Date/Time: Mon, 13 May 2024 20:40:20 +0000
Looking for stats on Volume itself
View Count: 903
[2016-09-06 00:40:10] |
User103002 - Posts: 1 |
I have an intra-day tick chart set up and have added Volume as a Study. What I would like to do is now try and quantify when a Volume bar might be important. So I am looking to add something like a moving average around the Volume itself to help me see when a volume bar might be abnormally high or low. I'd like to do this with either a certain number of bars or have it build everyday once regular trading hours start. Does Sierra offer this ability to add studies to look at Volume, and if so please advise how. I couldn't find anything in the help section.
[2016-09-06 01:27:23] |
Yes. Refer to: http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#BasedOn You can also use this study to do a Cumulative Sum: http://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s134 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
