Date/Time: Sun, 19 May 2024 06:52:40 +0000
Alert Coming Twice In One Day
View Count: 981
[2016-10-06 17:56:43] |
infpz - Posts: 826 |
This alert is sent to "only once per bar" but as you can see it came up twice about 4 minutes apart. Can you tell me what I might be doing to cause that? Please disregard the other alerts/errors - just the ones with arrows.
[2016-10-06 17:59:11] |
This can happen with Historical Daily charts when the chart is reloaded. So the alert can be triggered more than once a day even when using Alert Only Once per Bar. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-10-06 18:00:08
