Date/Time: Fri, 17 May 2024 18:16:53 +0000
[User Discussion] - JDT Trend catcher 3 indicator
View Count: 1905
[2016-10-06 03:41:35] |
User600819 - Posts: 43 |
Within the JDT Trend catcher 3 indicator found in the user contributed studies, I am attempting to set an alert for when the 3BR Color in this indicator fires off. The indicator draws a white or yellow color bar hollow around a candletick when it fires. I want to set an alert to make a sound when this happens but I can't figure out if that's possible.
[2016-10-06 04:01:42] |
Refer to: Study/Chart Alerts And Scanning: Writing Formulas for Studies without Obvious Values Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-06 14:23:16] |
I can see a value in the chart value window that allows an alert every time it fires, but I'm looking to distinguish between when the alert fires yellow and when it fires white. When it fires yellow, the number is a yellow number in the chart value tool and when it fires white, the number is a white number in the chart value tool.
[2016-10-06 17:03:17] |
You can only work with the values and not colors. If there are no unique values to distinguish the colors, then an alert Condition formula is simply impossible.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-10-06 17:03:42
[2018-04-20 22:31:57] |
User596803 - Posts: 2 |
Trying to use the jdttrendcatcher3 indicator. When I load it, the price chart gets flattened and only red and green dots appear, nothing else. Can anyone help? How to get the whole indicator on the chart? I see no arrows etc.
