Date/Time: Sun, 19 May 2024 06:58:33 +0000
Property DisplayOrder is not updated in chartbook when I update it in my study
View Count: 643
[2016-10-06 21:32:43] |
T29_Dev1 - Posts: 22 |
Property DisplayOrder for inputs works fine only when I add a new study to the chart. Description: 1. add a study with 2 parameters sc.inputs[1](DisplayOrder==1) and sc.inputs[3](DisplayOrder==2) to a chartbook, 2. save and close the chartbook, 3. add a new parameter to the study - sc.inputs[2](DisplayOrder==3), 4. open the chartbook - I can see the new parameter at the top of list, 5. save and close the chartbook again, 6. open the chartbook - I can see the new parameter on the second position in the list of parameters, but I expect to see it at the bottom (because DisplayOrder==3). Can you update the DisplayOrder property for all studies in chartbook when chartbook is loading? |
[2016-10-07 00:03:44] |
This will be fixed in the next release.
