Date/Time: Sat, 18 May 2024 13:22:42 +0000
Numbers Bars Calculated Volume
View Count: 650
[2016-10-11 08:30:48] |
User45578 - Posts: 49 |
Hi,how i can get ,Volume and Delta for one current bar only?
volume et delya pour bougie courante.PNG / V - Attached On 2016-10-11 08:30:28 UTC - Size: 57.88 KB - 266 views |
[2016-10-11 17:13:32] |
The chart you provided does show the difference between Ask Volume and Bid Volume and also the Volume for each bar as text, so we do not understand what the purpose of the question is?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-10-11 17:14:37
