Date/Time: Thu, 09 May 2024 16:57:14 +0000
Bid volume and ask volume colouring method on vbp
View Count: 740
[2016-10-01 10:41:29] |
User560062 - Posts: 100 |
hello, is it possible to add another option apart from the current options i.e. difference of bid and ask volume coloring and dominant side coloring but this time only highlighting the dominant side part and not the whole volume bar. This way the percentage of dominance could be known. This is different to the delta because the percentage of dominant side is not clearly visible. This should be a simple change. Would appreciate if you can add it. Thank you |
[2016-10-03 19:10:44] |
Yes we can do this. We will try to get this done in the next few days.
[2016-10-12 16:38:30] |
Hi, can you kindly let me know what is the status of this. I still cannot find it if you have implemented it.
[2016-10-12 16:47:13] |
Yes this has been released as part of the latest prerelease.
[2016-10-12 16:59:20] |
how can i access it the feature. What did you call it as I coulnd't find it or perhaps you have misunderstood me.
[2016-10-12 17:04:52] |
i found it ignore this please. many thanks |
