Date/Time: Sat, 18 May 2024 05:24:52 +0000
disconnection
View Count: 658
[2016-10-11 14:11:38] |
User107130 - Posts: 1 |
Hello, SC will start up and then begin to lag and eventually disconnect? I read and tested to see if the quote board has the same problem, and it does. I have turned off all the fire-walls and checked the bandwith speed. I'm getting about 30 mg download. I haven't got a clue? |
[2016-10-11 17:09:58] |
Use the Sierra Chart Exchange Data Feed: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions There is an additional cost for this data feed. And use the low bandwidth mode: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#LowBandwidthOption Otherwise, there is not anything we can do to help with this. Other than refer you to help topic 4: Https://www.sierrachart.com/index.php?page=doc/helpdetails4.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
