Date/Time: Tue, 14 May 2024 13:38:38 +0000
ATACHED ORDERS
View Count: 608
[2016-09-05 16:42:51] |
User82615 - Posts: 106 |
COULD ANYBODY PLEASE SEND ME AN EXAMPLE ON HOW TO PLACE AN ATACHED ORDER BUT USING THE PERCENTAGE AS THE OFFSETPRICE INSTEAD OF USING THE NUMBERS OF TICKS (BECAUSE I'M TRYING TO DO IT AND I CAN'T GET IT)? THANK YOU VERY MUCH |
[2016-09-06 17:43:04] |
Refer to the step-by-step instructions here: Attached Orders: Step-By-Step Instructions Specifically refer to step 6 and also the image below in those instructions. You just simply set the Limit Offset and Stop Offset to a percentage that you want to use. It is very simple. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-09-06 17:43:46
