Date/Time: Wed, 21 Oct 2026 09:54:07 +0000
Open How to get rig of the main window showing broker firm
View Count: 964
| [2016-10-11 15:01:27] |
| User191390 - Posts: 1 |
How to get rig of the main window status bar on top of File, Edit, showing my broker.? I want no status bar if possible on top of any Windows of the charts. |
| [2016-10-11 17:49:32] |
To remove that you need to set a Custom Title Bar Name: http://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#CustomTitleBarName You will also need to update to Sierra Chart 1472. This is the prerelease. Follow the instructions here: http://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Once again update to the Prerelease. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
