Date/Time: Sat, 18 May 2024 08:23:07 +0000
Import tick data
View Count: 797
[2016-09-29 23:57:39] |
Napoleon Dynamite - Posts: 54 Invalid SC Account Name. |
http://www.sierrachart.com/index.php?page=doc/TextCSVDataFormat.html#ExampleIntraday Does SC support the import of tick data text files or not ? Because that data format seems to be about 1 minute data only. Also, within the text file, is a "header" line before the data fines fine or should it be avoided ? Like Date, Open, High, Low, Close, Volume, OpenInterest 2013/06/10, 09:45, 19.17, 19.18, 19.16, 19.17, 0 Thanks Date Time Of Last Edit: 2016-09-30 00:01:15
[2016-09-30 00:02:29] |
Yes of course. All of the supported formats are clearly documented here: http://www.sierrachart.com/index.php?page=doc/TextCSVDataFormat.html#Formats Whether a header is required or not is clearly specified. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
