Date/Time: Wed, 29 May 2024 06:20:20 +0000
Question on sc.VolumeWeightedMovingAverage()
View Count: 735
[2016-09-22 11:51:00] |
bala - Posts: 74 |
my understanding of the VWAP is that it is calculated on all the bars of the daily chart and LENGTH is not an option . In the case of a SMA I understand that LENGTH is an option where we can have a moving average of different periods. What value of LENGTH should I use in the function sc.VolumeWeightedMovingAverage()? Thanks |
[2016-09-22 18:15:51] |
We do not know how to answer this question. The Length is simply the number of bars you want to compute the Volume Weighted Moving Average over.
