Date/Time: Wed, 15 May 2024 01:01:23 +0000
Coding inquiry
View Count: 609
[2016-09-06 20:22:41] |
User157806 - Posts: 71 |
I have a general question if a customer wants to convert code from another platform such as think or swim and that code is java based would it be a difficult task to convert that code over to C++ code within sierra charts?
[2016-09-06 21:05:25] |
It is not necessarily difficult but it is not necessarily easy either. It really depends upon the knowledge of the user/programmer and the complexity of what they are converting. Refer to: http://www.sierrachart.com/index.php?page=doc/AdvancedCustomStudyInterfaceAndLanguage.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
