Date/Time: Sun, 28 Apr 2024 21:14:58 +0000
Market Profile indicator
View Count: 2888
[2013-04-01 08:09:10] |
User39128 - Posts: 20 |
Dear Sir, do you prodive the Market Profile indicator? If yes, what should i do to see it on my charts UKOil and USOil? Thank you. Alexander
[2013-04-01 10:30:13] |
This is called the TPO Profile Chart Study: http://www.sierrachart.com/index.php?l=doc/doc_TPOVolProfileCharts.html You will have to change your Sierra Chart package to package 5.: To change your Sierra Chart service package, select "Help >> Purchase / Account Management" on the Sierra Chart program menu. On the displayed webpage, click on "Change Service Package".
The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your usage time is adjusted. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-04-01 20:49:18] |
okey, thank you very much.
[2013-04-02 22:44:32] |
Dear Sir, now i can see my TPO charts. How can i put a TPO chart with three important price levels (POC, the TPO Value Area upper and lower price levels) or only this 3 price levels from the previous day and the same 3 price levels (as horisontal lines) of the current day on to my candle chart? is it possible? Thank you. Alex
[2013-04-03 04:08:15] |
joshtrader - Posts: 439 |
Look at the TPO Value Area Lines study.
[2013-04-03 19:59:29] |
This can be done by using the TPO Value Area Lines study: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s158 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-04-03 20:17:37] |
ok, i will take a look at this study, thank you very much for your support.
