Date/Time: Sat, 18 May 2024 07:58:02 +0000
Spreadsheet Alert sytem question
View Count: 609
[2016-09-29 17:23:43] |
User578759 - Posts: 4 |
I want to confirm the priority between the BUY entry, BUY Exit, SELL entry, SELL exit Is it valid: SELL Entry is greater than BUY exit (if both are "1" the SELL Entry will take precedence) BUY Exit is greater than BUY Entry SELL Exit is greater than SELL Entry SELL Entry is greater than BUY Entry appreciate your validation of the above logic. |
[2016-09-29 19:01:23] |
This is documented here: http://www.sierrachart.com/index.php?page=doc/SystemsAlerts.php#OrderFormulaColumnProcessingAndCalcOrder Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
