Date/Time: Mon, 29 Apr 2024 02:09:54 +0000
Sierra Data Feed with Infinity Account
View Count: 2780
[2016-10-07 20:25:57] |
Profile Trader - Posts: 167 |
Can I get my sierra charting through my infinity account and still subscribe to the Sierra Charting data feed? or am I required to use the data feed from Infinity?
[2016-10-07 23:05:21] |
If you want to use the Sierra Chart Exchange Data Feed you do need to use your own Sierra Chart account. This is the one that you posted this Support Request with.
[2016-10-07 23:09:34] |
thank you for your insight. can you share with me your insight as too the differences between your data feed and the feed Infinity would provide. |
[2016-10-08 00:42:28] |
There is going to be very little difference. If very accurate Bid Volume and Ask Volume for CME markets is necessary, then we would recommend using the Sierra Chart Exchange Data Feed.
