Date/Time: Sun, 19 May 2024 02:34:48 +0000
help to 'float' to 'SCFloatArrayRef'
View Count: 933
[2016-09-29 11:54:32] |
bala - Posts: 74 |
1. Trying to use crossover function for vwap 2. One of the arguments is VWAP[Index] which is float 3. Doc has an example for converting a fixed value to float array 4. How can I convert this float to a float array to be used for cross over? |
[2016-09-29 17:51:53] |
You need to put those values into an available Subgraph extra Array: http://www.sierrachart.com/index.php?page=doc/ACSIL_Members_scSubgraph.html#scSubgraphArrays And use that array in the Crossover function. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
