Date/Time: Sat, 18 May 2024 07:14:07 +0000
drawing support and resistance lines/areas from a text file
View Count: 2371
[2016-09-27 20:09:07] |
amirN - Posts: 159 |
Is there any function allowing us to draw horizontal lines and extended rectangles at areas defined in a text file? The text file could also have the preferred thickness, colour and the text display for the lines. Thanks |
[2016-09-28 00:08:28] |
You would have to custom develop this by using ACSIL: http://www.sierrachart.com/index.php?page=doc/Contents.php#AdvancedCustomStudySystemInterfaceandLanguage Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-09-28 08:49:51] |
I think it is something you should seriously think about. Investor RT and Bookmap they both have it. In most of the rooms I am a member of, areas of interests are sent by a text file that could be loaded (with minor modification) in at least the charts above. I update my support/ resistance lines frequently. It is very inefficient when I want to do replay, as I have to erase all current ones from my chart and reenter all the previous ones again. If I could do it from a text file I would just use the one I have for replay day. Regards Date Time Of Last Edit: 2016-09-28 08:50:31
[2016-09-28 09:36:04] |
Sierra Chart for years has supported a far more advanced method of doing this. The use of a text file is a very antiquated method. Rather than a text file, these are requested from a remote server in the case where a trading educator or trading room wants to provide levels to display on a chart. You can also use the Spreadsheet Study to accomplish this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-04 03:04:25] |
tradernikki - Posts: 41 |
I would also like to see this feature added. Though outdated, it's still used by many educators. Are there any references to doing this using the spreadsheet studies? |
[2016-10-04 04:12:15] |
Here is documentation for the Spreadsheet study: https://www.sierrachart.com/index.php?page=doc/StudiesSystemsAlerts.php#Instructions You can simply enter the level values into the spreadsheet cells beginning with K3. If you have a tab delimited list of values you can paste them into the spreadsheet. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-04 05:17:54] |
It's actually really easy doing this using the spreadsheet study method. Is there any way to extend the line created to include the right-side margin?
[2021-03-05 10:25:11] |
User275592 - Posts: 97 |
Hi, could you tell me where i can find informations about "datas requested from a remote server in the case where a trading educator or trading room wants to provide levels to display on a chart" thank you very much Renaud |
[2021-03-05 15:34:08] |
Refer to the following: Trading Levels For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
