Date/Time: Sun, 19 May 2024 04:36:47 +0000
data incomplete displayed in copy instance.
View Count: 656
[2016-10-07 17:24:59] |
sierra28 - Posts: 120 |
i have 2 instances of sierra, i load futurs data from one in the second instance and datas are incomplete displayed (only 4 weeks) while in source instance datas are correctly displayed more than 2 years (in intraday-chart type). Parameters in chart setting in the copy are same as source instance. have you got an idea of the reason of my problem ? thanks |
[2016-10-07 17:51:21] |
As long as the data is in the source/server instance it will be accessible in the sub instance. Follow through the instructions here: http://www.sierrachart.com/index.php?page=doc/HistoricalIntradayData.html#DownloadingViewingMoreHistoricalIntradayData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
