Date/Time: Sun, 19 May 2024 03:48:20 +0000
cumulative stats
View Count: 686
[2016-09-09 15:24:51] |
User472677 - Posts: 316 |
Hello, Your market statistics are great. Is there a way to get cumulative stats without wring new code? Cumulative tick over 60 days cumulative ad over 60 days |
[2016-09-09 17:04:18] |
Yes. Use this study: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s134 In this particular case you will need to set the chart to load the number of days you want the calculation performed over and set the study to not reset every trading day through the Study Inputs. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
