Date/Time: Sun, 19 May 2024 11:19:21 +0000
analysis
View Count: 595
[2016-09-22 10:14:36] |
jimnovak - Posts: 42 |
would you be able to integrate into toolbar/controlbar an option to add studies under analysis thta a user creates. for instance i have several study collections i have created under analysis and depending on the timeframe etc i use different ones for which i have to click 'analysis' then select the appropriate analysis/study group. i am wondering if this can be done by one single click and an option under control/tool bar, much like 'custom drawing tool' you currently have in place which is very useful.
[2016-09-22 18:17:05] |
Yes we will see about this. But do not expect this would come soon. We already have an enormous amount of work to do.
[2016-09-22 18:21:12] |
great. thank you
