Date/Time: Sat, 12 Jul 2025 06:54:28 +0000
cannot find -lpthread collect2.exe: error: ld returned 1 exit status
View Count: 2487
[2016-08-31 15:36:51] |
msmith - Posts: 2 |
I am new to Sierra Chart. I've installed the compiler twice, and I get this message when I try to compile: -- Starting build of Custom Studies Source files: TEST.cpp. -- 11:28:25 "C:\SierraChart\CPPCompiler\bin\g++.exe" "C:\SierraChart\ACS_Source\TEST.cpp" -march=i686 -mtune=i686 -O2 -shared -static -static-libgcc -static-libstdc++ -s -fno-rtti -fno-exceptions -std=gnu++11 -o "C:\SierraChart\Data\TEST.dll" c:/sierrachart/cppcompiler/bin/../lib/gcc/mingw32/5.3.0/../../../../mingw32/bin/ld.exe: cannot find -lpthread collect2.exe: error: ld returned 1 exit status -- End of Build -- 11:28:28 Any ideas? |
[2016-08-31 18:04:37] |
We are not sure about this. Normally we would recommend installing the compiler again but you said you have done that. The other possibility is to use Visual C++: http://www.sierrachart.com/index.php?page=doc/VCExpress.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-31 18:22:34] |
We are able to reproduce the problem. We need some time to look into this.
[2016-08-31 22:47:47] |
We are going to use a new compiler. We will use the Microsoft Visual C++ compiler. Just give us a couple of days to get this set up. Install it using this link: http://go.microsoft.com/fwlink/?LinkId=691126 Use the default installation. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-31 23:16:15] |
i960 - Posts: 360 |
Wait, before just switching compilers entirely (which might be harder than you think for some people), why not figure out why ld cannot simply find libpthread? This isn't hard to debug. Use ld with --verbose for starters so one can see what it's using for it's library path - because either the libpath is wrong or libpthread isn't correctly installed. |
[2016-08-31 23:19:41] |
It will not be difficult for people to use because we are just using the low-level Visual C++ commandline compiler. That is what that installer installs. All of the details will be handled in the background and use the same user interface through the Build Custom Studies DLL window. There is no integrated development environment. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-08-31 23:21:14
[2016-09-01 13:38:40] |
msmith - Posts: 2 |
So, I need to the wait until an update is made in Sierra Chart before the Microsoft Visual C++ compiler will work, correct? Thanks! |
[2016-09-01 16:26:21] |
Yes this is correct.
[2016-09-03 00:46:15] |
For the solution to this problem, refer to this post here: NOTICE: New Custom Studies DLL Compiler/Solution to Compile Error Issue Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-09-08 21:30:41] |
msmith1 - Posts: 6 |
Works, thank you!
[2016-09-08 22:55:44] |
Good.
[2016-10-07 03:14:50] |
User35525 - Posts: 191 |
I've seen a number of people with issues with the new Microsoft Visual C++ compiler in the past 5 weeks (since 08/31), and am wondering if i960 (post #5) is correct. I've seen more of these compiler issues that support now needs to help with: one that just gave up and said he was taking his issue to Youtube; another was able to fix it with some pragma changes; another saw an issue with user contributed studies; a couple others --me included -- had compilation issues in Wine. I'm not saying things are worse, and maybe these issues aren't positively correlated to the new compiler, but maybe compilation could be improved. Every time -- and I mean "Every" -- I've seen Microsoft technology used, things "get worse". The Microsoft guys just can't create anything without a gazillion bugs/annoyances. Have you considered Intel's optimizing C++ compiler? https://software.intel.com/sites/default/files/managed/82/18/PSXE2017_Release_Notes_en_US_Lin_Win.pdf https://software.intel.com/en-us/node/682940 I presume it could "portably" be placed anywhere (/opt/intel/, $HOME/opt/intel, .../SierraChart/ACS_Source/intel/) and the location of compiler components easily specified: https://software.intel.com/en-us/node/682328 The license is free to open source contributors; I see DTC is open, but maybe not "open source"; surely that could be changed, or the compilation/API/DTC part of SC could be open sourced: https://software.intel.com/en-us/qualify-for-free-software https://software.intel.com/en-us/blogs/2013/01/03/free-intel-c-compilers-for-students-and-related-parallel-programming-tools |
[2016-10-07 03:39:41] |
ganz - Posts: 1048 |
User35525 Intel's compiler is extremely good, but did you see it? 4 System Requirements
4.1 Processor Requirements Systems based on Intel® 64 architecture: Intel® Core™ processor family or higher Intel® Xeon® E5 v5 processor families recommended Intel® Xeon® E7 v5 processor families recommended NOTE: It is assumed that the processors listed above are configured into homogeneous clusters. For Windows* OS, only processors based on the Intel® 64 architecture are supported. IA-32 support has been removed from the Intel® MPI Library and Intel® Trace Analyzer and
Collector. Installation on IA-32 hosts is no longer supported by any components. Runtime libraries other than the Intel® MPI Library are still supported on IA-32 hosts. On Microsoft Windows* OS, the Intel® C/C++ Compiler and Intel® Visual Fortran Compiler
require a version of Microsoft Visual Studio* to be installed. The following versions are currently supported: Microsoft Visual Studio* 2015, 2013, 2012 Microsoft Visual Studio Express* (only for command line compilation) being non 64 bit is the another issue from SC Team "principles" :) Date Time Of Last Edit: 2016-10-07 03:41:13
[2016-10-07 04:12:31] |
We understand what is said in post #12, and we are implementing a solution to this at this time. We will prioritize it and hope to get it out in about two weeks. This is remote compiling where the compiling will be done on our server. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-07 05:19:00] |
ganz Grrr, the devil's in the details... This page sounded nice: https://software.intel.com/en-us/c-compilers/iss/details# Too bad it needs Visual Studio and 64-bit Intel architecture if with Windows. Sierra Looking forward to remote compiling and then not worrying about cross-compilation. :-) Date Time Of Last Edit: 2016-10-07 05:26:31
