Date/Time: Sun, 19 May 2024 06:11:49 +0000
vstoxx ampfuture
View Count: 1025
[2016-09-08 16:30:34] |
User57241 - Posts: 5 |
hello you can add the symbol to the Sierra platform chart because ampfuture may do thank you I have a rithmic flow and CQG |
Capture sierrachart.PNG / V - Attached On 2016-09-08 16:30:21 UTC - Size: 130.14 KB - 199 views |
[2016-09-08 18:27:12] |
This has now been added. Restart Sierra Chart to see the new symbol listed for this in File >> Find Symbol.
[2016-09-09 08:11:40] |
hello with rhythmic as it is available please
[2016-09-09 17:05:30] |
You need to use CQG for this symbol and not Rithmic. Refer to this page: http://www.sierrachart.com/index.php?page=doc/CQGTrading.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
