Date/Time: Sun, 05 May 2024 22:34:18 +0000
Plotting or drawing the open position as a study
View Count: 1418
[2013-07-26 16:57:26] |
TheOddsAreYouDontKnowTheOdds - Posts: 29 |
In the "Spreadsheet System for Trading" there is a read-only cell that outputs the Current Open Position. I'd like to see that value for each bar/time period so I can construct/test strategies that scale in and out. Is there a study that can keep track of positions by time period? Thanks. |
[2013-07-29 03:54:48] |
The answer is yes for the first question. Refer to the documentation here: http://www.sierrachart.com/index.php?l=doc/doc_SystemsAlerts.php#CellJ5 We could add the capability to make position data available historically for a particular symbol. This will be through a "Trading:" study. We will see about that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-07-29 03:55:30
[2013-07-29 05:00:03] |
Sawtooth - Posts: 3993 |
I would be in favor of this. +1 |
