Date/Time: Sat, 18 May 2024 00:04:11 +0000
Google Finance Symbol
View Count: 1065
[2016-09-28 18:18:58] |
User8875 - Posts: 12 |
Hi I am trying to connect to Google Finance for charts. The symbol is SGX:Z74, I entered Z74-SGX, no charts appeared, pls help? |
[2016-09-28 18:29:03] |
The symbol format that you entered is correct. The general answer is if you do not receive data for a particular symbol when using Google Finance, then the data is not available and we do not provide any support for this because we have no control over Google data. We do not know what the limitations are. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
