Date/Time: Tue, 14 May 2024 11:03:34 +0000
Weird looking Renko chart
View Count: 728
[2016-09-01 12:24:59] |
buylosellhi - Posts: 60 |
Hi, Why is there an overlap in bars when I plot this Renko chart ? I've never had this before and I've not changed any settings etc.
Weird Renko chart.PNG / V - Attached On 2016-09-01 12:24:31 UTC - Size: 34.75 KB - 261 views |
[2016-09-01 17:33:53] |
This is because you have Chart >> Chart Settings >> New Bar at Session Start enabled. This is documented in the Introduction section here: http://www.sierrachart.com/index.php?page=doc/RenkoCharts.html#UsingRenko Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-09-06 04:17:16] |
That setting is unchecked. I have only "Fill Session Gap" and "New Bar When Exceeded" checked
[2016-09-06 05:03:44] |
So you are using Flex Renko? That is the reason for the problem! Understand what you are using: http://www.sierrachart.com/index.php?page=doc/RenkoCharts.html Do not use Flex Renko if you do not want to see what you do! Otherwise, you are getting exactly what you have configured the chart for. It you do not want an overlap, it is totally pointless to be using Flex Renko. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-09-06 05:08:42] |
If you still see the problem, this may be because there is 1 Minute data in the chart and this is a consequence of using IQ Feed and one reason we do not recommend it. Refer to: http://www.sierrachart.com/index.php?page=doc/TickbyTickDataConfiguration.php http://www.sierrachart.com/index.php?page=doc/DTNIQFeed.html#TickLimitMarketHours Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
