Date/Time: Tue, 14 May 2024 03:01:13 +0000
can not connect to cqg
View Count: 569
[2016-09-06 18:10:29] |
AC89271 - Posts: 2 |
can not connect to cqg and I try the same cqg on ninja trade and no problem so the problem is on sierra chart , what do I need to do ? I reset my computer to factory and reistal sierra chart it that can be the proble ? it was working fine before
[2016-09-06 18:17:54] |
For an issue like this you definitely do not have to reset your computer or reinstall Sierra Chart. Provide a copy of the Message Log by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
