Date/Time: Sun, 19 May 2024 15:10:39 +0000
Studies or Chart question
View Count: 632
[2016-09-21 15:30:02] |
User23815 - Posts: 209 |
I use a Renko chart for the ES. I would like to have the TICK-NYSE chart develop in context with the ES chart. Is there a study in SC of the NYSE-Tick that would allow this or is there a way to link the TICK chart with the ES chart so that they both develop based on the ES chart? Thanks
[2016-09-21 17:43:54] |
You can accomplish this by using the Study Overlay-OHLC study: http://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s149 The degree of accuracy is going to be higher when the TICK-NYSE is a much shorter time frame per bar than the Renko bars in the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
