Date/Time: Sat, 18 May 2024 23:30:06 +0000
help with orders
View Count: 597
[2016-10-06 03:08:50] |
dc2uh - Posts: 25 |
Sorry to be a noob but I think this is the right place to ask this question..... I'm going from 1 lot to 2 tomorrow and it will be my first time scaling out...for example if I short 2 lots and want to get out of 1 and let the other run how do I do that on sierra charts?
[2016-10-06 04:30:57] |
Would you be using Attached Orders (Target and/or Stop) with the main order/Position?
[2016-10-06 16:01:04] |
dc2uh - Posts: 25 |
yes I do use those .
[2016-10-06 17:23:01] |
You can use the Scale Out feature: http://www.sierrachart.com/index.php?page=doc/AttachedOrders.html#ScalingOut When using this feature, to reduce the quantity of the existing Position and Attached Orders just enter an order of quantity 1 with the opposite side. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
