Date/Time: Wed, 15 May 2024 09:24:30 +0000
[User Discussion] - Automate JDT Better Volume Indicator
View Count: 1813
[2016-09-18 04:22:06] |
User600819 - Posts: 43 |
Anyone know how to automate the JDT Better Volume indicator? There is an input to turn zero to 1 that gives off an alert on Volume Climax Up (buy) or Volume Climax down(sell). I would like to use spreadsheet trading for this, but I'm told this isn't possible.
[2016-09-18 05:42:56] |
Sawtooth - Posts: 3996 |
Even if you set those to 1, they do not output a 1 to the spreadsheets study. It's not possible to use a spreadsheet study to automate those alerts, unless you know the algo for them. |
[2016-12-22 13:50:21] |
User787778 - Posts: 139 |
Tom I respect that your your spreadsheet knowledge is much greater than mine will ever be, but could one not use the "Volume Climax Up/Down flags(SG.8 and SG.9) to trigger a trade in a spreadsheet?
[2016-12-22 14:30:50] |
Well, that's embarrassing. When I first looked at this, I didn't see any outputs. Yes, you could create automation formulas based on five subgraphs: SG8, SG9, SG10, SG11, SG12. And you don't have to turn on those alerts with those input settings. (To see what a study outputs, add the Spreadsheet Study study and look in columns AA and above.) Date Time Of Last Edit: 2016-12-22 14:31:53
[2018-04-25 16:33:18] |
ycomp - Posts: 277 |
is there a "Better Volume" indicator for Sierra Chart that can paint the candlestick bars by the colour of the indicator?
