20 to 2013-09-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMV13 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMX13 for the date range from 2013-09-20 to 2013-10-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMX13 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMZ13 for the date range from 2013-10-22 to 2013-11-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMZ13 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMF14 for the date range from 2013-11-20 to 2013-12-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMF14 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMG14 for the date range from 2013-12-20 to 2014-01-21. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMG14 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMH14 for the date range from 2014-01-21 to 2014-02-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMH14 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMJ14 for the date range from 2014-02-20 to 2014-03-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMJ14 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMK14 for the date range from 2014-03-20 to 2014-04-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMK14 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMM14 for the date range from 2014-04-22 to 2014-05-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMM14 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMN14 for the date range from 2014-05-20 to 2014-06-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMN14 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMQ14 for the date range from 2014-06-20 to 2014-07-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMQ14 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMU14 for the date range from 2014-07-22 to 2014-08-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMU14 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMV14 for the date range from 2014-08-20 to 2014-09-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMV14 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMX14 for the date range from 2014-09-22 to 2014-10-21. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMX14 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMZ14 for the date range from 2014-10-21 to 2014-11-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMZ14 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMF15 for the date range from 2014-11-20 to 2014-12-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMF15 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMG15 for the date range from 2014-12-22 to 2015-01-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMG15 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMH15 for the date range from 2015-01-20 to 2015-02-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMH15 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMJ15 for the date range from 2015-02-20 to 2015-03-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMJ15 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMK15 for the date range from 2015-03-20 to 2015-04-21. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMK15 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMM15 for the date range from 2015-04-21 to 2015-05-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMM15 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMN15 for the date range from 2015-05-20 to 2015-06-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMN15 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMQ15 for the date range from 2015-06-22 to 2015-07-21. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMQ15 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMU15 for the date range from 2015-07-21 to 2015-08-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMU15 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMV15 for the date range from 2015-08-20 to 2015-09-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMV15 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMX15 for the date range from 2015-09-22 to 2015-10-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMX15 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMZ15 for the date range from 2015-10-20 to 2015-11-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMZ15 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMF16 for the date range from 2015-11-20 to 2015-12-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMF16 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMG16 for the date range from 2015-12-22 to 2016-01-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMG16 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMH16 for the date range from 2016-01-20 to 2016-02-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMH16 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMJ16 for the date range from 2016-02-22 to 2016-03-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMJ16 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMK16 for the date range from 2016-03-22 to 2016-04-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMK16 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMM16 for the date range from 2016-04-20 to 2016-05-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMM16 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMN16 for the date range from 2016-05-20 to 2016-06-21. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMN16 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMQ16 for the date range from 2016-06-21 to 2016-07-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMQ16 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMU16 for the date range from 2016-07-20 to 2016-08-22. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMU16 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMV16 for the date range from 2016-08-22 to 2016-09-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMV16 since download was already done in last 24 hours. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMX16 for the date range from 2016-09-20 to 2016-10-11. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMZ16 for the date range from 2016-10-11 to 2016-10-11. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMZ16.dly. Date: 2016-10-11, Price: 51.275. Date: 2016-10-11, Price: 51.275 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMX16.dly. Date: 2016-09-20, Price: 44.05. Date: 2016-10-10, Price: 51.35 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMV16.dly. Date: 2016-08-22, Price: 47.41. Date: 2016-09-19, Price: 43.3 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMU16.dly. Date: 2016-07-20, Price: 45.75. Date: 2016-08-19, Price: 48.52 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMQ16.dly. Date: 2016-06-21, Price: 49.85. Date: 2016-07-19, Price: 44.65 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMN16.dly. Date: 2016-05-20, Price: 48.4. Date: 2016-06-20, Price: 49.375 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMM16.dly. Date: 2016-04-20, Price: 44.175. Date: 2016-05-19, Price: 48.15 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMK16.dly. Date: 2016-03-22, Price: 41.45. Date: 2016-04-19, Price: 41.075 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMJ16.dly. Date: 2016-02-22, Price: 33.4. Date: 2016-03-21, Price: 39.45 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMH16.dly. Date: 2016-01-20, Price: 28.35. Date: 2016-02-19, Price: 29.64 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMG16.dly. Date: 2015-12-22, Price: 36.15. Date: 2016-01-19, Price: 28.45 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMF16.dly. Date: 2015-11-20, Price: 41.9. Date: 2015-12-21, Price: 34.725 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMZ15.dly. Date: 2015-10-20, Price: 46.29. Date: 2015-11-19, Price: 40.54 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMX15.dly. Date: 2015-09-22, Price: 46.36. Date: 2015-10-19, Price: 45.89 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMV15.dly. Date: 2015-08-20, Price: 41.32. Date: 2015-09-21, Price: 46.68 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMU15.dly. Date: 2015-07-21, Price: 50.86. Date: 2015-08-19, Price: 40.8 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMQ15.dly. Date: 2015-06-22, Price: 60.375. Date: 2015-07-20, Price: 50.15 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMN15.dly. Date: 2015-05-20, Price: 58.975. Date: 2015-06-19, Price: 59.6 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMM15.dly. Date: 2015-04-21, Price: 56.6. Date: 2015-05-19, Price: 59.425 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMK15.dly. Date: 2015-03-20, Price: 46.575. Date: 2015-04-20, Price: 56.375 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMJ15.dly. Date: 2015-02-20, Price: 50.8. Date: 2015-03-19, Price: 43.95 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMH15.dly. Date: 2015-01-20, Price: 46.475. Date: 2015-02-19, Price: 51.15 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMG15.dly. Date: 2014-12-22, Price: 55.25. Date: 2015-01-19, Price: 48.7 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMF15.dly. Date: 2014-11-20, Price: 75.85. Date: 2014-12-19, Price: 54.1 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMZ14.dly. Date: 2014-10-21, Price: 82.5. Date: 2014-11-19, Price: 74.575 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMX14.dly. Date: 2014-09-22, Price: 90.875. Date: 2014-10-20, Price: 82.7 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMV14.dly. Date: 2014-08-20, Price: 93.45. Date: 2014-09-19, Price: 92.4 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMU14.dly. Date: 2014-07-22, Price: 102.4. Date: 2014-08-19, Price: 94.475 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMQ14.dly. Date: 2014-06-20, Price: 106.825. Date: 2014-07-21, Price: 104.6 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMN14.dly. Date: 2014-05-20, Price: 102.325. Date: 2014-06-19, Price: 106.425 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMM14.dly. Date: 2014-04-22, Price: 101.75. Date: 2014-05-19, Price: 102.6 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMK14.dly. Date: 2014-03-20, Price: 98.9. Date: 2014-04-21, Price: 104.375 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMJ14.dly. Date: 2014-02-20, Price: 102.75. Date: 2014-03-19, Price: 100.375 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMH14.dly. Date: 2014-01-21, Price: 94.975. Date: 2014-02-19, Price: 103.3 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMG14.dly. Date: 2013-12-20, Price: 99.325. Date: 2014-01-20, Price: 94.375 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMF14.dly. Date: 2013-11-20, Price: 93.85. Date: 2013-12-19, Price: 97.8 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMZ13.dly. Date: 2013-10-22, Price: 98.3. Date: 2013-11-19, Price: 93.35 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMX13.dly. Date: 2013-09-20, Price: 104.75. Date: 2013-10-21, Price: 99.225 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMV13.dly. Date: 2013-08-20, Price: 105.1. Date: 2013-09-19, Price: 106.4 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMU13.dly. Date: 2013-07-22, Price: 106.95. Date: 2013-08-19, Price: 107.1 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMQ13.dly. Date: 2013-06-20, Price: 95.15. Date: 2013-07-19, Price: 108.05 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMN13.dly. Date: 2013-05-21, Price: 96.175. Date: 2013-06-19, Price: 98.25 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMM13.dly. Date: 2013-04-22, Price: 89.2. Date: 2013-05-20, Price: 96.7 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMK13.dly. Date: 2013-03-20, Price: 93.5. Date: 2013-04-19, Price: 88 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMJ13.dly. Date: 2013-02-20, Price: 95.225. Date: 2013-03-19, Price: 92.15 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMH13.dly. Date: 2013-01-22, Price: 96.675. Date: 2013-02-19, Price: 96.65 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMG13.dly. Date: 2012-12-20, Price: 90.125. Date: 2013-01-21, Price: 95.55 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMF13.dly. Date: 2012-11-20, Price: 86.75. Date: 2012-12-19, Price: 87.925 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMZ12.dly. Date: 2012-10-22, Price: 88.65. Date: 2012-11-19, Price: 85.45 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMX12.dly. Date: 2012-09-20, Price: 92.425. Date: 2012-10-19, Price: 90.05 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMV12.dly. Date: 2012-08-21, Price: 96.85. Date: 2012-09-19, Price: 91.975 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMU12.dly. Date: 2012-07-20, Price: 91.825. Date: 2012-08-20, Price: 95.975 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMQ12.dly. Date: 2012-06-20, Price: 81.45. Date: 2012-07-19, Price: 92.65 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMN12.dly. Date: 2012-05-22, Price: 91.85. Date: 2012-06-19, Price: 84.025 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMM12.dly. Date: 2012-04-20, Price: 103.875. Date: 2012-05-21, Price: 92.575 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMK12.dly. Date: 2012-03-20, Price: 106.075. Date: 2012-04-19, Price: 102.275 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMJ12.dly. Date: 2012-02-21, Price: 106.25. Date: 2012-03-19, Price: 108.1 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMH12.dly. Date: 2012-01-20, Price: 98.325. Date: 2012-02-20, Price: 103.25 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMG12.dly. Date: 2011-12-20, Price: 97.25. Date: 2012-01-19, Price: 100.4 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMF12.dly. Date: 2011-11-22, Price: 98. Date: 2011-12-19, Price: 93.875 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMZ11.dly. Date: 2011-10-20, Price: 86.075. Date: 2011-11-21, Price: 98.825 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMX11.dly. Date: 2011-09-20, Price: 86.925. Date: 2011-10-19, Price: 86.1 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMV11.dly. Date: 2011-08-22, Price: 84.425. Date: 2011-09-19, Price: 85.7 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMU11.dly. Date: 2011-07-20, Price: 98.4. Date: 2011-08-19, Price: 82.25 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMQ11.dly. Date: 2011-06-21, Price: 94.175. Date: 2011-07-19, Price: 97.5 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMN11.dly. Date: 2011-05-20, Price: 100.1. Date: 2011-06-20, Price: 93.25 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMM11.dly. Date: 2011-04-20, Price: 111.45. Date: 2011-05-19, Price: 98.45 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMK11.dly. Date: 2011-03-22, Price: 104.975. Date: 2011-04-19, Price: 107.125 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMJ11.dly. Date: 2011-02-22, Price: 95.425. Date: 2011-03-21, Price: 102.325 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMH11.dly. Date: 2011-01-20, Price: 89.6. Date: 2011-02-21, Price: 86.2 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMG11.dly. Date: 2010-12-21, Price: 89.825. Date: 2011-01-19, Price: 90.85 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMF11.dly. Date: 2010-11-22, Price: 81.75. Date: 2010-12-20, Price: 88.025 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMZ10.dly. Date: 2010-10-20, Price: 82.55. Date: 2010-11-19, Price: 81.85 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMX10.dly. Date: 2010-09-21, Price: 74.975. Date: 2010-10-19, Price: 79.5 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMV10.dly. Date: 2010-08-20, Price: 73.825. Date: 2010-09-20, Price: 74.85 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMU10.dly. Date: 2010-07-20, Price: 77.575. Date: 2010-08-19, Price: 74.425 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMQ10.dly. Date: 2010-06-22, Price: 77.85. Date: 2010-07-19, Price: 76.55 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMQ10.dly has a volume of 0 at 2010-07-19. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMN10.dly. Date: 2010-05-20, Price: 70.8. Date: 2010-06-21, Price: 77.825 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMN10.dly has a volume of 0 at 2010-06-21. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMM10.dly. Date: 2010-04-20, Price: 83.85. Date: 2010-05-19, Price: 69.875 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMM10.dly has a volume of 0 at 2010-05-19. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMK10.dly. Date: 2010-03-22, Price: 81.6. Date: 2010-04-19, Price: 81.45 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMK10.dly has a volume of 0 at 2010-04-19. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMJ10.dly. Date: 2010-02-22, Price: 80.3. Date: 2010-03-19, Price: 80.675 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMJ10.dly has a volume of 0 at 2010-03-19. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMH10.dly. Date: 2010-01-20, Price: 77.75. Date: 2010-02-19, Price: 79.8 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMH10.dly has a volume of 0 at 2010-02-19. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMG10.dly. Date: 2009-12-22, Price: 74.4. Date: 2010-01-19, Price: 79.025 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMG10.dly has a volume of 0 at 2010-01-19. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMF10.dly. Date: 2009-11-20, Price: 77.475. Date: 2009-12-21, Price: 73.35 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMF10.dly has a volume of 0 at 2009-12-21. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMZ09.dly. Date: 2009-10-20, Price: 79.12. Date: 2009-11-19, Price: 77.45 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMZ09.dly has a volume of 0 at 2009-11-19. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMX09.dly. Date: 2009-09-22, Price: 71.76. Date: 2009-10-19, Price: 79.61 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMX09.dly has a volume of 0 at 2009-10-19. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMV09.dly. Date: 2009-08-20, Price: 72.91. Date: 2009-09-21, Price: 69.71 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMV09.dly has a volume of 0 at 2009-09-21. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMU09.dly. Date: 2009-07-21, Price: 65.61. Date: 2009-08-19, Price: 72.42001 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMU09.dly has a volume of 0 at 2009-08-19. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMQ09.dly. Date: 2009-06-22, Price: 67.5. Date: 2009-07-20, Price: 63.98 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMQ09.dly has a volume of 0 at 2009-07-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMN09.dly. Date: 2009-05-20, Price: 62.04. Date: 2009-06-19, Price: 69.55 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMN09.dly has a volume of 0 at 2009-06-19. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMM09.dly. Date: 2009-04-21, Price: 48.55. Date: 2009-05-19, Price: 59.03 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMM09.dly has a volume of 0 at 2009-05-19. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMK09.dly. Date: 2009-03-20, Price: 52.07. Date: 2009-04-20, Price: 45.88 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMK09.dly has a volume of 0 at 2009-04-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMJ09.dly. Date: 2009-02-20, Price: 40.03. Date: 2009-03-19, Price: 51.61 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMJ09.dly has a volume of 0 at 2009-03-19. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMH09.dly. Date: 2009-01-20, Price: 40.84. Date: 2009-02-19, Price: 39.48 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMH09.dly has a volume of 0 at 2009-02-19. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMG09.dly. Date: 2008-12-22, Price: 39.91. Date: 2009-01-19, Price: 36.51 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMF09.dly. Date: 2008-11-20, Price: 49.42. Date: 2008-12-19, Price: 36.22 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMF09.dly has a volume of 0 at 2008-12-19. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMZ08.dly. Date: 2008-10-21, Price: 72.18. Date: 2008-11-19, Price: 53.62 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMZ08.dly has a volume of 0 at 2008-11-19. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMX08.dly. Date: 2008-09-22, Price: 109.37. Date: 2008-10-20, Price: 74.25 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMX08.dly has a volume of 0 at 2008-10-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMV08.dly. Date: 2008-08-20, Price: 115.56. Date: 2008-09-19, Price: 104.55 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMV08.dly has a volume of 0 at 2008-09-19. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMU08.dly. Date: 2008-07-22, Price: 128.42. Date: 2008-08-19, Price: 114.53 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMU08.dly has a volume of 0 at 2008-08-19. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMQ08.dly. Date: 2008-06-20, Price: 135.36. Date: 2008-07-21, Price: 131.04 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMQ08.dly has a volume of 0 at 2008-07-21. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMN08.dly. Date: 2008-05-20, Price: 128.98. Date: 2008-06-19, Price: 131.93 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMN08.dly has a volume of 0 at 2008-06-19. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMM08.dly. Date: 2008-04-22, Price: 118.07. Date: 2008-05-19, Price: 127.05 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMM08.dly has a volume of 0 at 2008-05-19. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMK08.dly. Date: 2008-03-20, Price: 101.84. Date: 2008-04-21, Price: 117.48 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMK08.dly has a volume of 0 at 2008-04-21. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMJ08.dly. Date: 2008-02-20, Price: 99.7. Date: 2008-03-19, Price: 109.42 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMJ08.dly has a volume of 0 at 2008-03-19. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMH08.dly. Date: 2008-01-22, Price: 89.21. Date: 2008-02-19, Price: 100.01 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMH08.dly has a volume of 0 at 2008-02-19. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMG08.dly. Date: 2007-12-20, Price: 91.06. Date: 2008-01-21, Price: 90.57 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMG08.dly has a volume of 0 at 2008-01-21. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMF08.dly. Date: 2007-11-20, Price: 98.03. Date: 2007-12-19, Price: 90.63 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMF08.dly has a volume of 0 at 2007-12-19. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMZ07.dly. Date: 2007-10-22, Price: 86.02. Date: 2007-11-19, Price: 93.43 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMZ07.dly has a volume of 0 at 2007-11-19. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMX07.dly. Date: 2007-09-20, Price: 81.78. Date: 2007-10-19, Price: 88.6 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMX07.dly has a volume of 0 at 2007-10-19. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMV07.dly. Date: 2007-08-21, Price: 69.57. Date: 2007-09-19, Price: 81.93 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMV07.dly has a volume of 0 at 2007-09-19. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMU07.dly. Date: 2007-07-20, Price: 75.79. Date: 2007-08-20, Price: 71.12 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMU07.dly has a volume of 0 at 2007-08-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMQ07.dly. Date: 2007-06-20, Price: 68.86. Date: 2007-07-19, Price: 75.92001 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMQ07.dly has a volume of 0 at 2007-07-19. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMN07.dly. Date: 2007-05-22, Price: 65.51. Date: 2007-06-19, Price: 69.1 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMN07.dly has a volume of 0 at 2007-06-19. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMM07.dly. Date: 2007-04-20, Price: 64.11. Date: 2007-05-21, Price: 66.27 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMM07.dly has a volume of 0 at 2007-05-21. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMK07.dly. Date: 2007-03-20, Price: 59.25. Date: 2007-04-19, Price: 61.83 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMK07.dly has a volume of 0 at 2007-04-19. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMJ07.dly. Date: 2007-02-20, Price: 58.85. Date: 2007-03-19, Price: 56.59 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMJ07.dly has a volume of 0 at 2007-03-19. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMH07.dly. Date: 2007-01-22, Price: 52.58. Date: 2007-02-19, Price: 59.39 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMH07.dly has a volume of 0 at 2007-02-19. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMG07.dly. Date: 2006-12-20, Price: 63.72. Date: 2007-01-19, Price: 51.99 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMG07.dly has a volume of 0 at 2007-01-19. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMF07.dly. Date: 2006-11-21, Price: 60.17. Date: 2006-12-19, Price: 62.21 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMF07.dly has a volume of 0 at 2006-12-19. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMZ06.dly. Date: 2006-10-20, Price: 59.33. Date: 2006-11-20, Price: 56.26 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMZ06.dly has a volume of 0 at 2006-11-20. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMX06.dly. Date: 2006-09-20, Price: 60.74. Date: 2006-10-19, Price: 58.5 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMX06.dly has a volume of 0 at 2006-10-19. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMV06.dly. Date: 2006-08-22, Price: 73.1. Date: 2006-09-19, Price: 61.66 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | File QMV06.dly has a volume of 0 at 2006-09-19. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Symbols used for continuous contract chart: | 2016-10-11 15:24:40 QMV06 | 2016-10-11 15:24:40 QMX06 | 2016-10-11 15:24:40 QMZ06 | 2016-10-11 15:24:40 QMF07 | 2016-10-11 15:24:40 QMG07 | 2016-10-11 15:24:40 QMH07 | 2016-10-11 15:24:40 QMJ07 | 2016-10-11 15:24:40 QMK07 | 2016-10-11 15:24:40 QMM07 | 2016-10-11 15:24:40 QMN07 | 2016-10-11 15:24:40 QMQ07 | 2016-10-11 15:24:40 QMU07 | 2016-10-11 15:24:40 QMV07 | 2016-10-11 15:24:40 QMX07 | 2016-10-11 15:24:40 QMZ07 | 2016-10-11 15:24:40 QMF08 | 2016-10-11 15:24:40 QMG08 | 2016-10-11 15:24:40 QMH08 | 2016-10-11 15:24:40 QMJ08 | 2016-10-11 15:24:40 QMK08 | 2016-10-11 15:24:40 QMM08 | 2016-10-11 15:24:40 QMN08 | 2016-10-11 15:24:40 QMQ08 | 2016-10-11 15:24:40 QMU08 | 2016-10-11 15:24:40 QMV08 | 2016-10-11 15:24:40 QMX08 | 2016-10-11 15:24:40 QMZ08 | 2016-10-11 15:24:40 QMF09 | 2016-10-11 15:24:40 QMG09 | 2016-10-11 15:24:40 QMH09 | 2016-10-11 15:24:40 QMJ09 | 2016-10-11 15:24:40 QMK09 | 2016-10-11 15:24:40 QMM09 | 2016-10-11 15:24:40 QMN09 | 2016-10-11 15:24:40 QMQ09 | 2016-10-11 15:24:40 QMU09 | 2016-10-11 15:24:40 QMV09 | 2016-10-11 15:24:40 QMX09 | 2016-10-11 15:24:40 QMZ09 | 2016-10-11 15:24:40 QMF10 | 2016-10-11 15:24:40 QMG10 | 2016-10-11 15:24:40 QMH10 | 2016-10-11 15:24:40 QMJ10 | 2016-10-11 15:24:40 QMK10 | 2016-10-11 15:24:40 QMM10 | 2016-10-11 15:24:40 QMN10 | 2016-10-11 15:24:40 QMQ10 | 2016-10-11 15:24:40 QMU10 | 2016-10-11 15:24:40 QMV10 | 2016-10-11 15:24:40 QMX10 | 2016-10-11 15:24:40 QMZ10 | 2016-10-11 15:24:40 QMF11 | 2016-10-11 15:24:40 QMG11 | 2016-10-11 15:24:40 QMH11 | 2016-10-11 15:24:40 QMJ11 | 2016-10-11 15:24:40 QMK11 | 2016-10-11 15:24:40 QMM11 | 2016-10-11 15:24:40 QMN11 | 2016-10-11 15:24:40 QMQ11 | 2016-10-11 15:24:40 QMU11 | 2016-10-11 15:24:40 QMV11 | 2016-10-11 15:24:40 QMX11 | 2016-10-11 15:24:40 QMZ11 | 2016-10-11 15:24:40 QMF12 | 2016-10-11 15:24:40 QMG12 | 2016-10-11 15:24:40 QMH12 | 2016-10-11 15:24:40 QMJ12 | 2016-10-11 15:24:40 QMK12 | 2016-10-11 15:24:40 QMM12 | 2016-10-11 15:24:40 QMN12 | 2016-10-11 15:24:40 QMQ12 | 2016-10-11 15:24:40 QMU12 | 2016-10-11 15:24:40 QMV12 | 2016-10-11 15:24:40 QMX12 | 2016-10-11 15:24:40 QMZ12 | 2016-10-11 15:24:40 QMF13 | 2016-10-11 15:24:40 QMG13 | 2016-10-11 15:24:40 QMH13 | 2016-10-11 15:24:40 QMJ13 | 2016-10-11 15:24:40 QMK13 | 2016-10-11 15:24:40 QMM13 | 2016-10-11 15:24:40 QMN13 | 2016-10-11 15:24:40 QMQ13 | 2016-10-11 15:24:40 QMU13 | 2016-10-11 15:24:40 QMV13 | 2016-10-11 15:24:40 QMX13 | 2016-10-11 15:24:40 QMZ13 | 2016-10-11 15:24:40 QMF14 | 2016-10-11 15:24:40 QMG14 | 2016-10-11 15:24:40 QMH14 | 2016-10-11 15:24:40 QMJ14 | 2016-10-11 15:24:40 QMK14 | 2016-10-11 15:24:40 QMM14 | 2016-10-11 15:24:40 QMN14 | 2016-10-11 15:24:40 QMQ14 | 2016-10-11 15:24:40 QMU14 | 2016-10-11 15:24:40 QMV14 | 2016-10-11 15:24:40 QMX14 | 2016-10-11 15:24:40 QMZ14 | 2016-10-11 15:24:40 QMF15 | 2016-10-11 15:24:40 QMG15 | 2016-10-11 15:24:40 QMH15 | 2016-10-11 15:24:40 QMJ15 | 2016-10-11 15:24:40 QMK15 | 2016-10-11 15:24:40 QMM15 | 2016-10-11 15:24:40 QMN15 | 2016-10-11 15:24:40 QMQ15 | 2016-10-11 15:24:40 QMU15 | 2016-10-11 15:24:40 QMV15 | 2016-10-11 15:24:40 QMX15 | 2016-10-11 15:24:40 QMZ15 | 2016-10-11 15:24:40 QMF16 | 2016-10-11 15:24:40 QMG16 | 2016-10-11 15:24:40 QMH16 | 2016-10-11 15:24:40 QMJ16 | 2016-10-11 15:24:40 QMK16 | 2016-10-11 15:24:40 QMM16 | 2016-10-11 15:24:40 QMN16 | 2016-10-11 15:24:40 QMQ16 | 2016-10-11 15:24:40 QMU16 | 2016-10-11 15:24:40 QMV16 | 2016-10-11 15:24:40 QMX16 | 2016-10-11 15:24:40 QMZ16 | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Performing continuous futures contract back adjustment calculations. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMV06 Open price on 2006-09-20 is 63.9. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMX06 Open price on 2006-09-20 is 62.15. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMV06 price difference to QMX06 is -1.75. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMX06 Open price on 2006-10-20 is 57.8. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMZ06 Open price on 2006-10-20 is 60.6. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMX06 price difference to QMZ06 is 2.8. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMZ06 Open price on 2006-11-21 is 58.75. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMF07 Open price on 2006-11-21 is 58.95. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMZ06 price difference to QMF07 is 0.2. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMF07 Open price on 2006-12-20 is 63.25. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMG07 Open price on 2006-12-20 is 63.4. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMF07 price difference to QMG07 is 0.15. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMG07 Open price on 2007-01-22 is 50.475. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMH07 Open price on 2007-01-22 is 53.575. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMG07 price difference to QMH07 is 3.1. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMH07 Open price on 2007-02-20 is 58. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMJ07 Open price on 2007-02-20 is 59.55. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMH07 price difference to QMJ07 is 1.55. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMJ07 Open price on 2007-03-20 is 57.25. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMK07 Open price on 2007-03-20 is 59.9. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMJ07 price difference to QMK07 is 2.65. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMK07 Open price on 2007-04-20 is 62.625. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMM07 Open price on 2007-04-20 is 63.075. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMK07 price difference to QMM07 is 0.45. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMM07 Open price on 2007-05-22 is 64.95. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMN07 Open price on 2007-05-22 is 66.825. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMM07 price difference to QMN07 is 1.875. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMN07 Open price on 2007-06-20 is 69.1. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMQ07 Open price on 2007-06-20 is 69.425. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMN07 price difference to QMQ07 is 0.325. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMQ07 Open price on 2007-07-20 is 74.875. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMU07 Open price on 2007-07-20 is 76.1. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMQ07 price difference to QMU07 is 1.225. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMU07 Open price on 2007-08-21 is 71.95. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMV07 Open price on 2007-08-21 is 70.95. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMU07 price difference to QMV07 is -1. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMV07 Open price on 2007-09-20 is 82.2. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMX07 Open price on 2007-09-20 is 80.525. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMV07 price difference to QMX07 is -1.675. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMX07 Open price on 2007-10-22 is 89.775. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMZ07 Open price on 2007-10-22 is 86.875. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMX07 price difference to QMZ07 is -2.9. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMZ07 Open price on 2007-11-20 is 94.1. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMF08 Open price on 2007-11-20 is 94.825. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMZ07 price difference to QMF08 is 0.725. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMF08 Open price on 2007-12-20 is 91.375. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMG08 Open price on 2007-12-20 is 91.4. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMF08 price difference to QMG08 is 0.025. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMG08 Open price on 2008-01-22 is 89.85. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMH08 Open price on 2008-01-22 is 89.8. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMG08 price difference to QMH08 is -0.05. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMH08 Open price on 2008-02-20 is 95.4. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMJ08 Open price on 2008-02-20 is 99.55. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMH08 price difference to QMJ08 is 4.15. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMJ08 Open price on 2008-03-20 is 106. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMK08 Open price on 2008-03-20 is 102.1. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMJ08 price difference to QMK08 is -3.9. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMK08 Open price on 2008-04-22 is 116.625. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMM08 Open price on 2008-04-22 is 116.675. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMK08 price difference to QMM08 is 0.05. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMM08 Open price on 2008-05-20 is 126.3. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMN08 Open price on 2008-05-20 is 126.825. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMM08 price difference to QMN08 is 0.525. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMN08 Open price on 2008-06-20 is 136.1. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMQ08 Open price on 2008-06-20 is 132.275. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMN08 price difference to QMQ08 is -3.825. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMQ08 Open price on 2008-07-22 is 129.125. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMU08 Open price on 2008-07-22 is 131.9. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMQ08 price difference to QMU08 is 2.775. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMU08 Open price on 2008-08-20 is 113.175. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMV08 Open price on 2008-08-20 is 115.15. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMU08 price difference to QMV08 is 1.975. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMV08 Open price on 2008-09-22 is 98.05. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMX08 Open price on 2008-09-22 is 102.15. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMV08 price difference to QMX08 is 4.1. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMX08 Open price on 2008-10-21 is 72.3. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMZ08 Open price on 2008-10-21 is 75.8. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMX08 price difference to QMZ08 is 3.5. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMZ08 Open price on 2008-11-20 is 54.5. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMF09 Open price on 2008-11-20 is 53.6. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMZ08 price difference to QMF09 is -0.9. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMF09 Open price on 2008-12-22 is 40.2. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMG09 Open price on 2008-12-22 is 42.7. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMF09 price difference to QMG09 is 2.5. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMG09 Open price on 2009-01-20 is 35.4. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMH09 Open price on 2009-01-20 is 42.575. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMG09 price difference to QMH09 is 7.175. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMH09 Open price on 2009-02-20 is 34.75. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMJ09 Open price on 2009-02-20 is 39.55. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMH09 price difference to QMJ09 is 4.8. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMJ09 Open price on 2009-03-20 is 49.8. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMK09 Open price on 2009-03-20 is 51.775. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMJ09 price difference to QMK09 is 1.975. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMK09 Open price on 2009-04-21 is 50.05. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMM09 Open price on 2009-04-21 is 48.3. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMK09 price difference to QMM09 is -1.75. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMM09 Open price on 2009-05-20 is 56.425. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMN09 Open price on 2009-05-20 is 60.225. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMM09 price difference to QMN09 is 3.8. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMN09 Open price on 2009-06-22 is 71.45. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMQ09 Open price on 2009-06-22 is 70.15. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMN09 price difference to QMQ09 is -1.3. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMQ09 Open price on 2009-07-21 is 63.525. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMU09 Open price on 2009-07-21 is 65.4. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMQ09 price difference to QMU09 is 1.875. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMU09 Open price on 2009-08-20 is 70.225. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMV09 Open price on 2009-08-20 is 73.5. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMU09 price difference to QMV09 is 3.275. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMV09 Open price on 2009-09-22 is 72.05. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMX09 Open price on 2009-09-22 is 69.875. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMV09 price difference to QMX09 is -2.175. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMX09 Open price on 2009-10-20 is 78.85. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMZ09 Open price on 2009-10-20 is 80. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMX09 price difference to QMZ09 is 1.15. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMZ09 Open price on 2009-11-20 is 79.7. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMF10 Open price on 2009-11-20 is 78.475. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMZ09 price difference to QMF10 is -1.225. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMF10 Open price on 2009-12-22 is 72.85. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMG10 Open price on 2009-12-22 is 73.5. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMF10 price difference to QMG10 is 0.65. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMG10 Open price on 2010-01-20 is 77.825. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMH10 Open price on 2010-01-20 is 79.175. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMG10 price difference to QMH10 is 1.35. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMH10 Open price on 2010-02-22 is 78.325. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMJ10 Open price on 2010-02-22 is 80.3. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMH10 price difference to QMJ10 is 1.975. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMJ10 Open price on 2010-03-22 is 82.2. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMK10 Open price on 2010-03-22 is 80.875. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMJ10 price difference to QMK10 is -1.325. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMK10 Open price on 2010-04-20 is 82.975. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMM10 Open price on 2010-04-20 is 83.275. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMK10 price difference to QMM10 is 0.3. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMM10 Open price on 2010-05-20 is 69.025. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMN10 Open price on 2010-05-20 is 72.825. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMM10 price difference to QMN10 is 3.8. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMN10 Open price on 2010-06-22 is 77.9. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMQ10 Open price on 2010-06-22 is 78.175. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMN10 price difference to QMQ10 is 0.275. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMQ10 Open price on 2010-07-20 is 75.625. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMU10 Open price on 2010-07-20 is 76.725. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMQ10 price difference to QMU10 is 1.1. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMU10 Open price on 2010-08-20 is 75.2. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMV10 Open price on 2010-08-20 is 74.8. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMU10 price difference to QMV10 is -0.4. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMV10 Open price on 2010-09-21 is 73.575. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMX10 Open price on 2010-09-21 is 76.25. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMV10 price difference to QMX10 is 2.675. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMX10 Open price on 2010-10-20 is 82.95. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMZ10 Open price on 2010-10-20 is 79.975. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMX10 price difference to QMZ10 is -2.975. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMZ10 Open price on 2010-11-22 is 80.4. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMF11 Open price on 2010-11-22 is 82.2. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMZ10 price difference to QMF11 is 1.8. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMF11 Open price on 2010-12-21 is 87.925. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMG11 Open price on 2010-12-21 is 89.175. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMF11 price difference to QMG11 is 1.25. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMG11 Open price on 2011-01-20 is 91.225. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMH11 Open price on 2011-01-20 is 91.6. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMG11 price difference to QMH11 is 0.375. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMH11 Open price on 2011-02-22 is 86.45. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMJ11 Open price on 2011-02-22 is 90.1. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMH11 price difference to QMJ11 is 3.65. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMJ11 Open price on 2011-03-22 is 102.05. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMK11 Open price on 2011-03-22 is 102.7. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMJ11 price difference to QMK11 is 0.65. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMK11 Open price on 2011-04-20 is 109.35. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMM11 Open price on 2011-04-20 is 108.425. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMK11 price difference to QMM11 is -0.925. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMM11 Open price on 2011-05-20 is 99.675. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMN11 Open price on 2011-05-20 is 99.1. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMM11 price difference to QMN11 is -0.575. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMN11 Open price on 2011-06-21 is 92.875. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMQ11 Open price on 2011-06-21 is 93.825. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMN11 price difference to QMQ11 is 0.95. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMQ11 Open price on 2011-07-20 is 96.125. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMU11 Open price on 2011-07-20 is 98.475. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMQ11 price difference to QMU11 is 2.35. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMU11 Open price on 2011-08-22 is 81.45. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMV11 Open price on 2011-08-22 is 82.4. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMU11 price difference to QMV11 is 0.95. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMV11 Open price on 2011-09-20 is 87.25. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMX11 Open price on 2011-09-20 is 86. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMV11 price difference to QMX11 is -1.25. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMX11 Open price on 2011-10-20 is 88.2. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMZ11 Open price on 2011-10-20 is 86.2. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMX11 price difference to QMZ11 is -2. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMZ11 Open price on 2011-11-22 is 101.675. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMF12 Open price on 2011-11-22 is 97.125. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMZ11 price difference to QMF12 is -4.55. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMF12 Open price on 2011-12-20 is 93.625. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMG12 Open price on 2011-12-20 is 94.275. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMF12 price difference to QMG12 is 0.65. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMG12 Open price on 2012-01-20 is 101.1. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMH12 Open price on 2012-01-20 is 100.575. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMG12 price difference to QMH12 is -0.525. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMH12 Open price on 2012-02-21 is 102.3. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMJ12 Open price on 2012-02-21 is 104.55. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMH12 price difference to QMJ12 is 2.25. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMJ12 Open price on 2012-03-20 is 107.225. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMK12 Open price on 2012-03-20 is 108.35. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMJ12 price difference to QMK12 is 1.125. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMK12 Open price on 2012-04-20 is 102.75. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMM12 Open price on 2012-04-20 is 103. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMK12 price difference to QMM12 is 0.25. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMM12 Open price on 2012-05-22 is 91.35. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMN12 Open price on 2012-05-22 is 93. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMM12 price difference to QMN12 is 1.65. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMN12 Open price on 2012-06-20 is 83. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMQ12 Open price on 2012-06-20 is 84.25. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMN12 price difference to QMQ12 is 1.25. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMQ12 Open price on 2012-07-20 is 89.975. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMU12 Open price on 2012-07-20 is 92.6. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMQ12 price difference to QMU12 is 2.625. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMU12 Open price on 2012-08-21 is 96.375. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMV12 Open price on 2012-08-21 is 96.175. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMU12 price difference to QMV12 is -0.2. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMV12 Open price on 2012-09-20 is 95.525. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMX12 Open price on 2012-09-20 is 92.25. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMV12 price difference to QMX12 is -3.275. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMX12 Open price on 2012-10-22 is 92.05. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMZ12 Open price on 2012-10-22 is 90.175. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMX12 price difference to QMZ12 is -1.875. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMZ12 Open price on 2012-11-20 is 86.35. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMF13 Open price on 2012-11-20 is 89.1. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMZ12 price difference to QMF13 is 2.75. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMF13 Open price on 2012-12-20 is 87.4. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMG13 Open price on 2012-12-20 is 89.625. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMF13 price difference to QMG13 is 2.225. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMG13 Open price on 2013-01-22 is 95.2. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMH13 Open price on 2013-01-22 is 95.75. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMG13 price difference to QMH13 is 0.55. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMH13 Open price on 2013-02-20 is 95.95. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMJ13 Open price on 2013-02-20 is 97.1. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMH13 price difference to QMJ13 is 1.15. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMJ13 Open price on 2013-03-20 is 93.925. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMK13 Open price on 2013-03-20 is 92.45. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMJ13 price difference to QMK13 is -1.475. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMK13 Open price on 2013-04-22 is 88.275. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMM13 Open price on 2013-04-22 is 88.1. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMK13 price difference to QMM13 is -0.175. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMM13 Open price on 2013-05-21 is 96.15. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMN13 Open price on 2013-05-21 is 96.875. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMM13 price difference to QMN13 is 0.725. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMN13 Open price on 2013-06-20 is 98.575. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMQ13 Open price on 2013-06-20 is 98.2. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMN13 price difference to QMQ13 is -0.375. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMQ13 Open price on 2013-07-22 is 108.075. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMU13 Open price on 2013-07-22 is 108.025. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMQ13 price difference to QMU13 is -0.05. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMU13 Open price on 2013-08-20 is 107.625. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMV13 Open price on 2013-08-20 is 106.7. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMU13 price difference to QMV13 is -0.925. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMV13 Open price on 2013-09-20 is 108.425. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMX13 Open price on 2013-09-20 is 105.775. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMV13 price difference to QMX13 is -2.65. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMX13 Open price on 2013-10-22 is 100.8. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMZ13 Open price on 2013-10-22 is 99.55. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMX13 price difference to QMZ13 is -1.25. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMZ13 Open price on 2013-11-20 is 93.075. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMF14 Open price on 2013-11-20 is 93.875. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMZ13 price difference to QMF14 is 0.8. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMF14 Open price on 2013-12-20 is 97.325. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMG14 Open price on 2013-12-20 is 98.675. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMF14 price difference to QMG14 is 1.35. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMG14 Open price on 2014-01-21 is 94.1. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMH14 Open price on 2014-01-21 is 94.25. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMG14 price difference to QMH14 is 0.15. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMH14 Open price on 2014-02-20 is 103.1. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMJ14 Open price on 2014-02-20 is 102.9. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMH14 price difference to QMJ14 is -0.2. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMJ14 Open price on 2014-03-20 is 99.475. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMK14 Open price on 2014-03-20 is 99.15. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMJ14 price difference to QMK14 is -0.325. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMK14 Open price on 2014-04-22 is 104.45. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMM14 Open price on 2014-04-22 is 103.625. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMK14 price difference to QMM14 is -0.825. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMM14 Open price on 2014-05-20 is 102.025. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMN14 Open price on 2014-05-20 is 102.1. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMM14 price difference to QMN14 is 0.075. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMN14 Open price on 2014-06-20 is 106.05. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMQ14 Open price on 2014-06-20 is 106.075. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMN14 price difference to QMQ14 is 0.025. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMQ14 Open price on 2014-07-22 is 102.95. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMU14 Open price on 2014-07-22 is 102.75. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMQ14 price difference to QMU14 is -0.2. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMU14 Open price on 2014-08-20 is 96.6. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMV14 Open price on 2014-08-20 is 92.85. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMU14 price difference to QMV14 is -3.75. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMV14 Open price on 2014-09-22 is 92.975. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMX14 Open price on 2014-09-22 is 91.625. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMV14 price difference to QMX14 is -1.35. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMX14 Open price on 2014-10-21 is 83.1. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMZ14 Open price on 2014-10-21 is 81.85. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMX14 price difference to QMZ14 is -1.25. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMZ14 Open price on 2014-11-20 is 74.225. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMF15 Open price on 2014-11-20 is 74.325. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMZ14 price difference to QMF15 is 0.1. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMF15 Open price on 2014-12-22 is 55.8. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMG15 Open price on 2014-12-22 is 57.675. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMF15 price difference to QMG15 is 1.875. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMG15 Open price on 2015-01-20 is 46.25. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMH15 Open price on 2015-01-20 is 49.125. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMG15 price difference to QMH15 is 2.875. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMH15 Open price on 2015-02-20 is 50.575. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMJ15 Open price on 2015-02-20 is 52.175. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMH15 price difference to QMJ15 is 1.6. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMJ15 Open price on 2015-03-20 is 44.575. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMK15 Open price on 2015-03-20 is 45.6. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMJ15 price difference to QMK15 is 1.025. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMK15 Open price on 2015-04-21 is 56.075. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMM15 Open price on 2015-04-21 is 57.925. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMK15 price difference to QMM15 is 1.85. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMM15 Open price on 2015-05-20 is 59.85. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMN15 Open price on 2015-05-20 is 58.325. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMM15 price difference to QMN15 is -1.525. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMN15 Open price on 2015-06-22 is 60.45. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMQ15 Open price on 2015-06-22 is 59.75. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMN15 price difference to QMQ15 is -0.7. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMQ15 Open price on 2015-07-21 is 50.725. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMU15 Open price on 2015-07-21 is 50.25. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMQ15 price difference to QMU15 is -0.475. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMU15 Open price on 2015-08-20 is 42.425. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMV15 Open price on 2015-08-20 is 40.95. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMU15 price difference to QMV15 is -1.475. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMV15 Open price on 2015-09-22 is 44.85. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMX15 Open price on 2015-09-22 is 46.7. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMV15 price difference to QMX15 is 1.85. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMX15 Open price on 2015-10-20 is 47.1. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMZ15 Open price on 2015-10-20 is 46.575. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMX15 price difference to QMZ15 is -0.525. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMZ15 Open price on 2015-11-20 is 40.7. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMF16 Open price on 2015-11-20 is 41.875. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMZ15 price difference to QMF16 is 1.175. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMF16 Open price on 2015-12-22 is 34.8. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMG16 Open price on 2015-12-22 is 35.85. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMF16 price difference to QMG16 is 1.05. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMG16 Open price on 2016-01-20 is 29.35. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMH16 Open price on 2016-01-20 is 29.475. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMG16 price difference to QMH16 is 0.125. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMH16 Open price on 2016-02-22 is 30.675. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMJ16 Open price on 2016-02-22 is 31.95. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMH16 price difference to QMJ16 is 1.275. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMJ16 Open price on 2016-03-22 is 40.25. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMK16 Open price on 2016-03-22 is 41.6. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMJ16 price difference to QMK16 is 1.35. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMK16 Open price on 2016-04-20 is 39.975. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMM16 Open price on 2016-04-20 is 42.35. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMK16 price difference to QMM16 is 2.375. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMM16 Open price on 2016-05-20 is 47.9. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMN16 Open price on 2016-05-20 is 48.725. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMM16 price difference to QMN16 is 0.825. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMN16 Open price on 2016-06-21 is 48.35. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMQ16 Open price on 2016-06-21 is 49.775. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMN16 price difference to QMQ16 is 1.425. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMQ16 Open price on 2016-07-20 is 45.175. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMU16 Open price on 2016-07-20 is 45.475. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMQ16 price difference to QMU16 is 0.3. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMU16 Open price on 2016-08-22 is 48.375. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMV16 Open price on 2016-08-22 is 49.05. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMU16 price difference to QMV16 is 0.675. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMV16 Open price on 2016-09-20 is 43.2. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMX16 Open price on 2016-09-20 is 43.75. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMV16 price difference to QMX16 is 0.55. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMX16 Open price on 2016-10-11 is 51.125. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMZ16 Open price on 2016-10-11 is 51.65. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | QMX16 price difference to QMZ16 is 0.525. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMV06 is 63.4. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMX06 is 65.15. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMZ06 is 62.35. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMF07 is 62.15. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMG07 is 62. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMH07 is 58.9. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMJ07 is 57.35. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMK07 is 54.7. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMM07 is 54.25. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMN07 is 52.375. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMQ07 is 52.05. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMU07 is 50.825. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMV07 is 51.825. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMX07 is 53.5. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMZ07 is 56.4. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMF08 is 55.675. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMG08 is 55.65. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMH08 is 55.7. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMJ08 is 51.55. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMK08 is 55.45. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMM08 is 55.4. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMN08 is 54.875. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMQ08 is 58.7. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMU08 is 55.925. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMV08 is 53.95. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMX08 is 49.85. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMZ08 is 46.35. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMF09 is 47.25. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMG09 is 44.75. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMH09 is 37.575. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMJ09 is 32.775. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMK09 is 30.8. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMM09 is 32.55. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMN09 is 28.75. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMQ09 is 30.05. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMU09 is 28.175. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMV09 is 24.9. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMX09 is 27.075. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMZ09 is 25.925. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMF10 is 27.15. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMG10 is 26.5. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMH10 is 25.15. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMJ10 is 23.175. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMK10 is 24.5. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMM10 is 24.2. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMN10 is 20.4. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMQ10 is 20.125. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMU10 is 19.025. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMV10 is 19.425. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMX10 is 16.75. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMZ10 is 19.725. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMF11 is 17.925. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMG11 is 16.675. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMH11 is 16.3. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMJ11 is 12.65. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMK11 is 12. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMM11 is 12.925. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMN11 is 13.5. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMQ11 is 12.55. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMU11 is 10.2. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMV11 is 9.25. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMX11 is 10.5. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMZ11 is 12.5. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMF12 is 17.05. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMG12 is 16.4. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMH12 is 16.925. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMJ12 is 14.675. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMK12 is 13.55. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMM12 is 13.3. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMN12 is 11.65. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMQ12 is 10.4. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMU12 is 7.775. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMV12 is 7.975. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMX12 is 11.25. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMZ12 is 13.125. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMF13 is 10.375. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMG13 is 8.15. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMH13 is 7.6. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMJ13 is 6.45. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMK13 is 7.925. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMM13 is 8.1. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMN13 is 7.375. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMQ13 is 7.75. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMU13 is 7.8. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMV13 is 8.725. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMX13 is 11.375. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMZ13 is 12.625. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMF14 is 11.825. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMG14 is 10.475. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMH14 is 10.325. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMJ14 is 10.525. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMK14 is 10.85. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMM14 is 11.675. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMN14 is 11.6. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMQ14 is 11.575. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMU14 is 11.775. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMV14 is 15.525. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMX14 is 16.875. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMZ14 is 18.125. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMF15 is 18.025. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMG15 is 16.15. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMH15 is 13.275. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMJ15 is 11.675. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMK15 is 10.65. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMM15 is 8.8. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMN15 is 10.325. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMQ15 is 11.025. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMU15 is 11.5. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMV15 is 12.975. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMX15 is 11.125. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMZ15 is 11.65. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMF16 is 10.475. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMG16 is 9.425. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMH16 is 9.3. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMJ16 is 8.025. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMK16 is 6.675. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMM16 is 4.3. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMN16 is 3.475. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMQ16 is 2.05. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMU16 is 1.75. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMV16 is 1.075. | 2016-10-11 15:24:40 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMX16 is 0.525. | 2016-10-11 15:24:40 HD Request # 126 | Downloading Historical Daily chart data for QMZ16. Starting date: 2016-10-10. Service: tda | 2016-10-11 15:24:44 HD Request # 126 | Using user Barchart Historical data account. | 2016-10-11 15:24:44 HD Request # 126 | Requesting historical Daily data for QMZ16 starting at 2016-10-09 | 2016-10-11 15:24:44 Delaying start of download for QMZ16 | 2016-10-11 15:24:44 HD Request # 126 | Receiving historical Daily data for QMZ16 starting at 2016-10-10 | 2016-10-11 15:24:44 HD Request # 126 | Writing historical Daily data to the file QMZ16.dly | 2016-10-11 15:24:44 HD Request # 126 | Received 2 records from 2016-10-10 00:00:00 to 2016-10-11 00:00:00 (2.0 days) and wrote 2 records for QMZ16 | 2016-10-11 15:24:44 HD Request # 126 | Daily download COMPLETE for QMZ16. Completion time: 0s. Unique request ID: 126 | 2016-10-11 15:24:44 Removed historical data download ID 126 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Reloading chart. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMV06 to next contract occurs at 2006-09-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMX06 to next contract occurs at 2006-10-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMZ06 to next contract occurs at 2006-11-21. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMF07 to next contract occurs at 2006-12-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMG07 to next contract occurs at 2007-01-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMH07 to next contract occurs at 2007-02-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMJ07 to next contract occurs at 2007-03-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMK07 to next contract occurs at 2007-04-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMM07 to next contract occurs at 2007-05-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMN07 to next contract occurs at 2007-06-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMQ07 to next contract occurs at 2007-07-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMU07 to next contract occurs at 2007-08-21. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMV07 to next contract occurs at 2007-09-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMX07 to next contract occurs at 2007-10-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMZ07 to next contract occurs at 2007-11-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMF08 to next contract occurs at 2007-12-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMG08 to next contract occurs at 2008-01-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMH08 to next contract occurs at 2008-02-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMJ08 to next contract occurs at 2008-03-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMK08 to next contract occurs at 2008-04-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMM08 to next contract occurs at 2008-05-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMN08 to next contract occurs at 2008-06-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMQ08 to next contract occurs at 2008-07-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMU08 to next contract occurs at 2008-08-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMV08 to next contract occurs at 2008-09-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMX08 to next contract occurs at 2008-10-21. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMZ08 to next contract occurs at 2008-11-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMF09 to next contract occurs at 2008-12-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMG09 to next contract occurs at 2009-01-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMH09 to next contract occurs at 2009-02-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMJ09 to next contract occurs at 2009-03-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMK09 to next contract occurs at 2009-04-21. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMM09 to next contract occurs at 2009-05-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMN09 to next contract occurs at 2009-06-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMQ09 to next contract occurs at 2009-07-21. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMU09 to next contract occurs at 2009-08-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMV09 to next contract occurs at 2009-09-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMX09 to next contract occurs at 2009-10-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMZ09 to next contract occurs at 2009-11-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMF10 to next contract occurs at 2009-12-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMG10 to next contract occurs at 2010-01-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMH10 to next contract occurs at 2010-02-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMJ10 to next contract occurs at 2010-03-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMK10 to next contract occurs at 2010-04-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMM10 to next contract occurs at 2010-05-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMN10 to next contract occurs at 2010-06-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMQ10 to next contract occurs at 2010-07-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMU10 to next contract occurs at 2010-08-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMV10 to next contract occurs at 2010-09-21. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMX10 to next contract occurs at 2010-10-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMZ10 to next contract occurs at 2010-11-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMF11 to next contract occurs at 2010-12-21. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMG11 to next contract occurs at 2011-01-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMH11 to next contract occurs at 2011-02-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMJ11 to next contract occurs at 2011-03-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMK11 to next contract occurs at 2011-04-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMM11 to next contract occurs at 2011-05-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMN11 to next contract occurs at 2011-06-21. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMQ11 to next contract occurs at 2011-07-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMU11 to next contract occurs at 2011-08-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMV11 to next contract occurs at 2011-09-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMX11 to next contract occurs at 2011-10-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMZ11 to next contract occurs at 2011-11-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMF12 to next contract occurs at 2011-12-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMG12 to next contract occurs at 2012-01-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMH12 to next contract occurs at 2012-02-21. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMJ12 to next contract occurs at 2012-03-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMK12 to next contract occurs at 2012-04-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMM12 to next contract occurs at 2012-05-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMN12 to next contract occurs at 2012-06-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMQ12 to next contract occurs at 2012-07-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMU12 to next contract occurs at 2012-08-21. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMV12 to next contract occurs at 2012-09-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMX12 to next contract occurs at 2012-10-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMZ12 to next contract occurs at 2012-11-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMF13 to next contract occurs at 2012-12-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMG13 to next contract occurs at 2013-01-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMH13 to next contract occurs at 2013-02-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMJ13 to next contract occurs at 2013-03-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMK13 to next contract occurs at 2013-04-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMM13 to next contract occurs at 2013-05-21. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMN13 to next contract occurs at 2013-06-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMQ13 to next contract occurs at 2013-07-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMU13 to next contract occurs at 2013-08-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMV13 to next contract occurs at 2013-09-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMX13 to next contract occurs at 2013-10-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMZ13 to next contract occurs at 2013-11-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMF14 to next contract occurs at 2013-12-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMG14 to next contract occurs at 2014-01-21. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMH14 to next contract occurs at 2014-02-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMJ14 to next contract occurs at 2014-03-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMK14 to next contract occurs at 2014-04-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMM14 to next contract occurs at 2014-05-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMN14 to next contract occurs at 2014-06-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMQ14 to next contract occurs at 2014-07-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMU14 to next contract occurs at 2014-08-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMV14 to next contract occurs at 2014-09-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMX14 to next contract occurs at 2014-10-21. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMZ14 to next contract occurs at 2014-11-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMF15 to next contract occurs at 2014-12-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMG15 to next contract occurs at 2015-01-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMH15 to next contract occurs at 2015-02-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMJ15 to next contract occurs at 2015-03-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMK15 to next contract occurs at 2015-04-21. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMM15 to next contract occurs at 2015-05-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMN15 to next contract occurs at 2015-06-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMQ15 to next contract occurs at 2015-07-21. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMU15 to next contract occurs at 2015-08-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMV15 to next contract occurs at 2015-09-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMX15 to next contract occurs at 2015-10-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMZ15 to next contract occurs at 2015-11-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMF16 to next contract occurs at 2015-12-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMG16 to next contract occurs at 2016-01-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMH16 to next contract occurs at 2016-02-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMJ16 to next contract occurs at 2016-03-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMK16 to next contract occurs at 2016-04-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMM16 to next contract occurs at 2016-05-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMN16 to next contract occurs at 2016-06-21. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMQ16 to next contract occurs at 2016-07-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMU16 to next contract occurs at 2016-08-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMV16 to next contract occurs at 2016-09-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMX16 to next contract occurs at 2016-10-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMZ16 to next contract occurs at 2016-11-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMV06 for the date range from 2006-08-22 to 2006-09-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMV06 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMX06 for the date range from 2006-09-20 to 2006-10-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMX06 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMZ06 for the date range from 2006-10-20 to 2006-11-21. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMZ06 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMF07 for the date range from 2006-11-21 to 2006-12-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMF07 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMG07 for the date range from 2006-12-20 to 2007-01-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMG07 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMH07 for the date range from 2007-01-22 to 2007-02-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMH07 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMJ07 for the date range from 2007-02-20 to 2007-03-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMJ07 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMK07 for the date range from 2007-03-20 to 2007-04-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMK07 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMM07 for the date range from 2007-04-20 to 2007-05-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMM07 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMN07 for the date range from 2007-05-22 to 2007-06-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMN07 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMQ07 for the date range from 2007-06-20 to 2007-07-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMQ07 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMU07 for the date range from 2007-07-20 to 2007-08-21. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMU07 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMV07 for the date range from 2007-08-21 to 2007-09-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMV07 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMX07 for the date range from 2007-09-20 to 2007-10-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMX07 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMZ07 for the date range from 2007-10-22 to 2007-11-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMZ07 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMF08 for the date range from 2007-11-20 to 2007-12-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMF08 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMG08 for the date range from 2007-12-20 to 2008-01-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMG08 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMH08 for the date range from 2008-01-22 to 2008-02-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMH08 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMJ08 for the date range from 2008-02-20 to 2008-03-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMJ08 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMK08 for the date range from 2008-03-20 to 2008-04-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMK08 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMM08 for the date range from 2008-04-22 to 2008-05-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMM08 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMN08 for the date range from 2008-05-20 to 2008-06-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMN08 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMQ08 for the date range from 2008-06-20 to 2008-07-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMQ08 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMU08 for the date range from 2008-07-22 to 2008-08-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMU08 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMV08 for the date range from 2008-08-20 to 2008-09-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMV08 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMX08 for the date range from 2008-09-22 to 2008-10-21. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMX08 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMZ08 for the date range from 2008-10-21 to 2008-11-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMZ08 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMF09 for the date range from 2008-11-20 to 2008-12-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMF09 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMG09 for the date range from 2008-12-22 to 2009-01-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMG09 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMH09 for the date range from 2009-01-20 to 2009-02-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMH09 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMJ09 for the date range from 2009-02-20 to 2009-03-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMJ09 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMK09 for the date range from 2009-03-20 to 2009-04-21. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMK09 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMM09 for the date range from 2009-04-21 to 2009-05-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMM09 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMN09 for the date range from 2009-05-20 to 2009-06-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMN09 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMQ09 for the date range from 2009-06-22 to 2009-07-21. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMQ09 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMU09 for the date range from 2009-07-21 to 2009-08-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMU09 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMV09 for the date range from 2009-08-20 to 2009-09-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMV09 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMX09 for the date range from 2009-09-22 to 2009-10-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMX09 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMZ09 for the date range from 2009-10-20 to 2009-11-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMZ09 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMF10 for the date range from 2009-11-20 to 2009-12-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMF10 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMG10 for the date range from 2009-12-22 to 2010-01-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMG10 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMH10 for the date range from 2010-01-20 to 2010-02-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMH10 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMJ10 for the date range from 2010-02-22 to 2010-03-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMJ10 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMK10 for the date range from 2010-03-22 to 2010-04-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMK10 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMM10 for the date range from 2010-04-20 to 2010-05-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMM10 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMN10 for the date range from 2010-05-20 to 2010-06-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMN10 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMQ10 for the date range from 2010-06-22 to 2010-07-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMQ10 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMU10 for the date range from 2010-07-20 to 2010-08-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMU10 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMV10 for the date range from 2010-08-20 to 2010-09-21. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMV10 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMX10 for the date range from 2010-09-21 to 2010-10-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMX10 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMZ10 for the date range from 2010-10-20 to 2010-11-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMZ10 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMF11 for the date range from 2010-11-22 to 2010-12-21. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMF11 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMG11 for the date range from 2010-12-21 to 2011-01-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMG11 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMH11 for the date range from 2011-01-20 to 2011-02-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMH11 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMJ11 for the date range from 2011-02-22 to 2011-03-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMJ11 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMK11 for the date range from 2011-03-22 to 2011-04-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMK11 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMM11 for the date range from 2011-04-20 to 2011-05-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMM11 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMN11 for the date range from 2011-05-20 to 2011-06-21. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMN11 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMQ11 for the date range from 2011-06-21 to 2011-07-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMQ11 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMU11 for the date range from 2011-07-20 to 2011-08-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMU11 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMV11 for the date range from 2011-08-22 to 2011-09-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMV11 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMX11 for the date range from 2011-09-20 to 2011-10-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMX11 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMZ11 for the date range from 2011-10-20 to 2011-11-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMZ11 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMF12 for the date range from 2011-11-22 to 2011-12-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMF12 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMG12 for the date range from 2011-12-20 to 2012-01-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMG12 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMH12 for the date range from 2012-01-20 to 2012-02-21. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMH12 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMJ12 for the date range from 2012-02-21 to 2012-03-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMJ12 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMK12 for the date range from 2012-03-20 to 2012-04-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMK12 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMM12 for the date range from 2012-04-20 to 2012-05-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMM12 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMN12 for the date range from 2012-05-22 to 2012-06-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMN12 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMQ12 for the date range from 2012-06-20 to 2012-07-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMQ12 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMU12 for the date range from 2012-07-20 to 2012-08-21. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMU12 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMV12 for the date range from 2012-08-21 to 2012-09-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMV12 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMX12 for the date range from 2012-09-20 to 2012-10-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMX12 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMZ12 for the date range from 2012-10-22 to 2012-11-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMZ12 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMF13 for the date range from 2012-11-20 to 2012-12-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMF13 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMG13 for the date range from 2012-12-20 to 2013-01-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMG13 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMH13 for the date range from 2013-01-22 to 2013-02-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMH13 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMJ13 for the date range from 2013-02-20 to 2013-03-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMJ13 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMK13 for the date range from 2013-03-20 to 2013-04-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMK13 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMM13 for the date range from 2013-04-22 to 2013-05-21. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMM13 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMN13 for the date range from 2013-05-21 to 2013-06-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMN13 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMQ13 for the date range from 2013-06-20 to 2013-07-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMQ13 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMU13 for the date range from 2013-07-22 to 2013-08-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMU13 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMV13 for the date range from 2013-08-20 to 2013-09-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMV13 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMX13 for the date range from 2013-09-20 to 2013-10-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMX13 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMZ13 for the date range from 2013-10-22 to 2013-11-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMZ13 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMF14 for the date range from 2013-11-20 to 2013-12-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMF14 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMG14 for the date range from 2013-12-20 to 2014-01-21. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMG14 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMH14 for the date range from 2014-01-21 to 2014-02-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMH14 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMJ14 for the date range from 2014-02-20 to 2014-03-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMJ14 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMK14 for the date range from 2014-03-20 to 2014-04-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMK14 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMM14 for the date range from 2014-04-22 to 2014-05-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMM14 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMN14 for the date range from 2014-05-20 to 2014-06-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMN14 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMQ14 for the date range from 2014-06-20 to 2014-07-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMQ14 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMU14 for the date range from 2014-07-22 to 2014-08-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMU14 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMV14 for the date range from 2014-08-20 to 2014-09-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMV14 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMX14 for the date range from 2014-09-22 to 2014-10-21. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMX14 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMZ14 for the date range from 2014-10-21 to 2014-11-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMZ14 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMF15 for the date range from 2014-11-20 to 2014-12-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMF15 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMG15 for the date range from 2014-12-22 to 2015-01-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMG15 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMH15 for the date range from 2015-01-20 to 2015-02-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMH15 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMJ15 for the date range from 2015-02-20 to 2015-03-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMJ15 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMK15 for the date range from 2015-03-20 to 2015-04-21. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMK15 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMM15 for the date range from 2015-04-21 to 2015-05-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMM15 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMN15 for the date range from 2015-05-20 to 2015-06-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMN15 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMQ15 for the date range from 2015-06-22 to 2015-07-21. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMQ15 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMU15 for the date range from 2015-07-21 to 2015-08-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMU15 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMV15 for the date range from 2015-08-20 to 2015-09-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMV15 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMX15 for the date range from 2015-09-22 to 2015-10-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMX15 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMZ15 for the date range from 2015-10-20 to 2015-11-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMZ15 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMF16 for the date range from 2015-11-20 to 2015-12-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMF16 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMG16 for the date range from 2015-12-22 to 2016-01-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMG16 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMH16 for the date range from 2016-01-20 to 2016-02-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMH16 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMJ16 for the date range from 2016-02-22 to 2016-03-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMJ16 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMK16 for the date range from 2016-03-22 to 2016-04-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMK16 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMM16 for the date range from 2016-04-20 to 2016-05-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMM16 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMN16 for the date range from 2016-05-20 to 2016-06-21. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMN16 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMQ16 for the date range from 2016-06-21 to 2016-07-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMQ16 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMU16 for the date range from 2016-07-20 to 2016-08-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMU16 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMV16 for the date range from 2016-08-22 to 2016-09-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMV16 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMX16 for the date range from 2016-09-20 to 2016-10-11. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMZ16 for the date range from 2016-10-11 to 2016-10-11. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMZ16.dly. Date: 2016-10-11, Price: 51.275. Date: 2016-10-11, Price: 51.275 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMX16.dly. Date: 2016-09-20, Price: 44.05. Date: 2016-10-10, Price: 51.35 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMV16.dly. Date: 2016-08-22, Price: 47.41. Date: 2016-09-19, Price: 43.3 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMU16.dly. Date: 2016-07-20, Price: 45.75. Date: 2016-08-19, Price: 48.52 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMQ16.dly. Date: 2016-06-21, Price: 49.85. Date: 2016-07-19, Price: 44.65 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMN16.dly. Date: 2016-05-20, Price: 48.4. Date: 2016-06-20, Price: 49.375 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMM16.dly. Date: 2016-04-20, Price: 44.175. Date: 2016-05-19, Price: 48.15 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMK16.dly. Date: 2016-03-22, Price: 41.45. Date: 2016-04-19, Price: 41.075 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMJ16.dly. Date: 2016-02-22, Price: 33.4. Date: 2016-03-21, Price: 39.45 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMH16.dly. Date: 2016-01-20, Price: 28.35. Date: 2016-02-19, Price: 29.64 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMG16.dly. Date: 2015-12-22, Price: 36.15. Date: 2016-01-19, Price: 28.45 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMF16.dly. Date: 2015-11-20, Price: 41.9. Date: 2015-12-21, Price: 34.725 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMZ15.dly. Date: 2015-10-20, Price: 46.29. Date: 2015-11-19, Price: 40.54 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMX15.dly. Date: 2015-09-22, Price: 46.36. Date: 2015-10-19, Price: 45.89 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMV15.dly. Date: 2015-08-20, Price: 41.32. Date: 2015-09-21, Price: 46.68 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMU15.dly. Date: 2015-07-21, Price: 50.86. Date: 2015-08-19, Price: 40.8 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMQ15.dly. Date: 2015-06-22, Price: 60.375. Date: 2015-07-20, Price: 50.15 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMN15.dly. Date: 2015-05-20, Price: 58.975. Date: 2015-06-19, Price: 59.6 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMM15.dly. Date: 2015-04-21, Price: 56.6. Date: 2015-05-19, Price: 59.425 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMK15.dly. Date: 2015-03-20, Price: 46.575. Date: 2015-04-20, Price: 56.375 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMJ15.dly. Date: 2015-02-20, Price: 50.8. Date: 2015-03-19, Price: 43.95 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMH15.dly. Date: 2015-01-20, Price: 46.475. Date: 2015-02-19, Price: 51.15 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMG15.dly. Date: 2014-12-22, Price: 55.25. Date: 2015-01-19, Price: 48.7 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMF15.dly. Date: 2014-11-20, Price: 75.85. Date: 2014-12-19, Price: 54.1 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMZ14.dly. Date: 2014-10-21, Price: 82.5. Date: 2014-11-19, Price: 74.575 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMX14.dly. Date: 2014-09-22, Price: 90.875. Date: 2014-10-20, Price: 82.7 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMV14.dly. Date: 2014-08-20, Price: 93.45. Date: 2014-09-19, Price: 92.4 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMU14.dly. Date: 2014-07-22, Price: 102.4. Date: 2014-08-19, Price: 94.475 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMQ14.dly. Date: 2014-06-20, Price: 106.825. Date: 2014-07-21, Price: 104.6 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMN14.dly. Date: 2014-05-20, Price: 102.325. Date: 2014-06-19, Price: 106.425 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMM14.dly. Date: 2014-04-22, Price: 101.75. Date: 2014-05-19, Price: 102.6 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMK14.dly. Date: 2014-03-20, Price: 98.9. Date: 2014-04-21, Price: 104.375 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMJ14.dly. Date: 2014-02-20, Price: 102.75. Date: 2014-03-19, Price: 100.375 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMH14.dly. Date: 2014-01-21, Price: 94.975. Date: 2014-02-19, Price: 103.3 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMG14.dly. Date: 2013-12-20, Price: 99.325. Date: 2014-01-20, Price: 94.375 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMF14.dly. Date: 2013-11-20, Price: 93.85. Date: 2013-12-19, Price: 97.8 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMZ13.dly. Date: 2013-10-22, Price: 98.3. Date: 2013-11-19, Price: 93.35 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMX13.dly. Date: 2013-09-20, Price: 104.75. Date: 2013-10-21, Price: 99.225 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMV13.dly. Date: 2013-08-20, Price: 105.1. Date: 2013-09-19, Price: 106.4 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMU13.dly. Date: 2013-07-22, Price: 106.95. Date: 2013-08-19, Price: 107.1 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMQ13.dly. Date: 2013-06-20, Price: 95.15. Date: 2013-07-19, Price: 108.05 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMN13.dly. Date: 2013-05-21, Price: 96.175. Date: 2013-06-19, Price: 98.25 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMM13.dly. Date: 2013-04-22, Price: 89.2. Date: 2013-05-20, Price: 96.7 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMK13.dly. Date: 2013-03-20, Price: 93.5. Date: 2013-04-19, Price: 88 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMJ13.dly. Date: 2013-02-20, Price: 95.225. Date: 2013-03-19, Price: 92.15 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMH13.dly. Date: 2013-01-22, Price: 96.675. Date: 2013-02-19, Price: 96.65 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMG13.dly. Date: 2012-12-20, Price: 90.125. Date: 2013-01-21, Price: 95.55 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMF13.dly. Date: 2012-11-20, Price: 86.75. Date: 2012-12-19, Price: 87.925 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMZ12.dly. Date: 2012-10-22, Price: 88.65. Date: 2012-11-19, Price: 85.45 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMX12.dly. Date: 2012-09-20, Price: 92.425. Date: 2012-10-19, Price: 90.05 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMV12.dly. Date: 2012-08-21, Price: 96.85. Date: 2012-09-19, Price: 91.975 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMU12.dly. Date: 2012-07-20, Price: 91.825. Date: 2012-08-20, Price: 95.975 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMQ12.dly. Date: 2012-06-20, Price: 81.45. Date: 2012-07-19, Price: 92.65 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMN12.dly. Date: 2012-05-22, Price: 91.85. Date: 2012-06-19, Price: 84.025 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMM12.dly. Date: 2012-04-20, Price: 103.875. Date: 2012-05-21, Price: 92.575 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMK12.dly. Date: 2012-03-20, Price: 106.075. Date: 2012-04-19, Price: 102.275 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMJ12.dly. Date: 2012-02-21, Price: 106.25. Date: 2012-03-19, Price: 108.1 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMH12.dly. Date: 2012-01-20, Price: 98.325. Date: 2012-02-20, Price: 103.25 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMG12.dly. Date: 2011-12-20, Price: 97.25. Date: 2012-01-19, Price: 100.4 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMF12.dly. Date: 2011-11-22, Price: 98. Date: 2011-12-19, Price: 93.875 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMZ11.dly. Date: 2011-10-20, Price: 86.075. Date: 2011-11-21, Price: 98.825 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMX11.dly. Date: 2011-09-20, Price: 86.925. Date: 2011-10-19, Price: 86.1 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMV11.dly. Date: 2011-08-22, Price: 84.425. Date: 2011-09-19, Price: 85.7 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMU11.dly. Date: 2011-07-20, Price: 98.4. Date: 2011-08-19, Price: 82.25 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMQ11.dly. Date: 2011-06-21, Price: 94.175. Date: 2011-07-19, Price: 97.5 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMN11.dly. Date: 2011-05-20, Price: 100.1. Date: 2011-06-20, Price: 93.25 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMM11.dly. Date: 2011-04-20, Price: 111.45. Date: 2011-05-19, Price: 98.45 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMK11.dly. Date: 2011-03-22, Price: 104.975. Date: 2011-04-19, Price: 107.125 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMJ11.dly. Date: 2011-02-22, Price: 95.425. Date: 2011-03-21, Price: 102.325 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMH11.dly. Date: 2011-01-20, Price: 89.6. Date: 2011-02-21, Price: 86.2 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMG11.dly. Date: 2010-12-21, Price: 89.825. Date: 2011-01-19, Price: 90.85 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMF11.dly. Date: 2010-11-22, Price: 81.75. Date: 2010-12-20, Price: 88.025 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMZ10.dly. Date: 2010-10-20, Price: 82.55. Date: 2010-11-19, Price: 81.85 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMX10.dly. Date: 2010-09-21, Price: 74.975. Date: 2010-10-19, Price: 79.5 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMV10.dly. Date: 2010-08-20, Price: 73.825. Date: 2010-09-20, Price: 74.85 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMU10.dly. Date: 2010-07-20, Price: 77.575. Date: 2010-08-19, Price: 74.425 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMQ10.dly. Date: 2010-06-22, Price: 77.85. Date: 2010-07-19, Price: 76.55 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMQ10.dly has a volume of 0 at 2010-07-19. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMN10.dly. Date: 2010-05-20, Price: 70.8. Date: 2010-06-21, Price: 77.825 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMN10.dly has a volume of 0 at 2010-06-21. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMM10.dly. Date: 2010-04-20, Price: 83.85. Date: 2010-05-19, Price: 69.875 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMM10.dly has a volume of 0 at 2010-05-19. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMK10.dly. Date: 2010-03-22, Price: 81.6. Date: 2010-04-19, Price: 81.45 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMK10.dly has a volume of 0 at 2010-04-19. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMJ10.dly. Date: 2010-02-22, Price: 80.3. Date: 2010-03-19, Price: 80.675 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMJ10.dly has a volume of 0 at 2010-03-19. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMH10.dly. Date: 2010-01-20, Price: 77.75. Date: 2010-02-19, Price: 79.8 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMH10.dly has a volume of 0 at 2010-02-19. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMG10.dly. Date: 2009-12-22, Price: 74.4. Date: 2010-01-19, Price: 79.025 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMG10.dly has a volume of 0 at 2010-01-19. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMF10.dly. Date: 2009-11-20, Price: 77.475. Date: 2009-12-21, Price: 73.35 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMF10.dly has a volume of 0 at 2009-12-21. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMZ09.dly. Date: 2009-10-20, Price: 79.12. Date: 2009-11-19, Price: 77.45 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMZ09.dly has a volume of 0 at 2009-11-19. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMX09.dly. Date: 2009-09-22, Price: 71.76. Date: 2009-10-19, Price: 79.61 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMX09.dly has a volume of 0 at 2009-10-19. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMV09.dly. Date: 2009-08-20, Price: 72.91. Date: 2009-09-21, Price: 69.71 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMV09.dly has a volume of 0 at 2009-09-21. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMU09.dly. Date: 2009-07-21, Price: 65.61. Date: 2009-08-19, Price: 72.42001 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMU09.dly has a volume of 0 at 2009-08-19. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMQ09.dly. Date: 2009-06-22, Price: 67.5. Date: 2009-07-20, Price: 63.98 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMQ09.dly has a volume of 0 at 2009-07-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMN09.dly. Date: 2009-05-20, Price: 62.04. Date: 2009-06-19, Price: 69.55 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMN09.dly has a volume of 0 at 2009-06-19. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMM09.dly. Date: 2009-04-21, Price: 48.55. Date: 2009-05-19, Price: 59.03 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMM09.dly has a volume of 0 at 2009-05-19. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMK09.dly. Date: 2009-03-20, Price: 52.07. Date: 2009-04-20, Price: 45.88 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMK09.dly has a volume of 0 at 2009-04-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMJ09.dly. Date: 2009-02-20, Price: 40.03. Date: 2009-03-19, Price: 51.61 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMJ09.dly has a volume of 0 at 2009-03-19. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMH09.dly. Date: 2009-01-20, Price: 40.84. Date: 2009-02-19, Price: 39.48 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMH09.dly has a volume of 0 at 2009-02-19. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMG09.dly. Date: 2008-12-22, Price: 39.91. Date: 2009-01-19, Price: 36.51 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMF09.dly. Date: 2008-11-20, Price: 49.42. Date: 2008-12-19, Price: 36.22 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMF09.dly has a volume of 0 at 2008-12-19. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMZ08.dly. Date: 2008-10-21, Price: 72.18. Date: 2008-11-19, Price: 53.62 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMZ08.dly has a volume of 0 at 2008-11-19. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMX08.dly. Date: 2008-09-22, Price: 109.37. Date: 2008-10-20, Price: 74.25 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMX08.dly has a volume of 0 at 2008-10-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMV08.dly. Date: 2008-08-20, Price: 115.56. Date: 2008-09-19, Price: 104.55 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMV08.dly has a volume of 0 at 2008-09-19. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMU08.dly. Date: 2008-07-22, Price: 128.42. Date: 2008-08-19, Price: 114.53 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMU08.dly has a volume of 0 at 2008-08-19. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMQ08.dly. Date: 2008-06-20, Price: 135.36. Date: 2008-07-21, Price: 131.04 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMQ08.dly has a volume of 0 at 2008-07-21. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMN08.dly. Date: 2008-05-20, Price: 128.98. Date: 2008-06-19, Price: 131.93 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMN08.dly has a volume of 0 at 2008-06-19. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMM08.dly. Date: 2008-04-22, Price: 118.07. Date: 2008-05-19, Price: 127.05 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMM08.dly has a volume of 0 at 2008-05-19. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMK08.dly. Date: 2008-03-20, Price: 101.84. Date: 2008-04-21, Price: 117.48 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMK08.dly has a volume of 0 at 2008-04-21. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMJ08.dly. Date: 2008-02-20, Price: 99.7. Date: 2008-03-19, Price: 109.42 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMJ08.dly has a volume of 0 at 2008-03-19. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMH08.dly. Date: 2008-01-22, Price: 89.21. Date: 2008-02-19, Price: 100.01 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMH08.dly has a volume of 0 at 2008-02-19. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMG08.dly. Date: 2007-12-20, Price: 91.06. Date: 2008-01-21, Price: 90.57 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMG08.dly has a volume of 0 at 2008-01-21. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMF08.dly. Date: 2007-11-20, Price: 98.03. Date: 2007-12-19, Price: 90.63 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMF08.dly has a volume of 0 at 2007-12-19. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMZ07.dly. Date: 2007-10-22, Price: 86.02. Date: 2007-11-19, Price: 93.43 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMZ07.dly has a volume of 0 at 2007-11-19. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMX07.dly. Date: 2007-09-20, Price: 81.78. Date: 2007-10-19, Price: 88.6 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMX07.dly has a volume of 0 at 2007-10-19. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMV07.dly. Date: 2007-08-21, Price: 69.57. Date: 2007-09-19, Price: 81.93 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMV07.dly has a volume of 0 at 2007-09-19. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMU07.dly. Date: 2007-07-20, Price: 75.79. Date: 2007-08-20, Price: 71.12 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMU07.dly has a volume of 0 at 2007-08-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMQ07.dly. Date: 2007-06-20, Price: 68.86. Date: 2007-07-19, Price: 75.92001 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMQ07.dly has a volume of 0 at 2007-07-19. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMN07.dly. Date: 2007-05-22, Price: 65.51. Date: 2007-06-19, Price: 69.1 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMN07.dly has a volume of 0 at 2007-06-19. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMM07.dly. Date: 2007-04-20, Price: 64.11. Date: 2007-05-21, Price: 66.27 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMM07.dly has a volume of 0 at 2007-05-21. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMK07.dly. Date: 2007-03-20, Price: 59.25. Date: 2007-04-19, Price: 61.83 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMK07.dly has a volume of 0 at 2007-04-19. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMJ07.dly. Date: 2007-02-20, Price: 58.85. Date: 2007-03-19, Price: 56.59 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMJ07.dly has a volume of 0 at 2007-03-19. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMH07.dly. Date: 2007-01-22, Price: 52.58. Date: 2007-02-19, Price: 59.39 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMH07.dly has a volume of 0 at 2007-02-19. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMG07.dly. Date: 2006-12-20, Price: 63.72. Date: 2007-01-19, Price: 51.99 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMG07.dly has a volume of 0 at 2007-01-19. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMF07.dly. Date: 2006-11-21, Price: 60.17. Date: 2006-12-19, Price: 62.21 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMF07.dly has a volume of 0 at 2006-12-19. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMZ06.dly. Date: 2006-10-20, Price: 59.33. Date: 2006-11-20, Price: 56.26 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMZ06.dly has a volume of 0 at 2006-11-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMX06.dly. Date: 2006-09-20, Price: 60.74. Date: 2006-10-19, Price: 58.5 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMX06.dly has a volume of 0 at 2006-10-19. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMV06.dly. Date: 2006-08-22, Price: 73.1. Date: 2006-09-19, Price: 61.66 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | File QMV06.dly has a volume of 0 at 2006-09-19. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Symbols used for continuous contract chart: | 2016-10-11 15:24:44 QMV06 | 2016-10-11 15:24:44 QMX06 | 2016-10-11 15:24:44 QMZ06 | 2016-10-11 15:24:44 QMF07 | 2016-10-11 15:24:44 QMG07 | 2016-10-11 15:24:44 QMH07 | 2016-10-11 15:24:44 QMJ07 | 2016-10-11 15:24:44 QMK07 | 2016-10-11 15:24:44 QMM07 | 2016-10-11 15:24:44 QMN07 | 2016-10-11 15:24:44 QMQ07 | 2016-10-11 15:24:44 QMU07 | 2016-10-11 15:24:44 QMV07 | 2016-10-11 15:24:44 QMX07 | 2016-10-11 15:24:44 QMZ07 | 2016-10-11 15:24:44 QMF08 | 2016-10-11 15:24:44 QMG08 | 2016-10-11 15:24:44 QMH08 | 2016-10-11 15:24:44 QMJ08 | 2016-10-11 15:24:44 QMK08 | 2016-10-11 15:24:44 QMM08 | 2016-10-11 15:24:44 QMN08 | 2016-10-11 15:24:44 QMQ08 | 2016-10-11 15:24:44 QMU08 | 2016-10-11 15:24:44 QMV08 | 2016-10-11 15:24:44 QMX08 | 2016-10-11 15:24:44 QMZ08 | 2016-10-11 15:24:44 QMF09 | 2016-10-11 15:24:44 QMG09 | 2016-10-11 15:24:44 QMH09 | 2016-10-11 15:24:44 QMJ09 | 2016-10-11 15:24:44 QMK09 | 2016-10-11 15:24:44 QMM09 | 2016-10-11 15:24:44 QMN09 | 2016-10-11 15:24:44 QMQ09 | 2016-10-11 15:24:44 QMU09 | 2016-10-11 15:24:44 QMV09 | 2016-10-11 15:24:44 QMX09 | 2016-10-11 15:24:44 QMZ09 | 2016-10-11 15:24:44 QMF10 | 2016-10-11 15:24:44 QMG10 | 2016-10-11 15:24:44 QMH10 | 2016-10-11 15:24:44 QMJ10 | 2016-10-11 15:24:44 QMK10 | 2016-10-11 15:24:44 QMM10 | 2016-10-11 15:24:44 QMN10 | 2016-10-11 15:24:44 QMQ10 | 2016-10-11 15:24:44 QMU10 | 2016-10-11 15:24:44 QMV10 | 2016-10-11 15:24:44 QMX10 | 2016-10-11 15:24:44 QMZ10 | 2016-10-11 15:24:44 QMF11 | 2016-10-11 15:24:44 QMG11 | 2016-10-11 15:24:44 QMH11 | 2016-10-11 15:24:44 QMJ11 | 2016-10-11 15:24:44 QMK11 | 2016-10-11 15:24:44 QMM11 | 2016-10-11 15:24:44 QMN11 | 2016-10-11 15:24:44 QMQ11 | 2016-10-11 15:24:44 QMU11 | 2016-10-11 15:24:44 QMV11 | 2016-10-11 15:24:44 QMX11 | 2016-10-11 15:24:44 QMZ11 | 2016-10-11 15:24:44 QMF12 | 2016-10-11 15:24:44 QMG12 | 2016-10-11 15:24:44 QMH12 | 2016-10-11 15:24:44 QMJ12 | 2016-10-11 15:24:44 QMK12 | 2016-10-11 15:24:44 QMM12 | 2016-10-11 15:24:44 QMN12 | 2016-10-11 15:24:44 QMQ12 | 2016-10-11 15:24:44 QMU12 | 2016-10-11 15:24:44 QMV12 | 2016-10-11 15:24:44 QMX12 | 2016-10-11 15:24:44 QMZ12 | 2016-10-11 15:24:44 QMF13 | 2016-10-11 15:24:44 QMG13 | 2016-10-11 15:24:44 QMH13 | 2016-10-11 15:24:44 QMJ13 | 2016-10-11 15:24:44 QMK13 | 2016-10-11 15:24:44 QMM13 | 2016-10-11 15:24:44 QMN13 | 2016-10-11 15:24:44 QMQ13 | 2016-10-11 15:24:44 QMU13 | 2016-10-11 15:24:44 QMV13 | 2016-10-11 15:24:44 QMX13 | 2016-10-11 15:24:44 QMZ13 | 2016-10-11 15:24:44 QMF14 | 2016-10-11 15:24:44 QMG14 | 2016-10-11 15:24:44 QMH14 | 2016-10-11 15:24:44 QMJ14 | 2016-10-11 15:24:44 QMK14 | 2016-10-11 15:24:44 QMM14 | 2016-10-11 15:24:44 QMN14 | 2016-10-11 15:24:44 QMQ14 | 2016-10-11 15:24:44 QMU14 | 2016-10-11 15:24:44 QMV14 | 2016-10-11 15:24:44 QMX14 | 2016-10-11 15:24:44 QMZ14 | 2016-10-11 15:24:44 QMF15 | 2016-10-11 15:24:44 QMG15 | 2016-10-11 15:24:44 QMH15 | 2016-10-11 15:24:44 QMJ15 | 2016-10-11 15:24:44 QMK15 | 2016-10-11 15:24:44 QMM15 | 2016-10-11 15:24:44 QMN15 | 2016-10-11 15:24:44 QMQ15 | 2016-10-11 15:24:44 QMU15 | 2016-10-11 15:24:44 QMV15 | 2016-10-11 15:24:44 QMX15 | 2016-10-11 15:24:44 QMZ15 | 2016-10-11 15:24:44 QMF16 | 2016-10-11 15:24:44 QMG16 | 2016-10-11 15:24:44 QMH16 | 2016-10-11 15:24:44 QMJ16 | 2016-10-11 15:24:44 QMK16 | 2016-10-11 15:24:44 QMM16 | 2016-10-11 15:24:44 QMN16 | 2016-10-11 15:24:44 QMQ16 | 2016-10-11 15:24:44 QMU16 | 2016-10-11 15:24:44 QMV16 | 2016-10-11 15:24:44 QMX16 | 2016-10-11 15:24:44 QMZ16 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Performing continuous futures contract back adjustment calculations. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMV06 Open price on 2006-09-20 is 63.9. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMX06 Open price on 2006-09-20 is 62.15. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMV06 price difference to QMX06 is -1.75. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMX06 Open price on 2006-10-20 is 57.8. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMZ06 Open price on 2006-10-20 is 60.6. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMX06 price difference to QMZ06 is 2.8. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMZ06 Open price on 2006-11-21 is 58.75. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMF07 Open price on 2006-11-21 is 58.95. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMZ06 price difference to QMF07 is 0.2. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMF07 Open price on 2006-12-20 is 63.25. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMG07 Open price on 2006-12-20 is 63.4. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMF07 price difference to QMG07 is 0.15. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMG07 Open price on 2007-01-22 is 50.475. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMH07 Open price on 2007-01-22 is 53.575. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMG07 price difference to QMH07 is 3.1. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMH07 Open price on 2007-02-20 is 58. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMJ07 Open price on 2007-02-20 is 59.55. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMH07 price difference to QMJ07 is 1.55. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMJ07 Open price on 2007-03-20 is 57.25. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMK07 Open price on 2007-03-20 is 59.9. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMJ07 price difference to QMK07 is 2.65. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMK07 Open price on 2007-04-20 is 62.625. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMM07 Open price on 2007-04-20 is 63.075. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMK07 price difference to QMM07 is 0.45. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMM07 Open price on 2007-05-22 is 64.95. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMN07 Open price on 2007-05-22 is 66.825. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMM07 price difference to QMN07 is 1.875. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMN07 Open price on 2007-06-20 is 69.1. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMQ07 Open price on 2007-06-20 is 69.425. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMN07 price difference to QMQ07 is 0.325. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMQ07 Open price on 2007-07-20 is 74.875. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMU07 Open price on 2007-07-20 is 76.1. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMQ07 price difference to QMU07 is 1.225. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMU07 Open price on 2007-08-21 is 71.95. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMV07 Open price on 2007-08-21 is 70.95. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMU07 price difference to QMV07 is -1. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMV07 Open price on 2007-09-20 is 82.2. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMX07 Open price on 2007-09-20 is 80.525. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMV07 price difference to QMX07 is -1.675. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMX07 Open price on 2007-10-22 is 89.775. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMZ07 Open price on 2007-10-22 is 86.875. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMX07 price difference to QMZ07 is -2.9. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMZ07 Open price on 2007-11-20 is 94.1. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMF08 Open price on 2007-11-20 is 94.825. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMZ07 price difference to QMF08 is 0.725. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMF08 Open price on 2007-12-20 is 91.375. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMG08 Open price on 2007-12-20 is 91.4. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMF08 price difference to QMG08 is 0.025. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMG08 Open price on 2008-01-22 is 89.85. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMH08 Open price on 2008-01-22 is 89.8. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMG08 price difference to QMH08 is -0.05. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMH08 Open price on 2008-02-20 is 95.4. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMJ08 Open price on 2008-02-20 is 99.55. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMH08 price difference to QMJ08 is 4.15. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMJ08 Open price on 2008-03-20 is 106. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMK08 Open price on 2008-03-20 is 102.1. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMJ08 price difference to QMK08 is -3.9. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMK08 Open price on 2008-04-22 is 116.625. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMM08 Open price on 2008-04-22 is 116.675. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMK08 price difference to QMM08 is 0.05. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMM08 Open price on 2008-05-20 is 126.3. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMN08 Open price on 2008-05-20 is 126.825. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMM08 price difference to QMN08 is 0.525. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMN08 Open price on 2008-06-20 is 136.1. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMQ08 Open price on 2008-06-20 is 132.275. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMN08 price difference to QMQ08 is -3.825. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMQ08 Open price on 2008-07-22 is 129.125. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMU08 Open price on 2008-07-22 is 131.9. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMQ08 price difference to QMU08 is 2.775. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMU08 Open price on 2008-08-20 is 113.175. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMV08 Open price on 2008-08-20 is 115.15. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMU08 price difference to QMV08 is 1.975. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMV08 Open price on 2008-09-22 is 98.05. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMX08 Open price on 2008-09-22 is 102.15. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMV08 price difference to QMX08 is 4.1. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMX08 Open price on 2008-10-21 is 72.3. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMZ08 Open price on 2008-10-21 is 75.8. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMX08 price difference to QMZ08 is 3.5. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMZ08 Open price on 2008-11-20 is 54.5. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMF09 Open price on 2008-11-20 is 53.6. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMZ08 price difference to QMF09 is -0.9. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMF09 Open price on 2008-12-22 is 40.2. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMG09 Open price on 2008-12-22 is 42.7. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMF09 price difference to QMG09 is 2.5. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMG09 Open price on 2009-01-20 is 35.4. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMH09 Open price on 2009-01-20 is 42.575. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMG09 price difference to QMH09 is 7.175. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMH09 Open price on 2009-02-20 is 34.75. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMJ09 Open price on 2009-02-20 is 39.55. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMH09 price difference to QMJ09 is 4.8. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMJ09 Open price on 2009-03-20 is 49.8. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMK09 Open price on 2009-03-20 is 51.775. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMJ09 price difference to QMK09 is 1.975. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMK09 Open price on 2009-04-21 is 50.05. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMM09 Open price on 2009-04-21 is 48.3. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMK09 price difference to QMM09 is -1.75. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMM09 Open price on 2009-05-20 is 56.425. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMN09 Open price on 2009-05-20 is 60.225. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMM09 price difference to QMN09 is 3.8. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMN09 Open price on 2009-06-22 is 71.45. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMQ09 Open price on 2009-06-22 is 70.15. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMN09 price difference to QMQ09 is -1.3. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMQ09 Open price on 2009-07-21 is 63.525. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMU09 Open price on 2009-07-21 is 65.4. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMQ09 price difference to QMU09 is 1.875. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMU09 Open price on 2009-08-20 is 70.225. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMV09 Open price on 2009-08-20 is 73.5. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMU09 price difference to QMV09 is 3.275. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMV09 Open price on 2009-09-22 is 72.05. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMX09 Open price on 2009-09-22 is 69.875. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMV09 price difference to QMX09 is -2.175. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMX09 Open price on 2009-10-20 is 78.85. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMZ09 Open price on 2009-10-20 is 80. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMX09 price difference to QMZ09 is 1.15. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMZ09 Open price on 2009-11-20 is 79.7. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMF10 Open price on 2009-11-20 is 78.475. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMZ09 price difference to QMF10 is -1.225. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMF10 Open price on 2009-12-22 is 72.85. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMG10 Open price on 2009-12-22 is 73.5. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMF10 price difference to QMG10 is 0.65. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMG10 Open price on 2010-01-20 is 77.825. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMH10 Open price on 2010-01-20 is 79.175. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMG10 price difference to QMH10 is 1.35. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMH10 Open price on 2010-02-22 is 78.325. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMJ10 Open price on 2010-02-22 is 80.3. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMH10 price difference to QMJ10 is 1.975. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMJ10 Open price on 2010-03-22 is 82.2. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMK10 Open price on 2010-03-22 is 80.875. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMJ10 price difference to QMK10 is -1.325. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMK10 Open price on 2010-04-20 is 82.975. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMM10 Open price on 2010-04-20 is 83.275. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMK10 price difference to QMM10 is 0.3. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMM10 Open price on 2010-05-20 is 69.025. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMN10 Open price on 2010-05-20 is 72.825. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMM10 price difference to QMN10 is 3.8. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMN10 Open price on 2010-06-22 is 77.9. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMQ10 Open price on 2010-06-22 is 78.175. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMN10 price difference to QMQ10 is 0.275. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMQ10 Open price on 2010-07-20 is 75.625. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMU10 Open price on 2010-07-20 is 76.725. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMQ10 price difference to QMU10 is 1.1. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMU10 Open price on 2010-08-20 is 75.2. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMV10 Open price on 2010-08-20 is 74.8. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMU10 price difference to QMV10 is -0.4. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMV10 Open price on 2010-09-21 is 73.575. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMX10 Open price on 2010-09-21 is 76.25. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMV10 price difference to QMX10 is 2.675. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMX10 Open price on 2010-10-20 is 82.95. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMZ10 Open price on 2010-10-20 is 79.975. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMX10 price difference to QMZ10 is -2.975. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMZ10 Open price on 2010-11-22 is 80.4. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMF11 Open price on 2010-11-22 is 82.2. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMZ10 price difference to QMF11 is 1.8. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMF11 Open price on 2010-12-21 is 87.925. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMG11 Open price on 2010-12-21 is 89.175. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMF11 price difference to QMG11 is 1.25. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMG11 Open price on 2011-01-20 is 91.225. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMH11 Open price on 2011-01-20 is 91.6. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMG11 price difference to QMH11 is 0.375. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMH11 Open price on 2011-02-22 is 86.45. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMJ11 Open price on 2011-02-22 is 90.1. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMH11 price difference to QMJ11 is 3.65. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMJ11 Open price on 2011-03-22 is 102.05. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMK11 Open price on 2011-03-22 is 102.7. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMJ11 price difference to QMK11 is 0.65. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMK11 Open price on 2011-04-20 is 109.35. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMM11 Open price on 2011-04-20 is 108.425. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMK11 price difference to QMM11 is -0.925. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMM11 Open price on 2011-05-20 is 99.675. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMN11 Open price on 2011-05-20 is 99.1. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMM11 price difference to QMN11 is -0.575. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMN11 Open price on 2011-06-21 is 92.875. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMQ11 Open price on 2011-06-21 is 93.825. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMN11 price difference to QMQ11 is 0.95. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMQ11 Open price on 2011-07-20 is 96.125. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMU11 Open price on 2011-07-20 is 98.475. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMQ11 price difference to QMU11 is 2.35. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMU11 Open price on 2011-08-22 is 81.45. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMV11 Open price on 2011-08-22 is 82.4. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMU11 price difference to QMV11 is 0.95. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMV11 Open price on 2011-09-20 is 87.25. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMX11 Open price on 2011-09-20 is 86. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMV11 price difference to QMX11 is -1.25. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMX11 Open price on 2011-10-20 is 88.2. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMZ11 Open price on 2011-10-20 is 86.2. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMX11 price difference to QMZ11 is -2. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMZ11 Open price on 2011-11-22 is 101.675. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMF12 Open price on 2011-11-22 is 97.125. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMZ11 price difference to QMF12 is -4.55. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMF12 Open price on 2011-12-20 is 93.625. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMG12 Open price on 2011-12-20 is 94.275. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMF12 price difference to QMG12 is 0.65. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMG12 Open price on 2012-01-20 is 101.1. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMH12 Open price on 2012-01-20 is 100.575. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMG12 price difference to QMH12 is -0.525. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMH12 Open price on 2012-02-21 is 102.3. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMJ12 Open price on 2012-02-21 is 104.55. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMH12 price difference to QMJ12 is 2.25. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMJ12 Open price on 2012-03-20 is 107.225. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMK12 Open price on 2012-03-20 is 108.35. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMJ12 price difference to QMK12 is 1.125. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMK12 Open price on 2012-04-20 is 102.75. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMM12 Open price on 2012-04-20 is 103. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMK12 price difference to QMM12 is 0.25. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMM12 Open price on 2012-05-22 is 91.35. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMN12 Open price on 2012-05-22 is 93. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMM12 price difference to QMN12 is 1.65. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMN12 Open price on 2012-06-20 is 83. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMQ12 Open price on 2012-06-20 is 84.25. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMN12 price difference to QMQ12 is 1.25. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMQ12 Open price on 2012-07-20 is 89.975. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMU12 Open price on 2012-07-20 is 92.6. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMQ12 price difference to QMU12 is 2.625. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMU12 Open price on 2012-08-21 is 96.375. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMV12 Open price on 2012-08-21 is 96.175. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMU12 price difference to QMV12 is -0.2. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMV12 Open price on 2012-09-20 is 95.525. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMX12 Open price on 2012-09-20 is 92.25. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMV12 price difference to QMX12 is -3.275. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMX12 Open price on 2012-10-22 is 92.05. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMZ12 Open price on 2012-10-22 is 90.175. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMX12 price difference to QMZ12 is -1.875. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMZ12 Open price on 2012-11-20 is 86.35. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMF13 Open price on 2012-11-20 is 89.1. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMZ12 price difference to QMF13 is 2.75. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMF13 Open price on 2012-12-20 is 87.4. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMG13 Open price on 2012-12-20 is 89.625. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMF13 price difference to QMG13 is 2.225. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMG13 Open price on 2013-01-22 is 95.2. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMH13 Open price on 2013-01-22 is 95.75. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMG13 price difference to QMH13 is 0.55. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMH13 Open price on 2013-02-20 is 95.95. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMJ13 Open price on 2013-02-20 is 97.1. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMH13 price difference to QMJ13 is 1.15. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMJ13 Open price on 2013-03-20 is 93.925. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMK13 Open price on 2013-03-20 is 92.45. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMJ13 price difference to QMK13 is -1.475. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMK13 Open price on 2013-04-22 is 88.275. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMM13 Open price on 2013-04-22 is 88.1. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMK13 price difference to QMM13 is -0.175. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMM13 Open price on 2013-05-21 is 96.15. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMN13 Open price on 2013-05-21 is 96.875. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMM13 price difference to QMN13 is 0.725. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMN13 Open price on 2013-06-20 is 98.575. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMQ13 Open price on 2013-06-20 is 98.2. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMN13 price difference to QMQ13 is -0.375. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMQ13 Open price on 2013-07-22 is 108.075. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMU13 Open price on 2013-07-22 is 108.025. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMQ13 price difference to QMU13 is -0.05. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMU13 Open price on 2013-08-20 is 107.625. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMV13 Open price on 2013-08-20 is 106.7. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMU13 price difference to QMV13 is -0.925. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMV13 Open price on 2013-09-20 is 108.425. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMX13 Open price on 2013-09-20 is 105.775. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMV13 price difference to QMX13 is -2.65. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMX13 Open price on 2013-10-22 is 100.8. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMZ13 Open price on 2013-10-22 is 99.55. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMX13 price difference to QMZ13 is -1.25. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMZ13 Open price on 2013-11-20 is 93.075. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMF14 Open price on 2013-11-20 is 93.875. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMZ13 price difference to QMF14 is 0.8. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMF14 Open price on 2013-12-20 is 97.325. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMG14 Open price on 2013-12-20 is 98.675. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMF14 price difference to QMG14 is 1.35. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMG14 Open price on 2014-01-21 is 94.1. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMH14 Open price on 2014-01-21 is 94.25. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMG14 price difference to QMH14 is 0.15. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMH14 Open price on 2014-02-20 is 103.1. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMJ14 Open price on 2014-02-20 is 102.9. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMH14 price difference to QMJ14 is -0.2. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMJ14 Open price on 2014-03-20 is 99.475. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMK14 Open price on 2014-03-20 is 99.15. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMJ14 price difference to QMK14 is -0.325. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMK14 Open price on 2014-04-22 is 104.45. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMM14 Open price on 2014-04-22 is 103.625. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMK14 price difference to QMM14 is -0.825. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMM14 Open price on 2014-05-20 is 102.025. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMN14 Open price on 2014-05-20 is 102.1. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMM14 price difference to QMN14 is 0.075. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMN14 Open price on 2014-06-20 is 106.05. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMQ14 Open price on 2014-06-20 is 106.075. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMN14 price difference to QMQ14 is 0.025. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMQ14 Open price on 2014-07-22 is 102.95. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMU14 Open price on 2014-07-22 is 102.75. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMQ14 price difference to QMU14 is -0.2. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMU14 Open price on 2014-08-20 is 96.6. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMV14 Open price on 2014-08-20 is 92.85. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMU14 price difference to QMV14 is -3.75. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMV14 Open price on 2014-09-22 is 92.975. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMX14 Open price on 2014-09-22 is 91.625. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMV14 price difference to QMX14 is -1.35. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMX14 Open price on 2014-10-21 is 83.1. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMZ14 Open price on 2014-10-21 is 81.85. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMX14 price difference to QMZ14 is -1.25. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMZ14 Open price on 2014-11-20 is 74.225. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMF15 Open price on 2014-11-20 is 74.325. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMZ14 price difference to QMF15 is 0.1. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMF15 Open price on 2014-12-22 is 55.8. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMG15 Open price on 2014-12-22 is 57.675. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMF15 price difference to QMG15 is 1.875. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMG15 Open price on 2015-01-20 is 46.25. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMH15 Open price on 2015-01-20 is 49.125. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMG15 price difference to QMH15 is 2.875. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMH15 Open price on 2015-02-20 is 50.575. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMJ15 Open price on 2015-02-20 is 52.175. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMH15 price difference to QMJ15 is 1.6. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMJ15 Open price on 2015-03-20 is 44.575. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMK15 Open price on 2015-03-20 is 45.6. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMJ15 price difference to QMK15 is 1.025. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMK15 Open price on 2015-04-21 is 56.075. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMM15 Open price on 2015-04-21 is 57.925. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMK15 price difference to QMM15 is 1.85. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMM15 Open price on 2015-05-20 is 59.85. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMN15 Open price on 2015-05-20 is 58.325. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMM15 price difference to QMN15 is -1.525. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMN15 Open price on 2015-06-22 is 60.45. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMQ15 Open price on 2015-06-22 is 59.75. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMN15 price difference to QMQ15 is -0.7. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMQ15 Open price on 2015-07-21 is 50.725. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMU15 Open price on 2015-07-21 is 50.25. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMQ15 price difference to QMU15 is -0.475. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMU15 Open price on 2015-08-20 is 42.425. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMV15 Open price on 2015-08-20 is 40.95. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMU15 price difference to QMV15 is -1.475. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMV15 Open price on 2015-09-22 is 44.85. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMX15 Open price on 2015-09-22 is 46.7. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMV15 price difference to QMX15 is 1.85. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMX15 Open price on 2015-10-20 is 47.1. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMZ15 Open price on 2015-10-20 is 46.575. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMX15 price difference to QMZ15 is -0.525. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMZ15 Open price on 2015-11-20 is 40.7. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMF16 Open price on 2015-11-20 is 41.875. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMZ15 price difference to QMF16 is 1.175. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMF16 Open price on 2015-12-22 is 34.8. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMG16 Open price on 2015-12-22 is 35.85. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMF16 price difference to QMG16 is 1.05. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMG16 Open price on 2016-01-20 is 29.35. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMH16 Open price on 2016-01-20 is 29.475. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMG16 price difference to QMH16 is 0.125. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMH16 Open price on 2016-02-22 is 30.675. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMJ16 Open price on 2016-02-22 is 31.95. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMH16 price difference to QMJ16 is 1.275. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMJ16 Open price on 2016-03-22 is 40.25. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMK16 Open price on 2016-03-22 is 41.6. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMJ16 price difference to QMK16 is 1.35. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMK16 Open price on 2016-04-20 is 39.975. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMM16 Open price on 2016-04-20 is 42.35. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMK16 price difference to QMM16 is 2.375. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMM16 Open price on 2016-05-20 is 47.9. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMN16 Open price on 2016-05-20 is 48.725. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMM16 price difference to QMN16 is 0.825. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMN16 Open price on 2016-06-21 is 48.35. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMQ16 Open price on 2016-06-21 is 49.775. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMN16 price difference to QMQ16 is 1.425. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMQ16 Open price on 2016-07-20 is 45.175. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMU16 Open price on 2016-07-20 is 45.475. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMQ16 price difference to QMU16 is 0.3. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMU16 Open price on 2016-08-22 is 48.375. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMV16 Open price on 2016-08-22 is 49.05. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMU16 price difference to QMV16 is 0.675. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMV16 Open price on 2016-09-20 is 43.2. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMX16 Open price on 2016-09-20 is 43.75. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMV16 price difference to QMX16 is 0.55. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMX16 Open price on 2016-10-11 is 51.125. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMZ16 Open price on 2016-10-11 is 51.65. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | QMX16 price difference to QMZ16 is 0.525. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMV06 is 63.4. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMX06 is 65.15. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMZ06 is 62.35. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMF07 is 62.15. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMG07 is 62. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMH07 is 58.9. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMJ07 is 57.35. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMK07 is 54.7. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMM07 is 54.25. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMN07 is 52.375. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMQ07 is 52.05. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMU07 is 50.825. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMV07 is 51.825. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMX07 is 53.5. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMZ07 is 56.4. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMF08 is 55.675. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMG08 is 55.65. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMH08 is 55.7. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMJ08 is 51.55. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMK08 is 55.45. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMM08 is 55.4. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMN08 is 54.875. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMQ08 is 58.7. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMU08 is 55.925. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMV08 is 53.95. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMX08 is 49.85. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMZ08 is 46.35. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMF09 is 47.25. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMG09 is 44.75. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMH09 is 37.575. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMJ09 is 32.775. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMK09 is 30.8. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMM09 is 32.55. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMN09 is 28.75. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMQ09 is 30.05. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMU09 is 28.175. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMV09 is 24.9. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMX09 is 27.075. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMZ09 is 25.925. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMF10 is 27.15. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMG10 is 26.5. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMH10 is 25.15. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMJ10 is 23.175. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMK10 is 24.5. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMM10 is 24.2. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMN10 is 20.4. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMQ10 is 20.125. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMU10 is 19.025. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMV10 is 19.425. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMX10 is 16.75. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMZ10 is 19.725. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMF11 is 17.925. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMG11 is 16.675. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMH11 is 16.3. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMJ11 is 12.65. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMK11 is 12. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMM11 is 12.925. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMN11 is 13.5. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMQ11 is 12.55. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMU11 is 10.2. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMV11 is 9.25. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMX11 is 10.5. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMZ11 is 12.5. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMF12 is 17.05. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMG12 is 16.4. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMH12 is 16.925. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMJ12 is 14.675. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMK12 is 13.55. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMM12 is 13.3. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMN12 is 11.65. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMQ12 is 10.4. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMU12 is 7.775. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMV12 is 7.975. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMX12 is 11.25. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMZ12 is 13.125. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMF13 is 10.375. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMG13 is 8.15. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMH13 is 7.6. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMJ13 is 6.45. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMK13 is 7.925. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMM13 is 8.1. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMN13 is 7.375. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMQ13 is 7.75. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMU13 is 7.8. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMV13 is 8.725. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMX13 is 11.375. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMZ13 is 12.625. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMF14 is 11.825. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMG14 is 10.475. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMH14 is 10.325. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMJ14 is 10.525. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMK14 is 10.85. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMM14 is 11.675. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMN14 is 11.6. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMQ14 is 11.575. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMU14 is 11.775. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMV14 is 15.525. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMX14 is 16.875. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMZ14 is 18.125. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMF15 is 18.025. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMG15 is 16.15. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMH15 is 13.275. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMJ15 is 11.675. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMK15 is 10.65. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMM15 is 8.8. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMN15 is 10.325. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMQ15 is 11.025. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMU15 is 11.5. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMV15 is 12.975. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMX15 is 11.125. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMZ15 is 11.65. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMF16 is 10.475. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMG16 is 9.425. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMH16 is 9.3. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMJ16 is 8.025. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMK16 is 6.675. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMM16 is 4.3. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMN16 is 3.475. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMQ16 is 2.05. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMU16 is 1.75. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMV16 is 1.075. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMX16 is 0.525. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Reloading chart. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMV15 to next contract occurs at 2015-09-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMX15 to next contract occurs at 2015-10-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMZ15 to next contract occurs at 2015-11-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMF16 to next contract occurs at 2015-12-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMG16 to next contract occurs at 2016-01-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMH16 to next contract occurs at 2016-02-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMJ16 to next contract occurs at 2016-03-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMK16 to next contract occurs at 2016-04-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMM16 to next contract occurs at 2016-05-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMN16 to next contract occurs at 2016-06-21. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMQ16 to next contract occurs at 2016-07-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMU16 to next contract occurs at 2016-08-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMV16 to next contract occurs at 2016-09-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMX16 to next contract occurs at 2016-10-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMZ16 to next contract occurs at 2016-11-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMV15 for the date range from 2015-08-20 to 2015-09-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Skipping Daily data download for symbol QMV15 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMX15 for the date range from 2015-09-22 to 2015-10-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Skipping Daily data download for symbol QMX15 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMZ15 for the date range from 2015-10-20 to 2015-11-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Skipping Daily data download for symbol QMZ15 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMF16 for the date range from 2015-11-20 to 2015-12-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Skipping Daily data download for symbol QMF16 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMG16 for the date range from 2015-12-22 to 2016-01-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Skipping Daily data download for symbol QMG16 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMH16 for the date range from 2016-01-20 to 2016-02-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Skipping Daily data download for symbol QMH16 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMJ16 for the date range from 2016-02-22 to 2016-03-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Skipping Daily data download for symbol QMJ16 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMK16 for the date range from 2016-03-22 to 2016-04-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Skipping Daily data download for symbol QMK16 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMM16 for the date range from 2016-04-20 to 2016-05-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Skipping Daily data download for symbol QMM16 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMN16 for the date range from 2016-05-20 to 2016-06-21. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Skipping Daily data download for symbol QMN16 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMQ16 for the date range from 2016-06-21 to 2016-07-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Skipping Daily data download for symbol QMQ16 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMU16 for the date range from 2016-07-20 to 2016-08-22. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Skipping Daily data download for symbol QMU16 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMV16 for the date range from 2016-08-22 to 2016-09-20. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Skipping Daily data download for symbol QMV16 since download was already done in last 24 hours. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMX16 for the date range from 2016-09-20 to 2016-10-11. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMZ16 for the date range from 2016-10-11 to 2016-10-11. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMZ16.dly. Date: 2016-10-11, Price: 51.275. Date: 2016-10-11, Price: 51.275 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMX16.dly. Date: 2016-09-20, Price: 44.05. Date: 2016-10-10, Price: 51.35 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMV16.dly. Date: 2016-08-22, Price: 47.41. Date: 2016-09-19, Price: 43.3 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMU16.dly. Date: 2016-07-20, Price: 45.75. Date: 2016-08-19, Price: 48.52 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMQ16.dly. Date: 2016-06-21, Price: 49.85. Date: 2016-07-19, Price: 44.65 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMN16.dly. Date: 2016-05-20, Price: 48.4. Date: 2016-06-20, Price: 49.375 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMM16.dly. Date: 2016-04-20, Price: 44.175. Date: 2016-05-19, Price: 48.15 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMK16.dly. Date: 2016-03-22, Price: 41.45. Date: 2016-04-19, Price: 41.075 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMJ16.dly. Date: 2016-02-22, Price: 33.4. Date: 2016-03-21, Price: 39.45 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMH16.dly. Date: 2016-01-20, Price: 28.35. Date: 2016-02-19, Price: 29.64 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMG16.dly. Date: 2015-12-22, Price: 36.15. Date: 2016-01-19, Price: 28.45 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMF16.dly. Date: 2015-11-20, Price: 41.9. Date: 2015-12-21, Price: 34.725 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMZ15.dly. Date: 2015-10-20, Price: 46.29. Date: 2015-11-19, Price: 40.54 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMX15.dly. Date: 2015-09-22, Price: 46.36. Date: 2015-10-19, Price: 45.89 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMV15.dly. Date: 2015-08-20, Price: 41.32. Date: 2015-09-21, Price: 46.68 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Symbols used for continuous contract chart: | 2016-10-11 15:24:44 QMV15 | 2016-10-11 15:24:44 QMX15 | 2016-10-11 15:24:44 QMZ15 | 2016-10-11 15:24:44 QMF16 | 2016-10-11 15:24:44 QMG16 | 2016-10-11 15:24:44 QMH16 | 2016-10-11 15:24:44 QMJ16 | 2016-10-11 15:24:44 QMK16 | 2016-10-11 15:24:44 QMM16 | 2016-10-11 15:24:44 QMN16 | 2016-10-11 15:24:44 QMQ16 | 2016-10-11 15:24:44 QMU16 | 2016-10-11 15:24:44 QMV16 | 2016-10-11 15:24:44 QMX16 | 2016-10-11 15:24:44 QMZ16 | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Performing continuous futures contract back adjustment calculations. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMV15 Open price on 2015-09-22 is 44.85. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMX15 Open price on 2015-09-22 is 46.7. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMV15 price difference to QMX15 is 1.85. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMX15 Open price on 2015-10-20 is 47.1. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMZ15 Open price on 2015-10-20 is 46.575. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMX15 price difference to QMZ15 is -0.525. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMZ15 Open price on 2015-11-20 is 40.7. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMF16 Open price on 2015-11-20 is 41.875. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMZ15 price difference to QMF16 is 1.175. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMF16 Open price on 2015-12-22 is 34.8. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMG16 Open price on 2015-12-22 is 35.85. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMF16 price difference to QMG16 is 1.05. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMG16 Open price on 2016-01-20 is 29.35. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMH16 Open price on 2016-01-20 is 29.475. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMG16 price difference to QMH16 is 0.125. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMH16 Open price on 2016-02-22 is 30.675. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMJ16 Open price on 2016-02-22 is 31.95. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMH16 price difference to QMJ16 is 1.275. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMJ16 Open price on 2016-03-22 is 40.25. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMK16 Open price on 2016-03-22 is 41.6. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMJ16 price difference to QMK16 is 1.35. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMK16 Open price on 2016-04-20 is 39.975. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMM16 Open price on 2016-04-20 is 42.35. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMK16 price difference to QMM16 is 2.375. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMM16 Open price on 2016-05-20 is 47.9. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMN16 Open price on 2016-05-20 is 48.725. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMM16 price difference to QMN16 is 0.825. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMN16 Open price on 2016-06-21 is 48.35. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMQ16 Open price on 2016-06-21 is 49.775. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMN16 price difference to QMQ16 is 1.425. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMQ16 Open price on 2016-07-20 is 45.175. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMU16 Open price on 2016-07-20 is 45.475. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMQ16 price difference to QMU16 is 0.3. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMU16 Open price on 2016-08-22 is 48.375. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMV16 Open price on 2016-08-22 is 49.05. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMU16 price difference to QMV16 is 0.675. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMV16 Open price on 2016-09-20 is 43.2. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMX16 Open price on 2016-09-20 is 43.75. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMV16 price difference to QMX16 is 0.55. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMX16 Open price on 2016-10-11 is 51.125. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMZ16 Open price on 2016-10-11 is 51.65. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | QMX16 price difference to QMZ16 is 0.525. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMV15 is 12.975. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMX15 is 11.125. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMZ15 is 11.65. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMF16 is 10.475. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMG16 is 9.425. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMH16 is 9.3. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMJ16 is 8.025. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMK16 is 6.675. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMM16 is 4.3. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMN16 is 3.475. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMQ16 is 2.05. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMU16 is 1.75. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMV16 is 1.075. | 2016-10-11 15:24:44 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMX16 is 0.525. | 2016-10-11 15:24:44 HD Request # 127 | Downloading Intraday chart data for QMZ16 to the file QMZ16.scid. Service: nymex | 2016-10-11 15:24:49 HD Request # 127 | Download start date-time: 2016-10-11 15:02:42.000 | 2016-10-11 15:24:49 HD Request # 127 | Using server: ds6.sierracharts.com port 10149 | 2016-10-11 15:24:49 HD Request # 128 | Downloading Historical Daily chart data for QMZ16. Starting date: 2016-10-10. Service: tda | 2016-10-11 15:24:49 HD Request # 128 | Using user Barchart Historical data account. | 2016-10-11 15:24:49 HD Request # 128 | Requesting historical Daily data for QMZ16 starting at 2016-10-09 | 2016-10-11 15:24:49 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-10-11 15:24:49 Socket (11) | Connected. | 2016-10-11 15:24:49 HD Request # 128 | Receiving historical Daily data for QMZ16 starting at 2016-10-10 | 2016-10-11 15:24:49 HD Request # 128 | Writing historical Daily data to the file QMZ16.dly | 2016-10-11 15:24:49 Setting HD DTC Encoding to Binary VLS | 2016-10-11 15:24:49 * HD Request # 127 | Sending historical data logon request message. | 2016-10-11 15:24:49 HD Request # 128 | Received 2 records from 2016-10-10 00:00:00 to 2016-10-11 00:00:00 (2.0 days) and wrote 2 records for QMZ16 | 2016-10-11 15:24:49 HD Request # 128 | Daily download COMPLETE for QMZ16. Completion time: 1s. Unique request ID: 127 | 2016-10-11 15:24:49 Removed historical data download ID 127 | 2016-10-11 15:24:49 HD Request # 127 | Requesting Intraday data. Start date-time: 2016-10-11 15:02:42. Record interval: 0. Symbol: QMZ16 | 2016-10-11 15:24:49 HD Request # 127 | Decompressing data. | 2016-10-11 15:24:49 HD Request # 127 | Receiving Intraday data for QMZ16 starting at 2016-10-11 15:02:42 | 2016-10-11 15:24:49 Socket (11) | Shutdown and closed. | 2016-10-11 15:24:49 The network socket for historical data has been closed. | 2016-10-11 15:24:49 HD Request # 127 | Received 1 record from 2016-10-11 15:02:42 to 2016-10-11 15:02:42 (0.0 seconds) and wrote 0 records for QMZ16 | 2016-10-11 15:24:49 HD Request # 127 | Intraday download COMPLETE for QMZ16. Completion time: 1s. Unique request ID: 125 | 2016-10-11 15:24:49 Removed historical data download ID 125 | 2016-10-11 15:24:49 Real-time Intraday chart data file updates started for QMZ16 | 2016-10-11 15:24:49 Intraday chart data file opened for QMZ16 | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Reloading chart. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMV15 to next contract occurs at 2015-09-22. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMX15 to next contract occurs at 2015-10-20. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMZ15 to next contract occurs at 2015-11-20. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMF16 to next contract occurs at 2015-12-22. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMG16 to next contract occurs at 2016-01-20. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMH16 to next contract occurs at 2016-02-22. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMJ16 to next contract occurs at 2016-03-22. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMK16 to next contract occurs at 2016-04-20. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMM16 to next contract occurs at 2016-05-20. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMN16 to next contract occurs at 2016-06-21. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMQ16 to next contract occurs at 2016-07-20. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMU16 to next contract occurs at 2016-08-22. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMV16 to next contract occurs at 2016-09-20. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMX16 to next contract occurs at 2016-10-20. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Date rule based rollover from QMZ16 to next contract occurs at 2016-11-22. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMV15 for the date range from 2015-08-20 to 2015-09-22. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Skipping Daily data download for symbol QMV15 since download was already done in last 24 hours. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMX15 for the date range from 2015-09-22 to 2015-10-20. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Skipping Daily data download for symbol QMX15 since download was already done in last 24 hours. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMZ15 for the date range from 2015-10-20 to 2015-11-20. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Skipping Daily data download for symbol QMZ15 since download was already done in last 24 hours. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMF16 for the date range from 2015-11-20 to 2015-12-22. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Skipping Daily data download for symbol QMF16 since download was already done in last 24 hours. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMG16 for the date range from 2015-12-22 to 2016-01-20. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Skipping Daily data download for symbol QMG16 since download was already done in last 24 hours. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMH16 for the date range from 2016-01-20 to 2016-02-22. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Skipping Daily data download for symbol QMH16 since download was already done in last 24 hours. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMJ16 for the date range from 2016-02-22 to 2016-03-22. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Skipping Daily data download for symbol QMJ16 since download was already done in last 24 hours. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMK16 for the date range from 2016-03-22 to 2016-04-20. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Skipping Daily data download for symbol QMK16 since download was already done in last 24 hours. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMM16 for the date range from 2016-04-20 to 2016-05-20. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Skipping Daily data download for symbol QMM16 since download was already done in last 24 hours. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMN16 for the date range from 2016-05-20 to 2016-06-21. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Skipping Daily data download for symbol QMN16 since download was already done in last 24 hours. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMQ16 for the date range from 2016-06-21 to 2016-07-20. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Skipping Daily data download for symbol QMQ16 since download was already done in last 24 hours. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMU16 for the date range from 2016-07-20 to 2016-08-22. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Skipping Daily data download for symbol QMU16 since download was already done in last 24 hours. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMV16 for the date range from 2016-08-22 to 2016-09-20. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Skipping Daily data download for symbol QMV16 since download was already done in last 24 hours. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMX16 for the date range from 2016-09-20 to 2016-10-11. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Checking Daily data file for symbol QMZ16 for the date range from 2016-10-11 to 2016-10-11. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMZ16.dly. Date: 2016-10-11, Price: 51.275. Date: 2016-10-11, Price: 51.275 | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMX16.dly. Date: 2016-09-20, Price: 44.05. Date: 2016-10-10, Price: 51.35 | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMV16.dly. Date: 2016-08-22, Price: 47.41. Date: 2016-09-19, Price: 43.3 | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMU16.dly. Date: 2016-07-20, Price: 45.75. Date: 2016-08-19, Price: 48.52 | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMQ16.dly. Date: 2016-06-21, Price: 49.85. Date: 2016-07-19, Price: 44.65 | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMN16.dly. Date: 2016-05-20, Price: 48.4. Date: 2016-06-20, Price: 49.375 | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMM16.dly. Date: 2016-04-20, Price: 44.175. Date: 2016-05-19, Price: 48.15 | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMK16.dly. Date: 2016-03-22, Price: 41.45. Date: 2016-04-19, Price: 41.075 | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMJ16.dly. Date: 2016-02-22, Price: 33.4. Date: 2016-03-21, Price: 39.45 | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMH16.dly. Date: 2016-01-20, Price: 28.35. Date: 2016-02-19, Price: 29.64 | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMG16.dly. Date: 2015-12-22, Price: 36.15. Date: 2016-01-19, Price: 28.45 | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMF16.dly. Date: 2015-11-20, Price: 41.9. Date: 2015-12-21, Price: 34.725 | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMZ15.dly. Date: 2015-10-20, Price: 46.29. Date: 2015-11-19, Price: 40.54 | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMX15.dly. Date: 2015-09-22, Price: 46.36. Date: 2015-10-19, Price: 45.89 | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Price data for daily data file QMV15.dly. Date: 2015-08-20, Price: 41.32. Date: 2015-09-21, Price: 46.68 | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Symbols used for continuous contract chart: | 2016-10-11 15:24:49 QMV15 | 2016-10-11 15:24:49 QMX15 | 2016-10-11 15:24:49 QMZ15 | 2016-10-11 15:24:49 QMF16 | 2016-10-11 15:24:49 QMG16 | 2016-10-11 15:24:49 QMH16 | 2016-10-11 15:24:49 QMJ16 | 2016-10-11 15:24:49 QMK16 | 2016-10-11 15:24:49 QMM16 | 2016-10-11 15:24:49 QMN16 | 2016-10-11 15:24:49 QMQ16 | 2016-10-11 15:24:49 QMU16 | 2016-10-11 15:24:49 QMV16 | 2016-10-11 15:24:49 QMX16 | 2016-10-11 15:24:49 QMZ16 | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Performing continuous futures contract back adjustment calculations. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMV15 Open price on 2015-09-22 is 44.85. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMX15 Open price on 2015-09-22 is 46.7. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMV15 price difference to QMX15 is 1.85. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMX15 Open price on 2015-10-20 is 47.1. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMZ15 Open price on 2015-10-20 is 46.575. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMX15 price difference to QMZ15 is -0.525. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMZ15 Open price on 2015-11-20 is 40.7. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMF16 Open price on 2015-11-20 is 41.875. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMZ15 price difference to QMF16 is 1.175. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMF16 Open price on 2015-12-22 is 34.8. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMG16 Open price on 2015-12-22 is 35.85. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMF16 price difference to QMG16 is 1.05. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMG16 Open price on 2016-01-20 is 29.35. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMH16 Open price on 2016-01-20 is 29.475. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMG16 price difference to QMH16 is 0.125. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMH16 Open price on 2016-02-22 is 30.675. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMJ16 Open price on 2016-02-22 is 31.95. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMH16 price difference to QMJ16 is 1.275. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMJ16 Open price on 2016-03-22 is 40.25. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMK16 Open price on 2016-03-22 is 41.6. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMJ16 price difference to QMK16 is 1.35. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMK16 Open price on 2016-04-20 is 39.975. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMM16 Open price on 2016-04-20 is 42.35. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMK16 price difference to QMM16 is 2.375. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMM16 Open price on 2016-05-20 is 47.9. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMN16 Open price on 2016-05-20 is 48.725. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMM16 price difference to QMN16 is 0.825. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMN16 Open price on 2016-06-21 is 48.35. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMQ16 Open price on 2016-06-21 is 49.775. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMN16 price difference to QMQ16 is 1.425. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMQ16 Open price on 2016-07-20 is 45.175. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMU16 Open price on 2016-07-20 is 45.475. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMQ16 price difference to QMU16 is 0.3. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMU16 Open price on 2016-08-22 is 48.375. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMV16 Open price on 2016-08-22 is 49.05. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMU16 price difference to QMV16 is 0.675. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMV16 Open price on 2016-09-20 is 43.2. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMX16 Open price on 2016-09-20 is 43.75. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMV16 price difference to QMX16 is 0.55. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMX16 Open price on 2016-10-11 is 51.125. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMZ16 Open price on 2016-10-11 is 51.65. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | QMX16 price difference to QMZ16 is 0.525. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMV15 is 12.975. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMX15 is 11.125. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMZ15 is 11.65. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMF16 is 10.475. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMG16 is 9.425. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMH16 is 9.3. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMJ16 is 8.025. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMK16 is 6.675. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMM16 is 4.3. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMN16 is 3.475. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMQ16 is 2.05. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMU16 is 1.75. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMV16 is 1.075. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Daily #2 | Back adjust amount for symbol QMX16 is 0.525. | 2016-10-11 15:24:49 QMZ16 [CB] [M] Weekly #1 | Reloading chart. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMV06 to next contract occurs at 2006-09-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMX06 to next contract occurs at 2006-10-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMZ06 to next contract occurs at 2006-11-21. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMF07 to next contract occurs at 2006-12-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMG07 to next contract occurs at 2007-01-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMH07 to next contract occurs at 2007-02-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMJ07 to next contract occurs at 2007-03-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMK07 to next contract occurs at 2007-04-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMM07 to next contract occurs at 2007-05-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMN07 to next contract occurs at 2007-06-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMQ07 to next contract occurs at 2007-07-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMU07 to next contract occurs at 2007-08-21. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMV07 to next contract occurs at 2007-09-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMX07 to next contract occurs at 2007-10-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMZ07 to next contract occurs at 2007-11-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMF08 to next contract occurs at 2007-12-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMG08 to next contract occurs at 2008-01-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMH08 to next contract occurs at 2008-02-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMJ08 to next contract occurs at 2008-03-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMK08 to next contract occurs at 2008-04-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMM08 to next contract occurs at 2008-05-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMN08 to next contract occurs at 2008-06-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMQ08 to next contract occurs at 2008-07-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMU08 to next contract occurs at 2008-08-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMV08 to next contract occurs at 2008-09-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMX08 to next contract occurs at 2008-10-21. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMZ08 to next contract occurs at 2008-11-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMF09 to next contract occurs at 2008-12-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMG09 to next contract occurs at 2009-01-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMH09 to next contract occurs at 2009-02-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMJ09 to next contract occurs at 2009-03-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMK09 to next contract occurs at 2009-04-21. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMM09 to next contract occurs at 2009-05-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMN09 to next contract occurs at 2009-06-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMQ09 to next contract occurs at 2009-07-21. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMU09 to next contract occurs at 2009-08-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMV09 to next contract occurs at 2009-09-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMX09 to next contract occurs at 2009-10-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMZ09 to next contract occurs at 2009-11-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMF10 to next contract occurs at 2009-12-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMG10 to next contract occurs at 2010-01-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMH10 to next contract occurs at 2010-02-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMJ10 to next contract occurs at 2010-03-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMK10 to next contract occurs at 2010-04-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMM10 to next contract occurs at 2010-05-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMN10 to next contract occurs at 2010-06-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMQ10 to next contract occurs at 2010-07-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMU10 to next contract occurs at 2010-08-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMV10 to next contract occurs at 2010-09-21. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMX10 to next contract occurs at 2010-10-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMZ10 to next contract occurs at 2010-11-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMF11 to next contract occurs at 2010-12-21. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMG11 to next contract occurs at 2011-01-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMH11 to next contract occurs at 2011-02-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMJ11 to next contract occurs at 2011-03-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMK11 to next contract occurs at 2011-04-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMM11 to next contract occurs at 2011-05-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMN11 to next contract occurs at 2011-06-21. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMQ11 to next contract occurs at 2011-07-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMU11 to next contract occurs at 2011-08-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMV11 to next contract occurs at 2011-09-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMX11 to next contract occurs at 2011-10-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMZ11 to next contract occurs at 2011-11-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMF12 to next contract occurs at 2011-12-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMG12 to next contract occurs at 2012-01-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMH12 to next contract occurs at 2012-02-21. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMJ12 to next contract occurs at 2012-03-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMK12 to next contract occurs at 2012-04-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMM12 to next contract occurs at 2012-05-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMN12 to next contract occurs at 2012-06-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMQ12 to next contract occurs at 2012-07-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMU12 to next contract occurs at 2012-08-21. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMV12 to next contract occurs at 2012-09-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMX12 to next contract occurs at 2012-10-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMZ12 to next contract occurs at 2012-11-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMF13 to next contract occurs at 2012-12-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMG13 to next contract occurs at 2013-01-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMH13 to next contract occurs at 2013-02-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMJ13 to next contract occurs at 2013-03-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMK13 to next contract occurs at 2013-04-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMM13 to next contract occurs at 2013-05-21. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMN13 to next contract occurs at 2013-06-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMQ13 to next contract occurs at 2013-07-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMU13 to next contract occurs at 2013-08-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMV13 to next contract occurs at 2013-09-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMX13 to next contract occurs at 2013-10-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMZ13 to next contract occurs at 2013-11-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMF14 to next contract occurs at 2013-12-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMG14 to next contract occurs at 2014-01-21. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMH14 to next contract occurs at 2014-02-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMJ14 to next contract occurs at 2014-03-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMK14 to next contract occurs at 2014-04-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMM14 to next contract occurs at 2014-05-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMN14 to next contract occurs at 2014-06-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMQ14 to next contract occurs at 2014-07-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMU14 to next contract occurs at 2014-08-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMV14 to next contract occurs at 2014-09-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMX14 to next contract occurs at 2014-10-21. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMZ14 to next contract occurs at 2014-11-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMF15 to next contract occurs at 2014-12-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMG15 to next contract occurs at 2015-01-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMH15 to next contract occurs at 2015-02-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMJ15 to next contract occurs at 2015-03-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMK15 to next contract occurs at 2015-04-21. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMM15 to next contract occurs at 2015-05-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMN15 to next contract occurs at 2015-06-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMQ15 to next contract occurs at 2015-07-21. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMU15 to next contract occurs at 2015-08-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMV15 to next contract occurs at 2015-09-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMX15 to next contract occurs at 2015-10-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMZ15 to next contract occurs at 2015-11-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMF16 to next contract occurs at 2015-12-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMG16 to next contract occurs at 2016-01-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMH16 to next contract occurs at 2016-02-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMJ16 to next contract occurs at 2016-03-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMK16 to next contract occurs at 2016-04-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMM16 to next contract occurs at 2016-05-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMN16 to next contract occurs at 2016-06-21. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMQ16 to next contract occurs at 2016-07-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMU16 to next contract occurs at 2016-08-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMV16 to next contract occurs at 2016-09-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMX16 to next contract occurs at 2016-10-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Date rule based rollover from QMZ16 to next contract occurs at 2016-11-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMV06 for the date range from 2006-08-22 to 2006-09-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMV06 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMX06 for the date range from 2006-09-20 to 2006-10-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMX06 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMZ06 for the date range from 2006-10-20 to 2006-11-21. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMZ06 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMF07 for the date range from 2006-11-21 to 2006-12-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMF07 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMG07 for the date range from 2006-12-20 to 2007-01-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMG07 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMH07 for the date range from 2007-01-22 to 2007-02-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMH07 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMJ07 for the date range from 2007-02-20 to 2007-03-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMJ07 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMK07 for the date range from 2007-03-20 to 2007-04-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMK07 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMM07 for the date range from 2007-04-20 to 2007-05-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMM07 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMN07 for the date range from 2007-05-22 to 2007-06-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMN07 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMQ07 for the date range from 2007-06-20 to 2007-07-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMQ07 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMU07 for the date range from 2007-07-20 to 2007-08-21. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMU07 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMV07 for the date range from 2007-08-21 to 2007-09-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMV07 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMX07 for the date range from 2007-09-20 to 2007-10-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMX07 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMZ07 for the date range from 2007-10-22 to 2007-11-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMZ07 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMF08 for the date range from 2007-11-20 to 2007-12-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMF08 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMG08 for the date range from 2007-12-20 to 2008-01-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMG08 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMH08 for the date range from 2008-01-22 to 2008-02-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMH08 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMJ08 for the date range from 2008-02-20 to 2008-03-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMJ08 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMK08 for the date range from 2008-03-20 to 2008-04-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMK08 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMM08 for the date range from 2008-04-22 to 2008-05-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMM08 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMN08 for the date range from 2008-05-20 to 2008-06-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMN08 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMQ08 for the date range from 2008-06-20 to 2008-07-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMQ08 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMU08 for the date range from 2008-07-22 to 2008-08-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMU08 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMV08 for the date range from 2008-08-20 to 2008-09-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMV08 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMX08 for the date range from 2008-09-22 to 2008-10-21. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMX08 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMZ08 for the date range from 2008-10-21 to 2008-11-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMZ08 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMF09 for the date range from 2008-11-20 to 2008-12-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMF09 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMG09 for the date range from 2008-12-22 to 2009-01-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMG09 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMH09 for the date range from 2009-01-20 to 2009-02-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMH09 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMJ09 for the date range from 2009-02-20 to 2009-03-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMJ09 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMK09 for the date range from 2009-03-20 to 2009-04-21. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMK09 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMM09 for the date range from 2009-04-21 to 2009-05-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMM09 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMN09 for the date range from 2009-05-20 to 2009-06-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMN09 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMQ09 for the date range from 2009-06-22 to 2009-07-21. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMQ09 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMU09 for the date range from 2009-07-21 to 2009-08-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMU09 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMV09 for the date range from 2009-08-20 to 2009-09-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMV09 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMX09 for the date range from 2009-09-22 to 2009-10-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMX09 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMZ09 for the date range from 2009-10-20 to 2009-11-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMZ09 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMF10 for the date range from 2009-11-20 to 2009-12-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMF10 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMG10 for the date range from 2009-12-22 to 2010-01-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMG10 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMH10 for the date range from 2010-01-20 to 2010-02-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMH10 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMJ10 for the date range from 2010-02-22 to 2010-03-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMJ10 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMK10 for the date range from 2010-03-22 to 2010-04-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMK10 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMM10 for the date range from 2010-04-20 to 2010-05-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMM10 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMN10 for the date range from 2010-05-20 to 2010-06-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMN10 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMQ10 for the date range from 2010-06-22 to 2010-07-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMQ10 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMU10 for the date range from 2010-07-20 to 2010-08-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMU10 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMV10 for the date range from 2010-08-20 to 2010-09-21. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMV10 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMX10 for the date range from 2010-09-21 to 2010-10-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMX10 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMZ10 for the date range from 2010-10-20 to 2010-11-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMZ10 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMF11 for the date range from 2010-11-22 to 2010-12-21. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMF11 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMG11 for the date range from 2010-12-21 to 2011-01-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMG11 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMH11 for the date range from 2011-01-20 to 2011-02-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMH11 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMJ11 for the date range from 2011-02-22 to 2011-03-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMJ11 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMK11 for the date range from 2011-03-22 to 2011-04-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMK11 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMM11 for the date range from 2011-04-20 to 2011-05-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMM11 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMN11 for the date range from 2011-05-20 to 2011-06-21. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMN11 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMQ11 for the date range from 2011-06-21 to 2011-07-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMQ11 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMU11 for the date range from 2011-07-20 to 2011-08-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMU11 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMV11 for the date range from 2011-08-22 to 2011-09-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMV11 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMX11 for the date range from 2011-09-20 to 2011-10-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMX11 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMZ11 for the date range from 2011-10-20 to 2011-11-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMZ11 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMF12 for the date range from 2011-11-22 to 2011-12-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMF12 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMG12 for the date range from 2011-12-20 to 2012-01-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMG12 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMH12 for the date range from 2012-01-20 to 2012-02-21. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMH12 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMJ12 for the date range from 2012-02-21 to 2012-03-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMJ12 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMK12 for the date range from 2012-03-20 to 2012-04-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMK12 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMM12 for the date range from 2012-04-20 to 2012-05-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMM12 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMN12 for the date range from 2012-05-22 to 2012-06-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMN12 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMQ12 for the date range from 2012-06-20 to 2012-07-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMQ12 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMU12 for the date range from 2012-07-20 to 2012-08-21. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMU12 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMV12 for the date range from 2012-08-21 to 2012-09-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMV12 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMX12 for the date range from 2012-09-20 to 2012-10-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMX12 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMZ12 for the date range from 2012-10-22 to 2012-11-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMZ12 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMF13 for the date range from 2012-11-20 to 2012-12-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMF13 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMG13 for the date range from 2012-12-20 to 2013-01-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMG13 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMH13 for the date range from 2013-01-22 to 2013-02-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMH13 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMJ13 for the date range from 2013-02-20 to 2013-03-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMJ13 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMK13 for the date range from 2013-03-20 to 2013-04-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMK13 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMM13 for the date range from 2013-04-22 to 2013-05-21. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMM13 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMN13 for the date range from 2013-05-21 to 2013-06-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMN13 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMQ13 for the date range from 2013-06-20 to 2013-07-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMQ13 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMU13 for the date range from 2013-07-22 to 2013-08-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMU13 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMV13 for the date range from 2013-08-20 to 2013-09-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMV13 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMX13 for the date range from 2013-09-20 to 2013-10-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMX13 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMZ13 for the date range from 2013-10-22 to 2013-11-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMZ13 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMF14 for the date range from 2013-11-20 to 2013-12-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMF14 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMG14 for the date range from 2013-12-20 to 2014-01-21. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMG14 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMH14 for the date range from 2014-01-21 to 2014-02-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMH14 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMJ14 for the date range from 2014-02-20 to 2014-03-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMJ14 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMK14 for the date range from 2014-03-20 to 2014-04-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMK14 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMM14 for the date range from 2014-04-22 to 2014-05-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMM14 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMN14 for the date range from 2014-05-20 to 2014-06-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMN14 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMQ14 for the date range from 2014-06-20 to 2014-07-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMQ14 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMU14 for the date range from 2014-07-22 to 2014-08-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMU14 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMV14 for the date range from 2014-08-20 to 2014-09-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMV14 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMX14 for the date range from 2014-09-22 to 2014-10-21. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMX14 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMZ14 for the date range from 2014-10-21 to 2014-11-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMZ14 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMF15 for the date range from 2014-11-20 to 2014-12-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMF15 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMG15 for the date range from 2014-12-22 to 2015-01-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMG15 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMH15 for the date range from 2015-01-20 to 2015-02-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMH15 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMJ15 for the date range from 2015-02-20 to 2015-03-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMJ15 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMK15 for the date range from 2015-03-20 to 2015-04-21. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMK15 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMM15 for the date range from 2015-04-21 to 2015-05-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMM15 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMN15 for the date range from 2015-05-20 to 2015-06-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMN15 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMQ15 for the date range from 2015-06-22 to 2015-07-21. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMQ15 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMU15 for the date range from 2015-07-21 to 2015-08-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMU15 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMV15 for the date range from 2015-08-20 to 2015-09-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMV15 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMX15 for the date range from 2015-09-22 to 2015-10-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMX15 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMZ15 for the date range from 2015-10-20 to 2015-11-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMZ15 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMF16 for the date range from 2015-11-20 to 2015-12-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMF16 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMG16 for the date range from 2015-12-22 to 2016-01-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMG16 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMH16 for the date range from 2016-01-20 to 2016-02-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMH16 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMJ16 for the date range from 2016-02-22 to 2016-03-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMJ16 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMK16 for the date range from 2016-03-22 to 2016-04-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMK16 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMM16 for the date range from 2016-04-20 to 2016-05-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMM16 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMN16 for the date range from 2016-05-20 to 2016-06-21. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMN16 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMQ16 for the date range from 2016-06-21 to 2016-07-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMQ16 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMU16 for the date range from 2016-07-20 to 2016-08-22. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMU16 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMV16 for the date range from 2016-08-22 to 2016-09-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Skipping Daily data download for symbol QMV16 since download was already done in last 24 hours. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMX16 for the date range from 2016-09-20 to 2016-10-11. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Checking Daily data file for symbol QMZ16 for the date range from 2016-10-11 to 2016-10-11. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMZ16.dly. Date: 2016-10-11, Price: 51.275. Date: 2016-10-11, Price: 51.275 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMX16.dly. Date: 2016-09-20, Price: 44.05. Date: 2016-10-10, Price: 51.35 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMV16.dly. Date: 2016-08-22, Price: 47.41. Date: 2016-09-19, Price: 43.3 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMU16.dly. Date: 2016-07-20, Price: 45.75. Date: 2016-08-19, Price: 48.52 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMQ16.dly. Date: 2016-06-21, Price: 49.85. Date: 2016-07-19, Price: 44.65 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMN16.dly. Date: 2016-05-20, Price: 48.4. Date: 2016-06-20, Price: 49.375 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMM16.dly. Date: 2016-04-20, Price: 44.175. Date: 2016-05-19, Price: 48.15 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMK16.dly. Date: 2016-03-22, Price: 41.45. Date: 2016-04-19, Price: 41.075 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMJ16.dly. Date: 2016-02-22, Price: 33.4. Date: 2016-03-21, Price: 39.45 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMH16.dly. Date: 2016-01-20, Price: 28.35. Date: 2016-02-19, Price: 29.64 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMG16.dly. Date: 2015-12-22, Price: 36.15. Date: 2016-01-19, Price: 28.45 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMF16.dly. Date: 2015-11-20, Price: 41.9. Date: 2015-12-21, Price: 34.725 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMZ15.dly. Date: 2015-10-20, Price: 46.29. Date: 2015-11-19, Price: 40.54 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMX15.dly. Date: 2015-09-22, Price: 46.36. Date: 2015-10-19, Price: 45.89 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMV15.dly. Date: 2015-08-20, Price: 41.32. Date: 2015-09-21, Price: 46.68 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMU15.dly. Date: 2015-07-21, Price: 50.86. Date: 2015-08-19, Price: 40.8 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMQ15.dly. Date: 2015-06-22, Price: 60.375. Date: 2015-07-20, Price: 50.15 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMN15.dly. Date: 2015-05-20, Price: 58.975. Date: 2015-06-19, Price: 59.6 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMM15.dly. Date: 2015-04-21, Price: 56.6. Date: 2015-05-19, Price: 59.425 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMK15.dly. Date: 2015-03-20, Price: 46.575. Date: 2015-04-20, Price: 56.375 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMJ15.dly. Date: 2015-02-20, Price: 50.8. Date: 2015-03-19, Price: 43.95 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMH15.dly. Date: 2015-01-20, Price: 46.475. Date: 2015-02-19, Price: 51.15 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMG15.dly. Date: 2014-12-22, Price: 55.25. Date: 2015-01-19, Price: 48.7 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMF15.dly. Date: 2014-11-20, Price: 75.85. Date: 2014-12-19, Price: 54.1 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMZ14.dly. Date: 2014-10-21, Price: 82.5. Date: 2014-11-19, Price: 74.575 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMX14.dly. Date: 2014-09-22, Price: 90.875. Date: 2014-10-20, Price: 82.7 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMV14.dly. Date: 2014-08-20, Price: 93.45. Date: 2014-09-19, Price: 92.4 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMU14.dly. Date: 2014-07-22, Price: 102.4. Date: 2014-08-19, Price: 94.475 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMQ14.dly. Date: 2014-06-20, Price: 106.825. Date: 2014-07-21, Price: 104.6 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMN14.dly. Date: 2014-05-20, Price: 102.325. Date: 2014-06-19, Price: 106.425 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMM14.dly. Date: 2014-04-22, Price: 101.75. Date: 2014-05-19, Price: 102.6 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMK14.dly. Date: 2014-03-20, Price: 98.9. Date: 2014-04-21, Price: 104.375 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMJ14.dly. Date: 2014-02-20, Price: 102.75. Date: 2014-03-19, Price: 100.375 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMH14.dly. Date: 2014-01-21, Price: 94.975. Date: 2014-02-19, Price: 103.3 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMG14.dly. Date: 2013-12-20, Price: 99.325. Date: 2014-01-20, Price: 94.375 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMF14.dly. Date: 2013-11-20, Price: 93.85. Date: 2013-12-19, Price: 97.8 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMZ13.dly. Date: 2013-10-22, Price: 98.3. Date: 2013-11-19, Price: 93.35 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMX13.dly. Date: 2013-09-20, Price: 104.75. Date: 2013-10-21, Price: 99.225 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMV13.dly. Date: 2013-08-20, Price: 105.1. Date: 2013-09-19, Price: 106.4 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMU13.dly. Date: 2013-07-22, Price: 106.95. Date: 2013-08-19, Price: 107.1 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMQ13.dly. Date: 2013-06-20, Price: 95.15. Date: 2013-07-19, Price: 108.05 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMN13.dly. Date: 2013-05-21, Price: 96.175. Date: 2013-06-19, Price: 98.25 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMM13.dly. Date: 2013-04-22, Price: 89.2. Date: 2013-05-20, Price: 96.7 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMK13.dly. Date: 2013-03-20, Price: 93.5. Date: 2013-04-19, Price: 88 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMJ13.dly. Date: 2013-02-20, Price: 95.225. Date: 2013-03-19, Price: 92.15 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMH13.dly. Date: 2013-01-22, Price: 96.675. Date: 2013-02-19, Price: 96.65 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMG13.dly. Date: 2012-12-20, Price: 90.125. Date: 2013-01-21, Price: 95.55 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMF13.dly. Date: 2012-11-20, Price: 86.75. Date: 2012-12-19, Price: 87.925 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMZ12.dly. Date: 2012-10-22, Price: 88.65. Date: 2012-11-19, Price: 85.45 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMX12.dly. Date: 2012-09-20, Price: 92.425. Date: 2012-10-19, Price: 90.05 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMV12.dly. Date: 2012-08-21, Price: 96.85. Date: 2012-09-19, Price: 91.975 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMU12.dly. Date: 2012-07-20, Price: 91.825. Date: 2012-08-20, Price: 95.975 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMQ12.dly. Date: 2012-06-20, Price: 81.45. Date: 2012-07-19, Price: 92.65 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMN12.dly. Date: 2012-05-22, Price: 91.85. Date: 2012-06-19, Price: 84.025 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMM12.dly. Date: 2012-04-20, Price: 103.875. Date: 2012-05-21, Price: 92.575 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMK12.dly. Date: 2012-03-20, Price: 106.075. Date: 2012-04-19, Price: 102.275 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMJ12.dly. Date: 2012-02-21, Price: 106.25. Date: 2012-03-19, Price: 108.1 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMH12.dly. Date: 2012-01-20, Price: 98.325. Date: 2012-02-20, Price: 103.25 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMG12.dly. Date: 2011-12-20, Price: 97.25. Date: 2012-01-19, Price: 100.4 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMF12.dly. Date: 2011-11-22, Price: 98. Date: 2011-12-19, Price: 93.875 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMZ11.dly. Date: 2011-10-20, Price: 86.075. Date: 2011-11-21, Price: 98.825 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMX11.dly. Date: 2011-09-20, Price: 86.925. Date: 2011-10-19, Price: 86.1 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMV11.dly. Date: 2011-08-22, Price: 84.425. Date: 2011-09-19, Price: 85.7 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMU11.dly. Date: 2011-07-20, Price: 98.4. Date: 2011-08-19, Price: 82.25 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMQ11.dly. Date: 2011-06-21, Price: 94.175. Date: 2011-07-19, Price: 97.5 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMN11.dly. Date: 2011-05-20, Price: 100.1. Date: 2011-06-20, Price: 93.25 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMM11.dly. Date: 2011-04-20, Price: 111.45. Date: 2011-05-19, Price: 98.45 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMK11.dly. Date: 2011-03-22, Price: 104.975. Date: 2011-04-19, Price: 107.125 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMJ11.dly. Date: 2011-02-22, Price: 95.425. Date: 2011-03-21, Price: 102.325 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMH11.dly. Date: 2011-01-20, Price: 89.6. Date: 2011-02-21, Price: 86.2 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMG11.dly. Date: 2010-12-21, Price: 89.825. Date: 2011-01-19, Price: 90.85 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMF11.dly. Date: 2010-11-22, Price: 81.75. Date: 2010-12-20, Price: 88.025 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMZ10.dly. Date: 2010-10-20, Price: 82.55. Date: 2010-11-19, Price: 81.85 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMX10.dly. Date: 2010-09-21, Price: 74.975. Date: 2010-10-19, Price: 79.5 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMV10.dly. Date: 2010-08-20, Price: 73.825. Date: 2010-09-20, Price: 74.85 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMU10.dly. Date: 2010-07-20, Price: 77.575. Date: 2010-08-19, Price: 74.425 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMQ10.dly. Date: 2010-06-22, Price: 77.85. Date: 2010-07-19, Price: 76.55 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMQ10.dly has a volume of 0 at 2010-07-19. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMN10.dly. Date: 2010-05-20, Price: 70.8. Date: 2010-06-21, Price: 77.825 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMN10.dly has a volume of 0 at 2010-06-21. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMM10.dly. Date: 2010-04-20, Price: 83.85. Date: 2010-05-19, Price: 69.875 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMM10.dly has a volume of 0 at 2010-05-19. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMK10.dly. Date: 2010-03-22, Price: 81.6. Date: 2010-04-19, Price: 81.45 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMK10.dly has a volume of 0 at 2010-04-19. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMJ10.dly. Date: 2010-02-22, Price: 80.3. Date: 2010-03-19, Price: 80.675 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMJ10.dly has a volume of 0 at 2010-03-19. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMH10.dly. Date: 2010-01-20, Price: 77.75. Date: 2010-02-19, Price: 79.8 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMH10.dly has a volume of 0 at 2010-02-19. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMG10.dly. Date: 2009-12-22, Price: 74.4. Date: 2010-01-19, Price: 79.025 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMG10.dly has a volume of 0 at 2010-01-19. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMF10.dly. Date: 2009-11-20, Price: 77.475. Date: 2009-12-21, Price: 73.35 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMF10.dly has a volume of 0 at 2009-12-21. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMZ09.dly. Date: 2009-10-20, Price: 79.12. Date: 2009-11-19, Price: 77.45 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMZ09.dly has a volume of 0 at 2009-11-19. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMX09.dly. Date: 2009-09-22, Price: 71.76. Date: 2009-10-19, Price: 79.61 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMX09.dly has a volume of 0 at 2009-10-19. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMV09.dly. Date: 2009-08-20, Price: 72.91. Date: 2009-09-21, Price: 69.71 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMV09.dly has a volume of 0 at 2009-09-21. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMU09.dly. Date: 2009-07-21, Price: 65.61. Date: 2009-08-19, Price: 72.42001 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMU09.dly has a volume of 0 at 2009-08-19. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMQ09.dly. Date: 2009-06-22, Price: 67.5. Date: 2009-07-20, Price: 63.98 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMQ09.dly has a volume of 0 at 2009-07-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMN09.dly. Date: 2009-05-20, Price: 62.04. Date: 2009-06-19, Price: 69.55 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMN09.dly has a volume of 0 at 2009-06-19. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMM09.dly. Date: 2009-04-21, Price: 48.55. Date: 2009-05-19, Price: 59.03 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMM09.dly has a volume of 0 at 2009-05-19. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMK09.dly. Date: 2009-03-20, Price: 52.07. Date: 2009-04-20, Price: 45.88 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMK09.dly has a volume of 0 at 2009-04-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMJ09.dly. Date: 2009-02-20, Price: 40.03. Date: 2009-03-19, Price: 51.61 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMJ09.dly has a volume of 0 at 2009-03-19. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMH09.dly. Date: 2009-01-20, Price: 40.84. Date: 2009-02-19, Price: 39.48 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMH09.dly has a volume of 0 at 2009-02-19. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMG09.dly. Date: 2008-12-22, Price: 39.91. Date: 2009-01-19, Price: 36.51 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMF09.dly. Date: 2008-11-20, Price: 49.42. Date: 2008-12-19, Price: 36.22 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMF09.dly has a volume of 0 at 2008-12-19. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMZ08.dly. Date: 2008-10-21, Price: 72.18. Date: 2008-11-19, Price: 53.62 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMZ08.dly has a volume of 0 at 2008-11-19. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMX08.dly. Date: 2008-09-22, Price: 109.37. Date: 2008-10-20, Price: 74.25 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMX08.dly has a volume of 0 at 2008-10-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMV08.dly. Date: 2008-08-20, Price: 115.56. Date: 2008-09-19, Price: 104.55 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMV08.dly has a volume of 0 at 2008-09-19. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMU08.dly. Date: 2008-07-22, Price: 128.42. Date: 2008-08-19, Price: 114.53 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMU08.dly has a volume of 0 at 2008-08-19. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMQ08.dly. Date: 2008-06-20, Price: 135.36. Date: 2008-07-21, Price: 131.04 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMQ08.dly has a volume of 0 at 2008-07-21. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMN08.dly. Date: 2008-05-20, Price: 128.98. Date: 2008-06-19, Price: 131.93 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMN08.dly has a volume of 0 at 2008-06-19. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMM08.dly. Date: 2008-04-22, Price: 118.07. Date: 2008-05-19, Price: 127.05 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMM08.dly has a volume of 0 at 2008-05-19. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMK08.dly. Date: 2008-03-20, Price: 101.84. Date: 2008-04-21, Price: 117.48 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMK08.dly has a volume of 0 at 2008-04-21. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMJ08.dly. Date: 2008-02-20, Price: 99.7. Date: 2008-03-19, Price: 109.42 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMJ08.dly has a volume of 0 at 2008-03-19. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMH08.dly. Date: 2008-01-22, Price: 89.21. Date: 2008-02-19, Price: 100.01 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMH08.dly has a volume of 0 at 2008-02-19. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMG08.dly. Date: 2007-12-20, Price: 91.06. Date: 2008-01-21, Price: 90.57 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMG08.dly has a volume of 0 at 2008-01-21. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMF08.dly. Date: 2007-11-20, Price: 98.03. Date: 2007-12-19, Price: 90.63 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMF08.dly has a volume of 0 at 2007-12-19. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMZ07.dly. Date: 2007-10-22, Price: 86.02. Date: 2007-11-19, Price: 93.43 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMZ07.dly has a volume of 0 at 2007-11-19. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMX07.dly. Date: 2007-09-20, Price: 81.78. Date: 2007-10-19, Price: 88.6 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMX07.dly has a volume of 0 at 2007-10-19. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMV07.dly. Date: 2007-08-21, Price: 69.57. Date: 2007-09-19, Price: 81.93 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMV07.dly has a volume of 0 at 2007-09-19. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMU07.dly. Date: 2007-07-20, Price: 75.79. Date: 2007-08-20, Price: 71.12 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMU07.dly has a volume of 0 at 2007-08-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMQ07.dly. Date: 2007-06-20, Price: 68.86. Date: 2007-07-19, Price: 75.92001 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMQ07.dly has a volume of 0 at 2007-07-19. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMN07.dly. Date: 2007-05-22, Price: 65.51. Date: 2007-06-19, Price: 69.1 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMN07.dly has a volume of 0 at 2007-06-19. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMM07.dly. Date: 2007-04-20, Price: 64.11. Date: 2007-05-21, Price: 66.27 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMM07.dly has a volume of 0 at 2007-05-21. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMK07.dly. Date: 2007-03-20, Price: 59.25. Date: 2007-04-19, Price: 61.83 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMK07.dly has a volume of 0 at 2007-04-19. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMJ07.dly. Date: 2007-02-20, Price: 58.85. Date: 2007-03-19, Price: 56.59 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMJ07.dly has a volume of 0 at 2007-03-19. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMH07.dly. Date: 2007-01-22, Price: 52.58. Date: 2007-02-19, Price: 59.39 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMH07.dly has a volume of 0 at 2007-02-19. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMG07.dly. Date: 2006-12-20, Price: 63.72. Date: 2007-01-19, Price: 51.99 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMG07.dly has a volume of 0 at 2007-01-19. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMF07.dly. Date: 2006-11-21, Price: 60.17. Date: 2006-12-19, Price: 62.21 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMF07.dly has a volume of 0 at 2006-12-19. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMZ06.dly. Date: 2006-10-20, Price: 59.33. Date: 2006-11-20, Price: 56.26 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMZ06.dly has a volume of 0 at 2006-11-20. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMX06.dly. Date: 2006-09-20, Price: 60.74. Date: 2006-10-19, Price: 58.5 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMX06.dly has a volume of 0 at 2006-10-19. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Price data for daily data file QMV06.dly. Date: 2006-08-22, Price: 73.1. Date: 2006-09-19, Price: 61.66 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | File QMV06.dly has a volume of 0 at 2006-09-19. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Symbols used for continuous contract chart: | 2016-10-11 15:24:50 QMV06 | 2016-10-11 15:24:50 QMX06 | 2016-10-11 15:24:50 QMZ06 | 2016-10-11 15:24:50 QMF07 | 2016-10-11 15:24:50 QMG07 | 2016-10-11 15:24:50 QMH07 | 2016-10-11 15:24:50 QMJ07 | 2016-10-11 15:24:50 QMK07 | 2016-10-11 15:24:50 QMM07 | 2016-10-11 15:24:50 QMN07 | 2016-10-11 15:24:50 QMQ07 | 2016-10-11 15:24:50 QMU07 | 2016-10-11 15:24:50 QMV07 | 2016-10-11 15:24:50 QMX07 | 2016-10-11 15:24:50 QMZ07 | 2016-10-11 15:24:50 QMF08 | 2016-10-11 15:24:50 QMG08 | 2016-10-11 15:24:50 QMH08 | 2016-10-11 15:24:50 QMJ08 | 2016-10-11 15:24:50 QMK08 | 2016-10-11 15:24:50 QMM08 | 2016-10-11 15:24:50 QMN08 | 2016-10-11 15:24:50 QMQ08 | 2016-10-11 15:24:50 QMU08 | 2016-10-11 15:24:50 QMV08 | 2016-10-11 15:24:50 QMX08 | 2016-10-11 15:24:50 QMZ08 | 2016-10-11 15:24:50 QMF09 | 2016-10-11 15:24:50 QMG09 | 2016-10-11 15:24:50 QMH09 | 2016-10-11 15:24:50 QMJ09 | 2016-10-11 15:24:50 QMK09 | 2016-10-11 15:24:50 QMM09 | 2016-10-11 15:24:50 QMN09 | 2016-10-11 15:24:50 QMQ09 | 2016-10-11 15:24:50 QMU09 | 2016-10-11 15:24:50 QMV09 | 2016-10-11 15:24:50 QMX09 | 2016-10-11 15:24:50 QMZ09 | 2016-10-11 15:24:50 QMF10 | 2016-10-11 15:24:50 QMG10 | 2016-10-11 15:24:50 QMH10 | 2016-10-11 15:24:50 QMJ10 | 2016-10-11 15:24:50 QMK10 | 2016-10-11 15:24:50 QMM10 | 2016-10-11 15:24:50 QMN10 | 2016-10-11 15:24:50 QMQ10 | 2016-10-11 15:24:50 QMU10 | 2016-10-11 15:24:50 QMV10 | 2016-10-11 15:24:50 QMX10 | 2016-10-11 15:24:50 QMZ10 | 2016-10-11 15:24:50 QMF11 | 2016-10-11 15:24:50 QMG11 | 2016-10-11 15:24:50 QMH11 | 2016-10-11 15:24:50 QMJ11 | 2016-10-11 15:24:50 QMK11 | 2016-10-11 15:24:50 QMM11 | 2016-10-11 15:24:50 QMN11 | 2016-10-11 15:24:50 QMQ11 | 2016-10-11 15:24:50 QMU11 | 2016-10-11 15:24:50 QMV11 | 2016-10-11 15:24:50 QMX11 | 2016-10-11 15:24:50 QMZ11 | 2016-10-11 15:24:50 QMF12 | 2016-10-11 15:24:50 QMG12 | 2016-10-11 15:24:50 QMH12 | 2016-10-11 15:24:50 QMJ12 | 2016-10-11 15:24:50 QMK12 | 2016-10-11 15:24:50 QMM12 | 2016-10-11 15:24:50 QMN12 | 2016-10-11 15:24:50 QMQ12 | 2016-10-11 15:24:50 QMU12 | 2016-10-11 15:24:50 QMV12 | 2016-10-11 15:24:50 QMX12 | 2016-10-11 15:24:50 QMZ12 | 2016-10-11 15:24:50 QMF13 | 2016-10-11 15:24:50 QMG13 | 2016-10-11 15:24:50 QMH13 | 2016-10-11 15:24:50 QMJ13 | 2016-10-11 15:24:50 QMK13 | 2016-10-11 15:24:50 QMM13 | 2016-10-11 15:24:50 QMN13 | 2016-10-11 15:24:50 QMQ13 | 2016-10-11 15:24:50 QMU13 | 2016-10-11 15:24:50 QMV13 | 2016-10-11 15:24:50 QMX13 | 2016-10-11 15:24:50 QMZ13 | 2016-10-11 15:24:50 QMF14 | 2016-10-11 15:24:50 QMG14 | 2016-10-11 15:24:50 QMH14 | 2016-10-11 15:24:50 QMJ14 | 2016-10-11 15:24:50 QMK14 | 2016-10-11 15:24:50 QMM14 | 2016-10-11 15:24:50 QMN14 | 2016-10-11 15:24:50 QMQ14 | 2016-10-11 15:24:50 QMU14 | 2016-10-11 15:24:50 QMV14 | 2016-10-11 15:24:50 QMX14 | 2016-10-11 15:24:50 QMZ14 | 2016-10-11 15:24:50 QMF15 | 2016-10-11 15:24:50 QMG15 | 2016-10-11 15:24:50 QMH15 | 2016-10-11 15:24:50 QMJ15 | 2016-10-11 15:24:50 QMK15 | 2016-10-11 15:24:50 QMM15 | 2016-10-11 15:24:50 QMN15 | 2016-10-11 15:24:50 QMQ15 | 2016-10-11 15:24:50 QMU15 | 2016-10-11 15:24:50 QMV15 | 2016-10-11 15:24:50 QMX15 | 2016-10-11 15:24:50 QMZ15 | 2016-10-11 15:24:50 QMF16 | 2016-10-11 15:24:50 QMG16 | 2016-10-11 15:24:50 QMH16 | 2016-10-11 15:24:50 QMJ16 | 2016-10-11 15:24:50 QMK16 | 2016-10-11 15:24:50 QMM16 | 2016-10-11 15:24:50 QMN16 | 2016-10-11 15:24:50 QMQ16 | 2016-10-11 15:24:50 QMU16 | 2016-10-11 15:24:50 QMV16 | 2016-10-11 15:24:50 QMX16 | 2016-10-11 15:24:50 QMZ16 | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Performing continuous futures contract back adjustment calculations. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMV06 Open price on 2006-09-20 is 63.9. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMX06 Open price on 2006-09-20 is 62.15. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMV06 price difference to QMX06 is -1.75. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMX06 Open price on 2006-10-20 is 57.8. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMZ06 Open price on 2006-10-20 is 60.6. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMX06 price difference to QMZ06 is 2.8. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMZ06 Open price on 2006-11-21 is 58.75. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMF07 Open price on 2006-11-21 is 58.95. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMZ06 price difference to QMF07 is 0.2. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMF07 Open price on 2006-12-20 is 63.25. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMG07 Open price on 2006-12-20 is 63.4. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMF07 price difference to QMG07 is 0.15. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMG07 Open price on 2007-01-22 is 50.475. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMH07 Open price on 2007-01-22 is 53.575. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMG07 price difference to QMH07 is 3.1. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMH07 Open price on 2007-02-20 is 58. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMJ07 Open price on 2007-02-20 is 59.55. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMH07 price difference to QMJ07 is 1.55. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMJ07 Open price on 2007-03-20 is 57.25. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMK07 Open price on 2007-03-20 is 59.9. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMJ07 price difference to QMK07 is 2.65. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMK07 Open price on 2007-04-20 is 62.625. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMM07 Open price on 2007-04-20 is 63.075. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMK07 price difference to QMM07 is 0.45. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMM07 Open price on 2007-05-22 is 64.95. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMN07 Open price on 2007-05-22 is 66.825. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMM07 price difference to QMN07 is 1.875. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMN07 Open price on 2007-06-20 is 69.1. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMQ07 Open price on 2007-06-20 is 69.425. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMN07 price difference to QMQ07 is 0.325. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMQ07 Open price on 2007-07-20 is 74.875. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMU07 Open price on 2007-07-20 is 76.1. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMQ07 price difference to QMU07 is 1.225. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMU07 Open price on 2007-08-21 is 71.95. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMV07 Open price on 2007-08-21 is 70.95. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMU07 price difference to QMV07 is -1. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMV07 Open price on 2007-09-20 is 82.2. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMX07 Open price on 2007-09-20 is 80.525. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMV07 price difference to QMX07 is -1.675. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMX07 Open price on 2007-10-22 is 89.775. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMZ07 Open price on 2007-10-22 is 86.875. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMX07 price difference to QMZ07 is -2.9. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMZ07 Open price on 2007-11-20 is 94.1. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMF08 Open price on 2007-11-20 is 94.825. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMZ07 price difference to QMF08 is 0.725. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMF08 Open price on 2007-12-20 is 91.375. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMG08 Open price on 2007-12-20 is 91.4. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMF08 price difference to QMG08 is 0.025. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMG08 Open price on 2008-01-22 is 89.85. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMH08 Open price on 2008-01-22 is 89.8. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMG08 price difference to QMH08 is -0.05. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMH08 Open price on 2008-02-20 is 95.4. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMJ08 Open price on 2008-02-20 is 99.55. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMH08 price difference to QMJ08 is 4.15. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMJ08 Open price on 2008-03-20 is 106. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMK08 Open price on 2008-03-20 is 102.1. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMJ08 price difference to QMK08 is -3.9. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMK08 Open price on 2008-04-22 is 116.625. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMM08 Open price on 2008-04-22 is 116.675. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMK08 price difference to QMM08 is 0.05. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMM08 Open price on 2008-05-20 is 126.3. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMN08 Open price on 2008-05-20 is 126.825. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMM08 price difference to QMN08 is 0.525. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMN08 Open price on 2008-06-20 is 136.1. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMQ08 Open price on 2008-06-20 is 132.275. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMN08 price difference to QMQ08 is -3.825. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMQ08 Open price on 2008-07-22 is 129.125. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMU08 Open price on 2008-07-22 is 131.9. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMQ08 price difference to QMU08 is 2.775. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMU08 Open price on 2008-08-20 is 113.175. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMV08 Open price on 2008-08-20 is 115.15. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMU08 price difference to QMV08 is 1.975. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMV08 Open price on 2008-09-22 is 98.05. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMX08 Open price on 2008-09-22 is 102.15. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMV08 price difference to QMX08 is 4.1. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMX08 Open price on 2008-10-21 is 72.3. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMZ08 Open price on 2008-10-21 is 75.8. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMX08 price difference to QMZ08 is 3.5. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMZ08 Open price on 2008-11-20 is 54.5. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMF09 Open price on 2008-11-20 is 53.6. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMZ08 price difference to QMF09 is -0.9. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMF09 Open price on 2008-12-22 is 40.2. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMG09 Open price on 2008-12-22 is 42.7. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMF09 price difference to QMG09 is 2.5. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMG09 Open price on 2009-01-20 is 35.4. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMH09 Open price on 2009-01-20 is 42.575. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMG09 price difference to QMH09 is 7.175. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMH09 Open price on 2009-02-20 is 34.75. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMJ09 Open price on 2009-02-20 is 39.55. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMH09 price difference to QMJ09 is 4.8. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMJ09 Open price on 2009-03-20 is 49.8. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMK09 Open price on 2009-03-20 is 51.775. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMJ09 price difference to QMK09 is 1.975. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMK09 Open price on 2009-04-21 is 50.05. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMM09 Open price on 2009-04-21 is 48.3. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMK09 price difference to QMM09 is -1.75. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMM09 Open price on 2009-05-20 is 56.425. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMN09 Open price on 2009-05-20 is 60.225. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMM09 price difference to QMN09 is 3.8. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMN09 Open price on 2009-06-22 is 71.45. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMQ09 Open price on 2009-06-22 is 70.15. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMN09 price difference to QMQ09 is -1.3. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMQ09 Open price on 2009-07-21 is 63.525. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMU09 Open price on 2009-07-21 is 65.4. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMQ09 price difference to QMU09 is 1.875. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMU09 Open price on 2009-08-20 is 70.225. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMV09 Open price on 2009-08-20 is 73.5. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMU09 price difference to QMV09 is 3.275. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMV09 Open price on 2009-09-22 is 72.05. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMX09 Open price on 2009-09-22 is 69.875. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMV09 price difference to QMX09 is -2.175. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMX09 Open price on 2009-10-20 is 78.85. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMZ09 Open price on 2009-10-20 is 80. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMX09 price difference to QMZ09 is 1.15. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMZ09 Open price on 2009-11-20 is 79.7. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMF10 Open price on 2009-11-20 is 78.475. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMZ09 price difference to QMF10 is -1.225. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMF10 Open price on 2009-12-22 is 72.85. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMG10 Open price on 2009-12-22 is 73.5. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMF10 price difference to QMG10 is 0.65. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMG10 Open price on 2010-01-20 is 77.825. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMH10 Open price on 2010-01-20 is 79.175. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMG10 price difference to QMH10 is 1.35. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMH10 Open price on 2010-02-22 is 78.325. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMJ10 Open price on 2010-02-22 is 80.3. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMH10 price difference to QMJ10 is 1.975. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMJ10 Open price on 2010-03-22 is 82.2. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMK10 Open price on 2010-03-22 is 80.875. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMJ10 price difference to QMK10 is -1.325. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMK10 Open price on 2010-04-20 is 82.975. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMM10 Open price on 2010-04-20 is 83.275. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMK10 price difference to QMM10 is 0.3. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMM10 Open price on 2010-05-20 is 69.025. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMN10 Open price on 2010-05-20 is 72.825. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMM10 price difference to QMN10 is 3.8. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMN10 Open price on 2010-06-22 is 77.9. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMQ10 Open price on 2010-06-22 is 78.175. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMN10 price difference to QMQ10 is 0.275. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMQ10 Open price on 2010-07-20 is 75.625. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMU10 Open price on 2010-07-20 is 76.725. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMQ10 price difference to QMU10 is 1.1. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMU10 Open price on 2010-08-20 is 75.2. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMV10 Open price on 2010-08-20 is 74.8. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMU10 price difference to QMV10 is -0.4. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMV10 Open price on 2010-09-21 is 73.575. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMX10 Open price on 2010-09-21 is 76.25. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMV10 price difference to QMX10 is 2.675. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMX10 Open price on 2010-10-20 is 82.95. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMZ10 Open price on 2010-10-20 is 79.975. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMX10 price difference to QMZ10 is -2.975. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMZ10 Open price on 2010-11-22 is 80.4. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMF11 Open price on 2010-11-22 is 82.2. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMZ10 price difference to QMF11 is 1.8. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMF11 Open price on 2010-12-21 is 87.925. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMG11 Open price on 2010-12-21 is 89.175. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMF11 price difference to QMG11 is 1.25. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMG11 Open price on 2011-01-20 is 91.225. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMH11 Open price on 2011-01-20 is 91.6. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMG11 price difference to QMH11 is 0.375. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMH11 Open price on 2011-02-22 is 86.45. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMJ11 Open price on 2011-02-22 is 90.1. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMH11 price difference to QMJ11 is 3.65. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMJ11 Open price on 2011-03-22 is 102.05. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMK11 Open price on 2011-03-22 is 102.7. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMJ11 price difference to QMK11 is 0.65. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMK11 Open price on 2011-04-20 is 109.35. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMM11 Open price on 2011-04-20 is 108.425. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMK11 price difference to QMM11 is -0.925. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMM11 Open price on 2011-05-20 is 99.675. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMN11 Open price on 2011-05-20 is 99.1. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMM11 price difference to QMN11 is -0.575. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMN11 Open price on 2011-06-21 is 92.875. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMQ11 Open price on 2011-06-21 is 93.825. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMN11 price difference to QMQ11 is 0.95. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMQ11 Open price on 2011-07-20 is 96.125. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMU11 Open price on 2011-07-20 is 98.475. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMQ11 price difference to QMU11 is 2.35. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMU11 Open price on 2011-08-22 is 81.45. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMV11 Open price on 2011-08-22 is 82.4. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMU11 price difference to QMV11 is 0.95. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMV11 Open price on 2011-09-20 is 87.25. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMX11 Open price on 2011-09-20 is 86. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMV11 price difference to QMX11 is -1.25. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMX11 Open price on 2011-10-20 is 88.2. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMZ11 Open price on 2011-10-20 is 86.2. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMX11 price difference to QMZ11 is -2. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMZ11 Open price on 2011-11-22 is 101.675. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMF12 Open price on 2011-11-22 is 97.125. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMZ11 price difference to QMF12 is -4.55. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMF12 Open price on 2011-12-20 is 93.625. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMG12 Open price on 2011-12-20 is 94.275. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMF12 price difference to QMG12 is 0.65. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMG12 Open price on 2012-01-20 is 101.1. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMH12 Open price on 2012-01-20 is 100.575. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMG12 price difference to QMH12 is -0.525. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMH12 Open price on 2012-02-21 is 102.3. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMJ12 Open price on 2012-02-21 is 104.55. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMH12 price difference to QMJ12 is 2.25. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMJ12 Open price on 2012-03-20 is 107.225. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMK12 Open price on 2012-03-20 is 108.35. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMJ12 price difference to QMK12 is 1.125. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMK12 Open price on 2012-04-20 is 102.75. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMM12 Open price on 2012-04-20 is 103. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMK12 price difference to QMM12 is 0.25. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMM12 Open price on 2012-05-22 is 91.35. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMN12 Open price on 2012-05-22 is 93. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMM12 price difference to QMN12 is 1.65. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMN12 Open price on 2012-06-20 is 83. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMQ12 Open price on 2012-06-20 is 84.25. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMN12 price difference to QMQ12 is 1.25. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMQ12 Open price on 2012-07-20 is 89.975. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMU12 Open price on 2012-07-20 is 92.6. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMQ12 price difference to QMU12 is 2.625. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMU12 Open price on 2012-08-21 is 96.375. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMV12 Open price on 2012-08-21 is 96.175. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMU12 price difference to QMV12 is -0.2. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMV12 Open price on 2012-09-20 is 95.525. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMX12 Open price on 2012-09-20 is 92.25. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMV12 price difference to QMX12 is -3.275. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMX12 Open price on 2012-10-22 is 92.05. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMZ12 Open price on 2012-10-22 is 90.175. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMX12 price difference to QMZ12 is -1.875. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMZ12 Open price on 2012-11-20 is 86.35. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMF13 Open price on 2012-11-20 is 89.1. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMZ12 price difference to QMF13 is 2.75. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMF13 Open price on 2012-12-20 is 87.4. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMG13 Open price on 2012-12-20 is 89.625. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMF13 price difference to QMG13 is 2.225. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMG13 Open price on 2013-01-22 is 95.2. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMH13 Open price on 2013-01-22 is 95.75. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMG13 price difference to QMH13 is 0.55. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMH13 Open price on 2013-02-20 is 95.95. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMJ13 Open price on 2013-02-20 is 97.1. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMH13 price difference to QMJ13 is 1.15. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMJ13 Open price on 2013-03-20 is 93.925. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMK13 Open price on 2013-03-20 is 92.45. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMJ13 price difference to QMK13 is -1.475. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMK13 Open price on 2013-04-22 is 88.275. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMM13 Open price on 2013-04-22 is 88.1. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMK13 price difference to QMM13 is -0.175. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMM13 Open price on 2013-05-21 is 96.15. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMN13 Open price on 2013-05-21 is 96.875. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMM13 price difference to QMN13 is 0.725. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMN13 Open price on 2013-06-20 is 98.575. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMQ13 Open price on 2013-06-20 is 98.2. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMN13 price difference to QMQ13 is -0.375. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMQ13 Open price on 2013-07-22 is 108.075. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMU13 Open price on 2013-07-22 is 108.025. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMQ13 price difference to QMU13 is -0.05. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMU13 Open price on 2013-08-20 is 107.625. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMV13 Open price on 2013-08-20 is 106.7. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMU13 price difference to QMV13 is -0.925. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMV13 Open price on 2013-09-20 is 108.425. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMX13 Open price on 2013-09-20 is 105.775. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMV13 price difference to QMX13 is -2.65. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMX13 Open price on 2013-10-22 is 100.8. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMZ13 Open price on 2013-10-22 is 99.55. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMX13 price difference to QMZ13 is -1.25. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMZ13 Open price on 2013-11-20 is 93.075. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMF14 Open price on 2013-11-20 is 93.875. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMZ13 price difference to QMF14 is 0.8. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMF14 Open price on 2013-12-20 is 97.325. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMG14 Open price on 2013-12-20 is 98.675. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMF14 price difference to QMG14 is 1.35. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMG14 Open price on 2014-01-21 is 94.1. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMH14 Open price on 2014-01-21 is 94.25. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMG14 price difference to QMH14 is 0.15. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMH14 Open price on 2014-02-20 is 103.1. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMJ14 Open price on 2014-02-20 is 102.9. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMH14 price difference to QMJ14 is -0.2. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMJ14 Open price on 2014-03-20 is 99.475. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMK14 Open price on 2014-03-20 is 99.15. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMJ14 price difference to QMK14 is -0.325. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMK14 Open price on 2014-04-22 is 104.45. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMM14 Open price on 2014-04-22 is 103.625. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMK14 price difference to QMM14 is -0.825. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMM14 Open price on 2014-05-20 is 102.025. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMN14 Open price on 2014-05-20 is 102.1. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMM14 price difference to QMN14 is 0.075. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMN14 Open price on 2014-06-20 is 106.05. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMQ14 Open price on 2014-06-20 is 106.075. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMN14 price difference to QMQ14 is 0.025. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMQ14 Open price on 2014-07-22 is 102.95. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMU14 Open price on 2014-07-22 is 102.75. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMQ14 price difference to QMU14 is -0.2. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMU14 Open price on 2014-08-20 is 96.6. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMV14 Open price on 2014-08-20 is 92.85. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMU14 price difference to QMV14 is -3.75. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMV14 Open price on 2014-09-22 is 92.975. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMX14 Open price on 2014-09-22 is 91.625. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMV14 price difference to QMX14 is -1.35. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMX14 Open price on 2014-10-21 is 83.1. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMZ14 Open price on 2014-10-21 is 81.85. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMX14 price difference to QMZ14 is -1.25. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMZ14 Open price on 2014-11-20 is 74.225. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMF15 Open price on 2014-11-20 is 74.325. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMZ14 price difference to QMF15 is 0.1. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMF15 Open price on 2014-12-22 is 55.8. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMG15 Open price on 2014-12-22 is 57.675. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMF15 price difference to QMG15 is 1.875. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMG15 Open price on 2015-01-20 is 46.25. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMH15 Open price on 2015-01-20 is 49.125. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMG15 price difference to QMH15 is 2.875. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMH15 Open price on 2015-02-20 is 50.575. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMJ15 Open price on 2015-02-20 is 52.175. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMH15 price difference to QMJ15 is 1.6. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMJ15 Open price on 2015-03-20 is 44.575. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMK15 Open price on 2015-03-20 is 45.6. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMJ15 price difference to QMK15 is 1.025. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMK15 Open price on 2015-04-21 is 56.075. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMM15 Open price on 2015-04-21 is 57.925. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMK15 price difference to QMM15 is 1.85. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMM15 Open price on 2015-05-20 is 59.85. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMN15 Open price on 2015-05-20 is 58.325. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMM15 price difference to QMN15 is -1.525. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMN15 Open price on 2015-06-22 is 60.45. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMQ15 Open price on 2015-06-22 is 59.75. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMN15 price difference to QMQ15 is -0.7. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMQ15 Open price on 2015-07-21 is 50.725. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMU15 Open price on 2015-07-21 is 50.25. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMQ15 price difference to QMU15 is -0.475. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMU15 Open price on 2015-08-20 is 42.425. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMV15 Open price on 2015-08-20 is 40.95. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMU15 price difference to QMV15 is -1.475. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMV15 Open price on 2015-09-22 is 44.85. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMX15 Open price on 2015-09-22 is 46.7. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMV15 price difference to QMX15 is 1.85. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMX15 Open price on 2015-10-20 is 47.1. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMZ15 Open price on 2015-10-20 is 46.575. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMX15 price difference to QMZ15 is -0.525. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMZ15 Open price on 2015-11-20 is 40.7. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMF16 Open price on 2015-11-20 is 41.875. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMZ15 price difference to QMF16 is 1.175. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMF16 Open price on 2015-12-22 is 34.8. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMG16 Open price on 2015-12-22 is 35.85. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMF16 price difference to QMG16 is 1.05. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMG16 Open price on 2016-01-20 is 29.35. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMH16 Open price on 2016-01-20 is 29.475. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMG16 price difference to QMH16 is 0.125. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMH16 Open price on 2016-02-22 is 30.675. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMJ16 Open price on 2016-02-22 is 31.95. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMH16 price difference to QMJ16 is 1.275. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMJ16 Open price on 2016-03-22 is 40.25. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMK16 Open price on 2016-03-22 is 41.6. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMJ16 price difference to QMK16 is 1.35. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMK16 Open price on 2016-04-20 is 39.975. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMM16 Open price on 2016-04-20 is 42.35. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMK16 price difference to QMM16 is 2.375. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMM16 Open price on 2016-05-20 is 47.9. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMN16 Open price on 2016-05-20 is 48.725. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMM16 price difference to QMN16 is 0.825. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMN16 Open price on 2016-06-21 is 48.35. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMQ16 Open price on 2016-06-21 is 49.775. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMN16 price difference to QMQ16 is 1.425. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMQ16 Open price on 2016-07-20 is 45.175. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMU16 Open price on 2016-07-20 is 45.475. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMQ16 price difference to QMU16 is 0.3. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMU16 Open price on 2016-08-22 is 48.375. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMV16 Open price on 2016-08-22 is 49.05. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMU16 price difference to QMV16 is 0.675. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMV16 Open price on 2016-09-20 is 43.2. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMX16 Open price on 2016-09-20 is 43.75. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMV16 price difference to QMX16 is 0.55. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMX16 Open price on 2016-10-11 is 51.125. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMZ16 Open price on 2016-10-11 is 51.65. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | QMX16 price difference to QMZ16 is 0.525. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMV06 is 63.4. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMX06 is 65.15. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMZ06 is 62.35. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMF07 is 62.15. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMG07 is 62. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMH07 is 58.9. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMJ07 is 57.35. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMK07 is 54.7. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMM07 is 54.25. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMN07 is 52.375. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMQ07 is 52.05. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMU07 is 50.825. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMV07 is 51.825. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMX07 is 53.5. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMZ07 is 56.4. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMF08 is 55.675. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMG08 is 55.65. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMH08 is 55.7. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMJ08 is 51.55. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMK08 is 55.45. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMM08 is 55.4. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMN08 is 54.875. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMQ08 is 58.7. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMU08 is 55.925. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMV08 is 53.95. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMX08 is 49.85. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMZ08 is 46.35. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMF09 is 47.25. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMG09 is 44.75. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMH09 is 37.575. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMJ09 is 32.775. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMK09 is 30.8. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMM09 is 32.55. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMN09 is 28.75. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMQ09 is 30.05. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMU09 is 28.175. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMV09 is 24.9. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMX09 is 27.075. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMZ09 is 25.925. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMF10 is 27.15. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMG10 is 26.5. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMH10 is 25.15. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMJ10 is 23.175. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMK10 is 24.5. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMM10 is 24.2. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMN10 is 20.4. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMQ10 is 20.125. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMU10 is 19.025. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMV10 is 19.425. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMX10 is 16.75. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMZ10 is 19.725. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMF11 is 17.925. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMG11 is 16.675. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMH11 is 16.3. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMJ11 is 12.65. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMK11 is 12. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMM11 is 12.925. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMN11 is 13.5. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMQ11 is 12.55. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMU11 is 10.2. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMV11 is 9.25. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMX11 is 10.5. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMZ11 is 12.5. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMF12 is 17.05. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMG12 is 16.4. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMH12 is 16.925. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMJ12 is 14.675. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMK12 is 13.55. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMM12 is 13.3. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMN12 is 11.65. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMQ12 is 10.4. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMU12 is 7.775. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMV12 is 7.975. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMX12 is 11.25. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMZ12 is 13.125. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMF13 is 10.375. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMG13 is 8.15. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMH13 is 7.6. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMJ13 is 6.45. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMK13 is 7.925. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMM13 is 8.1. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMN13 is 7.375. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMQ13 is 7.75. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMU13 is 7.8. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMV13 is 8.725. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMX13 is 11.375. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMZ13 is 12.625. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMF14 is 11.825. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMG14 is 10.475. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMH14 is 10.325. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMJ14 is 10.525. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMK14 is 10.85. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMM14 is 11.675. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMN14 is 11.6. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMQ14 is 11.575. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMU14 is 11.775. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMV14 is 15.525. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMX14 is 16.875. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMZ14 is 18.125. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMF15 is 18.025. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMG15 is 16.15. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMH15 is 13.275. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMJ15 is 11.675. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMK15 is 10.65. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMM15 is 8.8. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMN15 is 10.325. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMQ15 is 11.025. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMU15 is 11.5. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMV15 is 12.975. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMX15 is 11.125. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMZ15 is 11.65. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMF16 is 10.475. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMG16 is 9.425. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMH16 is 9.3. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMJ16 is 8.025. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMK16 is 6.675. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMM16 is 4.3. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMN16 is 3.475. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMQ16 is 2.05. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMU16 is 1.75. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMV16 is 1.075. | 2016-10-11 15:24:50 QMZ16 [CB] [M] Weekly #1 | Back adjust amount for symbol QMX16 is 0.525. | 2016-10-11 15:24:50 |
[2016-10-12 02:38:54] |
We have the information we need. Disable Global Settings >> General Settings >> Detailed Continuous Futures Contract Chart Logging. Follow the instructions here to update the Symbol Settings: http://www.sierrachart.com/index.php?page=doc/GlobalSymbolSettings.php#UpdateSettingsSteps The problem is now resolved. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
