Date/Time: Sun, 19 May 2024 08:35:57 +0000
STOCK SPLITS - DUST JDST JNUG NUGT
View Count: 2195
[2016-08-29 18:47:58] |
LadyTrader - Posts: 19 |
There are a number of ETFs that split last week - some were reverse splits and some were just splits - I have a list of 9 of them. I use TDAmeritrade for data. The data on the Daily chart was adjusted for the splits properly by using the Edit>>Delete All Data and Download The data on the intraday charts will not adjust using the Edit>>Delete All Data and Download nor will it adjust if I use the stock split adjust and set the split ratios. Would appreciate any help in getting the charts adjusted for DUST JDST GASX DRIP JNUG NUGT BRZU DRN TMF Thank you |
[2016-08-29 19:12:33] |
These adjustments will be done at the end of the day today. You can adjust the data yourself using this method: nor will it adjust if I use the stock split adjust and set the split ratios.
You must be doing something incorrectly. But in any case we will adjust the data after the close. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-30 05:02:15] |
These stocks are now adjusted. If you re-download the data with Edit >>Delete All Data Download, you will now get the corrected data. Let us know if there any remaining issues. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
