Date/Time: Sun, 19 May 2024 09:17:05 +0000
Quick question about rithmic
View Count: 686
[2016-09-22 00:28:55] |
dc2uh - Posts: 25 |
I just got my account set up with rithmic and i am using your charts. I have been using gclx6 for crude and esz6 for the es and now it says both are invalid symbols. Could someone please help me with this. Thank you |
[2016-09-22 01:25:08] |
The symbols are different with Rithmic. You need to use the symbols in File >> Find Symbol. Refer to the instructions here: https://www.sierrachart.com/index.php?page=doc/helpdetails1.php#h1.3 You will need to change the symbols of existing charts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
