Date/Time: Tue, 07 May 2024 11:28:47 +0000
NinjaTrader brokerage connection
View Count: 4655
[2016-09-10 09:34:38] |
Napoleon Dynamite - Posts: 54 Invalid SC Account Name. |
As a trading platform, SierraChart is much better than NinjaTrader even 8 However, the newish brokerage firm of NinjaTrader, based on the ashes of Mirus Futures is very good : low fees, low margins, solid FCMs Do you plan to support a NinjaTrader brokerage connection ? Date Time Of Last Edit: 2016-09-10 09:38:59
[2016-09-10 10:22:48] |
This is already supported by using either CQG or Rithmic. Just enter your connection details. For the setup instructions refer to: https://www.sierrachart.com/index.php?page=doc/Data.php#Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-11 22:28:38] |
Do I have to make a special setting under Sierra Chart so that I get the historical data coming along my SC package 5 instead of the one from Ninja ?
No. The data will come from Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-11-08 08:25:35] |
User494255 - Posts: 1 |
Hello, I cannot connect to Ninjatrader data feed. The data feed is called NinjaTrader Continuum. Are you sure that it is still from either CQG or Rithmic?
[2017-11-08 18:57:23] |
This is CQG. Refer to the instructions here: http://www.sierrachart.com/index.php?page=doc/CQGTrading.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
