Date/Time: Sat, 12 Jul 2025 07:18:49 +0000
Get color of remote subgraph
View Count: 1250
[2016-09-15 03:43:57]
onnb - Posts: 663
is it possible to retrieve the color of a remote subgraph?
I see this function - GetStudyDataColorArrayFromChartUsingID
Should that work?
[2016-09-15 05:47:36]
This function needs to be documented and it is for getting a Subgraph Data Color array for another study which can also be in a different chart.
So unless that array is filled in, it will not useful.
Date Time Of Last Edit: 2016-09-15 05:49:15
[2016-09-15 16:34:48]
onnb - Posts: 663
Just to see I understand
I have study A that is referencing a subgraph from study B. I should be able to see the COLORREF values for the subgraph at each index?
In the following example, if study id 1 is MACD, data[sc.Index] should be the color of the COLORREF value of the histogram?
(Right now I am getting 0's)
SCColorArray data;
sc.GetStudyDataColorArrayFromChartUsingID(sc.ChartNumber, 1, 2, data);
For the same chart/study, the following returns the values of the macd histogram.
SCFloatArray value;
sc.GetStudyArrayUsingID(1, 2, value);
[2016-09-15 17:23:05]
This is not going to work because the MACD study does not use this member:
http://www.sierrachart.com/index.php?page=doc/ACSIL_Members_scSubgraph.html#scSubgraphDataColor
[2016-09-15 17:38:10]
onnb - Posts: 663
"So unless that array is filled in, it will not useful."
Now I get it.
Can you consider extending this function so it returns the color that is used when this member is not set?
[2016-09-15 19:06:45]
There would have to be a completely new function for this. This is part of our longer-term development plans for ACSIL which will be starting on sometime later this year.
[2020-03-13 16:18:37]
@sstfrederik - Posts: 407
This would be great to add. Any new updates?
[2020-03-13 16:38:09]
User978794 - Posts: 1
Yes, I'm wondering about this as well. What would it take to push this along?
