Date/Time: Sat, 27 Apr 2024 22:40:56 +0000
Did I miss a memo? YM-201306-CBOT vs CME
View Count: 3018
[2013-04-01 04:16:49] |
DarthSidious - Posts: 63 |
I am with Velocity Futures / TT feed Something funny is going on with YM. YM-201306-CBOT, till last friday got quotes. As of market open today, I have no quotes, no bid/ask on DOM, and no chart updates. However, I tried YM-201306-CME, and that works fine. Chart backfill comes in for YM-201306-CME as well, but data only goes back to tonight's open. What should I do? Rename my YM-201306-CBOT data files to YM-201306-CME and be done with it? |
[2013-04-01 05:13:22] |
This is because Velocity Futures is now using the CME gateway for the CBOT market center. So use the CME symbols.
[2013-04-01 05:14:37] |
We do see the limited data issue now, we will have to resolve that tomorrow. Renaming the CBOT Exchange name on the file to CME is a good solution. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-01 05:15:53
[2013-04-01 16:57:11] |
Yes, the memo was late. Got this from Velocity today. The change has already taken place In accordance with the Trading Technologies announcement “Single X_TRADER Market License for CME/CBOT Gateway” (see https://www.tradingtechnologies.com/en/support/advisories/2013/03/NI053-13/) , CBOT products are now listed under the CME gateway. This will go into effect on your Sierra Chart front-end at the end of today. Please click here (http://www.sierrachart.com/index.php?l=doc/doc_SwitchingSymbols.html#ChangingChartSymbol) for Sierra Chart instruction on how to update the symbols on your Charts and trading DOMs. No update of Sierra Chart platform is necessary. Date Time Of Last Edit: 2013-04-01 16:57:59
