Date/Time: Sun, 19 May 2024 15:33:01 +0000
SC ExcelSpreadsheet to a normal Excel sheet
View Count: 733
[2016-09-21 11:15:17] |
ZuPrague - Posts: 1 |
Hello, I am trying to copy real time quotes from the SC Excel file to an independent normal Excel file, where I store some market statistics, but I am not able to do that. Do you know how can I accomplish that? I am trying to create a link between the two spreadsheets, but it is not working. Even the copied data do not match. Please see the screen shot. Thank you. Regards Otakar |
sierra chart.jpg / V - Attached On 2016-09-21 11:15:01 UTC - Size: 490.64 KB - 298 views |
[2016-09-21 11:18:32] |
The way that Excel is processing the data on the clipboard must be in a way which is different than the way that Sierra Chart would process it. Also there is no way to establish an actual real-time link between the two spreadsheets. That is simply not supported at all. Consider using the Use Excel input: Spreadsheet Study Inputs Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-09-21 11:19:56
