Date/Time: Mon, 02 Nov 2026 03:42:10 +0000
Daily OHLC value different to Intraday OHLC
View Count: 2435
| [2013-07-26 13:56:10] |
| FXDojiStar - Posts: 8 |
I have observed that the daily OHLC values are different to the intraday (60min chart) OHLC. The system seems to calculate the Close value based on the 9pm close instead of the Midnight close. This is resulting in OHLC being diffeernet for intraday and daily candles. |
Attachment Deleted. Attachment Deleted. |
| [2013-07-27 01:49:31] |
Historical Daily charts will never use a midnight close. Assuming you are referring to New York time. Refer to help topic 12: http://www.sierrachart.com/index.php?l=doc/helpdetails12.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-07-29 10:03:05
| [2013-07-29 08:33:47] |
Yes New York Close time. Does that mean that a daily close when viewed in UK, will always be different from GMT daily close? If thats the case it can mean the charts have not adjusted logically to time zones. Not helpful for analysis. Since other charting packages synch better. |
| [2013-07-29 10:04:27] |
It does not matter where you view the charts and it does not matter what your Time Zone setting in Sierra Chart is and it does not matter what charting package you are using. Historical Daily data is data which originates from the external data or trading service you are using. It is that simple. Sierra Chart does not control the session times for Historical Daily data. Neither can you. If you do want to control the session times, you need to use an Intraday chart. For instructions, refer to this section here: http://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#CreatingDailyBars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-07-29 10:05:47
