Date/Time: Sun, 19 May 2024 10:32:07 +0000
Difference in time zone for volume by price chart
View Count: 672
[2016-09-08 09:28:53] |
hursthead - Posts: 28 |
hi, i made sure global time zone is set the same as individual chart attached screenshot.png file. timezone set to Hong Kong time but it seems like the volume by price is showing a new day at 11am HK time. attached is the setting for the volume by price study. thank you.
screenshot.png / V - Attached On 2016-09-08 09:27:56 UTC - Size: 57.77 KB - 220 views screenshot2.png / V - Attached On 2016-09-08 09:28:11 UTC - Size: 77.94 KB - 224 views Attachment Deleted. |
[2016-09-09 04:34:57] |
Refer to the description for Volume Graph Period Type: http://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#InputVolumeGraphPeriodType With the setting you are using, the Volume Profiles are going to be aligned to the Session Times in the Chart Settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
