Date/Time: Thu, 10 Jul 2025 02:50:44 +0000
Creating a function within a custom study
View Count: 1442
[2016-10-07 21:47:03] |
bala - Posts: 74 |
Objective: Need to draw a marker a few times in a study. Currently writing 10 or so lines for each time I draw. Can I declare a function within the study to draw a marker and call that function? Is the following scenario possible? +++++++++++++++++ #include "sierrachart.h" #include "scstudyfunctions.h" { SCSFExport scsf_Mytest2(SCStudyGraphRef sc) {if (sc.SetDefaults) {} int drawmymarker(parameters) {use sc_tool .... .... return 0; } ++++++++++++++++++++++++++++++++++ //main study if condition { drawmarker(parameters): } |
[2016-10-10 09:35:24] |
Refer to: ACSIL Programming Concepts: Passing ACSIL Interface Members Structure To Secondary Function Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-11 22:12:00] |
bala - Posts: 74 |
Thanks for the example, this shows the function but no parameters in the called function. void PassingSCStrutureExampleFunction(SCStudyInterfaceRef sc) { //The "sc" structure can be used anywhere within this function. } If I want to call the "PassingSCStrutureExampleFunction" with a parameter how do I define it? (PLEASE NOTE THAT THIS IS NOT A PROGRAMING HELP BUT FEATURE AND DOCUMENTATION HELP) |
[2016-10-12 01:00:47] |
Functions are explained here: C++ Functions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-12 01:12:22] |
ejtrader - Posts: 688 |
Bala - You can use the following pseudo code as an example. void PassingSCStrutureExampleFunction(SCStudyInterfaceRef sc) { ...... return; } SCSFExport scsf_Mytest2(SCStudyInterfaceRef sc) { .... .. PassingSCStrutureExampleFunction(sc); ... return; } Date Time Of Last Edit: 2016-10-12 01:15:02
[2016-10-12 10:59:09] |
bala - Posts: 74 |
Hi, Not what I was looking for..? / In youer example no paramaters are passsed...plese see below an imaginary example +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ int calctest(SCStudyInterfaceRef sc, int testsum) { int testsum2; testsum2=testsum*1000; return testsum2; } CSFExport scsf_Mytest2(SCStudyInterfaceRef sc) { .... .. Calctest(testsum); ... return; } |
[2016-10-12 17:15:56] |
