Date/Time: Tue, 14 May 2024 13:47:36 +0000
Distinguish between user reloading and full recalculation
View Count: 770
[2016-09-07 01:45:22] |
@sstfrederik - Posts: 403 |
Hi, would like to know if it is possible to distinguish between study reloads initiated by the user changing settings and SC doing a full recalculation. I have some settings I reset at sc.Index == 0, but I only want to do that when a user is actually changing the study settings and not when the chart is in recalculation for some other reason. Any pointers appreciated. |
[2016-09-07 02:26:15] |
No, there is no way to tell this from a custom study. At least not that we can think of. There is this ACSIL member though but it will not tell you what you need: http://www.sierrachart.com/index.php?page=doc/ACSIL_Members_Variables_And_Arrays.html#scIsFullRecalculation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
